查看: 1325|回復: 0
JAVA socket 實現(xiàn)同時讀寫
ID:341350 發(fā)表于 2018-5-30 14:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
package cn.com.socket;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStreamWriter;
import java.io.Reader;
import java.io.Writer;
import java.net.ServerSocket;
import java.net.Socket;
* 服務端同時讀和寫
* @author Administrator
public class ServerDemo1 {
public static void main(String[] args) throws IOException {
//為了簡單起見,所有的異常信息都往外拋
     int port = 8899;
     //定義一個ServerSocket監(jiān)聽在端口8899上
     ServerSocket server = new ServerSocket(port);
     //server嘗試接收其他Socket的連接請求,server的accept方法是阻塞式的
     Socket socket = server.accept();
     //跟客戶端建立好連接之后,我們就可以獲取socket的InputStream,并從中讀取客戶端發(fā)過來的信息了。
     Reader reader = new InputStreamReader(socket.getInputStream());
     char chars[] = new char[64];
     int len;
     StringBuilder sb = new StringBuilder();
     String temp;
     int index;
     while ((len=reader.read(chars)) != -1) {
        temp = new String(chars, 0, len);
        if ((index = temp.indexOf("eof")) != -1) {//遇到eof時就結(jié)束接收
           sb.append(temp.substring(0, index));
           break;
        sb.append(temp);
     System.out.println("我是服務器,客戶端說: " + sb);
     //讀完后寫一句
     Writer writer = new OutputStreamWriter(socket.getOutputStream());
     writer.write("Hello Client.");
     writer.flush();
     writer.close();
     reader.close();
     socket.close();
     server.close();
import java.net.UnknownHostException;
* 客戶端同時讀和寫
public class ClientDemo1 {
public static void main(String[] args) throws UnknownHostException, IOException {
  //為了簡單起見,所有的異常都直接往外拋
    String host = "localHost";  //要連接的服務端IP地址
    int port = 8899;   //要連接的服務端對應的監(jiān)聽端口
    //與服務端建立連接
    Socket client = new Socket(host, port);
     //建立連接后就可以往服務端寫數(shù)據(jù)了
    Writer writer = new OutputStreamWriter(client.getOutputStream());
     writer.write("Hello Server.");
     writer.write("eof");
     writer.flush();
     //寫完以后進行讀操作
    Reader reader = new InputStreamReader(client.getInputStream());
     int len;
     StringBuffer sb = new StringBuffer();
     String temp;
     int index;
           break;
        sb.append(new String(chars, 0, len));
     System.out.println("我是客戶端,服務器說: " + sb);
     writer.close();
     reader.close();
     client.close();
