查看: 5857|回復(fù): 2
基于51單片機(jī)+DAC0832的簡易波形發(fā)生器仿真與程序源碼
ID:350855 發(fā)表于 2018-6-13 21:18 | 顯示全部樓層 |閱讀模式
通過AT89C51和DAC0832實(shí)現(xiàn)的波形發(fā)生器 函源文件和仿真圖
  1. #include<reg52.h>
  2. #define  uchar unsigned char
  3. #define  uint  unsigned int
  4. //#define  Fosc  24000000/12000000  //12分頻后的頻率
  5. #define DAdata  P0        //DA數(shù)據(jù)端口
  6. sbit DA_S1= P2^0;   // 控制DAC0832的8位輸入寄存器,僅當(dāng)都為0時(shí),可以輸出數(shù)據(jù)(處于直通狀態(tài)),否則,輸出將被鎖存
  7. sbit DA_S2= P2^1;   // 控制DAC0832的8位DAC寄存器,僅當(dāng)都為0時(shí),可以輸出數(shù)據(jù)(處于直通狀態(tài)),否則,輸出將被鎖存
  8. sbit key=   P3^2;
  9. uchar wavecount;    //'抽點(diǎn)'計(jì)數(shù)
  10. uchar THtemp,TLtemp;//傳遞頻率的中間變量
  11. //uint T_temp;
  12. uchar judge=1;      //在方波輸出函數(shù)中用于簡單判別作用
  13. uchar waveform;            //當(dāng)其為0、1、2時(shí),分別代表三種波
  14. uchar code freq_unit[3]={10,50,200}; //三種波的頻率單位
  15. uchar idata wavefreq[3]={1,1,1};           //給每種波定義一個(gè)數(shù)組單元,用于存放單位頻率的個(gè)數(shù)
  16. uchar code  lcd_hang1[]={"Sine Wave       " "Triangle Wave   " "Square Wave     " "Select Wave:    " "press No.1 key! "};
  17. uchar idata lcd_hang2[16]={"f=    Hz        "};
  18. /*uchar code wave_freq_adjust[]={       //頻率調(diào)整中間值
  19.     0xff,0xb8,0x76,0x56,0x43,0x37,0x2e,0x26,0x20,0x1c,  //正弦波頻率調(diào)整中間值
  20.         0xff,0x8e,0x5a,0x41,0x32,0x28,0x20,0x1b,0x17,0x0e,        //三角波頻率調(diào)整中間值
  21.         0xff,0x8e,0x5a,0x41,0x32,0x28,0x20,0x1b,0x17,0x0e};
  22. uint code wave_freq_adjust[]={       //頻率調(diào)整中間值
  23.     380,184,118,86,67,55,46,28,38,32,
  24.         295,142, 90,65,50,40,32,27,23,14,
  25.         295,142, 90,65,50,40,32,27,23,14}; */
  26. /*uchar code waveTH[]={
  27.     0xfc,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  28.         0xfc,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  29.         0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
  30. uchar code waveTL[]={
  31.     0xf2,0x78,0xfb,0x3c,0x63,0x7d,0x8f,0x9d,0xa8,0xb1,
  32.         0x17,0x0b,0xb2,0x05,0x37,0x58,0x70,0x82,0x90,0x9b,
  33.     0x4d,0xa7,0xc4,0xd3,0xdc,0xe2,0xe6,0xea,0xec,0xee};*/
  34. /***********這兩組數(shù)組很重要,需要根據(jù)波形來調(diào)試,選擇合適的值,使輸出波形達(dá)到頻率要求************/
  35. uchar code waveTH[]={
  36.     0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  37.         0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  38.         0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
  39. uchar code waveTL[]={
  40.     0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波頻率調(diào)整中間值
  41.         0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,        //三角波頻率調(diào)整中間值
  42.         0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c};
  43. /*************************************************************************************************/
  44. uchar code triangle_tab[]={         //每隔數(shù)字8,采取一次
  45.         0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
  46.         0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
  47.         0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
  48.         0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
  49. uchar code sine_tab[256]={
  50.         //輸出電壓從0到最大值(正弦波1/4部分)
  51.         0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
  52.         0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
  53.         0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
  54.         //輸出電壓從最大值到0(正弦波1/4部分)
  55.         0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
  56.         0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
  57.         0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
  58.         //輸出電壓從0到最小值(正弦波1/4部分)
  59.         0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
  60.         0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
  61.         0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  62.         //輸出電壓從最小值到0(正弦波1/4部分)
  63.         0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
  64.         0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
  65.         0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
  66. void delay(uchar z)
  67. {
  68.     uint x,y;
  69.         for(x=z;x>0;x--)
  70.         for(y=110;y>0;y--);
  71. }
  72. void triangle_out()        //三角波輸出
  73. {
  74.     DAdata=triangle_tab[wavecount++];
  75.         if(wavecount>64) wavecount=0;
  76.         DA_S1=0;  //打開8位輸入寄存器
  77.         DA_S1=1;  //關(guān)閉8位輸入寄存器
  78. }
  79. void sine_out()         //正弦波輸出
  80. {
  81.     DAdata=sine_tab[wavecount++];
  82.         DA_S1=0;  //打開8位輸入寄存器
  83.         DA_S1=1;  //關(guān)閉8位輸入寄存器
  84. }
  85. void square_out()  //方波輸出
  86. {
  87.     judge=~judge;
  88.     if(judge==1) DAdata=0xff;
  89.         else  DAdata=0x00;
  90.         DA_S1=0;  //打開8位輸入寄存器
  91.         DA_S1=1;  //關(guān)閉8位輸入寄存器
  92. }
  93. /************1602液晶的相關(guān)函數(shù)*************/
  94. #define lcd_ports P1
  95. sbit rs=P2^2;
  96. sbit rw=P2^3;
  97. sbit lcden=P2^4;
  98. void write_com(uchar com)
  99. {
  100.         rs=0;        //置零,表示寫指令
  101.         lcden=0;
  102.         lcd_ports=com;
  103.         delay(5);
  104.         lcden=1;
  105.         delay(5);
  106.         lcden=0;
  107. }
  108. void write_date(uchar date)
  109. {
  110.         rs=1;        //置1,表示寫數(shù)據(jù)(在指令所指的地方寫數(shù)據(jù))
  111.         lcden=0;
  112.         lcd_ports=date;
  113.         delay(5);
  114.         lcden=1;
  115.         delay(5);
  116.         lcden=0;
  117. }
  118. void disp_lcd(uchar addr,uchar *temp1)
  119. {
  120.         uchar num;
  121.         write_com(addr);
  122.         delay(1);   //延時(shí)一會(huì)兒???
  123.         for(num=0;num<16;num++)
  124.         {
  125.                 write_date(temp1[num]);//或者這樣寫write_date(*(temp1+num));
  126.                 delay(1);
  127.         }
  128. }
  129. void init_lcd()
  130. {
  131.         //uchar num;
  132.         lcden=0;  //可有可無???
  133.         rw=0;  //初始化一定要設(shè)置為零,表示寫數(shù)據(jù)
  134.         write_com(0x38);  //使液晶顯示點(diǎn)陣,為下面做準(zhǔn)備
  135.         write_com(0x0c);  //初始設(shè)置
  136.         write_com(0x06);  //初始設(shè)置
  137.         write_com(0x01);  //清零
  138.         write_com(0x80);  //使指針指向第一行第一格
  139.     disp_lcd(0x80,&lcd_hang1[3*16]);  //在第一行顯示
  140.     disp_lcd(0xc0,&lcd_hang1[4*16]);  //在第二行顯示
  141.         /*for(num=0;num<16;num++)
  142.                 {
  143.                         write_date(table[num]);
  144.                         delay(5);
  145.                 }
  146.         write_com(0x80+0x40);   //給指針重新賦值,使之指向第二行第一格
  147.         for(num=0;num<16;num++)
  148.                 {
  149.                         write_date(table1[num]);
  150.                         delay(5);
  151.                 } */
  152.         /*TMOD=0x01;          //選用定時(shí)方式1
  153.         TH0=(65536-50000)/256;  //賦初值
  154.         TL0=(65536-50000)%256;        //
  155.         EA=1;        //開總中斷
  156.         ET0=1;          //開定時(shí)器中斷
  157.         TR0=1;          //啟動(dòng)定時(shí)器*/
  158. }
  159. /********************1602液晶函數(shù)聲明結(jié)束*********************/
  160. void main()
  161. {
  162.     uchar i=0;
  163.         DA_S2=0;    //使DAC寄存器處于直通狀態(tài)
  164.         DAdata=0;
  165.         DA_S1=1;    //關(guān)閉8位輸入寄存器
  166.         init_lcd();
  167.     waveform=0;
  168.         TMOD=0x01;  //設(shè)置定時(shí)器0為16位工作方式
  169.         IT0=1;      //設(shè)置外部中斷0為下降沿觸發(fā)
  170.         ET0=1;      //開定時(shí)器中斷
  171.         EX0=1;
  172.         EA=1;
  173.         while(1)
  174.         {
  175.                 //DAout(0xff);           //可輸出TTL波形
  176.                 //DAout(0x80);
  177.                 //T_temp=32;
  178.         }
  179. }
  180.
  181. void timer0() interrupt 1
  182. {
  183.         TH0=THtemp;
  184.         TL0=TLtemp;
  185.         if(waveform==0)      sine_out();
  186.         else if(waveform==1) triangle_out();
  187.         else if(waveform==2) square_out();
  188. }
  189. void key_int0() interrupt 0
  190. {
  191.     uchar keytemp;
  192.         uint total_freq; //總頻率
  193.         EA=0; TR0=0;     //關(guān)總中斷與定時(shí)器
  194.         delay(5);       //延時(shí)夠嗎???
  195.         if(key==0)       //確實(shí)有按鍵按下而引發(fā)中斷
  196.         {
  197.                 keytemp=P3&0xf0; //獲取P3口高四位的值
  198.                 switch(keytemp)
  199.                 {
  200.                     case 0xe0:        //選擇波形
  201.                              waveform++;
  202.                                  if(waveform>2) waveform=0;
  203.                                  break;
  204.                     case 0xd0:  //頻率按規(guī)定單位依次增加
  205.                              wavefreq[waveform]++;
  206.                                  if(wavefreq[waveform]>10) wavefreq[waveform]=1; // /*這邊要用“>10”,因?yàn)樗取?11”可靠
  207.                                  break;        //   性更高,使加數(shù)有個(gè)上限,不會(huì)一直加下去*/
  208.                     case 0xb0:  //頻率按規(guī)定單位依次衰減
  209.                              wavefreq[waveform]--;
  210.                                  if(wavefreq[waveform]<1) wavefreq[waveform]=10; //這邊要用“<1”,因?yàn)樗取?0”可靠性更高
  211.                                  break;
  212.                     case 0x70:    //TTL輸出
  213.                              DA_S2=1; //使DAC寄存器關(guān)閉
  214.                                  break;
  215.                 }
  216.             THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括號(hào)中選取第幾個(gè)數(shù)后,并把該值賦給T_temp
  217.                 TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
  218.             total_freq= wavefreq[waveform] * freq_unit[waveform]; //求輸出頻率(個(gè)數(shù)*單位)
  219.             lcd_hang2[5]=total_freq%10+0x30;                 //在液晶中顯示個(gè)位,(0x30 在液晶顯示中表示數(shù)字0)
  220.             total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中顯示時(shí)十位
  221.             total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中顯示時(shí)百位
  222.             total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中顯示時(shí)千位
  223.             disp_lcd(0x80,&lcd_hang1[waveform*16]);  //在第一行顯示
  224.             disp_lcd(0xc0,lcd_hang2);  //在第二行顯示
  225.         }
  226.         wavecount=0; //'抽點(diǎn)'計(jì)數(shù)清零
  227.         while(!key);
  228.         EA=1; TR0=1;     //開啟總中斷與定時(shí)器
  229. }
波形發(fā)生器.rar (65.23 KB, 下載次數(shù): 119)
ID:351733 發(fā)表于 2018-6-14 11:44 | 顯示全部樓層
這個(gè)沒用啊
ID:351976 發(fā)表于 2018-7-3 17:43 | 顯示全部樓層
除了方波,都沒用啊
ID:1042619 發(fā)表于 2023-3-30 10:50 | 顯示全部樓層
有三角波,正玄波等的 波形發(fā)生器程序
在 STC提供的能硬件仿真的8051,開天斧-STC8H8K64U-老劉愛搗鼓示波器程序包中:
