STM32F4+W5500以太網(wǎng)通訊+freemodbus
- /******************** (C) COPYRIGHT 2014 91mcu **************************
- * 文件名 :main.c
- * 描述 :W5500 以太網(wǎng)模塊測試程序:Modbus-TCP 功能實(shí)現(xiàn)。
- * 實(shí)驗(yàn)平臺(tái):STM32F103VCT6+W5500
- * 庫版本 :ST3.5.0
- * 作者 :zhangsz
- #include <string.h>
- #include <stdio.h>
- #include "stm32f10x.h"
- #include "W5500.h"
- #include "device.h"
- #include "systick.h"
- #include "led.h"
- #include "mb.h"
- /* ----------------------- Holding register Defines ------------------------------------------*/
- #define REG_HOLDING_START 1000
- #define REG_HOLDING_NREGS 4
- /* ----------------------- Static variables ---------------------------------*/
- static unsigned short usRegHoldingStart = REG_HOLDING_START;
- static unsigned short usRegHoldingBuf[REG_HOLDING_NREGS]={0xaa,0x55,0x5599,0x5588};
- /* ----------------------- input register Defines ------------------------------------------*/
- #define REG_INPUT_START 1000
- #define REG_INPUT_NREGS 4
- static unsigned short usRegInputStart = REG_INPUT_START;
- static unsigned short usRegInputBuf[REG_INPUT_NREGS]={0,0,0x5599,0x5588};
- /* ----------------------- coils register Defines ------------------------------------------*/
- #define REG_COILS_START 1000
- #define REG_COILS_SIZE 16
- static unsigned char ucRegCoilsBuf[REG_COILS_SIZE / 8]={0xaa,0xfe}; //數(shù)量低于8個(gè)還需要驗(yàn)證一下,是否需要加1呢。
- /* ----------------------- discrete register Defines ------------------------------------------*/
- #define REG_DISC_START 1000
- #define REG_DISC_SIZE 16
- static unsigned char ucRegDiscBuf[REG_DISC_SIZE / 8] = { 0x98, 0x6e }; //數(shù)量8的整數(shù)倍。
- void BSP_LED(void); //LED指示線圈操作
- /* W5500 configuration */
- void W5500_Configuration()
- unsigned char array[6];
- GPIO_SetBits(GPIO_W5500_RST_PORT, GPIO_W5500_RST_Pin);
- Delay_ms(100); /*delay 100ms 使用systick 1ms時(shí)基的延時(shí)*/
- while((Read_1_Byte(PHYCFGR)&LINK)==0); /* Waiting for Ethernet Link */
- Write_1_Byte(MR, RST);
- Delay_ms(20); /*delay 20ms */
- /* Set Gateway IP as: 192.168.1.1 */
- array[0]=192;
- array[1]=168;
- array[2]=1;
- array[3]=1;
- Write_Bytes(GAR, array, 4);
- /* Set Subnet Mask as: 255.255.255.0 */
- array[0]=255;
- array[1]=255;
- array[2]=255;
- array[3]=0;
- Write_Bytes(SUBR, array, 4);
- /* Set MAC Address as: 0x48,0x53,0x00,0x57,0x55,0x00 */
- array[0]=0x48;
- array[1]=0x53;
- array[2]=0x00;
- array[3]=0x57;
- array[4]=0x55;
- array[5]=0x00;
- Write_Bytes(SHAR, array, 6);
- /* Set W5500 IP as: 192.168.1.128 */
- array[0]=192;
- array[1]=168;
- array[2]=1;
- array[3]=128;
- Write_Bytes(SIPR, array, 4);
- Main Program
- int main(void)
- unsigned char i;
- /* Initialize STM32F103 */
- System_Initialization();
- SysTick_Init();
- /* Config W5500 */
- W5500_Configuration();
- Delay_ms(200);
- /* Modbus-TCP Init */
- eMBTCPInit(MB_TCP_PORT_USE_DEFAULT);
- Delay_ms(200);
- /* Enable Modbus-TCP Stack */
- eMBEnable();
- printf("\r\nModbus-TCP Start!\r\n");
- printf("IP:192.168.1.128\r\n");
- while(1)
- i=Read_SOCK_1_Byte(0,Sn_SR); //讀W5500狀態(tài)
- if(i==0)
- do
- Delay_ms(100);
- }while(Socket_Listen(0)==FALSE);
- else if(i==SOCK_ESTABLISHED) //建立TCP連接
- eMBPoll();
- BSP_LED();
- eMBErrorCode
- eMBRegHoldingCB( UCHAR * pucRegBuffer, USHORT usAddress, USHORT usNRegs,
- eMBRegisterMode eMode )
- eMBErrorCode eStatus = MB_ENOERR;
- int iRegIndex;
- if( ( usAddress >= REG_HOLDING_START ) &&
- ( usAddress + usNRegs <= REG_HOLDING_START + REG_HOLDING_NREGS ) )
- iRegIndex = ( int )( usAddress - usRegHoldingStart );
- switch ( eMode )
- /* Pass current register values to the protocol stack. */
- case MB_REG_READ:
- while( usNRegs > 0 )
- *pucRegBuffer++ =
- ( unsigned char )( usRegHoldingBuf[iRegIndex] >> 8 );
- *pucRegBuffer++ =
- ( unsigned char )( usRegHoldingBuf[iRegIndex] &
- 0xFF );
- iRegIndex++;
- usNRegs--;
- break;
- /* Update current register values with new values from the
- * protocol stack. */
- case MB_REG_WRITE:
- usRegHoldingBuf[iRegIndex] = *pucRegBuffer++ << 8;
- usRegHoldingBuf[iRegIndex] |= *pucRegBuffer++;
- iRegIndex++;
- usNRegs--;
- else
- eStatus = MB_ENOREG;
- return eStatus;
- * @功能
- * @參數(shù)
- * @返回值
- eMBErrorCode
- eMBRegInputCB( UCHAR * pucRegBuffer, USHORT usAddress, USHORT usNRegs )
- int iRegIndex;
- if( ( usAddress >= REG_INPUT_START )
- && ( usAddress + usNRegs <= REG_INPUT_START + REG_INPUT_NREGS ) )
- iRegIndex = ( int )( usAddress - usRegInputStart );
- *pucRegBuffer++ =
- ( unsigned char )( usRegInputBuf[iRegIndex] >> 8 );
- *pucRegBuffer++ =
- ( unsigned char )( usRegInputBuf[iRegIndex] & 0xFF );
- iRegIndex++;
- usNRegs--;
- else
- return eStatus;
- * @功能
- * @參數(shù)
- * @返回值
- eMBErrorCode
- eMBRegCoilsCB( UCHAR * pucRegBuffer, USHORT usAddress, USHORT usNCoils,
- int iNCoils = ( int )usNCoils;
- unsigned short usBitOffset;
- /* Check if we have registers mapped at this block. */
- if( ( usAddress >= REG_COILS_START ) &&
- ( usAddress + usNCoils <= REG_COILS_START + REG_COILS_SIZE ) )
- usBitOffset = ( unsigned short )( usAddress - REG_COILS_START );
- switch ( eMode )
- /* Read current values and pass to protocol stack. */
- case MB_REG_READ:
- while( iNCoils > 0 )
- *pucRegBuffer++ =
- xMBUtilGetBits( ucRegCoilsBuf, usBitOffset,
- ( unsigned char )( iNCoils >
- 8 ? 8 :
- iNCoils ) );
- iNCoils -= 8;
- usBitOffset += 8;
- break;
- /* Update current register values. */
- xMBUtilSetBits( ucRegCoilsBuf, usBitOffset,
- ( unsigned char )( iNCoils > 8 ? 8 : iNCoils ),
- *pucRegBuffer++ );
- iNCoils -= 8;
- usBitOffset += 8;
- break;
- else
- return eStatus;
- eMBErrorCode
- eMBRegDiscreteCB( UCHAR * pucRegBuffer, USHORT usAddress, USHORT usNDiscrete )
- short iNDiscrete = ( short )usNDiscrete;
- if( ( usAddress >= REG_DISC_START ) &&
- ( usAddress + usNDiscrete <= REG_DISC_START + REG_DISC_SIZE ) )
- usBitOffset = ( unsigned short )( usAddress - REG_DISC_START );
- while( iNDiscrete > 0 )
- *pucRegBuffer++ =
- xMBUtilGetBits( ucRegDiscBuf, usBitOffset,
- ( unsigned char )( iNDiscrete >
- 8 ? 8 : iNDiscrete ) );
- iNDiscrete -= 8;
- usBitOffset += 8;
- else
- return eStatus;
- // 線圈操作用于LED控制
- uint8_t led_state = ucRegCoilsBuf[0];
- if(led_state & 0x01)
- LED1(ON);
- else
- LED1(OFF);
- if(led_state & 0x02)
- LED2(ON);
- else
- LED2(OFF);
- if(led_state & 0x04)
- LED3(ON);
- else
- LED3(OFF);
- if(led_state & 0x08)
- LED4(ON);
- else
- LED4(OFF);
- /******************* (C) COPYRIGHT 2014 91mcu *****END OF FILE************/
fsmd-stm32_w5500_freemodbus_v1-master.zip
(386.72 KB, 下載次數(shù): 263)
2018-5-18 13:48 上傳
點(diǎn)擊文件名下載附件
程序
