- #include "ZNFAT.H"
- #include "sd.h"
- #include "uart.h"
- #include "vs1003.h"
- struct znFAT_Init_Args idata Init_Args; // 初始化參數(shù)集合
- struct FileInfo idata fileinfo; // 文件信息集合
- void port_mode() // 端口模式
- P0M1=0xff; P0M0=0xff;P1M1=0x0C;P1M0=0x0C;P4M1=0x80;P4M0=0x80;
- int main()
- unsigned int res=0,n=0;
- port_mode(); // 所有IO口設(shè)為準(zhǔn)雙向弱上拉方式。
- UART_Init(); // 波特率:9600 /22.1184MHZ
- UART_Send_Str("串口設(shè)置完畢\r\n");
- znFAT_Device_Init(); // 存儲(chǔ)設(shè)備初始化
- UART_Send_Str("SD卡初始化完畢\r\n");
- znFAT_Select_Device(0,&Init_Args); // 選擇設(shè)備
- res=znFAT_Init(); // 文件系統(tǒng)初始化
- if(!res) // 文件系統(tǒng)初始化成功
- UART_Send_Str("文件系統(tǒng)初始化成功\r\n");
- UART_Send_StrNum("DBR扇區(qū)地址:",Init_Args.BPB_Sector_No);
- UART_Send_StrNum("總存儲(chǔ)容量(K字節(jié)):",Init_Args.Total_SizeKB);
- UART_Send_StrNum("每扇區(qū)字節(jié)(個(gè)):",Init_Args.BytesPerSector);
- UART_Send_StrNum("FAT扇區(qū)數(shù):",Init_Args.FATsectors);
- UART_Send_StrNum("每簇扇區(qū)(個(gè)):",Init_Args.SectorsPerClust);
- UART_Send_StrNum("第一FAT扇區(qū):",Init_Args.FirstFATSector);
- UART_Send_StrNum("根目錄開始扇區(qū):",Init_Args.FirstDirSector);
- UART_Send_StrNum("FSINFO扇區(qū)地址:",Init_Args.FSINFO_Sec);
- UART_Send_StrNum("下一空閑簇:",Init_Args.Next_Free_Cluster);
- UART_Send_StrNum("剩余空閑簇:",Init_Args.Free_nCluster);
- else // 文件系統(tǒng)初始化失敗
- UART_Send_StrNum("文件系統(tǒng)初始化失敗 , 錯(cuò)誤碼:",res);
- VS_Reset(); // VS1003復(fù)位初始化
- while(!znFAT_Open_File(&fileinfo,"/*.mp3",n,1)) //打開SD卡根目錄下所有MP3文件中的第n個(gè)
- UART_Send_Str("===========================================================\n");
- UART_Send_Str("打開文件成功\n"); // 從串口輸出文件參數(shù)信息
- UART_Send_Str("文件名為:");
- UART_Send_Str(fileinfo.File_Name);
- UART_Send_Enter();
- UART_Send_StrNum("文件大小(字節(jié)):",fileinfo.File_Size);
- UART_Send_StrNum("文件當(dāng)前偏移量(字節(jié)):",fileinfo.File_CurOffset);
- UART_Send_Str("文件創(chuàng)建時(shí)間:\n");
- UART_Send_Num(fileinfo.File_CDate.year); UART_Send_Str("年");
- UART_Send_Num(fileinfo.File_CDate.month);UART_Send_Str("月");
- UART_Send_Num(fileinfo.File_CDate.day); UART_Send_Str("日");
- UART_Send_Num(fileinfo.File_CTime.hour); UART_Send_Str("時(shí)");
- UART_Send_Num(fileinfo.File_CTime.min); UART_Send_Str("分");
- UART_Send_Num(fileinfo.File_CTime.sec); UART_Send_Str("秒\r\n");
- VS_sin_test(200); // 正弦測(cè)試,可以聽(tīng)到一聲滴
- znFAT_ReadDataX(&fileinfo,0,fileinfo.File_Size); //調(diào)用讀取文件函數(shù)(重定向),將數(shù)據(jù)送至VS1003
- VS_Reset();
- n++;
- UART_Send_StrNum("文件列舉完畢,共有文件(個(gè)):",n);
- while(1);
- return 0;
第21章 MP3播放器.zip
(19.99 MB, 下載次數(shù): 177)
2018-5-18 01:22 上傳
點(diǎn)擊文件名下載附件
