查看: 1788|回復(fù): 3
求大神幫個(gè)忙,初學(xué)單片機(jī)以下代碼怎么改成共陰極的?功能是顯示時(shí)分秒
ID:312571 發(fā)表于 2018-5-28 21:06 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#define  uchar unsigned char
#define  uint  unsigned int
void   KeyHandle(void);   /*按鍵處理模塊*/
void   Delay ();          /*10ms延時(shí)*/
void   DispClock();
uchar  Control[6]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//數(shù)碼管控制選通
uchar  DisplayArray[6]={0x00,0x00,0x00,0x00,0x00,0x00};//中間存儲(chǔ)變量
uchar code CodeNum[16]={0x28,0xEB,0x32,0xA2,0xE1,
0xA4,0x24,0xE8,0x20,0xA0};//0-f段碼
uchar  Keyflag=0;/*按鍵處理標(biāo)記*/
uchar  SetFlag=0;//=0,Normal;=1,調(diào)秒; =2,調(diào)分;=3,調(diào)時(shí);
uchar  Msecond,Second,Minite,Hour;
sbit P1_0 = P1^0;
sbit P1_1 = P1^1;
sbit P3_7 = P3^7;
sbit P3_3 = P3^3;
void main(void)
  EA=1;
  ET0=1;
  ET1=1;
  P1_1=1;
  P3_7=1;
  P3_3=1;
  TMOD = 0x11;
  TH0=(65536-20000)/256;
  TL0=(65536-20000)%256; //設(shè)定時(shí)值為20ms
  TH1=(65536-500)/256;
  TL1=(65536-500)%256; //設(shè)定時(shí)值為500us
  TR0=1;
  TR1=1; //開(kāi)始定時(shí)
  for(;;)//while(1)
        DispClock();
        KeyHandle();
void Time0(void) interrupt 1
  Msecond++;
  if(Msecond>=50)
        Msecond=0;
        Second++;
        if(Second>=60)
          Second=0;
          Minite++;
  if(Minite>=60)
            Minite=0;
             Hour++;
           if(Hour>=24)
             Hour=0;
void Time1(void) interrupt 3
  static uchar s_count=0;//變量定義在其它語(yǔ)句之前,keil c(非C語(yǔ)言規(guī)則)
  uchar temp;
  P0=Control[s_count];
  temp=DisplayArray[s_count];
  P2=CodeNum[temp];
  s_count++;
  if(s_count>5)
   s_count=0;
void KeyHandle(void)             /*按鍵處理*/
  P1_0=1;
  if(P1_0==0)
   Delay();
   if(P1_0==0)
             SetFlag++;
          if(SetFlag>3)
          SetFlag=0;
          switch (SetFlag)
           { case 1:
                   P3_7 = 0;
                   P3_3 = 0;
                   break;
             case 2:
                   P3_7 = 1;
                   P3_3 = 0;
                   break;
                 case 3:
                   P3_7 = 0;
                   P3_3 = 1;
                   break;
                 default:
                   P3_7 = 1;
                   P3_3 = 1;
                   break;
         P1_0=1;                  //防止按鍵不放
     while((P1_0&0x01)!=0x01);
         //加法處理
         P1_1=1;
         if(P1_1==0)
           Delay();
           if(P1_1==0)
            switch (SetFlag)
                  case 1:
                          Second++;
                          if(Second>=60) Second=0;
                          break;
                  case 2:
                          Minite++;
                          if(Minite>=60) Minite=0;
                          break;
                  case 3:
                          Hour++;
                          if(Hour>=24) Hour=0;break;
                  default:        break;
                P1_1=1;                                   //防止按鍵不放
            while((P1_1&0x01)!=0x01);
void  DispClock()
uchar tempData=0;
tempData=Second;//秒鐘分解
DisplayArray[0]=tempData%10;
DisplayArray[1]=tempData/10;
tempData=Minite;//分鐘分解
DisplayArray[2]=tempData%10;
DisplayArray[3]=tempData/10;
tempData=Hour;//小時(shí)分解
DisplayArray[4]=tempData%10;
DisplayArray[5]=tempData/10;
void Delay()//10ms延時(shí)
        uchar i,j;
        for(i=20;i>0;i--)
        for(j=249;j>0;j--);
ID:317135 發(fā)表于 2018-5-29 11:59 | 只看該作者
第一要你的顯示數(shù)碼管是共陰級(jí)的
第二程序中uchar  Control[6]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//數(shù)碼管控制選通
這一塊看你是不是使用共陰來(lái)編寫段選的,如果是的話就OK了
ID:312571 發(fā)表于 2018-5-29 14:22 | 只看該作者
loading88 發(fā)表于 2018-5-29 11:59
第二程序中uchar  Control[6]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//數(shù)碼管 ...
請(qǐng)問(wèn)一下1.0  1-1   3-7  和3-3是控制什么的啊
ID:340390 發(fā)表于 2018-5-29 21:29 | 只看該作者
應(yīng)該按位取反就好了吧,P2=~(CodeNum[temp]);
