查看: 2165|回復(fù): 2
為什么這樣寫12864顯示不正常,從第二行開始就錯位
ID:356940 發(fā)表于 2018-6-23 19:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
sbit rs=P2^2;
sbit rw=P2^1;
sbit e=P2^0;
sbit cs1=P2^4;
sbit cs2=P2^3;
uchar i;
const char code table[] = {
/* GB2312 16x16點陣字庫*/
/* 字串 我你它他她塔呀有  128x16  */
/* 的[0xB5C4]   16x16 */
/* 我[0xCED2]   16x16 */
0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0xFF,0x20,0x22,0xAC,0x20,0x30,0x20,0x00,
0x00,0x08,0x48,0x84,0x7F,0x02,0x21,0x10,0x09,0x06,0x1A,0x61,0x80,0xE0,0x00,0x00,
/* 愛[0xB0AE]   16x16 */
0x40,0xB0,0x92,0x96,0x9A,0x92,0xF2,0x9E,0x92,0x91,0x99,0x95,0x91,0x50,0x30,0x00,
0x00,0x00,0x40,0x30,0x8C,0x83,0x46,0x2A,0x12,0x2A,0x26,0x42,0xC0,0x40,0x00,0x00,
/* 你[0xC4E3]   16x16 */
0x40,0x20,0xF8,0x07,0x40,0x20,0x18,0x0F,0x08,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
0x00,0x00,0xFF,0x00,0x00,0x08,0x04,0x43,0x80,0x7F,0x00,0x01,0x06,0x0C,0x00,0x00,
/* 它[0xCBFC]   16x16 */
0x10,0x0C,0x04,0x04,0xE4,0x04,0x05,0x06,0x04,0x84,0xC4,0x04,0x04,0x14,0x0C,0x00,
0x00,0x00,0x00,0x00,0x3F,0x42,0x42,0x41,0x41,0x40,0x40,0x40,0x70,0x00,0x00,0x00,
/* 他[0xCBFB]   16x16 */
0x80,0x40,0x20,0xF8,0x87,0x80,0xF0,0x40,0x40,0xFF,0x20,0x20,0xF0,0x20,0x00,0x00,
0x00,0x00,0x00,0xFF,0x00,0x00,0x3F,0x40,0x40,0x5F,0x42,0x44,0x43,0x40,0x70,0x00,
/* 哦[0xC5B6]   16x16 */
0x00,0xFC,0x04,0x04,0xFE,0x24,0x24,0xFC,0x22,0x20,0xFF,0x22,0x24,0x30,0x20,0x00,
0x00,0x3F,0x10,0x10,0x1F,0x44,0x84,0x7F,0x42,0x22,0x11,0x1E,0x64,0x82,0xE0,0x00,
/* 奧[0xB0C2]   16x16 */
0x00,0x00,0x00,0xFC,0x44,0x56,0x45,0xFC,0x44,0x54,0x44,0xFE,0x04,0x00,0x00,0x00,
0x08,0x88,0x88,0x4B,0x48,0x29,0x18,0x0F,0x18,0x29,0x28,0x4B,0xC8,0x4C,0x08,0x00
const char code table1[] = {
0x00,0x10,0xF0,0x30,0xF0,0xC0,0x00,0x00,
0x00,0x00,0xC0,0x20,0xF0,0xF0,0x10,0x00,
0x80,0x80,0xFF,0x80,0x80,0x07,0x1E,0xF8,
0x18,0x06,0x01,0x80,0xFF,0xFF,0x80,0x00,  //32
0x00,0x00,0x10,0xF0,0xF0,0x10,0x10,0x10,
0x10,0x20,0x60,0xC0,0x80,0x00,0x00,0x00,
0x00,0x80,0x80,0xFF,0xFF,0x80,0x80,0x80,
0x80,0x40,0x60,0x3F,0x1F,0x02,0x00,0x00,
0x00,0x00,0x00,0x80,0xC0,0x20,0x10,0x10,
0x10,0x10,0x20,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x3F,0x7F,0x60,0xC0,0x80,
0x80,0x80,0x40,0x41,0x20,0x00,0x00,0x00,
0x80,0x80,0x40,0x41,0x20,0x00,0x00,0x00    //256
const char code table2[] = {
const char code table3[] = {
void delay(uint x)
  uchar i;
  while(x--)
  for(i=0;i<110;i++);
void com(uchar com)
  rs=0;
  rw=0;
  P0=com;
  delay(5);
  e=1;
  delay(5);
  e=0;
void date(uchar date)
  rs=1;
  rw=0;
  P0=date;
  delay(5);
  e=1;
  delay(5);
  e=0;
void chushihua()
  com(0x30);                 //初始化
  delay(5);
  com(0x0c);                                 //顯示開關(guān)設(shè)置 0000 1DCB
  delay(5);                  //D=1整體顯示開 C=1游標(biāo)顯示開 B=1游標(biāo)位置顯示反白開
  com(0x01);                 //清屏指令
  delay(5);
void weizhi(uchar hang,uchar lie)
{  hang=hang & 0x07;
   hang=hang | 0xb8;   //1011 1xxx 上半部分行
   com(hang);
   hang=hang & 0x3f;
   lie = lie | 0x40;   //01xx xxxx 上半部分列
   com(lie);
/*顯示1*/
void disp1()
  uchar j,k;
  uchar h,l;
  h=0;l=0;
  j=0;k=16;
  while(l<49)
   cs1=0;
   cs2=1;
  weizhi(h,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+1,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
  l=0;
  j=128;k=144;
  while(l<49)
   cs1=1;
   cs2=0;
  weizhi(h,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+1,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
/*顯示2*/
void disp2()
  uchar j,k;
  uchar h,l;
  h=0;l=0;
  j=0;k=16;
  while(l<49)
   cs1=0;
   cs2=1;
  weizhi(h+2,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+3,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
  l=0;
  j=128;k=144;
  while(l<49)
   cs1=1;
   cs2=0;
  weizhi(h+2,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+3,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
/*顯示3*/
void disp3()
  uchar j,k;
  uchar h,l;
  h=0;l=0;
  j=0;k=16;
  while(l<49)
   cs1=0;
   cs2=1;
  weizhi(h+4,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+5,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
  l=0;
  j=128;k=144;
  while(l<49)
   cs1=1;
   cs2=0;
  weizhi(h+4,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+5,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
/*顯示4*/
void disp4()
  uchar j,k;
  uchar h,l;
  h=0;l=0;
  j=0;k=16;
  while(l<49)
   cs1=0;
   cs2=1;
  weizhi(h+6,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+7,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
  l=0;
  j=128;k=144;
  while(l<49)
   cs1=1;
   cs2=0;
  weizhi(h+6,l);
  for(i=j;i<k;i++)
  date(table[i]);
  weizhi(h+7,l);
  for(i=k;i<k+16;i++)
  date(table[i]);
  j=j+32;
  k=k+32;
  l=l+16;
           chushihua();
    disp1();
        delay(5);
        chushihua();
        disp2();
        delay(5);
        chushihua();
        disp3();
        delay(5);
        chushihua();
        disp4();
        delay(5);
    while(1);
ID:356940 發(fā)表于 2018-6-24 09:28 | 只看該作者
解決了解決了,把uchar改成int 就行了,因為uchar只能存儲128單位,不夠,會溢出,所以用int就可以了
ID:356940 發(fā)表于 2018-6-24 09:30 | 只看該作者
解決了,將uchar改成int 就可以顯示全屏幕了
