利用STM8驅(qū)動的陀螺儀程序,參考其他人寫的32的程序,自己修改接口,完成驅(qū)動陀螺儀。
- #include "MPU6050.h"
- #include "IOI2C.h"
- #include "usart1.h"
- #include <math.h>
- #include "inv_mpu_dmp_motion_driver.h"
- #include "inv_mpu.h"
- #include <stdio.h>
- #define PRINT_ACCEL (0x01)
- #define PRINT_GYRO (0x02)
- #define PRINT_QUAT (0x04)
- #define ACCEL_ON (0x01)
- #define GYRO_ON (0x02)
- #define MOTION (0)
- #define NO_MOTION (1)
- #define DEFAULT_MPU_HZ (200)
- #define FLASH_SIZE (512)
- #define FLASH_MEM_START ((void*)0x1800)
- #define q30 1073741824.0f
- static signed char gyro_orientation[9] = {-1, 0, 0,
- 0,-1, 0,
- 0, 0, 1};
- static unsigned short inv_row_2_scale(const signed char *row)
- unsigned short b;
- if (row[0] > 0)
- b = 0;
- else if (row[0] < 0)
- b = 4;
- else if (row[1] > 0)
- b = 1;
- else if (row[1] < 0)
- b = 5;
- else if (row[2] > 0)
- b = 2;
- else if (row[2] < 0)
- b = 6;
- else
- b = 7; // error
- return b;
- static unsigned short inv_orientation_matrix_to_scalar(
- const signed char *mtx)
- unsigned short scalar;
- scalar = inv_row_2_scale(mtx);
- scalar |= inv_row_2_scale(mtx + 3) << 3;
- scalar |= inv_row_2_scale(mtx + 6) << 6;
- return scalar;
- static void run_self_test(void)
- int result;
- long gyro[3], accel[3];
- result = mpu_run_self_test(gyro, accel);
- if (result == 0x7) {
- /* Test passed. We can trust the gyro data here, so let's push it down
- * to the DMP.
- float sens;
- unsigned short accel_sens;
- mpu_get_gyro_sens(&sens);
- gyro[0] = (long)(gyro[0] * sens);
- gyro[1] = (long)(gyro[1] * sens);
- gyro[2] = (long)(gyro[2] * sens);
- dmp_set_gyro_bias(gyro);
- mpu_get_accel_sens(&accel_sens);
- accel[0] *= accel_sens;
- accel[1] *= accel_sens;
- accel[2] *= accel_sens;
- dmp_set_accel_bias(accel);
- printf("setting bias succesfully ......\r\n");
- uint8_t buffer[14];
- int16_t MPU6050_FIFO[6][11];
- int16_t Gx_offset=0,Gy_offset=0,Gz_offset=0;
- /**************************實(shí)現(xiàn)函數(shù)********************************************
- *函數(shù)原型: void MPU6050_newValues(int16_t ax,int16_t ay,int16_t az,int16_t gx,int16_t gy,int16_t gz)
- *功 能: 將新的ADC數(shù)據(jù)更新到 FIFO數(shù)組,進(jìn)行濾波處理
- void MPU6050_newValues(int16_t ax,int16_t ay,int16_t az,int16_t gx,int16_t gy,int16_t gz)
- unsigned char i ;
- int32_t sum=0;
- for(i=1;i<10;i++){ //FIFO 操作
- MPU6050_FIFO[0][i-1]=MPU6050_FIFO[0][i];
- MPU6050_FIFO[1][i-1]=MPU6050_FIFO[1][i];
- MPU6050_FIFO[2][i-1]=MPU6050_FIFO[2][i];
- MPU6050_FIFO[3][i-1]=MPU6050_FIFO[3][i];
- MPU6050_FIFO[4][i-1]=MPU6050_FIFO[4][i];
- MPU6050_FIFO[5][i-1]=MPU6050_FIFO[5][i];
- MPU6050_FIFO[0][9]=ax;//將新的數(shù)據(jù)放置到 數(shù)據(jù)的最后面
- MPU6050_FIFO[1][9]=ay;
- MPU6050_FIFO[2][9]=az;
- MPU6050_FIFO[3][9]=gx;
- MPU6050_FIFO[4][9]=gy;
- MPU6050_FIFO[5][9]=gz;
- sum=0;
- for(i=0;i<10;i++){ //求當(dāng)前數(shù)組的合,再取平均值
- sum+=MPU6050_FIFO[0][i];
- MPU6050_FIFO[0][10]=sum/10;
- sum=0;
- sum+=MPU6050_FIFO[1][i];
- MPU6050_FIFO[1][10]=sum/10;
- sum=0;
- sum+=MPU6050_FIFO[2][i];
- MPU6050_FIFO[2][10]=sum/10;
- sum=0;
- sum+=MPU6050_FIFO[3][i];
- MPU6050_FIFO[3][10]=sum/10;
- sum=0;
- sum+=MPU6050_FIFO[4][i];
- MPU6050_FIFO[4][10]=sum/10;
- sum=0;
- sum+=MPU6050_FIFO[5][i];
- MPU6050_FIFO[5][10]=sum/10;
- *函數(shù)原型: void MPU6050_setClockSource(uint8_t source)
- *功 能: 設(shè)置 MPU6050 的時鐘源
- * CLK_SEL | Clock Source
- * 0 | Internal oscillator
- * 1 | PLL with X Gyro reference
- * 2 | PLL with Y Gyro reference
- * 3 | PLL with Z Gyro reference
- * 4 | PLL with external 32.768kHz reference
- * 5 | PLL with external 19.2MHz reference
- * 6 | Reserved
- * 7 | Stops the clock and keeps the timing generator in reset
- void MPU6050_setClockSource(uint8_t source){
- IICwriteBits(devAddr, MPU6050_RA_PWR_MGMT_1, MPU6050_PWR1_CLKSEL_BIT, MPU6050_PWR1_CLKSEL_LENGTH, source);
- /** Set full-scale gyroscope range.
- * @param range New full-scale gyroscope range value
- * @see getFullScaleRange()
- * @see MPU6050_GYRO_FS_250
- * @see MPU6050_RA_GYRO_CONFIG
- * @see MPU6050_GCONFIG_FS_SEL_BIT
- * @see MPU6050_GCONFIG_FS_SEL_LENGTH
- void MPU6050_setFullScaleGyroRange(uint8_t range) {
- IICwriteBits(devAddr, MPU6050_RA_GYRO_CONFIG, MPU6050_GCONFIG_FS_SEL_BIT, MPU6050_GCONFIG_FS_SEL_LENGTH, range);
- *函數(shù)原型: void MPU6050_setFullScaleAccelRange(uint8_t range)
- *功 能: 設(shè)置 MPU6050 加速度計的最大量程
- void MPU6050_setFullScaleAccelRange(uint8_t range) {
- IICwriteBits(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_AFS_SEL_BIT, MPU6050_ACONFIG_AFS_SEL_LENGTH, range);
- *函數(shù)原型: void MPU6050_setSleepEnabled(uint8_t enabled)
- *功 能: 設(shè)置 MPU6050 是否進(jìn)入睡眠模式
- enabled =1 睡覺
- enabled =0 工作
- void MPU6050_setSleepEnabled(uint8_t enabled) {
- IICwriteBit(devAddr, MPU6050_RA_PWR_MGMT_1, MPU6050_PWR1_SLEEP_BIT, enabled);
- *函數(shù)原型: uint8_t MPU6050_getDeviceID(void)
- *功 能: 讀取 MPU6050 WHO_AM_I 標(biāo)識 將返回 0x68
- uint8_t MPU6050_getDeviceID(void) {
- IICreadBytes(devAddr, MPU6050_RA_WHO_AM_I, 1, buffer);
- return buffer[0];
- *函數(shù)原型: uint8_t MPU6050_testConnection(void)
- *功 能: 檢測MPU6050 是否已經(jīng)連接
- uint8_t MPU6050_testConnection(void) {
- if(MPU6050_getDeviceID() == 0x68) //0b01101000;
- return 1;
- else return 0;
- *函數(shù)原型: void MPU6050_setI2CMasterModeEnabled(uint8_t enabled)
- *功 能: 設(shè)置 MPU6050 是否為AUX I2C線的主機(jī)
- void MPU6050_setI2CMasterModeEnabled(uint8_t enabled) {
- IICwriteBit(devAddr, MPU6050_RA_USER_CTRL, MPU6050_USERCTRL_I2C_MST_EN_BIT, enabled);
- *函數(shù)原型: void MPU6050_setI2CBypassEnabled(uint8_t enabled)
- void MPU6050_setI2CBypassEnabled(uint8_t enabled) {
- IICwriteBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_I2C_BYPASS_EN_BIT, enabled);
- *函數(shù)原型: void MPU6050_initialize(void)
- *功 能: 初始化 MPU6050 以進(jìn)入可用狀態(tài)。
- void MPU6050_initialize(void) {
- MPU6050_setClockSource(MPU6050_CLOCK_PLL_XGYRO); //設(shè)置時鐘
- MPU6050_setFullScaleGyroRange(MPU6050_GYRO_FS_2000);//陀螺儀最大量程 +-1000度每秒
- MPU6050_setFullScaleAccelRange(MPU6050_ACCEL_FS_2); //加速度度最大量程 +-2G
- MPU6050_setSleepEnabled(0); //進(jìn)入工作狀態(tài)
- MPU6050_setI2CMasterModeEnabled(0); //不讓MPU6050 控制AUXI2C
- MPU6050_setI2CBypassEnabled(0); //主控制器的I2C與 MPU6050的AUXI2C 直通?刂破骺梢灾苯釉L問HMC5883L
- 函數(shù)功能:MPU6050內(nèi)置DMP的初始化
- 入口參數(shù):無
- 返回 值:無
- 作 者:平衡小車之家
- void DMP_Init(void)
- u8 temp[1]={0};
- i2cRead(0x68,0x75,1,temp);
- printf("mpu_set_sensor complete ......\r\n");
- if(temp[0]!=0x68)NVIC_SystemReset();
- if(!mpu_init())
- if(!mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL))
- if(!mpu_configure_fifo(INV_XYZ_GYRO | INV_XYZ_ACCEL))
- printf("mpu_configure_fifo complete ......\r\n");
- if(!mpu_set_sample_rate(DEFAULT_MPU_HZ))
- printf("mpu_set_sample_rate complete ......\r\n");
- if(!dmp_load_motion_driver_firmware())
- printf("dmp_load_motion_driver_firmware complete ......\r\n");
- if(!dmp_set_orientation(inv_orientation_matrix_to_scalar(gyro_orientation)))
- printf("dmp_set_orientation complete ......\r\n");
- if(!dmp_enable_feature(DMP_FEATURE_6X_LP_QUAT | DMP_FEATURE_TAP |
- DMP_FEATURE_ANDROID_ORIENT | DMP_FEATURE_SEND_RAW_ACCEL | DMP_FEATURE_SEND_CAL_GYRO |
- DMP_FEATURE_GYRO_CAL))
- printf("dmp_enable_feature complete ......\r\n");
- if(!dmp_set_fifo_rate(DEFAULT_MPU_HZ))
- printf("dmp_set_fifo_rate complete ......\r\n");
- run_self_test();
- if(!mpu_set_dmp_state(1))
- printf("mpu_set_dmp_state complete ......\r\n");
- 函數(shù)功能:讀取MPU6050內(nèi)置DMP的姿態(tài)信息
- 入口參數(shù):無
- 返回 值:無
- 作 者:平衡小車之家
- uint8_t Read_DMP(float* Pitch,float* Roll,float* Yaw)
6050測試3.rar
(598.63 KB, 下載次數(shù): 301)
2018-5-22 16:23 上傳
點(diǎn)擊文件名下載附件
