給大家分享一個用1602顯示的光照檢測儀,干貨都在壓縮包里呢,請大家品嘗
電路原理圖如下:
2018-5-30 02:43 上傳
單片機源程序如下:
- 聲明:此程序僅供大家學習使用,不得用于商業(yè)用途!
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- uchar data_byte;
- uchar RH,RL,TH,TL;
- sbit io = P3^2 ;
- int BJReadTempDate;//取前2位出來與設置的報警溫度比較
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P3^3; //IIC時鐘引腳定義
- sbit SDA=P3^4; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P2^5; //LCD1602命令端口
- sbit LCM_RW=P2^6; //LCD1602命令端口
- sbit LCM_EN=P2^7; //LCD1602命令端口
- sbit K1 = P1^0;
- sbit K2 = P1^1;
- sbit K3 = P1^2;
- sbit control_bell = P1^7;
- sbit control_light = P2^0;
- #define SlaveAddress 0x46 //定義器件在IIC總線中的從地址,根據(jù)ALT ADDRESS地址引腳不同修改
- //ALT ADDRESS引腳接地時地址為0x46,接電源時地址為0xB8
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- float temp;
- BYTE BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- uchar Ntemp,Nhumi,Nlight;
- uchar yemian=0;
- int dis_data; //變量
- int S_Temp,Light;
- uchar flag=0,flagone=1;
- #include "eeprom52.h"
- void delay_nms(unsigned int k);
- void InitLcd();
- void Init_BH1750(void);
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(uint temp_data);
- void Single_Write_BH1750(uchar REG_Address); //單個寫入數(shù)據(jù)
- uchar Single_Read_BH1750(uchar REG_Address); //單個讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read_BH1750(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void BH1750_Start(); //起始信號
- void BH1750_Stop(); //停止信號
- void BH1750_SendACK(bit ack); //應答ACK
- bit BH1750_RecvACK(); //讀ack
- void BH1750_SendByte(BYTE dat); //IIC單個字節(jié)寫
- BYTE BH1750_RecvByte(); //IIC單個字節(jié)讀
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /****************************延時程序****************************/
- void delay(uchar ms)
- { // 延時子程序
- uchar i ;
- while(ms--)
- for(i = 0 ; i<250;i++) ;
- void delay1()//延時10us
- uchar i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void longdelay(uchar s) //長延時
- while(s--)
- delay(20) ;
- /******************把數(shù)據(jù)保存到單片機內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2001, Nlight);
- byte_write(0x2002, Ntemp);
- byte_write(0x2003, Nhumi);
- byte_write(0x2060, a_a);
- /******************把數(shù)據(jù)從單片機內(nèi)部eeprom中讀出來*****************/
- void read_eeprom()
- Nlight = byte_read(0x2001);
- Ntemp = byte_read(0x2002);
- Nhumi = byte_read(0x2003);
- a_a = byte_read(0x2060);
- /**************開機自檢eeprom初始化*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 2) //新的單片機初始單片機內(nèi)問eeprom
- a_a=2;
- Nlight =10;
- Ntemp =35;
- Nhumi =30;
- write_eeprom();
- /*********************** DHT11測試模塊***************************************/
- void start()//開始信號
- io=1;
- delay1();
- io=0;
- delay(20);//>18ms
- io=1;
- delay1();//20-40us
- delay1();
- delay1();
- delay1();
- delay1();
- uchar receive_byte()//接收一個字節(jié)
- uchar i,temp,count;
- for(i=0;i<8;i++)
- count=2;
- while((!io)&&count++)//等待50us低電平結(jié)束
- temp=0;
- delay1();delay1();delay1();delay1();
- if(io==1)temp=1;
- count=2;
- while((io)&&count++);
- if(count==1)break;
- data_byte<<=1;
- data_byte|=temp;
- return data_byte;
- void receive()//接收數(shù)據(jù)
- uchar T_H,T_L,R_H,R_L,check,num_check;
- uchar count;
- start();//開始信號
- io=1;
- if(!io)//讀取DHT11響應信號
- R_H=receive_byte();
- R_L=receive_byte();
- T_H=receive_byte();
- T_L=receive_byte();
- check=receive_byte();
- io=0;//拉低延時50us
- delay1();delay1();delay1();delay1();delay1();
- io=1;
- num_check=R_H+R_L+T_H+T_L;
- if(num_check=check)
- RH=R_H;
- RL=R_L;
- TH=T_H;
- TL=T_L;
- check=num_check;
- void conversion(uint temp_data) // 數(shù)據(jù)轉(zhuǎn)換出 個,十,百,千,萬
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運算
- ge=temp_data+0x30;
- //毫秒延時**************************
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 延時5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時鐘過快時需要修改
- 當改用1T的MCU時,請調(diào)整此延時函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 0; //產(chǎn)生下降沿
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- 停止信號
- SDA = 0; //拉低數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 1; //產(chǎn)生上升沿
- Delay5us(); //延時
- 發(fā)送應答信號
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- 接收應答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- CY = SDA; //讀應答信號
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return CY;
- 向IIC總線發(fā)送一個字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- BH1750_RecvACK();
- 從IIC總線接收一個字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準備讀取數(shù)據(jù),
- dat <<= 1;
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- dat |= SDA; //讀數(shù)據(jù)
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return dat;
- BH1750_SendByte(SlaveAddress); //發(fā)送設備地址+寫信號
- BH1750_SendByte(REG_Address); //內(nèi)部寄存器地址,
- // BH1750_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),
- BH1750_Stop(); //發(fā)送停止信號
- //********單字節(jié)讀取*****************************************
- { uchar REG_data;
- BH1750_Start(); //起始信號
- BH1750_SendByte(REG_Address); //發(fā)送存儲單元地址,從0開始
- BH1750_SendByte(SlaveAddress+1); //發(fā)送設備地址+讀信號
- REG_data=BH1750_RecvByte(); //讀出寄存器數(shù)據(jù)
- BH1750_SendACK(1);
- BH1750_Stop(); //停止信號
- return REG_data;
- //連續(xù)讀出BH1750內(nèi)部數(shù)據(jù)
- void Multiple_read_BH1750(void)
- { uchar i;
- for (i=0; i<3; i++) //連續(xù)讀取2個地址數(shù)據(jù),存儲中BUF
- BUF[i] = BH1750_RecvByte(); //BUF[0]存儲0x32地址中的數(shù)據(jù)
- if (i == 3)
- BH1750_SendACK(1); //最后一個數(shù)據(jù)需要回NOACK
- else
- BH1750_SendACK(0); //回應ACK
- Delay5ms();
- //初始化BH1750,根據(jù)需要請參考pdf進行修改****
- void Init_BH1750()
- Single_Write_BH1750(0x01);
- void set_temp()
- DisplayOneChar(7,1,S_Temp/10+'0');
- DisplayOneChar(8,1,S_Temp%10+'0');
- void set_light()
- conversion(Light); //計算數(shù)據(jù)和顯示
- DisplayOneChar(4,1,wan); //顯示數(shù)據(jù)
- DisplayOneChar(5,1,qian);
- DisplayOneChar(6,1,bai);
- DisplayOneChar(7,1,shi);
- DisplayOneChar(8,1,ge);
- DisplayOneChar(10,1,'L'); ////顯示數(shù)單位
- DisplayOneChar(11,1,'x');
- void key() //按鍵程序 選擇菜單模式
- if(!K1)
- delay_1ms(80);
- if(!K1)
- while(!K1)
- yemian++;
- if(yemian>=4) { yemian=0; }
- void shezhi() //對里面的數(shù)值進行修改
- if(!K2) //按下按鍵
- delay_1ms(80);
- if(!K2)
- //==============================光線====================
- if(yemian==1)
- Nlight+=1; //按下一次,數(shù)值加1
- if(Nlight>=250) {Nlight=250;}
- write_eeprom(); //保存數(shù)據(jù)
- Light=Nlight*100;
- set_light();
- //==============================溫度===================
- if(yemian==2)
- Ntemp+=1; //按下一次,數(shù)值加1
- if( Ntemp>=250) { Ntemp=250;}
- S_Temp=Ntemp;
- set_temp();
- //=================================濕度====================
- if(yemian==3)
- Nhumi+=1; //按下一次,數(shù)值加1
- if(Nhumi>=99) {Nhumi=99;}
- S_Temp=Nhumi;
- set_temp();
- if(!K3) //按下按鍵
- delay_1ms(80);
- if(!K3)
- if(yemian==1)
- Nlight-=1; //沒按下一次,數(shù)值加1
- if(Nlight<=1) {Nlight=1;}
- Light=Nlight*100;
- set_light();
- //==============================溫度====================
- if(yemian==2)
- Ntemp-=1; //沒按下一次,數(shù)值加1
- if(Ntemp<=1) {Ntemp=1;}
- S_Temp=Ntemp;
- set_temp();
- //==================================濕度=====================
- if(yemian==3)
- Nhumi-=1; //按下一次,數(shù)值加1
- if(Nhumi<=1) {Nhumi=1;}
- S_Temp=Nhumi;
- set_temp();
- void working()
- Single_Write_BH1750(0x01); // power on
- Single_Write_BH1750(0x10); // H- resolution mode
- Multiple_Read_BH1750(); //連續(xù)讀出數(shù)據(jù),存儲在BUF中
- dis_data=BUF[0];
- dis_data=(dis_data<<8)+BUF[1];//合成數(shù)據(jù),即光照數(shù)據(jù)
- temp=(float)dis_data/1.2;
- conversion(temp); //計算數(shù)據(jù)和顯示
- DisplayOneChar(7,1,wan); //顯示數(shù)據(jù)
- DisplayOneChar(8,1,qian);
- DisplayOneChar(9,1,bai);
- DisplayOneChar(10,1,shi);
- DisplayOneChar(11,1,ge);
- void show_dht11() //溫度和濕度處理函數(shù)
- receive();
- DisplayOneChar(3,0,RH/10+'0');
- DisplayOneChar(4,0,RH%10+'0');
- DisplayOneChar(11,0,TH/10+'0');
- DisplayOneChar(12,0,TH%10+'0');
- void baojin()
- //control_temp
- if(temp<=Nlight*100 ) { control_light=0; }
- if(temp>Nlight*100 ) { control_light=1; }
- if(TH>=Ntemp || RH<=Nhumi ) { control_bell=0; }
- if(TH<Ntemp && RH>Nhumi ) { control_bell=1; }
- // if(RH>Nhumi ) { control_humi=1; }
- // if(RH<=Nhumi ) { control_humi=0; }
- /*************定時器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X01; //定時器0、定時器1工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- //主程序********
- void main()
- delay_nms(100); //延時100ms
- time_init(); //初始化定時器
- InitLcd(); //初始化LCD
- Init_BH1750(); //初始化BH1750
- init_eeprom(); //讀eeprom數(shù)據(jù)
- while(1) //循環(huán)
- KEY(); //按鍵處理
- //==================//進入工作狀態(tài)=====================
- if(yemian==0)
- if(flagone==1)
- flagone=0;
- if(flag==0)
- flag=1;
- DisplayOneChar(0,0,' ');
- DisplayOneChar(1,0,'H');
- DisplayOneChar(2,0,':');
- DisplayOneChar(3,0,' ');
- DisplayOneChar(4,0,' ');
- DisplayOneChar(5,0,'%');
- DisplayOneChar(8,0,' ');
- DisplayOneChar(9,0,'T');
- DisplayOneChar(10,0,':');
- DisplayOneChar(11,0,' ');
- DisplayOneChar(12,0,' ');
- DisplayOneChar(13,0,0xdf);
- DisplayOneChar(14,0,'C');
- DisplayOneChar(15,0,' ');
- DisplayOneChar(1,1,'L');
- DisplayOneChar(2,1,'i');
- DisplayOneChar(3,1,'g');
- DisplayOneChar(4,1,'h');
- DisplayOneChar(5,1,'t');
- DisplayOneChar(6,1,':');
- DisplayOneChar(13,1,'L');
- DisplayOneChar(14,1,'x');
- show_dht11();
- working();
- baojin();
- //==================//進入 Light_ 設置狀態(tài)=====================
- if(yemian==1) //進入設置模式
- if(flag==1)
- flag=2;
- control_bell = 1;
- control_light = 1;
復制代碼
程序.rar
(82.81 KB, 下載次數(shù): 21)
2018-5-29 19:18 上傳
點擊文件名下載附件
程序 下載積分: 黑幣 -5
原理圖.pdf
(50.1 KB, 下載次數(shù): 24)
2018-5-29 19:19 上傳
點擊文件名下載附件
原理圖 下載積分: 黑幣 -5
