網上找來的,需要的可以看一看
2018-5-22 01:09 上傳
arduino源程序如下:
- //Arduino 1.0+ Only
- /*Based largely on code by Jim Lindblom
- Get pressure, altitude, and temperature from the BMP085.
- Serial.print it out at 9600 baud to serial monitor.
- #include <Wire.h>
- #define BMP085_ADDRESS 0x77 // I2C address of BMP085
- const unsigned char OSS = 0; // Oversampling Setting
- // Calibration values
- int ac1;
- int ac2;
- int ac3;
- unsigned int ac4;
- unsigned int ac5;
- unsigned int ac6;
- int b1;
- int b2;
- int mb;
- int mc;
- int md;
- // b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
- // so ...Temperature(...) must be called before ...Pressure(...).
- long b5;
- void setup(){
- Serial.begin(9600);
- Wire.begin();
- bmp085Calibration();
- void loop()
- float temperature = bmp085GetTemperature(bmp085ReadUT()); //MUST be called first
- float pressure = bmp085GetPressure(bmp085ReadUP());
- float atm = pressure / 101325; // "standard atmosphere"
- float altitude = calcAltitude(pressure); //Uncompensated caculation - in Meters
- Serial.print("Temperature: ");
- Serial.print(temperature, 2); //display 2 decimal places
- Serial.println("deg C");
- Serial.print("Pressure: ");
- Serial.print(pressure, 0); //whole number only.
- Serial.println(" Pa");
- Serial.print("Standard Atmosphere: ");
- Serial.println(atm, 4); //display 4 decimal places
- Serial.print("Altitude: ");
- Serial.print(altitude, 2); //display 2 decimal places
- Serial.println(" M");
- Serial.println();//line break
- delay(1000); //wait a second and get values again.
- // Stores all of the bmp085's calibration values into global variables
- // Calibration values are required to calculate temp and pressure
- // This function should be called at the beginning of the program
- void bmp085Calibration()
- ac1 = bmp085ReadInt(0xAA);
- ac2 = bmp085ReadInt(0xAC);
- ac3 = bmp085ReadInt(0xAE);
- ac4 = bmp085ReadInt(0xB0);
- ac5 = bmp085ReadInt(0xB2);
- ac6 = bmp085ReadInt(0xB4);
- b1 = bmp085ReadInt(0xB6);
- b2 = bmp085ReadInt(0xB8);
- mb = bmp085ReadInt(0xBA);
- mc = bmp085ReadInt(0xBC);
- md = bmp085ReadInt(0xBE);
- // Calculate temperature in deg C
- float bmp085GetTemperature(unsigned int ut){
- long x1, x2;
- x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
- x2 = ((long)mc << 11)/(x1 + md);
- b5 = x1 + x2;
- float temp = ((b5 + 8)>>4);
- temp = temp /10;
- return temp;
- // Calculate pressure given up
- // calibration values must be known
- // b5 is also required so bmp085GetTemperature(...) must be called first.
- // Value returned will be pressure in units of Pa.
- long bmp085GetPressure(unsigned long up){
- long x1, x2, x3, b3, b6, p;
- unsigned long b4, b7;
- b6 = b5 - 4000;
- // Calculate B3
- x1 = (b2 * (b6 * b6)>>12)>>11;
- x2 = (ac2 * b6)>>11;
- x3 = x1 + x2;
- b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
- // Calculate B4
- x1 = (ac3 * b6)>>13;
- x2 = (b1 * ((b6 * b6)>>12))>>16;
- x3 = ((x1 + x2) + 2)>>2;
- b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
- b7 = ((unsigned long)(up - b3) * (50000>>OSS));
- if (b7 < 0x80000000)
- p = (b7<<1)/b4;
- else
- p = (b7/b4)<<1;
- x1 = (p>>8) * (p>>8);
- x1 = (x1 * 3038)>>16;
- x2 = (-7357 * p)>>16;
- p += (x1 + x2 + 3791)>>4;
- long temp = p;
- return temp;
- // Read 1 byte from the BMP085 at 'address'
- char bmp085Read(unsigned char address)
- unsigned char data;
- Wire.beginTransmission(BMP085_ADDRESS);
- Wire.write(address);
- Wire.endTransmission();
- Wire.requestFrom(BMP085_ADDRESS, 1);
- while(!Wire.available())
- return Wire.read();
- // Read 2 bytes from the BMP085
- // First byte will be from 'address'
- // Second byte will be from 'address'+1
- int bmp085ReadInt(unsigned char address)
- unsigned char msb, lsb;
- Wire.requestFrom(BMP085_ADDRESS, 2);
- while(Wire.available()<2)
- msb = Wire.read();
- lsb = Wire.read();
- return (int) msb<<8 | lsb;
- // Read the uncompensated temperature value
- unsigned int bmp085ReadUT(){
- unsigned int ut;
- // Write 0x2E into Register 0xF4
- // This requests a temperature reading
- Wire.write(0xF4);
- Wire.write(0x2E);
- // Wait at least 4.5ms
- delay(5);
- // Read two bytes from registers 0xF6 and 0xF7
- ut = bmp085ReadInt(0xF6);
- return ut;
- // Read the uncompensated pressure value
- unsigned long bmp085ReadUP(){
- unsigned char msb, lsb, xlsb;
- unsigned long up = 0;
- // Write 0x34+(OSS<<6) into register 0xF4
- // Request a pressure reading w/ oversampling setting
- Wire.write(0xF4);
- Wire.write(0x34 + (OSS<<6));
- // Wait for conversion, delay time dependent on OSS
- delay(2 + (3<<OSS));
- // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
- msb = bmp085Read(0xF6);
- lsb = bmp085Read(0xF7);
- xlsb = bmp085Read(0xF8);
- up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
- return up;
- void writeRegister(int deviceAddress, byte address, byte val) {
- Wire.beginTransmission(deviceAddress); // start transmission to device
- Wire.write(address); // send register address
- Wire.write(val); // send value to write
- Wire.endTransmission(); // end transmission
- int readRegister(int deviceAddress, byte address){
- int v;
- Wire.write(address); // register to read
- Wire.requestFrom(deviceAddress, 1); // read a byte
- while(!Wire.available()) {
- // waiting
- v = Wire.read();
- return v;
- float calcAltitude(float pressure){
- float A = pressure/101325;
- float B = 1/5.25588;
- float C = pow(A,B);
- C = 1 - C;
- C = C /0.0000225577;
- return C;
復制代碼
51單片機源碼
- // BMP085 IIC測試程序
- // 使用單片機STC89C51
- // 晶振:11.0592M
- // 顯示:LCD1602
- // 編譯環(huán)境 Keil uVision2
- // 參考宏晶網站24c04通信程序
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdlib.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H> //Keil library
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據端口
- sbit SCL=P1^0; //IIC時鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據引腳定義
- sbit LCM_RS=P2^0; //LCD1602命令端口
- sbit LCM_RW=P2^1; //LCD1602命令端口
- sbit LCM_EN=P2^2; //LCD1602命令端口
- #define BMP085_SlaveAddress 0xee //定義器件在IIC總線中的從地址
- #define OSS 0 // Oversampling Setting (note: code is not set up to use other OSS values)
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- uchar ge,shi,bai,qian,wan,shiwan; //顯示變量
- int dis_data; //變量
- short ac1;
- short ac2;
- short ac3;
- unsigned short ac4;
- unsigned short ac5;
- unsigned short ac6;
- short b1;
- short b2;
- short mb;
- short mc;
- short md;
- void delay(unsigned int k);
- void InitLcd(); //初始化lcd1602
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(long temp_data);
- void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data); //單個寫入數(shù)據
- uchar Single_Read(uchar REG_Address); //單個讀取內部寄存器數(shù)據
- void Multiple_Read(uchar,uchar); //連續(xù)的讀取內部寄存器數(shù)據
- void Delay5us();
- void Delay5ms();
- void BMP085_Start();
- void BMP085_Stop();
- void BMP085_SendACK(bit ack);
- bit BMP085_RecvACK();
- void BMP085_SendByte(BYTE dat);
- BYTE BMP085_RecvByte();
- void BMP085_ReadPage();
- void BMP085_WritePage();
- shiwan=temp_data/100000+0x30 ;
- temp_data=temp_data%100000; //取余運算
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運算
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 延時5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調整此函數(shù),注意時鐘過快時需要修改
- 當改用1T的MCU時,請調整此延時函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號
- SDA = 1; //拉高數(shù)據線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 0; //產生下降沿
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- 停止信號
- SDA = 0; //拉低數(shù)據線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 1; //產生上升沿
- Delay5us(); //延時
- 發(fā)送應答信號
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- 接收應答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- CY = SDA; //讀應答信號
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return CY;
- 向IIC總線發(fā)送一個字節(jié)數(shù)據
- BYTE i;
- for (i=0; i<8; i++) //8位計數(shù)器
- dat <<= 1; //移出數(shù)據的最高位
- SDA = CY; //送數(shù)據口
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- BMP085_RecvACK();
- 從IIC總線接收一個字節(jié)數(shù)據
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內部上拉,準備讀取數(shù)據,
- dat <<= 1;
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- dat |= SDA; //讀數(shù)據
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return dat;
- //單字節(jié)寫入BMP085內部數(shù)據*******************************
- BMP085_Start(); //起始信號
- BMP085_SendByte(SlaveAddress); //發(fā)送設備地址+寫信號
- BMP085_SendByte(REG_Address); //內部寄存器地址
- BMP085_SendByte(REG_data); //內部寄存器數(shù)據
- BMP085_Stop(); //發(fā)送停止信號
- //單字節(jié)讀取BMP085內部數(shù)據********************************
- { uchar REG_data;
- BMP085_SendByte(BMP085_SlaveAddress); //發(fā)送設備地址+寫信號
- BMP085_SendByte(REG_Address); //發(fā)送存儲單元地址
- BMP085_SendByte(BMP085_SlaveAddress+1); //發(fā)送設備地址+讀信號
- REG_data=BMP085_RecvByte(); //讀出寄存器數(shù)據
- BMP085_SendACK(1);
- BMP085_Stop(); //停止信號
- return REG_data;
- //讀出BMP085內部數(shù)據,連續(xù)兩個
- short Multiple_read(uchar ST_Address)
- uchar msb, lsb;
- short _data;
- BMP085_SendByte(ST_Address); //發(fā)送存儲單元地址
- msb = BMP085_RecvByte(); //BUF[0]存儲
- BMP085_SendACK(0); //回應ACK
- lsb = BMP085_RecvByte();
- BMP085_SendACK(1); //最后一個數(shù)據需要回NOACK
- Delay5ms();
- _data = msb << 8;
- _data |= lsb;
- return _data;
- long bmp085ReadTemp(void)
- BMP085_SendByte(0xF4); // write register address
- BMP085_SendByte(0x2E); // write register data for temp
- delay(10); // max time is 4.5ms
- return (long) Multiple_read(0xF6);
- long bmp085ReadPressure(void)
- long pressure = 0;
- BMP085_SendByte(0x34); // write register data for pressure
- pressure = Multiple_read(0xF6);
- pressure &= 0x0000FFFF;
- return pressure;
- //return (long) bmp085ReadShort(0xF6);
- //初始化BMP085,根據需要請參考pdf進行修改**************
- void Init_BMP085()
- ac1 = Multiple_read(0xAA);
- ac2 = Multiple_read(0xAC);
- ac3 = Multiple_read(0xAE);
- ac4 = Multiple_read(0xB0);
- ac5 = Multiple_read(0xB2);
- ac6 = Multiple_read(0xB4);
- b1 = Multiple_read(0xB6);
- b2 = Multiple_read(0xB8);
- mb = Multiple_read(0xBA);
- mc = Multiple_read(0xBC);
- md = Multiple_read(0xBE);
- void bmp085Convert()
- long ut;
- long up;
- long x1, x2, b5, b6, x3, b3, p;
- long temperature;
- long pressure;
- ut = bmp085ReadTemp();
- ut = bmp085ReadTemp(); // 讀取溫度
- up = bmp085ReadPressure();
- up = bmp085ReadPressure(); // 讀取壓強
- x1 = ((long)ut - ac6) * ac5 >> 15;
- x2 = ((long) mc << 11) / (x1 + md);
- b5 = x1 + x2;
- temperature = (b5 + 8) >> 4;
- conversion(temperature);
- DisplayOneChar(4,0,'T'); //溫度顯示
- DisplayOneChar(5,0,':');
- DisplayOneChar(7,0,bai);
- DisplayOneChar(8,0,shi);
- DisplayOneChar(9,0,'.');
- DisplayOneChar(10,0,ge);
- DisplayOneChar(11,0,0XDF); //溫度單位
- DisplayOneChar(12,0,'C');
- b6 = b5 - 4000;
復制代碼
【批量下載】GY-68 BMP180 新款 BOSCH溫度 代替BMP085 氣壓傳感器模塊1等.zip
(2.21 MB, 下載次數(shù): 58)
2018-5-21 17:55 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
