查看: 3085|回復(fù): 1
單片機制作音頻分貝測試的程序?
ID:269260 發(fā)表于 2018-6-20 11:50 | 顯示全部樓層 |閱讀模式
本帖最后由 wdsg 于 2018-6-20 11:52 編輯
程序:#include <reg52.h>
unsigned long int fre;
unsigned char time;
unsigned int count;
unsigned int count1;
sbit   LCD_RS=P1^0;          //片選信號
sbit   LCD_RW=P1^1;          //讀寫信號
sbit   LCD_E=P1^2;           //使能信號
#define LCD_DB  P0        //數(shù)據(jù)信號
unsigned char character[10]={0};//在屏幕上顯示的字符串
unsigned char character_1[]={"fre= Hz"};
unsigned char FLAG = 0;  //是否分頻選擇標(biāo)志
void LCD_init(void);//初始化函數(shù)
void LCD_write_command(unsigned char command);//寫指令函數(shù)
void LCD_write_data(unsigned char dat);//寫數(shù)據(jù)函數(shù)
void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat);//在某個屏幕位置上顯示一個字符,X(0-15),y(1-2)
void delay_n40us(unsigned int n);//延時函數(shù)
void timer_init();            //中斷初始化函數(shù)
//-----------------------------延時函數(shù)---------------------------
void delay_n40us(unsigned int n)                  //延時函數(shù)
        unsigned int i;
        unsigned char j;
        for(i=n;i>0;i--)
        for(j=0;j<2;j++);
void delay_1s()
        unsigned int i,j;
        for(i = 0;i<100;i++)
                for(j = 0;j<1000;j++);
//---------------------lcd1602液晶顯示函數(shù)--------------------
void LCD_init(void)         //液晶初始化函數(shù)
        LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
        LCD_write_command(0x0c);//整體顯示,關(guān)光標(biāo),不閃爍
        LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
        LCD_write_command(0x01);//清除屏幕顯示
        delay_n40us(100);//清屏延時
void LCD_write_command(unsigned char dat)  //寫命令函數(shù)
        LCD_DB=dat;
        LCD_RS=0;//指令
        LCD_RW=0;//寫入
        LCD_E=1; //使能
        LCD_E=0;
        delay_n40us(1);//寫命令延時
void LCD_write_data(unsigned char dat)          //寫數(shù)據(jù)函數(shù)
        LCD_DB=dat;
        LCD_RS=1;//數(shù)據(jù)
        LCD_RW=0;//寫入
        LCD_E=1;//使能
        LCD_E=0;
        delay_n40us(1);         //寫數(shù)據(jù)延時
void LCD_disp_char(unsigned char x,unsigned char y,unsigned char dat)//顯示一個字符
        unsigned char address;
        if(y==1)
                 address=0x80+x;         //顯示在第一排的時候的x的地址
                 address=0xc0+x;         //顯示在第二排的時候的x的地址
        LCD_write_command(address);         //輸入地址
        LCD_write_data(dat);                 //輸入數(shù)據(jù)
void LCD_disp_num(unsigned char x,unsigned char y,unsigned char dat)//顯示一個數(shù)字
        if(y==1)
        LCD_write_data(dat+48);                 //輸入數(shù)據(jù)
void dis_num(void)
        unsigned char i=0,j=0,k=0;
        character[0] = fre/10000000;
        character[1] = fre/1000000%10;
        character[2] = fre/100000%10;
        character[3] = fre/10000%10;
        character[4] = fre/1000%10;
        character[5] = fre/100%10;
        character[6] = fre/10%10;
        character[7] = fre%10;
    character[8] = 'H';
        character[9] = 'z';
        for(i = 0;i<4;i++)                 //顯示“fre=”
                 LCD_disp_char(i+0,1,character_1);
        for(i = 0;i<10;i++)         //判斷第一個不為0的數(shù)
                if(character!=0)
                        break;
        k = 8-i;
        for(j = 0;j<k;j++)         //顯示所有的數(shù)字
                        LCD_disp_num(4+j,1,character[i++]);
    for(i = 5;i<7;i++)         //顯示“Hz”
                 LCD_disp_char(j+4,1,character_1);
                j++;
//----------------主函數(shù)--------------------
        unsigned char i;
        LCD_init();
        timer_init();             //定時/計數(shù)器初始化
        for(i = 0;i<4;i++)
                dis_num();         //顯示
                delay_1s();
//-------------------定時/計數(shù)器初始化--------------
void timer_init(void)         //定時/計數(shù)器初始化
        TMOD=0x66;                //計數(shù)器0和計數(shù)器1工作工作方式2,自動重裝初值
        TH0=0;                    //計數(shù)器初值為0
        TL0=0;
        TR0=1;                    //計數(shù)器開始計數(shù)
        ET0=1;                    //打開計數(shù)器0中斷
        TH1=0;                    //計數(shù)器初值為0
        TL1=0;
        TR1=1;                    //計數(shù)器開始計數(shù)
        ET1=1;                    //打開計數(shù)器1中斷
        RCAP2H=(65536-62500)/256; //在程序初始化的時候給RCAP2L和RCAP2H賦值,
        RCAP2L=(65536-62500)%256; //TH2和TL2將會在中斷產(chǎn)生時自動使TH2=RCAP2H,TL2=RCAP2L。
        TH2=RCAP2H;               //12M晶振下每次中斷62.5ms(1s=1000ms=62.5ms×16)
        TL2=RCAP2L;
        ET2=1;                    //打開定時器2中斷
        TR2=1;                    //定時器2開始計時
        EA=1;                     //開總中斷
//------------------中斷函數(shù)----------------------
void timer2(void) interrupt 5 //定時器2中斷(62.5ms)
        time++;
        TF2=0;                    //定時器2的中斷標(biāo)志位TF2不能夠由硬件清零,所以要在中斷服務(wù)程序中將其清零
        if (time==16)             //定時1s時間到
           time=0;                //計時清0
           EA=0;                  //關(guān)中斷
           fre=(long)count1*256+TL1;     //count*256強制轉(zhuǎn)換成long型,否則將不產(chǎn)生進(jìn)位~先判斷分頻后(計數(shù)器1)
           FLAG = 0;
           if(fre<2000)//如果不到200KHz則讀取分頻前(計數(shù)器0)頻率(200K÷100=2000)
                           fre = (long)count*256+TL0;
                        FLAG = 1;
                if(!FLAG)
                        fre = fre *100;//100分頻
           TL0=0;                 //清零計數(shù)器0計數(shù)
           TH0=0;
           TL1=0;
           TH1=0;
           count=0;               //清零計數(shù)器0計數(shù)
           count1=0;
           EA=1;                  //開中斷
void timer0(void) interrupt 1 //計數(shù)器0中斷(100分頻前)
        count++;
void timer1(void) interrupt 3 //計數(shù)器1中斷(100分頻后)
        count1++;
參與人數(shù) 1黑幣 +2 收起 理由
云走殘陽 + 2
ID:355221 發(fā)表于 2018-6-20 15:50 | 顯示全部樓層
LCD與數(shù)碼管完全不同。
