查看: 6459|回復: 5
獨立按鍵矩陣鍵盤定時器消抖非延時消抖程序
ID:349802 發(fā)表于 2018-6-14 09:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit KEY_IN_1 = P2^4;
sbit KEY_IN_2 = P2^5;
sbit KEY_IN_3 = P2^6;
sbit KEY_IN_4 = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char KeySta[4][4] = {
        {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號到標準鍵盤鍵碼的映射表
    { 0x31, 0x32, 0x33, 0x26 }, //數字鍵1、數字鍵2、數字鍵3、向上鍵
    { 0x34, 0x35, 0x36, 0x25 }, //數字鍵4、數字鍵5、數字鍵6、向左鍵
    { 0x37, 0x38, 0x39, 0x28 }, //數字鍵7、數字鍵8、數字鍵9、向下鍵
    { 0x30, 0x1B, 0x0D, 0x27 }  //數字鍵0、ESC鍵、  回車鍵、 向右鍵
void  KeyDriver();
    EA = 1;       //使能總中斷
    TMOD = 0x01;  //設置T0為模式1
    TH0  = 0xFC;  //為T0賦初值0xFC67,定時1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中斷
    TR0  = 1;     //啟動T0
    while (1)
        KeyDriver();   //調用按鍵驅動函數
void KeyAction(unsigned char keycode)                                        //按鍵處理函數,根據不同鍵值執(zhí)行動作
        if((keycode >= 0x30) &&(keycode <= 0x39))                        //數字鍵
        else if(keycode == 0x26)                                                        //向上鍵
        else if(keycode == 0x25)                                                        //向左鍵
        else if(keycode == 0x28)                                                        //向下鍵
        else if(keycode == 0x27)                                                        //向右鍵
        else if(keycode == 0x0D)                                                        //回車鍵
        else if(keycode == 0x1B)                                                        //ESC鍵
void  KeyDriver()
        unsigned char i, j;
        static        unsigned char backup [4][4] = {
        for(i=0; i<4; i++)
                        for(j=0; j<4; j++)
                                if(backup[i][j] != KeySta[i][j])
                                        if(backup[i][j] == 0)
                                                KeyAction(KeyCodeMap[i][j]);
                                        backup[i][j] = KeySta[i][j];
/* 按鍵掃描函數,需在定時中斷中調用,推薦調用間隔1ms */
void KeyScan()
    unsigned char i;
    static unsigned char keyout = 0;   //矩陣按鍵掃描輸出索引
    static unsigned char keybuf[4][4] = {  //矩陣按鍵掃描緩沖區(qū)
        {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
    //將一行的4個按鍵值移入緩沖區(qū)
    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
    //消抖后更新按鍵狀態(tài)
    for (i=0; i<4; i++)  //每行4個按鍵,所以循環(huán)4次
        if ((keybuf[keyout][i] & 0x0F) == 0x00)
        {   //連續(xù)4次掃描值為0,即4*4ms內都是按下狀態(tài)時,可認為按鍵已穩(wěn)定的按下
            KeySta[keyout][i] = 0;
        else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
        {   //連續(xù)4次掃描值為1,即4*4ms內都是彈起狀態(tài)時,可認為按鍵已穩(wěn)定的彈起
            KeySta[keyout][i] = 1;
    //執(zhí)行下一次的掃描輸出
    keyout++;                //輸出索引遞增
    keyout = keyout & 0x03;  //索引值加到4即歸零
    switch (keyout)          //根據索引,釋放當前輸出引腳,拉低下次的輸出引腳
        case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
        case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
        case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
        case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
        default: break;
/* T0中斷服務函數,用于數碼管顯示掃描與按鍵掃描 */
void InterruptTimer0() interrupt 1
        TH0 = 0xFC;
        TL0 = 0x67;
        KeyScan();
獨立按鍵矩陣鍵盤定時器消抖非延時消抖程序.zip
2.07 KB, 下載次數: 32, 下載積分: 黑幣 -5
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
ID:332133 發(fā)表于 2018-6-29 13:49 | 只看該作者
樓主你好,我用這個矩陣鍵盤程序有個問題,只在按鍵第一次按下有效,再次按下就沒反應了,遇到過這種情況嗎
ID:80456 發(fā)表于 2018-6-29 14:59 | 只看該作者
感謝分享
ID:349802 發(fā)表于 2018-7-5 18:17 | 只看該作者
T奉義 發(fā)表于 2018-6-29 13:49
不應該吧,這個我是測試過的,需要在1-2ms的定時器中斷中調用keyscan(),在主函數中循環(huán)調用keydriver(),這個按鍵掃描按鍵按下只會執(zhí)行一次,需要彈開再次按下觸發(fā)下一次操作,也就是單擊
ID:205182 發(fā)表于 2018-7-5 23:30 | 只看該作者
謝謝樓主
ID:426132 發(fā)表于 2020-7-4 08:01 | 只看該作者
樓主:為什么4*4就沒問題,4*6怎么調都不行,關鍵在哪里
Powered by 單片機教程網
