本程序用于測(cè)試4相步進(jìn)電機(jī)常規(guī)驅(qū)動(dòng)
使用1-2相勵(lì)磁
1-2相激勵(lì)功率增倍,步進(jìn)角度減半,抖動(dòng)減少
順序如下 a-ab-b-bc-c-cd-d-da 又稱4相8拍
數(shù)碼管顯示 03-19速度等級(jí),數(shù)字越大,速度越慢
- #include <reg52.h>
- #define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
- sbit LATCH1=P2^2;//定義鎖存使能端口 段鎖存
- sbit LATCH2=P2^3;// 位鎖存
- unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 顯示段碼值0~9
- unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對(duì)應(yīng)相應(yīng)的數(shù)碼管點(diǎn)亮,即位碼
- unsigned char TempData[8]; //存儲(chǔ)顯示值的全局變量
- sbit A1=P1^0; //定義步進(jìn)電機(jī)連接端口
- sbit B1=P1^1;
- sbit C1=P1^2;
- sbit D1=P1^3;
- #define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}//AB相通電,其他相斷電
- #define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}//BC相通電,其他相斷電
- #define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;}//CD相通電,其他相斷電
- #define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
- #define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}//A相通電,其他相斷電
- #define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}//B相通電,其他相斷電
- #define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}//C相通電,其他相斷電
- #define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}//D相通電,其他相斷電
- #define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}//全部斷電
- unsigned char Speed;
- void Display(unsigned char FirstBit,unsigned char Num);
- void Init_Timer0(void);
- uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
- unsigned char 是定義無符號(hào)字符變量,其值的范圍是
- 0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
- 長(zhǎng)度如下 T=tx2+5 uS
- void DelayUs2x(unsigned char t)
- while(--t);
- mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
- void DelayMs(unsigned char t)
- while(t--)
- //大致延時(shí)1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 主函數(shù)
- main()
- unsigned int i=512;//旋轉(zhuǎn)一周時(shí)間
- Init_Timer0();
- EA=1; //全局中斷開
- EX0=1; //外部中斷0開
- IT0=1; //1表示邊沿觸發(fā)
- Speed=3;
- TempData[0]=dofly_DuanMa[Speed/10];//分解顯示信息,如要顯示68,
- TempData[1]=dofly_DuanMa[Speed%10];//則68/10=6 68%10=8
- Coil_OFF
- while(i--) //正向
- { Coil_A1
- DelayMs(Speed);
- Coil_AB1 //遇到Coil_AB1 用{A1=1;B1=1;C1=0;D1=0;}代替
- DelayMs(Speed); //改變這個(gè)參數(shù)可以調(diào)整電機(jī)轉(zhuǎn)速 ,
- //數(shù)字越小,轉(zhuǎn)速越大,力矩越小
- Coil_B1
- DelayMs(Speed);
- Coil_BC1
- DelayMs(Speed);
- Coil_C1
- DelayMs(Speed);
- Coil_CD1
- DelayMs(Speed);
- Coil_D1
- DelayMs(Speed);
- Coil_DA1
- DelayMs(Speed);
- 外部中斷程序
- void ISR_INT0(void) interrupt 0
- if(!INT0)
- DelayMs(10);//在此處可以添加去抖動(dòng)程序,防止按鍵抖動(dòng)造成錯(cuò)誤
- if(!INT0)
- //while(!INT1);//等待按鍵釋放
- Speed++;
- if(Speed==20)
- Speed=3;
- 顯示函數(shù),用于動(dòng)態(tài)掃描數(shù)碼管
- 輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個(gè)數(shù)碼管開始顯示
- 如輸入0表示從第一個(gè)顯示。
- Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
- static unsigned char i=0;
- DataPort=0; //清空數(shù)據(jù),防止有交替重影
- LATCH1=1; //段鎖存
- LATCH1=0;
- DataPort=dofly_WeiMa[i+FirstBit]; //取位碼
- LATCH2=1; //位鎖存
- LATCH2=0;
- DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
- LATCH1=1; //段鎖存
- LATCH1=0;
- i++;
- if(i==Num)
- i=0;
- 定時(shí)器初始化子程序
- TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
- //TH0=0x00; //給定初值
- //TL0=0x00;
- EA=1; //總中斷打開
- ET0=1; //定時(shí)器中斷打開
- TR0=1; //定時(shí)器開關(guān)打開
- PT0=1; //優(yōu)先級(jí)打開
- 定時(shí)器中斷子程序
- void Timer0_isr(void) interrupt 1
- TH0=(65536-2000)/256; //重新賦值 2ms
- TL0=(65536-2000)%256;
- Display(0,8);
