查看: 3717|回復: 1
緊急求助。。。大家來看看
ID:33246 發(fā)表于 2011-11-15 12:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大家看下這個程序,簡單的1602程序,不知道為什么小時位進不了位,只有分鐘,秒可以進位,大家?guī)蛶兔�。。我真的身心疲憊了
#include<reg52.h>
sbit wela=P2^7;
sbit dula=P2^6;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit lcdwr=P3^6;
uchar table[]=" 2011-11-14 MON ";
uchar table1[]="   23:59:00 ";
uchar count,miao,fen;
uint shi;
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void write_com(com)//寫指令函數(shù)
 lcdrs=0;
 lcden=0;
 P0=com;
 delay(5);
 lcden=1;
 delay(5);
 lcden=0;
void write_dat(dat)//寫數(shù)據(jù)函數(shù)
 lcdrs=1;
 lcden=0;
 P0=dat;
 delay(5);
 lcden=1;
 delay(5);
 lcden=0;
void init()
{uchar num;
 wela=0;
 dula=0;
 lcden=0;
 lcdwr=0;
 write_com(0x38);
 delay(1);
 write_com(0x0c);
 write_com(0x06);
 //write_com(0x01);
 write_com(0x80);
 for(num=0;num<16;num++)
  write_dat(table[num]);
  delay(20);
write_com(0x80+0x40);
for(num=0;num<12;num++)
  write_dat(table1[num]);
  delay(20);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
miao=54;
//shi=23;
void write_sfm(uchar add, uchar date)
 uchar shi,ge;
 shi=date/10;
 ge=date%10;
 write_com(0x80+0x40+add);
 write_dat(0x30+shi);
 write_dat(0x30+ge);
 init();
 if(count==20)
 { count=0;
   miao++;
   if(miao==60)
   miao=0;
   fen++;
    if(fen==60)
   fen=0;
   shi++;
    if(shi==24)
      shi=0;
write_sfm(3,shi);
write_sfm(6,fen);
 write_sfm(9,miao);
void timer0() interrupt 1
{ TH0=(65536-50000)/256;
  count++;}
ID:24977 發(fā)表于 2011-11-19 09:28 | 只看該作者
lz有沒有進行proteus仿真?是程序的問題還是硬件電路的問題?
