簡單的運用外部中斷的仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機源程序如下:
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SMG[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
- 0x6f,0x00};//共陰段碼,最后一位為數碼管不顯示
- uchar Display_Smg[4] = {0,0,0,0}; //計數值分解后的各待顯示數位
- uchar Dis_Buffer[4]; //顯示緩沖,用于存放待顯示的數字的段碼
- uint Count = 0;
- sbit Key_Clear = P3^6;
- void delay(uchar t)
- uchar i;
- while(t--) for(i = 0;i < 120;i++);
- void Display_Count()
- static uchar Scan_Bit = 0xF7;
- static uchar Dsy_Idx = 0;
- uchar i;
- Display_Smg[3] = Count /1000;//取千位
- Display_Smg[2] = Count /100%10;//取百位
- Display_Smg[1] = Count % 100/10;
- Display_Smg[0] = Count % 10;
- for(i = 0; i < 4;i++)
- Dis_Buffer[i] = SMG[Display_Smg[i]];
- P2 = Scan_Bit;
- P0 = Dis_Buffer[Dsy_Idx];
- delay(1);
- Scan_Bit = _cror_(Scan_Bit,1);
- Dsy_Idx = (Dsy_Idx+1)%4;
- void main()
- EA = 1;
- EX0 = 1;
- EX1 = 1;
- IT0 = 1;
- IT1 = 1;
- while(1)
- if(Count == 10000) Count = 0;
- Display_Count();
- void jishu() interrupt 0
- Count++;
- void clear0() interrupt 2
- Count = 0;
復制代碼
兩個外部中斷控制計數和清零.zip
(59.21 KB, 下載次數: 25)
2018-5-28 18:16 上傳
點擊文件名下載附件
