stm32智能小車
- #include "pwm_output.h"
- * 函數(shù)名:TIM3_GPIO_Config
- * 描述 :配置TIM3復用輸出PWM時用到的I/O
- * 輸入 :無
- * 輸出 :無
- * 調(diào)用 :內(nèi)部調(diào)用
- static void TIM3_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* TIM3 clock enable */
- //PCLK1經(jīng)過2倍頻后作為TIM3的時鐘源等于72MHz
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1|RCC_APB2Periph_GPIOA, ENABLE);
- /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 復用推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- * 函數(shù)名:TIM3_Mode_Config
- * 描述 :配置TIM3輸出的PWM信號的模式,如周期、極性、占空比
- * 輸入 :無
- * 輸出 :無
- static void TIM3_Mode_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* PWM信號電平跳變值 */
- u16 CCR1_Val = 1001;
- u16 CCR2_Val = 1001;
- u16 CCR3_Val = 1001;
- u16 CCR4_Val = 1001;
- TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
- TIM3CLK = 72 MHz, Prescaler = 0x0, TIM3 counter clock = 72 MHz
- TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
- TIM3 Frequency = 72 KHz.
- TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
- TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
- TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
- TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 19999; //當定時器從0計數(shù)到999,即為1000次,為一個定時周期
- TIM_TimeBaseStructure.TIM_Prescaler = 71; //設置預分頻:不預分頻,即為72MHz
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ; //設置時鐘分頻系數(shù):不分頻
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計數(shù)模式
- TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置為PWM模式1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //設置跳變值,當計數(shù)器計數(shù)到這個值時,電平發(fā)生跳變
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //當定時器計數(shù)值小于CCR1_Val時為高電平
- TIM_OC1Init(TIM1, &TIM_OCInitStructure); //使能通道1
- TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.TIM_Pulse = CCR2_Val; //設置通道2的電平跳變值,輸出另外一個占空比的PWM
- TIM_OC2Init(TIM1, &TIM_OCInitStructure); //使能通道2
- TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel3 */
- TIM_OCInitStructure.TIM_Pulse = CCR3_Val; //設置通道3的電平跳變值,輸出另外一個占空比的PWM
- TIM_OC3Init(TIM1, &TIM_OCInitStructure); //使能通道3
- TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel4 */
- TIM_OCInitStructure.TIM_Pulse = CCR4_Val; //設置通道4的電平跳變值,輸出另外一個占空比的PWM
- TIM_OC4Init(TIM1, &TIM_OCInitStructure); //使能通道4
- TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(TIM1, ENABLE); // 使能TIM3重載寄存器ARR
- /* TIM3 enable counter */
- TIM_Cmd(TIM1, ENABLE); //使能定時器3
- * 函數(shù)名:TIM3_PWM_Init
- * 描述 :TIM3 輸出PWM信號初始化,只要調(diào)用這個函數(shù)
- * TIM3的四個通道就會有PWM信號輸出
- * 輸入 :無
- * 輸出 :無
- * 調(diào)用 :外部調(diào)用
- void TIM3_PWM_Init(void)
- TIM3_GPIO_Config();
- TIM3_Mode_Config();
- void TIM3_OUT( u16 CCR1 , u16 CCR2 , u16 CCR3 , u16 CCR4 )
- /* PWM信號電平跳變值 */
- u16 CCR1_Val;
- u16 CCR2_Val;
- u16 CCR3_Val;
- u16 CCR4_Val;
- CCR1_Val=CCR1;
- CCR2_Val=CCR2;
- CCR3_Val=CCR3;
- CCR4_Val=CCR4;
- TIM_OCInitStructure.TIM_Pulse = CCR1; //設置跳變值,當計數(shù)器計數(shù)到這個值時,電平發(fā)生跳變
- TIM_OCInitStructure.TIM_Pulse = CCR2; //設置通道2的電平跳變值,輸出另外一個占空比的PWM
- TIM_OCInitStructure.TIM_Pulse = CCR3; //設置通道3的電平跳變值,輸出另外一個占空比的PWM
- TIM_OCInitStructure.TIM_Pulse = CCR4; //設置通道4的電平跳變值,輸出另外一個占空比的PWM
- /******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
復制代碼
Keil workspace.rar
2018-6-20 05:21 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
410.31 KB, 下載次數(shù): 14, 下載積分: 黑幣 -5
智能小車
