程序的運(yùn)行界面:
全部資料51hei下載地址:
5、COM_LoRa模塊設(shè)置.zip
(3.62 MB, 下載次數(shù): 98)
2018-6-14 20:52 上傳
點(diǎn)擊文件名下載附件
部分源碼預(yù)覽:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Windows.Forms;
- using System.IO.Ports;
- using System.Threading;
- using System.Collections;
- using System.IO;
- namespace COM_A
- public partial class Form1 : Form
- public byte[] myBy;//傳遞串口接收到的數(shù)據(jù)
- public int myByLenth = 0;//串口接收到的數(shù)據(jù)長度
- public string myStr;//串口接收的字符串
- public bool receiveDtatFlag = false;
- public int send_count = 0;
- public Form1()
- InitializeComponent();
- //this.ControlBox = false;//最小化最大化關(guān)閉按鈕處理
- private void Form1_Load(object sender, EventArgs e)//頁面加載
- #region 串口設(shè)置初始化加載
- try
- foreach (string com in System.IO.Ports.SerialPort.GetPortNames())//串口檢測
- comboBox1.Items.Add(com);
- //comboBox1.Text = (string)comboBox1.Items[0];//初始化選擇串口
- comboBox1.Text = myConfing.ConfingGetValue("COM");//使用配置文件加載
- if (comboBox1.Text == "")
- comboBox1.Text = (string)comboBox1.Items[0];//初始化選擇串口
- catch (Exception er)
- MessageBox.Show("端口加載失。" + er.Message, "提示");
- //列出常用的波特率
- string[] ss = new string[] { "1200", "2400", "4800", "9600", "19200", "38400", "43000", "56000", "57600", "115200" };
- comboBox2.DataSource = ss;
- /*for (int temp = 0; temp < 10; temp++)
- comboBox2.Items.Add(ss[temp]);
- comboBox2.Text = myConfing.ConfingGetValue("buadRate");
- if (comboBox2.Text == "")
- comboBox2.SelectedIndex = 3;
- //comboBox2.SelectedIndex = 3;
- //列出奇偶校驗(yàn)位
- comboBox3.DataSource = Enum.GetNames(typeof(Parity));
- //comboBox3.Items.Add("無校驗(yàn)");
- //comboBox3.Items.Add("奇校驗(yàn)");
- //comboBox3.Items.Add("偶校驗(yàn)");
- //comboBox3.SelectedIndex = 0;
- comboBox3.Text = myConfing.ConfingGetValue("Parity");
- if (comboBox3.Text == "")
- comboBox3.Text = "None";
- //列出數(shù)據(jù)位
- ss = new string[] { "5", "6", "7", "8", "9", "10" };
- comboBox4.DataSource = ss;
- //comboBox4.Text = "8";
- comboBox4.Text = myConfing.ConfingGetValue("dataBits");
- if (comboBox4.Text == "")
- comboBox4.SelectedIndex = 3;
- //列出停止位
- comboBox5.DataSource = Enum.GetNames(typeof(StopBits));
- //comboBox5.Text = Enum.Format(typeof(StopBits), StopBits.One, "G");
- comboBox5.Text = myConfing.ConfingGetValue("stopBits");
- if (comboBox5.Text == "")
- comboBox5.SelectedIndex = 1;
- button1.Text = "打開串口";
- //開始執(zhí)行后臺操作
- //backgroundWorker1.RunWorkerAsync();
- checkBox1.Checked = true;
- checkBox2.Checked = true;
- checkBox3.Checked = true;
- checkBox4.Checked = true;
- #endregion
- //this.button3.Visible = false;
- #region 加載開選擇的模塊
- cmbSetParaLoRaDataRate.Items.Clear();
- cmbSetParaWakeUpTime.Items.Clear();
- if (cmbSelectLoRaMode.Text == "杭州塔石")//
- //LoRa的空中速率
- cmbSetParaLoRaDataRate.Items.Add("000_0.3K");
- cmbSetParaLoRaDataRate.Items.Add("001_0.6K");
- cmbSetParaLoRaDataRate.Items.Add("010_1.2K");
- cmbSetParaLoRaDataRate.Items.Add("011_2.5K");
- cmbSetParaLoRaDataRate.Items.Add("100_4.5K");
- cmbSetParaLoRaDataRate.Items.Add("101_9.1K");
- cmbSetParaLoRaDataRate.Items.Add("110_18.2K");
- cmbSetParaLoRaDataRate.Items.Add("111_21.8K");//(默認(rèn))
- //cmbSetParaLoRaDataRate.Text = "111_21.8K";//(默認(rèn))
- cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[7].ToString();
- //喚醒時(shí)間
- cmbSetParaWakeUpTime.Items.Add("000_500");//(默認(rèn))
- cmbSetParaWakeUpTime.Items.Add("001_1000");
- cmbSetParaWakeUpTime.Items.Add("010_1500");
- cmbSetParaWakeUpTime.Items.Add("011_2000");
- cmbSetParaWakeUpTime.Items.Add("100_2500");
- cmbSetParaWakeUpTime.Items.Add("101_3000");
- cmbSetParaWakeUpTime.Items.Add("110_3500");
- cmbSetParaWakeUpTime.Items.Add("111_4000");
- //cmbSetParaWakeUpTime.Text = "000_500";//(默認(rèn))
- cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[0].ToString();
- else
- //LoRa的空中速率
- cmbSetParaLoRaDataRate.Items.Add("011_2.4K");//(默認(rèn))
- cmbSetParaLoRaDataRate.Items.Add("100_4.8K");
- cmbSetParaLoRaDataRate.Items.Add("101_9.6K");
- cmbSetParaLoRaDataRate.Items.Add("110_19.2K");
- cmbSetParaLoRaDataRate.Items.Add("111_19.2K");
- //cmbSetParaLoRaDataRate.Text = "011_2.4K";//(默認(rèn))
- cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[3].ToString();
- //喚醒時(shí)間
- cmbSetParaWakeUpTime.Items.Add("000_250");//(默認(rèn))
- cmbSetParaWakeUpTime.Items.Add("001_500");
- cmbSetParaWakeUpTime.Items.Add("010_750");
- cmbSetParaWakeUpTime.Items.Add("011_1000");
- cmbSetParaWakeUpTime.Items.Add("100_1250");
- cmbSetParaWakeUpTime.Items.Add("101_1500");
- cmbSetParaWakeUpTime.Items.Add("110_1750");
- cmbSetParaWakeUpTime.Items.Add("111_2000");
- //cmbSetParaWakeUpTime.Text = "000_250";//(默認(rèn))
- #endregion
- private void comboBox1_DropDown_1(object sender, EventArgs e)//串口下拉框更新COM口
- try
- comboBox1.Items.Clear();
- MessageBox.Show("端口加載失!" + er.Message, "提示");
- #region 打開串口按鈕處理
- public void RefrespictureBox1()//刷新打開串口按鍵顯示以及顏色
- if (serialPort1.IsOpen)
- button1.BackColor = SystemColors.GradientActiveCaption;
- button1.Text = "關(guān)閉串口";
- else
- button1.BackColor = SystemColors.Control;
- myConfing.SetValue("COM", comboBox1.Text);
- myConfing.SetValue("buadRate", comboBox2.Text);
- myConfing.SetValue("Parity", comboBox3.Text);
- myConfing.SetValue("dataBits", comboBox4.Text);
- myConfing.SetValue("stopBits", comboBox5.Text);
- private void button1_Click(object sender, EventArgs e)//打開串口
- try
- if (serialPort1.IsOpen)//如果串口是開的則關(guān)閉
- serialPort1.Close();
- comboBox1.Enabled = true;
- comboBox2.Enabled = true;
- comboBox3.Enabled = true;
- comboBox4.Enabled = true;
- comboBox5.Enabled = true;
- #region
- //button1.Text = "打開串口";
- /*//關(guān)閉串口后,串口設(shè)置選項(xiàng)便可以繼續(xù)使用
- comboBox5.Enabled = true;*/
- #endregion
- else//否則打開串口
- //button1.Text = "關(guān)閉串口";
- serialPort1.PortName = comboBox1.Text;
- serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text);
- serialPort1.Parity = (Parity)Enum.Parse(typeof(Parity), comboBox3.Text);
- serialPort1.DataBits = Int32.Parse(comboBox4.Text);
- serialPort1.StopBits = (StopBits)Enum.Parse(typeof(StopBits), comboBox5.Text);
- serialPort1.Encoding = Encoding.GetEncoding("Gb2312");//返回與指定代碼頁名稱關(guān)聯(lián)的編碼Gb2312
- serialPort1.Open();
- comboBox1.Enabled = false;
- comboBox2.Enabled = false;
- comboBox3.Enabled = false;
- comboBox4.Enabled = false;
- comboBox5.Enabled = false;
- RefrespictureBox1();//刷新打開串口按鍵顯示以及顏色
- catch (Exception)
- //打開串口失敗后,相應(yīng)標(biāo)志位取消
- MessageBox.Show("串口無效或已被占用!", "錯(cuò)誤提示");
- #endregion
- #region 發(fā)送區(qū)形式處理、串口按鍵發(fā)送、定時(shí)自動發(fā)送以及其他外部調(diào)用發(fā)送相關(guān)接口
- private bool CheckSendData()//檢查串口發(fā)送區(qū)域
- if (textBox2.Text.Trim() == "") return false;
- return true;
- private void checkBox4_CheckedChanged(object sender, EventArgs e)//發(fā)送區(qū)HEX處理
- string s = "";
- if (checkBox4.CheckState == CheckState.Checked)//發(fā)送HEX顯示
- byte[] by = Encoding.GetEncoding("Gb2312").GetBytes(textBox2.Text);
- textBox2.Text = "";
- foreach (byte btmp in by)
- s = "00" + string.Format("{0:X}", btmp);
- textBox2.Text += s.Substring(s.Length - 2, 2);
- textBox2.Text += " ";
- else//發(fā)送ASCII顯示
- ArrayList al = myClass.Str16ToArrayList(textBox2.Text);
- byte[] by = new byte[al.Count];
- int i = 0;
- foreach (string stmp in al)
- by[i] += Convert.ToByte(stmp, 16);
- i++;
- textBox2.Text = Encoding.GetEncoding("Gb2312").GetString(by);
- private void textBox2_KeyPress(object sender, KeyPressEventArgs e)//發(fā)送區(qū)有按鍵鍵入,
- if (checkBox1.CheckState == CheckState.Checked)//HEX發(fā)送時(shí)
- if (!Uri.IsHexDigit(e.KeyChar) && e.KeyChar != ' ')//不符合HEX的鍵入清除
- e.KeyChar = (char)0;
- private void button2_Click(object sender, EventArgs e)//按鍵發(fā)送
- try
- /*if (!CheckSendData())//檢測要發(fā)送的數(shù)據(jù)
- MessageBox.Show("請輸入要發(fā)送的數(shù)據(jù)!", "錯(cuò)誤提示");
- return;
- string s = "";
- //MessageBox.Show(checkBox4.Checked.ToString());
- if (checkBox4.Checked)//十六進(jìn)制發(fā)送
- int i = 0;
- by[i] += Convert.ToByte(stmp, 16);//將指定基的數(shù)字的字符串表示形式轉(zhuǎn)換為等效的 8 位無符號整數(shù)。
- i++;
- serialPort1.Write(by, 0, i);//發(fā)送字節(jié)
- //s = Encoding.GetEncoding("Gb2312").GetString(by);//在派生類中重寫時(shí),將指定字節(jié)數(shù)組中的所有字節(jié)解碼為一個(gè)字符串。。
- else//ASCII發(fā)送
- s = textBox2.Text;
- serialPort1.Write(s);//串口發(fā)送字符串
- //MessageBox.Show(s);
- else
- MessageBox.Show("串口未打開!", "錯(cuò)誤提示");
- catch (Exception)
- MessageBox.Show("發(fā)送數(shù)據(jù)時(shí)發(fā)生錯(cuò)誤!", "錯(cuò)誤提示");
- public void sendData(string dataIn)//調(diào)用的發(fā)送函數(shù)
- try
- return;
- string s = "";
- textBox2.Text = dataIn;
- int i = 0;
- i++;
- else//ASCII發(fā)送
- else
- catch (Exception)
- public void sendData_NoDispaly(string dataIn)//調(diào)用的發(fā)送函數(shù)并且不顯示在發(fā)送區(qū)域
- try
- return;
- string s = "";
- //textBox2.Text = dataIn;//不顯示在發(fā)送區(qū)域
- int i = 0;
- i++;
- else//ASCII發(fā)送
- else
- catch (Exception)
- private void timer1_Tick(object sender, EventArgs e)//定時(shí)自動發(fā)送
- timer1.Interval = Convert.ToInt32(textBox1.Text);
- try
- if ((serialPort1.IsOpen) && (checkBox5.Checked == true))
- return;
- string s = "";
- int i = 0;
- i++;
- else//ASCII發(fā)送
- send_count++;
- textBox5.Text = send_count.ToString();
- else
- //MessageBox.Show("串口未打開!", "錯(cuò)誤提示");
- catch (Exception)
- //MessageBox.Show("發(fā)送數(shù)據(jù)時(shí)發(fā)生錯(cuò)誤!", "錯(cuò)誤提示");
- #endregion
- #region 接收方法一用到的線程處理,不用
- delegate void SetTextCallback(string text);//委托,使用回調(diào)函數(shù)時(shí)考慮使用
- private void SetText(string text)
- try
- if (this.richTextBox1.InvokeRequired)//獲取一個(gè)值,該值指示調(diào)用方在對控件進(jìn)行方法調(diào)用時(shí)是否必須調(diào)用 Invoke 方法,因?yàn)檎{(diào)用方位于創(chuàng)建控件所在的線程以外的線程中。
- SetTextCallback d = new SetTextCallback(SetText);//回調(diào)函數(shù)
- this.Invoke(d, new object[] { text });//執(zhí)行delegate里的搭載函數(shù)
- else
- this.richTextBox1.Text += text;
- //this.richTextBox2.Focus();//獲取焦點(diǎn)
- //this.richTextBox2.Select(this.richTextBox2.TextLength, 0);//光標(biāo)定位到文本最后
- /* //設(shè)定光標(biāo)所在位置
- this.richTextBox1.SelectionStart = richTextBox1.TextLength;
- //滾動到當(dāng)前光標(biāo)處
- this.richTextBox1.ScrollToCaret();*/
- catch (Exception)
- #endregion
- #region 串口接收處理
- //int receive_count_test = 0;
- private void linkLabel1_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)//清除接收
- richTextBox1.Text = "";
- send_count = 0;
- //receive_count_test = 0;
- textBox5.Text = "";
- //textBox5.Text = "";
- private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)//接收事件觸發(fā)
- #region
- /* char[] c;
- //StringBuilder builder = new StringBuilder();//避免在事件處理方法中反復(fù)的創(chuàng)建,定義到外面。
- try
- c = new char[serialPort1.BytesToRead];
- serialPort1.Read(c, 0, c.Length);//串口讀取
- if (c.Length > 0)
- if (checkBox1.Checked)//接收HEX顯示
- if (checkBox3.Checked)//接收時(shí)間顯示
- SetText(DateTime.Now.ToString());
- SetText(" ");
- byte[] by = Encoding.GetEncoding("Gb2312").GetBytes(c);
- myBy = by;
- myByLenth = by.Length;
- /*if (by[0] == 0x7b)
- MessageBox.Show("正確");
- else
- MessageBox.Show(by[0].ToString());
- string s = "00" + string.Format("{0:X}", btmp);//將指定字符串中的一個(gè)或多個(gè)格式項(xiàng)替換為指定對象的字符串表示形式
- s = s.Substring(s.Length - 2, 2);
- SetText(new string(s.ToCharArray()));
- SetText(" ");
- if (checkBox2.Checked)//接收換行顯示
- SetText("\n");
- else
- SetText(new string(c));
- if (checkBox3.Checked)//接收換行顯示
- SetText("\n");
- //this.richTextBox2.Text += "\n";
- catch (Exception)
- if (checkBox2.Checked)//接收HEX顯示
- Thread.Sleep(500);//延時(shí)500ms 等待接收完數(shù)據(jù)
- else
- Thread.Sleep(10);//延時(shí)100ms 等待接收完數(shù)據(jù)
- //追加的形式添加到文本框末端,并滾動到最后。
- //this.richTextBox1.AppendText(builder.ToString());
- #endregion
- #region
- Thread.Sleep(Convert.ToInt32(textBox5.Text.Trim()));//延時(shí)100ms 等待接收完數(shù)據(jù)
- //第二種接收方式
- StringBuilder builder = new StringBuilder();//避免在事件處理方法中反復(fù)的創(chuàng)建,定義到外面。
- long received_count = 0;//接收計(jì)數(shù)
- int n = serialPort1.BytesToRead;//先記錄下來,避免某種原因,人為的原因,操作幾次之間時(shí)間長,緩存不一致
- byte[] buf = new byte[n];//聲明一個(gè)臨時(shí)數(shù)組存儲當(dāng)前來的串口數(shù)據(jù)
- received_count += n;//增加接收計(jì)數(shù)
- serialPort1.Read(buf, 0, n);//讀取緩沖數(shù)據(jù)
- builder.Clear();//清除字符串構(gòu)造器的內(nèi)容
- myBy = buf;
- myByLenth = buf.Length;
- //因?yàn)橐L問ui資源,所以需要使用invoke方式同步ui。
- this.Invoke((EventHandler)(delegate
- this.richTextBox1.AppendText(DateTime.Now.ToString(@"yyyy\:MM\:dd") + " ");
- this.richTextBox1.AppendText(DateTime.Now.ToString(@"HH\:mm\:ss\:fff") + " ");
- //判斷是否是顯示為16禁止
- //依次的拼接出16進(jìn)制字符串
- foreach (byte b in buf)
- builder.Append(b.ToString("X2") + " ");//在此實(shí)例的結(jié)尾追加指定字符串的副本
- else
- //直接按ASCII規(guī)則轉(zhuǎn)換成字符串
- builder.Append(Encoding.ASCII.GetString(buf));
- this.richTextBox1.AppendText(builder.ToString());
- myStr = builder.ToString();//字符串輸出
- this.richTextBox1.AppendText("\n");
- //修改接收計(jì)數(shù)
- //labelGetCount.Text = "Get:" + received_count.ToString();
- try
- if (receiveDtatFlag == true)//保存數(shù)據(jù)
- string fName = saveFileDialog1.FileName;
- FileStream fs = File.Open(fName, FileMode.Append);
- StreamWriter sw = new StreamWriter(fs);
- //this.richTextBox1.AppendText(DateTime.Now.ToString() + " ");
- sw.Write(DateTime.Now.ToString(@"hh\:mm\:ss\:fff") + " ");
- sw.Write(builder.ToString());
- sw.WriteLine("\n");
- //sw.WriteLine(richTextBox1.Text);
- //textBox3.Text = fName;
- sw.Close();
- fs.Close();
- catch
- myReceDataAnalysis(myStr);//數(shù)據(jù)解析處理
- //analysis myans = new analysis();
- //myans.analysisData(myStr);
- #endregion
- private void richTextBox1_TextChanged(object sender, EventArgs e)//接收窗處理
- if (richTextBox1.Lines.Length > 8000)//大于8000行時(shí)清楚前面的
- int n = 500;
- int start = richTextBox1.GetFirstCharIndexFromLine(0);//第一行第一個(gè)字符索引
- int end = richTextBox1.GetFirstCharIndexFromLine(n);//第n行第一個(gè)字符索引
- richTextBox1.Select(start, end);//選中n行
- richTextBox1.SelectedText = "";//設(shè)置前n行為空
- richTextBox1.Focus();
- richTextBox1.Select(richTextBox1.TextLength, 0);
- #endregion
- #region 窗體處理
- private void Form1_FormClosing(object sender, FormClosingEventArgs e)//關(guān)閉提醒
- Properties.Settings.Default.Save();
- if (DialogResult.Yes == MessageBox.Show("程序正在使用中,確認(rèn)退出?", "確認(rèn)退出", MessageBoxButtons.YesNo))
- //MessageBox.Show("立即退出!");
- this.Dispose();
- e.Cancel = false;
- else
- e.Cancel = true;
- /*private void Form1_FormClosed(object sender, FormClosedEventArgs e)//關(guān)閉整個(gè)窗口
- /*private void button3_Click(object sender, EventArgs e)//窗口隱藏
- //this.Hide();//隱藏窗體
- #endregion
- #region 數(shù)據(jù)文件保存處理
- private void button4_Click(object sender, EventArgs e)//保存路徑選擇
- //saveFileDialog1.InitialDirectory = @"G:\自制軟件\C#練習(xí)\20.19 文件保存SaveFileDialog控件\51zxw";
- saveFileDialog1.Filter = "文本文件(*.txt)|*.txt";
- saveFileDialog1.FilterIndex = 1;
- saveFileDialog1.FileName = "ReceiveData";
- if (saveFileDialog1.ShowDialog() == DialogResult.OK)
- textBox3.Text = fName;
- sw.Close();
- fs.Close();
- private void checkBox6_CheckedChanged(object sender, EventArgs e)//保存數(shù)據(jù)勾選處理
- if (checkBox6.CheckState == CheckState.Checked)//選中
- receiveDtatFlag = true;
- else
- receiveDtatFlag = false;
- #endregion
- #region 數(shù)據(jù)處理過程
- private void btnSetPara_Click(object sender, EventArgs e)//設(shè)置參數(shù)
- string mySendDataTemp = "";
- //幀頭
- string mySendHead_0 = "";
- if (chbSetParaSave.Checked == true)//掉電保存
- mySendHead_0 = "C0" + " ";
- else
- mySendHead_0 = "C2" + " ";
- //地址
- if (txbSetParaAddr.Text.Trim().Length != 4)
- MessageBox.Show("地址長度不為4!", "錯(cuò)誤提示");
- return;
- string mySendAddr_1_2 = txbSetParaAddr.Text.Trim() + " ";
- //字節(jié)3
- string mySendChar_3 = "";
- byte mySendByte_3 = 0;
- //串口校驗(yàn)位,mySendByte_3的7、6位
- switch (cmbSetParaDataBit.Text.Trim().Substring(0, 2))
- case "00"://8N1(默認(rèn))
- mySendByte_3 &= 0x3F;
- break;
- case "01"://8O1
- mySendByte_3 |= (1<<6);
- break;
- case "10"://8E1
- mySendByte_3 |= (2 << 6);
- break;
- case "11"://8N1(默認(rèn))
- break;
- default:
- mySendByte_3 &= 0x3F;//8N1(默認(rèn))
- break;
- //TTL 串口速率(bps),mySendByte_3的5、4、3位
- switch (cmbSetParaBuadRate.Text.Trim().Substring(0, 3))
- case "000"://1200
- mySendByte_3 &= 0xC7;
- break;
- case "001"://2400
- mySendByte_3 |= (1 << 3);
- break;
- case "010"://4800
- mySendByte_3 |= (2 << 3);
- break;
- case "011"://9600(默認(rèn))
- mySendByte_3 |= (3 << 3);
- break;
- case "100"://19200
- mySendByte_3 |= (4 << 3);
- break;
- case "101"://38400
- mySendByte_3 |= (5 << 3);
- break;
- case "110"://57600
- mySendByte_3 |= (6 << 3);
- break;
- case "111"://115200
- mySendByte_3 |= (7 << 3);
- break;
- default:
- mySendByte_3 |= (3 << 3);//9600(默認(rèn))
- break;
- //無線空中速率(bps)
- switch (cmbSetParaLoRaDataRate.Text.Trim().Substring(0, 3))
- case "000"://0.3K
- mySendByte_3 &= 0xF8;
- break;
- case "001"://0.6K
- mySendByte_3 |= 1 ;
- break;
- case "010"://1.2K
- mySendByte_3 |= 2 ;
- break;
- case "011"://2.5K/2.4k(默認(rèn))
- mySendByte_3 |= 3 ;
- break;
- case "100"://4.5K/4.8k
- mySendByte_3 |= 4 ;
- break;
- case "101"://9.1K/9.6k
- mySendByte_3 |= 5 ;
- break;
- case "110"://18.2K/19.2k
- mySendByte_3 |= 6 ;
- break;
- case "111"://21.8K(默認(rèn))/19.2k
- mySendByte_3 |= 7 ;
- break;
- default:
- mySendByte_3 |= 7 ;//21.8K(默認(rèn))
- else
- mySendByte_3 |= 3;//2.4K(默認(rèn))
- break;
- mySendChar_3 = mySendByte_3.ToString("X2") + " ";
- //信道
- string mySendChannel_4 = "";//txbSetParaLoRaChannel.Text.Trim().Substring(0, 2) + " ";
- Int16 mySendChannelTempInt = Convert.ToInt16(txbSetParaLoRaChannel.Text.Trim());
- //byte mySendChannelTempByte = Convert.ToByte((mySendChannelTempInt - 398).ToString("X2"));
- mySendChannel_4 = (mySendChannelTempInt - 398).ToString("X2");
- else
- mySendChannel_4 = (mySendChannelTempInt - 410).ToString("X2");
- //字節(jié)5
- string mySendChar_5 = "";
- byte mySendByte_5 = 0;
- //發(fā)送模式,mySendByte_5的1位
- if (cmbSetParaSendMode.Text.Trim().Substring(0, 1) == "1")
- mySendByte_5 |= (1 << 7);
- else
- mySendByte_5 &= 0x7F;//默認(rèn)
- //IO 驅(qū)動方式(默認(rèn)1),mySendByte_5的6位
- if (cmbSetParaIOMode.Text.Trim().Substring(0, 1) == "1")
- mySendByte_5 |= (1 << 6);
- else
- mySendByte_5 &= 0xBF;//默認(rèn)
- //無線喚醒時(shí)間,mySendByte_5的5、4、3位
- switch (cmbSetParaWakeUpTime.Text.Trim().Substring(0, 3))
- case "000"://500ms(默認(rèn))/250ms(默認(rèn))
- mySendByte_5 &= 0xC7;
- break;
- case "001"://1000ms/500ms
- mySendByte_5 |= (1 << 3);
- break;
- case "010"://1500ms/750ms
- mySendByte_5 |= (2 << 3);
- break;
- case "011"://2000ms/1000ms
- mySendByte_5 |= (3 << 3);
- break;
- case "100"://2500ms/1250ms
- mySendByte_5 |= (4 << 3);
- break;
- case "101"://3000ms/1500ms
- mySendByte_5 |= (5 << 3);
- break;
- case "110"://3500ms/1750ms
- mySendByte_5 |= (6 << 3);
- break;
- case "111"://4000ms/2000ms
- mySendByte_5 |= (7 << 3);
- break;
- default:
- mySendByte_5 &= 0xC7;//500ms(默認(rèn))/250ms(默認(rèn))
- break;
- //FEC 開關(guān),mySendByte_5的2位
- if (chbSetParaOpenFec.Checked == true)//定點(diǎn)傳輸
- mySendByte_5 |= (1 << 2);
- else//透明傳輸
- mySendByte_5 &= 0xFB;
- //發(fā)射功率,mySendByte_5的1、0位
- case "00":////20dBm(默認(rèn))
- mySendByte_5 &= 0xFC;
- break;
- case "01"://17dBm
- mySendByte_5 |= 1;
- break;
- case "10"://14dBm
- mySendByte_5 |= 2;
- break;
- case "11"://10dBm
- mySendByte_5 |= 3;
- break;
- default:
- mySendByte_5 &= 0xFC;//20dBm(默認(rèn))
- break;
- mySendChar_5 = mySendByte_5.ToString("X2");
- //綜合
- mySendDataTemp = mySendHead_0 + mySendAddr_1_2 + mySendChar_3 + mySendChannel_4 + mySendChar_5;
- sendData(myClass.strAddSpace(mySendDataTemp));
- this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
- this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
- this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
- this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
- private void btnReadPara_Click(object sender, EventArgs e)//讀取參數(shù)
- sendData("C1 C1 C1");
- this.pictureBox1.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
- this.pictureBox2.Image = Image.FromFile(Application.StartupPath + "\\red.png");//bin文件中
- private void btnReadVersion_Click(object sender, EventArgs e)//讀取版本號
- sendData("C3 C3 C3");
- this.pictureBox3.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
- private void btnReset_Click(object sender, EventArgs e)//復(fù)位
- sendData("C4 C4 C4");
- this.pictureBox4.Image = Image.FromFile(Application.StartupPath + "\\green.png");//bin文件中
- //數(shù)據(jù)解析過程
- public void myReceDataAnalysis(string str)
- byte[] myReceByte = myClass.strAsciiToHexBy(str);
- if (myReceByte.Length >= 4)
- try
- switch (myReceByte[0])
- case 0xC0:
- case 0xC2://讀取工作參數(shù)
- #region //工作參數(shù)顯示
- //字節(jié)0掉電是否保存
- if (myReceByte[0] == 0xC0)//要掉電保存的參數(shù)
- chbSetParaSave.Checked = true;
- else
- chbSetParaSave.Checked = false;
- //字節(jié)1、2 地址
- txbSetParaAddr.Text = myReceByte[1].ToString("X2") + myReceByte[2].ToString("X2");
- //字節(jié)3
- //串口校驗(yàn)位,字節(jié)3的7、6位
- cmbSetParaDataBit.Text = cmbSetParaDataBit.Items[(myReceByte[3] >> 6) & 0x03].ToString();
- #region
- /*switch ((myReceByte[3] >> 6) & 0x03)
- case 0://8N1(默認(rèn))
- cmbSetParaDataBit.Text = "00_8N1";
- break;
- case 1://8O1
- cmbSetParaDataBit.Text = "01_8O1";
- break;
- case 2://8E1
- cmbSetParaDataBit.Text = "01_8E1";
- break;
- case 3://8N1(默認(rèn))
- break;
- default:
- cmbSetParaDataBit.Text = "error";
- break;
- #endregion
- //TTL 串口速率(bps),字節(jié)3的5、4、3位
- cmbSetParaBuadRate.Text = cmbSetParaBuadRate.Items[(myReceByte[3] >> 3) & 0x07].ToString();
- #region
- /*switch ((myReceByte[3] >> 3) & 0x07)
- case 0://1200
- cmbSetParaBuadRate.Text = "000_1200";
- break;
- case 1://2400
- cmbSetParaBuadRate.Text = "001_2400";
- break;
- case 2://4800
- cmbSetParaBuadRate.Text = "010_4800";
- break;
- case 3://9600(默認(rèn))
- cmbSetParaBuadRate.Text = "011_9600";
- break;
- case 4://19200
- cmbSetParaBuadRate.Text = "100_19200";
- break;
- case 5://38400
- cmbSetParaBuadRate.Text = "101_38400";
- break;
- case 6://57600
- cmbSetParaBuadRate.Text = "110_57600";
- break;
- case 7://115200
- cmbSetParaBuadRate.Text = "111_115200";
- break;
- default:
- cmbSetParaBuadRate.Text = "error";
- break;
- #endregion
- //無線空中速率(bps),字節(jié)3的2、1、0位
- cmbSetParaLoRaDataRate.Text = cmbSetParaLoRaDataRate.Items[(myReceByte[3] >> 0) & 0x07].ToString();
- #region
- /*switch ((myReceByte[3] >> 0) & 0x07)
- case 0://0.3K
- cmbSetParaLoRaDataRate.Text = "000_0.3K";
- break;
- case 1://0.6K
- cmbSetParaLoRaDataRate.Text = "001_0.6K";
- break;
- case 2://1.2K
- cmbSetParaLoRaDataRate.Text = "010_1.2K";
- break;
- case 3://2.5K/2.4k
- cmbSetParaLoRaDataRate.Text = "011_2.5K";
- else
- cmbSetParaLoRaDataRate.Text = "011_2.4K";
- break;
- case 4://4.5K/4.8k
- cmbSetParaLoRaDataRate.Text = "100_4.5K";
- else
- cmbSetParaLoRaDataRate.Text = "100_4.8K";
- break;
- case 5://9.1K/9.6K
- cmbSetParaLoRaDataRate.Text = "101_9.1K";
- else
- cmbSetParaLoRaDataRate.Text = "101_9.6K";
- break;
- case 6://18.2K/19.2K
- cmbSetParaLoRaDataRate.Text = "110_18.2K";
- else
- cmbSetParaLoRaDataRate.Text = "110_19.2K";
- break;
- case 7://21.8K(默認(rèn))
- cmbSetParaLoRaDataRate.Text = "111_21.8K";
- else
- cmbSetParaLoRaDataRate.Text = "111_19.2K";
- break;
- default:
- cmbSetParaLoRaDataRate.Text = "error";
- break;
- #endregion
- //字節(jié)4信道號
- txbSetParaLoRaChannel.Text = (myReceByte[4] + 398).ToString();
- //字節(jié)5
- //發(fā)送模式,字節(jié)5的第7位
- cmbSetParaSendMode.Text = cmbSetParaSendMode.Items[(myReceByte[5] >> 7) & 0x01].ToString();
- #region
- /*if (((myReceByte[5] >> 7) & 0x01) == 1)//定點(diǎn)
- cmbSetParaSendMode.Text = "1_定點(diǎn)傳輸";
- else//透明
- cmbSetParaSendMode.Text = "0_透明傳輸";
- #endregion
- //IO 驅(qū)動方式(默認(rèn)1),字節(jié)5的第6位
- cmbSetParaIOMode.Text = cmbSetParaIOMode.Items[(myReceByte[5] >> 6) & 0x01].ToString();
- #region
- /*if (((myReceByte[5] >> 6) & 0x01) == 1)//
- cmbSetParaIOMode.Text = "1_推挽上拉";
- else//
- cmbSetParaIOMode.Text = "0_開漏浮空";
- #endregion
- //無線喚醒時(shí)間,字節(jié)5的第5、4、3位
- cmbSetParaWakeUpTime.Text = cmbSetParaWakeUpTime.Items[(myReceByte[5] >> 3) & 0x07].ToString();
- #region
- /*switch ((myReceByte[5] >> 3) & 0x07)
- case 0://500ms(默認(rèn))
- cmbSetParaWakeUpTime.Text = "000_500";
- break;
- case 1://1000ms
- cmbSetParaWakeUpTime.Text = "001_1000";
- break;
- case 2://1500ms
- cmbSetParaWakeUpTime.Text = "010_1500";
- break;
- case 3://2000ms
- cmbSetParaWakeUpTime.Text = "011_2000";
- break;
- case 4://2500ms
- cmbSetParaWakeUpTime.Text = "100_2500";
- break;
- case 5://3000ms
- cmbSetParaWakeUpTime.Text = "101_3000";
- break;
- case 6://3500ms
- cmbSetParaWakeUpTime.Text = "110_3500";
- break;
- case 7://4000ms
- cmbSetParaWakeUpTime.Text = "111_4000";
- break;
- default:
- cmbSetParaWakeUpTime.Text = "error";
- break;
- #endregion
- //FEC 開關(guān)(默認(rèn)1),字節(jié)5的第3位
- if (((myReceByte[5] >> 2) & 0x01) == 1)//
- chbSetParaOpenFec.Checked = true;
- else//
- chbSetParaOpenFec.Checked = false;
- //發(fā)射功率,字節(jié)5的第1、0位
- cmbSetParaSendPower.Text = cmbSetParaSendPower.Items[(myReceByte[5] >> 0) & 0x03].ToString();
- #region
- /*switch ((myReceByte[5] >> 0) & 0x03)
- case 0://20dBm(默認(rèn))
- cmbSetParaSendPower.Text = "00_20";
- break;
- case 1://17dBm
- cmbSetParaSendPower.Text = "01_17";
- break;
- case 2://14dBm
- cmbSetParaSendPower.Text = "10_14";
- break;
- case 3://10dBm
- cmbSetParaSendPower.Text = "11_10";
- break;
- default:
- cmbSetParaSendPower.Text = "error";
- break;
- #endregion
- #endregion
- break;
- case 0xC3://讀取版本號
- txbReadVersionOut.Text = str;
- if (myReceByte[1] == 0x28)//杭州塔石
- cmbSelectLoRaMode.Text = cmbSelectLoRaMode.Items[0].ToString();
- else//成都億佰特
- cmbSelectLoRaMode.Text = cmbSelectLoRaMode.Items[1].ToString();
- break;
- default:
- break;
- catch (Exception)
- #endregion//*/
- #region 沒有使用
- public void portIDGet()//串口自動獲取
- try
- //comboBox1.Text = myConfing.ConfingGetValue("COM");//使用配置文件加載
- private void comboBox1_DragDrop(object sender, DragEventArgs e)
- portIDGet();
- private void comboBox1_DropDown(object sender, EventArgs e)
- portIDGet();
- #endregion
- #region 模塊選擇
- private void cmbSelectLoRaMode_TextChanged(object sender, EventArgs e)//選擇模塊
- //LoRa的空中速率
- //喚醒時(shí)間
- else
- //LoRa的空中速率
- //喚醒時(shí)間
- #endregion
復(fù)制代碼 |
