查看: 7315|回復(fù): 3
這是這幾天來做的基于51單片機(jī)PWM調(diào)速的藍(lán)牙小車代碼,希望能幫到需要的人
ID:336097 發(fā)表于 2018-5-22 22:13 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
uchar n='0',num0=0,num1=0;
char zuo_pwm=35,you_pwm=35 ;
sbit zuo1=P0^0;//in1
sbit zuo2=P0^1;//in2
sbit you1=P0^2;
sbit you2=P0^3;
sbit ENA=P0^4;
sbit ENB=P0^5;
/* 函數(shù)功能:設(shè)置串口*/
void init()          //time0
        TMOD=0x21;
        SCON=0x50;
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TMOD |= 0x01;                //設(shè)置定時(shí)器模式
    TL0 = 0x91;                //設(shè)置定時(shí)初值
        TH0 = 0xFF;                //設(shè)置定時(shí)初值
        TH1=0xfd;
        TL1=0xfd;
        EA=1;                         //打開總中斷
        ET0=1;                        //打開定時(shí)器0中斷允許
        TR1=1;                         //定時(shí)器1開始計(jì)時(shí)
        TR0=1;                         //定時(shí)器0開始計(jì)時(shí)
        ES=1;                   //打開接收中斷
void qian ()
        zuo_pwm=17;
        you_pwm=17;
        zuo1=1;
        zuo2=0;
        you1=1;
        you2=0;
void jiansu ()                                  //智能燈熄滅
        zuo_pwm=8;
        you_pwm=8;
        zuo1=1;
        zuo2=0;
        you1=1;
        you2=0;
//        zuo1=0;
//        zuo2=0;
//        you1=0;
//        you2=0;
//zuo_pwm=0;
//you_pwm=0;
void jiasu ()
        zuo_pwm=35;
        you_pwm=35;
        zuo1=1;
        zuo2=0;
        you1=1;
        you2=0;
void hou ()                        //智能燈1/3亮度
        zuo_pwm=17;
        you_pwm=17;
        zuo1=0;
        zuo2=1;
        you1=0;
        you2=1;
void turnleft ()                             //智能燈2/3亮度
    zuo_pwm = 13;
        you_pwm = 16;
    zuo1=1;
        zuo2=0;
        you1=1;
        you2=0;
void turnright ()
        zuo_pwm = 16;
        you_pwm = 13;
        zuo1=1;
        zuo2=0;
        you1=1;
        you2=0;
void stop ()
        zuo1=0;
        zuo2=0;
        you1=0;
        you2=0;
void zhuandong ()
        zuo_pwm=35;
        you_pwm=35;
        zuo1=1;
        zuo2=0;
        you1=0;
        you2=1;
void zhuandong_jian ()
        zuo_pwm=12;
        you_pwm=12;
        zuo1=1;
        zuo2=0;
        you1=0;
        you2=1;
void main ()
        init ();                                                  //初始化
        while (1)
                           switch (n)                                                    //藍(lán)牙控制
                                case '2':qian ();    break;
                                case '3':jiansu ();   break;
                                case '4':jiasu ();    break;
                                case '5':hou ();      break;
                                case '6':turnleft (); break;
                                case '7':turnright (); break;
                                case '8':zhuandong ();  break;
                                case '9':zhuandong_jian (); break;
                                case '0':stop (); break;
                                default:break;
void UART_SER()interrupt 4
        if (RI)
                RI=0;
                n=SBUF;
                TI=1;
                SBUF=n;
        if (TI)
        TI=0;
//定時(shí)器0中斷函數(shù)
void Timer1Interrupt(void) interrupt 1
    //PWM調(diào)占空比
        num0++;
                num0++;
        num1++;
        if(num0<=zuo_pwm)
         {ENA=1;}
             ENA=0;
               if(num0==40)
               ENA=~ENA;
               num0=0;
               if(num1<=you_pwm)
               ENB=1;
                ENB=0;
                 if(num1==40)
                {ENB=~ENB;num1=0;}
參與人數(shù) 1黑幣 +5 收起 理由
GRYESR + 5 很給力!
ID:479857 發(fā)表于 2022-10-26 15:01 | 顯示全部樓層
ena,enb沒開啟
ID:479857 發(fā)表于 2022-10-26 15:14 | 顯示全部樓層
代碼問題在左右轉(zhuǎn),電機(jī)控制轉(zhuǎn)動(dòng)只能一個(gè)輪子有電,另一個(gè)停止
ID:479857 發(fā)表于 2022-10-26 15:16 | 顯示全部樓層
左右電機(jī)轉(zhuǎn)彎電機(jī)速度控制,彎度過大
