實(shí)驗(yàn):仿真開始時(shí),數(shù)碼管不顯示,順序按下矩陣鍵盤后,在數(shù)碼管上依次顯示0~F,6個(gè)數(shù)碼管同時(shí)靜態(tài)顯示。
keilc程序
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar num,temp,key;
uint i,j;
void delayms(uint x)
for(i=x;i>0;i--)
for(j=110;j>0;j--);
void display(uchar num)
dula=1;
P0=table[num];
dula=0;
void matrixkeyscan()
uchar temp,key;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0) //檢測(cè)是否真的按下了
temp=P3;
switch(temp)
case 0xee:
key=0;
break;
case 0xde:
key=1;
break;
case 0xbe:
key=2;
break;
case 0x7e:
key=3;
break;
while (temp!=0xf0) //等待按鍵釋放 或確認(rèn)釋放
temp=P3;
temp=temp&0xf0;
display(key);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:
key=4;
break;
case 0xdd:
key=5;
break;
case 0xbd:
key=6;
break;
case 0x7d:
key=7;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:
key=8;
break;
case 0xdb:
key=9;
break;
case 0xbb:
key=10;
break;
case 0x7b:
key=11;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delayms(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:
key=12;
break;
case 0xd7:
key=13;
break;
case 0xb7:
key=14;
break;
case 0x77:
key=15;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
P0=0;
dula=1;
dula=0;
P0=0xc0;
wela=1;
wela=0;
matrixkeyscan();
附仿真圖
