查看: 4255|回復(fù): 3
求一份基于stc12c5204ad的sht30的c51驅(qū)動(dòng)程序
ID:352616 發(fā)表于 2018-6-18 09:34 | 顯示全部樓層 |閱讀模式
25黑幣
沒(méi)有多余描述,設(shè)計(jì),感覺(jué)有點(diǎn)難
最佳答案
查看完整內(nèi)容
#include sbit SDA=P2^1; sbit SCL=P2^2; sbit lcden=P2^7; sbit lcdrs=P2^6; unsigned char a,b,c,d,z1,z2,z3,z4,z5,flag,e; unsigned int number,sensor; int time,second,key; void nop() { unsigned int TempCyc = 22; while(TempCyc--) ; } unsigned char code table[]="Temperature:"; unsigned char code table1[]="Humidity:"; unsigned char num,adc; void delay(unsign ...
ID:134271 發(fā)表于 2018-6-18 09:34 | 顯示全部樓層
#include<reg51.h>
sbit SDA=P2^1;
sbit SCL=P2^2;
sbit lcden=P2^7;
sbit lcdrs=P2^6;
void nop()
    while(TempCyc--)  ;
void delay(unsigned int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y<110;y>0;y--);
void write_com(unsigned char com)
{  delay(5);
lcdrs=0;
P0=com;
delay(5);
lcden=1;
  delay(5);
lcden=0;
void write_data(unsigned char date)
{     delay(5);
lcdrs=1;
P0=date;
delay(5);
lcden=1;
  delay(5);
lcden=0;
void init()
lcden=0;
write_com(0x38);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
void init1()
{SCL=1;
nop();
SDA=1;
nop();
void start()
SDA=1;
nop();
SCL=1;
nop();
SDA=0;
nop();
SCL=0;
nop();
void respons()
unsigned char g=0;
SCL=1;
nop();
while((SDA==1)&&(g<255))
g++    ;
SCL=0;
nop();
void stop()
{SDA=0;
nop();
SCL=0;
nop();
SCL=1;
nop();
SDA=1;
nop();
void write_byte(unsigned char date)
unsigned char g,temp;
temp=date;
for(g=0;g<8;g++)
temp=temp<<1;
SCL=0;
nop();
SDA=CY;
nop();
SCL=1;
nop();
SCL=0;
nop();
SDA=1;
nop();
void cpuack()
{SDA=0;
nop();
SCL=1;
nop();
SCL=0;
nop();
unsigned char read_byte()
unsigned char g,k;
SCL=0;
nop();
SDA=1;
for(g=0;g<8;g++)
SCL=1;
nop();
k=(k<<1)|SDA;
SCL=0;
nop();
nop();
return k;
         main()
        init();
for(;;)
  write_com(0x80);
  for(num=0;num<12;num++)
  write_data(table[num]) ;
  delay(5);
     write_data(c+48) ;
  delay(5);
   write_data(d+48) ;
  delay(5);
   write_data(46) ;
  delay(5);
   write_data(e+48) ;
  delay(5);
   write_com(0x80+0x40);
  for(adc=0;adc<9;adc++)
   write_data(table1[adc]);
   delay(5);
   write_data(a+48) ;
  delay(5);
  write_data(b+48) ;
  delay(5);
  write_data(37) ;
  delay(5);
              init1();
            start();
            write_byte(0x88);
            respons();
            write_byte(0x24);
            respons();
            write_byte(0x16);
            respons();
            stop();
            nop();
            start();
            write_byte(0x89);
            respons();
            nop();
            nop();
            if(SCL==0)
            z2=read_byte();
            cpuack() ;
            z3=read_byte();
            cpuack() ;
            read_byte();
            cpuack()    ;
            z4=read_byte();
            cpuack();
            z5=read_byte();
            cpuack() ;
            read_byte();
            stop();
            number=256*z2+z3;
            sensor=256*z4+z5;
                number=(number/37.5)-450    ;
                sensor=sensor/656;
             a=sensor/10;
             b=sensor%10 ;
      c=(number%1000)/100;
      d=(number%100)/10;
      e=number%10;
ID:352616 發(fā)表于 2018-11-21 20:05 | 顯示全部樓層
謝謝大哥
ID:824719 發(fā)表于 2020-10-23 13:38 | 顯示全部樓層
number=256*z2+z3;
            sensor=256*z4+z5;
                sensor=sensor/656;
能不能解釋一下這幾行代碼
