查看: 1894|回復(fù): 1
Mesh v1.0規(guī)范 英文版下載
ID:347029 發(fā)表于 2018-6-7 16:49 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
Mesh v1.0規(guī)范 官方搬運(yùn)
1    Introduction
The Bluetooth Mesh Profile specification defines fundamental requirements to enable an interoperable mesh networking solution for Bluetooth low energy wireless technology.
1.1    Conformance
If conformance to this specification is claimed, all capabilities indicated as mandatory for this specification shall be supported in the specified manner (process-mandatory). This also applies for all optional and conditional capabilities for which support is indicated.
1.2    Bluetooth specification release compatibility
This specification shall be used with:
•    Core Specification Addendum 6 [3] combined with an allowed Bluetooth Core Specification (see [3] Volume 1, Part D, Section 1.2, Table 1.3), OR
•    Any version of the Bluetooth Core Specification later than v5.0.
The Generic Attribute Profile (GATT) is required if the GATT provisioning bearer defined in Section 5.2.2 is supported or if the GATT bearer defined in Section 3.3.2 is supported.
1.3    Language
1.3.1    Language conventions
The Bluetooth SIG has established the following conventions for use of the words shall, must, will, should, may, can, is, and note in the development of specifications:
全部資料51hei下載地址:
Mesh_v1.0 (1).docx (4.52 MB, 下載次數(shù): 19)
收藏收藏 分享淘帖 頂1 踩
ID:548072 發(fā)表于 2019-5-27 08:44 | 只看該作者
好資料
