#include<reg52.h>
#define Fosc 24000000/12000000 //12分頻后的頻率
#define DAdata P0//DA數(shù)據(jù)端口
sbit DA_S1= P2^0; // 給P2.0腳賦一個新的變量,方便使用
sbit DA_S2= P2^1; // 同上
sbit key= P3^2;
uchar wavecount; //波形波碼計數(shù)標(biāo)志
uchar THtemp,TLtemp;//傳遞頻率的中間變量
uint T_temp;
uchar judge=1; //用于方波函數(shù),作標(biāo)志
uchar waveform; //波形計數(shù)標(biāo)志,值不同代表不同的波形
uchar code freq_unit[4]={50,50,100,100}; //四種波形的頻率單位
uchar idata wavefreq[4]={1,1,1,1}; //數(shù)組單元,存放頻率單位計數(shù)
uchar code lcd_hang1[]={"Sine Wave " "Triangle Wave " "Square Wave ""sawtooth Wave ""Select Wave: " "press key S2 !"};
uchar idata lcd_hang2[16]={"f= Hz "};
uchar code waveTH[]={
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xfff,0xff,
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe,
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
uchar code waveTL[]={
0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波頻率調(diào)整中間值
0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,//三角波頻率調(diào)整中間值
0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c,
0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde};
uchar code triangle_tab[]={ //每隔數(shù)字8,采取一次
0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
uchar code sine_tab[256]={
//輸出電壓從0到最大值(正弦波1/4部分)
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
//輸出電壓從最大值到0(正弦波1/4部分)
//輸出電壓從最小值到0(正弦波1/4部分)
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
0x11,0x13,0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,
0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
void delay(uchar z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void triangle_out()//三角波輸出
DAdata=triangle_tab[wavecount++];
if(wavecount>64) wavecount=0;
DA_S1=0; //打開8位-輸入寄存器
DA_S1=1; //
void sine_out() //正弦波輸出
DAdata=sine_tab[wavecount++];
DA_S1=1; //
void square_out() //方波輸出
judge=~judge;
if(judge==1) DAdata=0xff;
else DAdata=0x00;
DA_S1=0; //
DA_S1=1; //關(guān)閉8位-輸入寄存器
void sawtooth_out() //鋸齒波輸出
uchar j;
for(j=0;j<25;j++)
DAdata=j;
delay(5) ;
/************1602液晶的相關(guān)函數(shù)*************/
#define lcd_ports P1
sbit rs=P2^2;
sbit rw=P2^3;
sbit lcden=P2^4;
void write_com(uchar com)
rs=0;//置零,表示寫指令
lcden=0;
lcd_ports=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;//置1,表示寫數(shù)據(jù)
lcden=0;
lcd_ports=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void disp_lcd(uchar addr,uchar *temp1)
uchar num;
write_com(addr);
delay(1); //延時一會兒
for(num=0;num<16;num++)
write_date(temp1[num]);//或者這樣寫write_date(*(temp1+num));
delay(1);
void init_lcd()
//uchar num;
lcden=0;
rw=0; //初始化為零,寫數(shù)據(jù)
write_com(0x38); //使液晶顯示點陣
write_com(0x0c); //初始設(shè)置
write_com(0x06);
write_com(0x01);
write_com(0x80); //指針指向第一格
disp_lcd(0x80,&lcd_hang1[4*16]); //在第一行顯示
disp_lcd(0xc0,&lcd_hang1[5*16]); //在第二行顯示
/********************1602液晶函數(shù)聲明結(jié)束*********************/
uchar i=0;
DA_S2=0; //使DAC寄存器處于直通狀態(tài)
DAdata=0;
DA_S1=1; //關(guān)閉8位輸入寄存器
init_lcd();
waveform=0;
TMOD=0x01; //設(shè)置定時器,16位工作方式
IT0=1; //設(shè)置外部中斷,下降沿觸發(fā)
ET0=1;
EX0=1;
EA=1; //開中斷
void timer0() interrupt 1
TH0=THtemp;
TL0=TLtemp;
if(waveform==0) sine_out();//正弦波輸出
else if(waveform==1) triangle_out();
else if(waveform==2) square_out();//方波
else if(waveform==3) sawtooth_out();
else if(waveform==4) waveform=0; //鋸齒波后重復(fù)正弦波
void key_int0() interrupt 0
uchar keytemp;
uint total_freq; //總頻率
EA=0; TR0=0;
delay(5); //延時
if(key==0) //判斷按鍵是否按下
keytemp=P3&0xf0; //獲取P3口高四位的值
switch(keytemp) //根據(jù)按鍵次數(shù)選擇波形
case 0xe0:
waveform++;
if(waveform>3) waveform=0;
break;
case 0xd0:
wavefreq[waveform]++; //頻率按單位增加
if(wavefreq[waveform]>10) wavefreq[waveform]=1;
break;
case 0xb0: //頻率按規(guī)定單位依次衰減
wavefreq[waveform]--;
if(wavefreq[waveform]<1) wavefreq[waveform]=10;
break;
case 0x70: //TTL輸出
DA_S2=1; //使DAC寄存器關(guān)閉
break;
THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)];
TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
total_freq= wavefreq[waveform] * freq_unit[waveform]; lcd_hang2[5]=total_freq%10+0x30;
total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //LCD顯示十位
total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //百位
total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //千位
disp_lcd(0x80,&lcd_hang1[waveform*16]); //在第一行顯示
disp_lcd(0xc0,lcd_hang2); //在第二行顯示
EA=1; TR0=1; //開啟總中斷與定時器
