基于stm32f051的無刷電機無傳感器的控制。成本低,st原代碼
電路原理圖如下:
2018-6-8 02:25 上傳
2018-6-8 02:25 上傳
stm32單片機源程序如下:
- #include "stm32f0xx.h"
- #include "definitions.h"
- #include "motorcontrolsettings.h"
- unsigned char zcfound;
- unsigned char phase;
- unsigned char autostep;
- unsigned char risingdelay;
- unsigned char fallingdelay;
- unsigned char risingedge;
- unsigned char startstate;
- unsigned char run;
- unsigned char ontimesample;
- unsigned short commcounter;
- unsigned short step;
- unsigned short bemfsample;
- unsigned short dcbussample;
- unsigned short demagcounter;
- unsigned short zccounter;
- unsigned short commthreshold;
- unsigned short demagthreshold;
- unsigned short runningdc;
- unsigned short potvalue;
- unsigned short zcthreshold;
- unsigned short dutycyclehold;
- unsigned long holdcounter;
- unsigned long alignmentcounter;
- unsigned long rampspeed;
- unsigned long bemfchannel;
- void commutate(void);
- void commutate2(void);
- void motorstartinit(void);
- void delay( unsigned long time);
- void flashled(unsigned char flashes);
- void selftest(void);
- unsigned short readadc( unsigned char chnl);
- int main(void)
- // clock chain setup
- RCC->CFGR = (4<<18); // set PLL X6 for 24MHZ
- RCC->CR = 0x00000083 + (1<<24); //turn PLL on
- RCC->CFGR = (4<<18) + 2; // select PLL as clock
- RCC->AHBENR = b19+b18+b17; // enable GPIOA, B, C input clock
- RCC->APB2ENR = b11+b9+b0; // enable tim1 and ADC input clocks
- RCC->APB1ENR = b29; // enable DAC input clock
- delay(5000000) ; //let power supply settle
- selftest();
- // port A setup
- //GPIOA->MODER = 0x2A2AFFF0; // a5,a4,3,2,6,7 anlg, a8,9,10,12 AF
- GPIOA->MODER = 0x2A6AFFF0; // 11 pp, a5,a4,3,2,6,7 anlg, a8,9,10,12 AF
- GPIOA->AFRH = 0x00020222; // pa8,9,10,12 AF2 for timer
- // port B setup
- // b22 PB11 as output
- GPIOB->MODER = 0xA800000F+b22; // b1,0 anlg, b15,14,13 AF
- GPIOB->AFRH = 0x22220000; // b15,14,13,12 AF2 for timer
- // port C setup
- GPIOC->ODR = 0;
- // ADC setup
- ADC1->CR= b31 ; // start ADC calibration
- while( ADC1->CR & b31); // wait for calibration to complete
- ADC1->CR = 1; // enable ADC
- ADC1->CFGR1 = b16; // enable discontinuous mode
- ADC1->SMPR = 1;
- // comparator setup
- // (b25+b24) send comp2 output to tim1 OCref clear
- // b27 invert comp2 output
- // b16 enable comp2
- // b22+b20 select PA5 as inverting input for comp2
- // b0 enable comp1
- // (b6+b5) select PA0 comp1 inverting input
- // b8 send comp1 output to tim1 break
- // b11 to invert comp1 output
- COMP->CSR = 0;
- #ifdef currentlimitenable
- COMP->CSR = COMP->CSR + b27+b16+b22+b20+b25+b24; // cy-by-cy active
- #endif
- #ifdef overcurrentenable
- COMP->CSR = COMP->CSR + b0+b6+b5+b11+b8; // brk active
- #endif
- // tim1 setup
- TIM1->SMCR = b15+b4+b5+b6; // make ETR input active low
- TIM1->CR2= 0;
- TIM1->CCR1= 200;
- TIM1->CCR2= 200;
- TIM1->CCR3= 200;
- TIM1->CCR4= 1100;
- TIM1->ARR=1200;
- TIM1->CR1=0x0001;
- // note: b15 b7 and b7 are to enable ETR based current limit
- TIM1->CCMR1= 0x6868 +b15 + b7;
- TIM1->CCMR2= 0x6868 +b7;
- // b4 for cc4 and b7 for brk interrupt
- //TIM1->DIER = b4+b7; // enable cc4 interrupt
- TIM1->DIER = b4+b6;
- // DAC setup
- DAC->CR = 1; // enable DAC
- // set up interrupts
- NVIC_EnableIRQ(14);
- __enable_irq();
- // initialization
- run=0;
- motorstartinit();
- clearmark;
- while(1)
- { // backgroung loop
- if( (TIM1->BDTR & b15)==0) // overcurrent fault condition
- run=0;
- while(1)
- ledon;
- delay(1000000);
- ledoff;
- delay(1000000);
- if( (4095-potvalue)<100)
- TIM1->BDTR= b15+b11+b10+b12+b13; // set MOE
- break;
- } //end of LED flash loop
- } // end of if overcurrent
- //TIM1->BDTR= b15+b11+b10+b12+b13; // set MOE
- if( (4095-potvalue)>200) run=255;
- if( (4095-potvalue)<100) run=0;
- if(run) ledon;
- if(run==0) ledoff;
- runningdc = ((4095-potvalue)*1200)>>12;
- if(runningdc>1195) runningdc=1300;
- if(dutycyclehold && (runningdc>600)) runningdc=600;
- #ifdef ontimesampleenable
- if(runningdc>800) ontimesample=255;
- else ontimesample=0;
- #endif
- //if(COMP->CSR & b30) // comp2
- if(COMP->CSR & b14) // comp1
- setmark;
- else
- //clearmark;
- //DAC->DHR12R1 = potvalue; // put out for diagnostic purposes
- } // end of backgroung loop
- } // end of main
- switch(phase)
- case 0: // phase AB
- TIM1->CCER = b3+b0 +b7+b4 +b8; //
- TIM1->CCMR1= 0x4868 +b15 + b7; // force B active low
- break;
- case 1: // phase AC
- TIM1->CCER = b3+b0 +b4 +b8+b11; //
- TIM1->CCMR2= 0x6848 +b7; // force C active low
- break;
- case 2: // phase BC
- TIM1->CCER = b4+b7 +b8+b11 +b0;
- break;
- case 3: // phase BA
- TIM1->CCER = b4+b7 +b3+b0 +b8;
- TIM1->CCMR1= 0x6848 +b15 + b7; // force A active low
- break;
- case 4: // phase CA
- TIM1->CCER = b8+b11 +b3+b0 +b4;
- break;
- case 5: // phase CB
- TIM1->CCER = b8+b11 +b4+b7 +b0;
- break;
- } // end of phase switch statement
- } // end of commutate function
- //TIM1->CCER=b10+b8+b6+b4+b2+b0; // enable all 6
- switch(phase)
- // enable all 6 except AN
- // invert AN
- TIM1->CCER=b10+b8+b6+b4+b0 +b3;
- TIM1->CCMR1=0x4868+b15+b7; // B low, A PWM
- TIM1->CCMR2= 0x6858 +b7; // force C ref high (phc en low)
- break;
- // invert AN
- TIM1->CCMR1=0x5868+b15+b7; // force B high and A PWM
- TIM1->CCMR2= 0x6848 +b7; // force C ref low
- break;
- // enable all 6 except BN
- // invert BN
- TIM1->CCER=b10+b8+b4+b2+b0 +b7;
- TIM1->CCMR1=0x6858+b15+b7; // force B PWM and A high
- break;
- // invert BN
- TIM1->CCMR1=0x6848+b15+b7; // force B PWM and A ref low
- break;
- // enable all 6 except CN
- // invert CN
- TIM1->CCER=b8+b6+b4+b2+b0 +b11; // enable all 6 except CN
- TIM1->CCMR1=0x5848+b15+b7; // force B high and A ref low
- TIM1->CCMR2= 0x6868 +b7; // force C PWM
- break;
- // invert CN
- TIM1->CCMR1=0x4858+b15+b7; // force B low and A high
- break;
- } // end of commutate2 function
- // pwmisr runs just at the end of each PWM cycle
- void pwmisr(void)
- unsigned long long0;
- ADC1->CHSELR = bemfchannel; // set ADC MUX to proper bemf channel
- ADC1->CR = b2; // start adc conversion
- // housekeeping increment of some timers while adc is converting
- zccounter++; // housekeeping increment of some timers while adc is converting
- alignmentcounter++;
- holdcounter++;
- while((ADC1->CR & b2)==b2) ; // wait for conversion to complete
- bemfsample= ADC1->DR;
- //DAC->DHR12R1 = bemfsample; // put out for diagnostic purposes
- // autostep is true during ramping up
- if(autostep)
- commcounter++;
- if(commcounter>step)
- commcounter=0;
- phase++;
- if(phase>5) phase=0;
- commutate2();
- } // end of if(autostep)
- if(run==0) startstate=0;
- switch(startstate)
- case 0:
- TIM1->CCER = 0;
- if(run)
- motorstartinit();
- startstate=5;
- break;
- case 5: // setup alignment
- TIM1->CCR1= alignmentdc;
- TIM1->CCR2= alignmentdc;
- TIM1->CCR3= alignmentdc;
- phase=0;
- commutate2();
- alignmentcounter=0;
- startstate=10;
- break;
- case 10: // timing out alignment
- if(alignmentcounter>alignmenttime)
- rampspeed=1;
- commcounter=0;
- autostep=255;
- TIM1->CCR1= rampupdc;
- TIM1->CCR2= rampupdc;
- TIM1->CCR3= rampupdc;
- startstate=20;
- break;
- case 20: // ramping up
- rampspeed = rampspeed+rampuprate; // accelerate
- long0 = 4000000000;
- long0 = long0/rampspeed; // step time = constant/speed
- if(long0>30000) long0=30000;
- step=long0;
- if(step<=minstep)
- holdcounter=0;
- startstate=100;
- break;
- case 100: // wait for hold time, holding at speed to allow sync
- if(holdcounter>holdtime) startstate=110;
- break;
- case 110: // wait to get into phase 5
- if(phase==5) startstate=120;
- break;
- case 120: // wait for leading edge of phase 0 (commutation)
- if(phase==0)
- demagcounter=0;
- demagthreshold = (step*demagallowance)>>8;
- startstate=130;
- break;
- case 130: // wait out demag time (for current in phase to go to 0)
- demagcounter++;
- if(demagcounter>demagthreshold)
- startstate=140;
- break;
- case 140: // looking for zero crossing of bemf
- if( zcfound && (zccounter>maxstep) )
- startstate=0;
- break;
- if(risingedge)
- if((bemfsample>zcthreshold)||(zccounter>maxstep) )
- if(zcfound) step = zccounter;
- commthreshold = (step*risingdelay)>>8;
- zccounter=0;
- commcounter=0;
- startstate=150;
- risingedge=0;
- zcfound=255;
- autostep=0;
- else
- if((bemfsample<zcthreshold)||(zccounter>maxstep) )
- commthreshold = (step*fallingdelay)>>8;
- zccounter=0;
- commcounter=0;
- startstate=150;
- risingedge = 255;
- zcfound=255;
- autostep=0;
- break;
- case 150: // wait out commutation delay (nominal 1/2 step time)
- TIM1->CCR1= runningdc;
- TIM1->CCR2= runningdc;
- TIM1->CCR3= runningdc;
- commcounter++;
- if(commcounter>commthreshold)
- phase++; // commutate
- commutate2();
- demagcounter=0;
- startstate=130; // go back to wait out demag
- if(dutycyclehold) dutycyclehold--;
- break;
- } // end of startstate state machine
- ADC1->CHSELR = b2; // set ADC MUX to pot channel (ain2)
- // switch statement determines next bemf ADC input channel
- switch(phase)
- case 0: // ab
- bemfchannel= 1<<8 ; // read phase c
- break;
- case 1: // ac
- bemfchannel= 1<<7 ; // read phase b
- break;
- case 2: // bc
- bemfchannel= 1<<6 ; // read phase a
- break;
- case 3: // ba
- break;
- case 4: // ca
- break;
- case 5: // cb
- break;
- if(ontimesample)
- GPIOC->MODER = 0x54000000; // C15,14,13 PP to turn on attenuator
- TIM1->CCR4 = 100; // move isr to halfway thry on time
- //zcthreshold = 620; // for 12V bus
- long0 = dcbussample;
- long0 = long0 * 599;
- long0 = long0>>10;
- zcthreshold = long0;
- else
- GPIOC->MODER = 0; // turn attenuator off
- TIM1->CCR4 = 1100;
- zcthreshold = 200; // threshold to about zero
- potvalue= ADC1->DR;
- ADC1->CHSELR = b9; // set ADC MUX to dc bus channel (ain9)
- dcbussample = ADC1->DR;
- DAC->DHR12R1 = dcbussample; // put out for diagnostic purposes
- // clear interrupt
- TIM1->SR &= ~0x01F;
- NVIC_ClearPendingIRQ(14);
- TIM1->CCER = 0;
- // b12 to enable brk input
- // b13 for break polarity
- // (b15+b11); // set MOE
- // ADC count used as zero crossing threshold
- // may need to be set higher/lower for higher/lower bemf motors
- // setting too low may cause noise sensitivity issues
- zcthreshold = 200 ;
- ontimesample=0;
- phase = 0;
- holdcounter=0;
- startstate=0;
- commcounter=0;
- step=3670; // unit is 50uS pwm periods
- autostep = 0;
- risingedge = 0;
- zcfound=0;
- rampspeed=1;
- commthreshold=0;
- // risingdelay and fallingdelay control the time delay waited
- // between zero crossing detection and commutation. The nominal
- // value is 128 which means 128/256 or 1/2 of a step time, which
- // is the phase shift between line to neutral zero crossing
- // (what is actually detected) and line to line zero cross
- // (nominal correct commutation time)
- // adjustment will advance or delay commutation (phase advance)
- risingdelay=128;
- fallingdelay=128;
- // sets open loop motor voltage (speed) 1200 for 100% duty cycle
- runningdc = 600;
- dutycyclehold=100;
- } // end of motor start init function
- void delay( unsigned long time) // 1000 is 200 usec
- while(time>0) time--;
- unsigned short word0;
- // port B setup
- GPIOB->ODR = 0;
- 15 14 13 12 11 10 09 08 07 06 05 04 03 02 01 00
- pp pp pp pp in pp pp pp pp pp pp pp pp pp an an
- 01 01 01 01 00 01 01 01 01 01 01 01 01 01 11 11
- 5 5 1 5 5 5 5 F
- GPIOB->MODER = 0x5515555F;
- //test for jumper from P6-2(pb10) to P6-1(pb11)and return from selftest if not
- GPIOB->ODR &= ~b10;
- delay(1000);
- if((GPIOB->IDR & b11) != 0) return;
- GPIOB->ODR |= b10;
- delay(1000);
- if((GPIOB->IDR & b11) != b11) return;
- delay(1000);
- delay(1000);
- // program is in test mode
- // port A setup
- GPIOA->ODR = 0;
- in af af in pp pp pp pp an an an an an an an an
- 00 10 10 00 01 01 01 01 11 11 11 11 11 11 11 11
- 2 8 5 5 F F F F
- GPIOA->MODER = 0x2855FFFF;
- COMP->CSR = 0;
- #endif
- #endif
- // ADC setup
- ADC1->SMPR = 1;
- // routine to manually test pot and LED
- while(1)
- potvalue = 4095 - readadc(2);
- switch((potvalue>>9))
- case 0:
- ledoff;
- break;
- case 1:
- ledon;
- break;
- case 2:
- ledoff;
- break;
- case 3:
- ledon;
- break;
- case 4:
- ledoff;
- break;
- case 5:
- ledon;
- break;
- case 6:
- ledoff;
- break;
- case 7:
- ledon;
- break;
- case 8:
- break;
- } // end of pot test case statement
- //test for jumper from P6-2(pb10) to P6-1(pb11)and break out of loop if not
- delay(1000);
- if((GPIOB->IDR & b11) != 0) break;
- delay(1000);
- if((GPIOB->IDR & b11) != b11) break;
- delay(1000);
- delay(1000);
- } // end of pot test endless loop
- ledoff;
- delay(19999999);
- // now test DC bus sensing
- word0 = readadc(9); // read bemfa
- if(word0<1430) flashled(11);
- if(word0>1748) flashled(12);
- // now test bridge outputs and bemf sensing
- phaseadisable;
- phasebdisable;
- phasecdisable;
- phaseahigh;
- phaseblow;
- phaseclow;
- // enable A and set high. disable B and C
- phaseaenable;
- delay(500); // wait 100 usec for settling
- word0 = readadc(6); // read bemfa
- if(word0<2048) flashled(13); // fault if pha not high
- word0 = readadc(7); // read bemfb
- if(word0<2048) flashled(14); // fault if phb not high
- word0 = readadc(8); // read bemfc
- if(word0<2048) flashled(15); // fault if phc not high
- // now enable B low
- phasebenable;
- phasebdisable;
- if(word0>2048) flashled(21); // fault if phb not low
- // now enable C low
- phasecenable;
- phasecdisable;
- if(word0>2048) flashled(22); // fault if phc not low
- phaseadisable;
- phasebenable;
- phasebhigh;
- // B is high, A and C disabled
- if(word0<2048) flashled(23); // fault if pha not high
- // disable verified for all three phases
- phaseadisable;
- phasebdisable;
- phasecdisable;
- // activate phase AB
- phaseahigh;
- phaseblow;
- phaseaenable;
- phasebenable;
- if(word0<2048) flashled(24); // fault if pha not high
- if(word0>2048) flashled(24); // fault if phb not low
- // activate phase BA
- phasebhigh;
- phasealow;
- if(word0>2048) flashled(25); // fault if pha not low
- if(word0<2048) flashled(25); // fault if phb not high
- // activate phase AC
- phasebdisable;
- phaseahigh;
- phaseclow;
- phasecenable;
- if(word0<2048) flashled(31); // fault if pha not high
- if(word0>2048) flashled(31); // fault if phc not low
- // activate phase CA
- phasechigh;
- phasealow;
- if(word0>2048) flashled(32); // fault if pha not low
- if(word0<2048) flashled(32); // fault if phc not high
- // activate phase BC
- phaseadisable;
- phasebenable;
- phasebhigh;
- phaseclow;
- if(word0<2048) flashled(33); // fault if phb not high
- if(word0>2048) flashled(33); // fault if phc not low
- // activate phase CB
- phasechigh;
- phaseblow;
- if(word0>2048) flashled(34); // fault if phb not low
- if(word0<2048) flashled(34); // fault if phc not high
- // all 6 phases have been tested (voltage sensing)
- phaseadisable;
- phasebdisable;
- phasecdisable;
- // activate phase AB (should not trip)
- phaseahigh;
- phaseblow;
- phaseaenable;
- phasebenable;
- if(COMP->CSR & b30) flashled(35); // comp2 at 2.24A threshold
- // now turn on C lower (should trip)
- phaseclow;
- phasecenable;
- if((COMP->CSR & b30)==0) flashled(41); // comp2 at 2.24A threshold
- // overcurrent (higher threshold) should be low
- if((COMP->CSR & b14)) flashled(42); // comp1 high threshold
- phaseadisable;
- phasebdisable;
- phasecdisable;
- ledon;
- while(1)
- word0=0;
- // break out of loop when jumper restored
- delay(1000);
- if((GPIOB->IDR & b11) != 0) word0=0;
- else word0++;
- delay(1000);
- if((GPIOB->IDR & b11) != b11) word0=0 ;
- else word0++;
- delay(1000);
- if((GPIOB->IDR & b11) != 0) word0=0 ;
復制代碼
en.DM00072008.pdf
2018-6-7 17:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
946.49 KB, 下載次數(shù): 37, 下載積分: 黑幣 -5
en.DM00073153.pdf
2018-6-7 17:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
159.14 KB, 下載次數(shù): 40, 下載積分: 黑幣 -5
說明材料
en.steval-ihm043v1_bom.pdf
2018-6-7 17:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
10.47 KB, 下載次數(shù): 37, 下載積分: 黑幣 -5
器件清單
en.steval-ihm043v1_fw.zip
2018-6-7 17:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
448.24 KB, 下載次數(shù): 66, 下載積分: 黑幣 -5
代碼
en.steval-ihm043v1_schematic.pdf
2018-6-7 17:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
83.58 KB, 下載次數(shù): 41, 下載積分: 黑幣 -5
原理圖
