查看: 1841|回復(fù): 1
簡易計算器(數(shù)碼管顯示)
ID:352512 發(fā)表于 2018-6-15 14:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
uchar a0=16,b0=16,c0=16,d0=16,e0=16,f0=16,wei,temp,key,i,j,k;
uchar jia,jian,cheng,chu,dengyu,jia0,jian0,cheng0,chu0,qingling;
uchar s0,s1,s2,s3,s4,s5; //參加運算的各個位
unsigned long qian,hou;//定義參于運算的第一個數(shù)和第二個數(shù)。
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
void delay(uchar i)
        for(j=i;j>0;j--)
        for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
   dula=0;
   P0=table[a];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table[b];
   dula=1;
   dula=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(5);
   P0=table[c];
   dula=1;
   dula=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(5);
   P0=table[d];
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   P0=table[e];
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[f];
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=0;
                           wei++;
               break;
          case 0xde:
               key=1;
                           wei++;
               break;
          case 0xbe:
               key=2;
                           wei++;
               break;
          case 0x7e:
               key=3;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=4;
                           wei++;
               break;
          case 0xdd:
               key=5;
                           wei++;
               break;
          case 0xbd:
               key=6;
                           wei++;
               break;
          case 0x7d:
               key=7;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=8;
                           wei++;
               break;
          case 0xdb:
               key=9;
                           wei++;
               break;
          case 0xbb:
               qingling=1;
                           //key=10;
                           //wei++;
               break;
          case 0x7b:
               dengyu=1;
                           //key=11;
                           //wei++;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
              P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xe7:
                             jia=1;
               //key=12;
                          // wei++;
               break;
          case 0xd7:
               jian=1;
               break;
          case 0xb7:
               cheng=1;
               break;
          case 0x77:
               chu=1;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
void display0()
        if(key!=20)
        switch(wei)
                        case 1: a0=key;
                                        b0=16;
                                        c0=16;
                                        d0=16;
                                        e0=16;
                                        f0=16;
                                        break;
                        case 2: b0=key;
                                        c0=16;
                                        d0=16;
                                        e0=16;
                                        f0=16;
                                        break;
                        case 3: c0=key;
                                        d0=16;
                                        e0=16;
                                        f0=16;
                                        break;
                        case 4: d0=key;
                                        e0=16;
                                        f0=16;
                                        break;
                        case 5: e0=key;
                                        f0=16;
                                        break;
                        case 6: f0=key;
                                        //wei=0;
                                        break;
        key=20;
        display(a0,b0,c0,d0,e0,f0);
        if(a0!=16) s5=a0;
        if(b0!=16) s4=b0;
        if(c0!=16) s3=c0;
        if(d0!=16) s2=d0;
        if(e0!=16) s1=e0;
        if(f0!=16) s0=f0;
{        uchar gongneng,yunsuan;
                  keyscan();
                gongneng=jia|jian|cheng|chu|dengyu|qingling;
                if(gongneng==0)
                        display0();
                {          yunsuan=jia|jian|cheng|chu;
                        if(yunsuan)
                                a0=16;
                                b0=16;
                                c0=16;
                                d0=16;
                                e0=16;
                                f0=16;
                                //wei=0;
                                if(jia)
                                {jia=0;        jia0=1;jian0=0;cheng0=0;chu0=0;}
                                if(jian)
                                {jian=0;jia0=0;jian0=1;cheng0=0;chu0=0;}
                                if(cheng)
                                {cheng=0;jia0=0;jian0=0;cheng0=1;chu0=0;}
                                if(chu)
                                {chu=0;        jia0=0;jian0=0;cheng0=0;chu0=1;}
                                switch(wei)
                                        case 6:
                                        qian=s5*100000+s4*10000+s3*1000+s2*100+s1*10+s0;break;
                                        case 5:
                                        qian=s5*10000+s4*1000+s3*100+s2*10+s1;break;
                                        case 4:
                                        qian=s5*1000+s4*100+s3*10+s2;break;
                                        case 3:
                                        qian=s5*100+s4*10+s3;break;
                                        case 2:
                                        qian=s5*10+s4;break;
                                        case 1:
                                        qian=s5;break;
                                wei=0;
                                s0=0;s1=0;s2=0;s3=0;s4=0;s5=0;
                                //P1=0x55;
                        if(dengyu)
                                 dengyu=0;
                                 //display(16,16,16,16,16,16);
                                 switch(wei)
                                        case 6:
                                        hou=s5*100000+s4*10000+s3*1000+s2*100+s1*10+s0;break;
                                        case 5:
                                        hou=s5*10000+s4*1000+s3*100+s2*10+s1;break;
                                        case 4:
                                        hou=s5*1000+s4*100+s3*10+s2;break;
                                        case 3:
                                        hou=s5*100+s4*10+s3;break;
                                        case 2:
                                        hou=s5*10+s4;break;
                                        case 1:
                                        hou=s5;break;
                                wei=0;
                                 if(jia0)
                                 {jia0=0;        hou=qian+hou;}
                                 if(jian0)
                                 {jian0=0;        hou=qian-hou;}
                                 if(cheng0)
                                 {cheng0=0;        hou=qian*hou;}
                                 if(chu0)
                                 {chu0=0;        hou=qian/hou;}
                                 if(hou<10)
                                         a0=hou;b0=16;c0=16;d0=16;e0=16;f0=16;
                                         if(hou<100)
                                        {a0=hou/10;b0=hou%10;c0=16;d0=16;e0=16;f0=16;}
                                                if(hou<1000)
                                                {a0=hou/100;b0=hou%100/10;c0=hou%10;d0=16;e0=16;f0=16;}
                                                        if(hou<10000)
                                                        {a0=hou/1000;b0=hou%1000/100;c0=hou%100/10;d0=hou%10;e0=16;f0=16;}
        if(hou<100000)
        {a0=hou/10000;b0=hou%10000/1000;c0=hou%1000/100;d0=hou%100/10;e0=hou%10;f0=16;}
        if(hou<1000000)
        {a0=hou/100000;b0=hou%100000/10000;c0=hou%10000/1000;d0=hou%1000/100;e0=hou%100/10;f0=hou%10;}
                                 P1=hou;
                        if(qingling)
                                a0=16;b0=16;c0=16;d0=16;e0=16;f0=16;
                                jia=0;jian=0;cheng=0;chu=0;
                                jia0=0;jian0=0;cheng0=0;chu0=0;
                                qingling=0;dengyu=0;
                                qian=0;hou=0;
ID:354047 發(fā)表于 2018-6-20 19:31 來自手機 | 只看該作者
樓主你這是89c52的還是15系列的
