查看: 3527|回復(fù): 0
JW5252電路圖與資料下載
性價(jià)比超高的IC JW5252電路原理圖:
DESCRIPTION
The JW®5252  is a current mode monolithic buck
switching regulator. Operating with an input range
of 2.5V-6V, the JW5252 delivers 2A of continuous
output  current  with  integrated  P-Channel  and
N-Channel MOSFETs. The  internal synchronous
power  switches  provide  high  efficiency.  At  light
loads,  the regulator operates  in  low  frequency  to
maintain high efficiency and low output ripples.
The JW5252 guarantees  robustness with hiccup
output  short-circuit  protection,  FB  short-circuit
protection,  start-up  current  run-away  protection,
input  under  voltage  lockout  and  hot-plug  in
protection, and thermal protection.
The  JW5252  provides  output  power  good
indication  which  is  only  available  in  SOT23-6
package.
The  JW5252  is  available  in  6-pin SOT23-6  and
5-pin  SOT23-5  package,  which  provides  a
compact  solution  with  minimal  external
components.
JW5252.pdf
149.37 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
DC/DC
