51單片機(jī)交通燈仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2018-6-5 00:24 上傳
2018-6-5 00:24 上傳
- #include <reg51.h>
- #include <stdio.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar h;
- uint r=0;
- uint s;
- uchar code dis[]={0Xc0,0Xf9,0Xa4,0Xb0,0X99,
- 0X92,0X82,0Xf8,0X80,0X90,0Xff,};
- void delay(uint c)
- uint i,j;
- for(i=0;i<c;i++)
- for(j=0;j<100;j++);
- //interrupt 1
- void t0(void) interrupt 0 using 1
- delay(2);
- if(INT0==0)
- r++;
- if(r==2)
- r=0;
- r%=2;
- if(r==0)
- P0=0xeb;
- P1=0x00;
- P2=0xff;
- }while(1)
- if(INT0==0|INT1==0|T0==0)
- delay(2);
- break;
- //interrupt 2
- void t1(void) interrupt 2 using 1
- delay(2);
- if(INT1==0)
- r++;
- if(r==2)
- r=0;
- r%=2;
- if(r==0)
- P0=0xdd;
- P1=0x00;
- P2=0xff;
- }while(1)
- if(INT1==0|INT0==0|T0==0)
- delay(2);
- break;
- //interrupt 3
- void t2(void) interrupt 1 using 1
- TH0=0xff;
- TL0=0xff;
- delay(2);
- if(T0==0)
- P0=0xdb;
- P1=0x00;
- P2=0xff;
- }while(1)
- if(INT0==0|INT1==0)
- delay(2);
- break;
- void main(void)
- TMOD=0x06;
- TH0=0xff;
- TL0=0xff;
- TR0=1;
- EA=1;
- EX0=1;
- EX1=1;
- ET0=1;
- while(1)
- P0=0xeb;
- for(h=28;h>0;h--)
- for(s=248;s>0;s--)
- P1=0x00;
- P2=0xff;
- P1=0x01;
- P2=dis[h/10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x02;
- P2=dis[h%10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x04;
- P2=dis[(h+2)/10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x08;
- P2=dis[(h+2)%10];
- delay(1);
- delay(248);
- P0=0xf3;
- for(h=3;h>0;h--)
- delay(392);
- P0=0xf3;
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0xaa;
- P2=dis[(h-1)%10];
- delay(600);
- P0=0xfb;
- delay(248);
- P0=0xdd;
- for(h=38;h>0;h--)
- P1=0x00;
- P2=0xff;
- P1=0x01;
- P2=dis[(h+2)/10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x02;
- P2=dis[(h+2)%10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x04;
- P2=dis[h/10];
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0x08;
- P2=dis[h%10];
- delay(1);
- delay(248);
- P0=0xde;
- for(h=3;h>0;h--)
- delay(392);
- P0=0xde;
- delay(1);
- P1=0x00;
- P2=0xff;
- P1=0xaa;
- P2=dis[(h-1)%10];
- delay(600);
- P0=0xdf;
- delay(248);
C51交通燈.zip
(82.17 KB, 下載次數(shù): 105)
2018-6-4 09:19 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
