#include<reg52.h>
uchar code table[]=".. Play ball! ..";
uchar code table1[]="!!GO GO GO!!" ;
sbit key_ST=P1^5; //功能鍵(開始/暫停)
sbit key_A1=P1^0; //功能鍵(A隊(duì)分?jǐn)?shù)加1)
sbit key_A2=P1^3; //功能鍵(A隊(duì)分?jǐn)?shù)加2)
sbit key_1A=P1^6; //功能鍵(A隊(duì)分?jǐn)?shù)減1)
sbit key_B1=P1^1; //功能鍵(B隊(duì)分?jǐn)?shù)加1)
sbit key_B2=P1^4; //功能鍵(B隊(duì)分?jǐn)?shù)加2)
sbit key_1B=P1^7; //功能鍵(B隊(duì)分?jǐn)?shù)減1)
sbit key_EX=P1^2; //功能鍵(交換場(chǎng)地,A/B兩隊(duì)分?jǐn)?shù)交換)
sbit key_JS=P3^0; //功能鍵(比賽節(jié)數(shù)加1)
sbit lcdrs=P3^5; //LCD顯示的數(shù)據(jù)/命令選擇端
sbit lcden=P3^4; //LCD顯示的使能信號(hào)
uchar flag,ms,mg,ss,sg,ags,agg,bgs,bgg,num,num2,js=1,C,D,t,min=0;
int sec=12;
void delayms(uint xms) //定義延時(shí)函數(shù)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void write_data(uchar date) //定義為數(shù)據(jù)模式
lcdrs=1; //清屏
P0=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void write_com(uchar com) //定義為命令模式
lcdrs=0; //RS=0 寫命令
P0=com;
delayms(5);
lcden=1; //E=1
delayms(5);
lcden=0; //E=0 當(dāng)E由1變0時(shí)LCD執(zhí)行命令
void lcd_init() //LCD顯示屏的初始化
lcden=0; //E=0
write_com(0x38); //00111000兩行顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
write_com(0x0c); //00001100開整體顯示,光標(biāo)關(guān),無閃爍
write_com(0x06); //00000110寫入1個(gè)字符后,地址指針加一
write_com(0x01); //00000001清屏
void init() //LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
lcden=0; //E=0
write_com(0x82); //在02位置輸出
write_data('T');
write_data('-');
write_com(0x8a);
write_data('Q');
write_data('-');
write_com(0x80+0x43);
write_data('A');
write_data(':');
write_com(0x80+0x49);
write_data('B');
write_data(':');
void init_start()
lcden=0; //E=0
write_com(0x80+0x10); //在第一行10位置顯示
for(num2=0;num2<16;num2++) //寫第二行字
write_data(table1[num2]);
delayms(5);
write_com(0x80+0x50); //在第一行50位置輸出
for(num2=0;num2<17;num2++)
write_data(table[num2]); //輸出第一行
delayms(5);
write_com(0x1c); //00011100移動(dòng)顯示的字符
delayms(400);
void display(uchar min,int sec,uchar C,uchar D,uchar js) //顯示函數(shù),顯示分,秒,節(jié)數(shù)
ss=sec/10; //秒的十位
sg=sec%10; //秒的各位
ms=min/10; //分的十位
mg=min%10; //分的各位
ags=C/10; //A隊(duì)分?jǐn)?shù)的十位
agg=C%10; //A隊(duì)分?jǐn)?shù)的各位
bgs=D/10; //B對(duì)分?jǐn)?shù)的十位
bgg=D%10; //B隊(duì)分?jǐn)?shù)的各位
write_com(0x84); //在04位置輸出
write_data(0x30+ms); // LCD1602只能識(shí)別ASCII碼數(shù)據(jù),所以需要把數(shù)據(jù)先轉(zhuǎn)換成其對(duì)應(yīng)的ASCII碼,才能正確顯示 ...
//因?yàn)?X30是數(shù)字0的ASCII碼,當(dāng)要顯示顯示數(shù)字時(shí),必須要加上這個(gè)數(shù),不過還可以這樣寫:write_data(‘0’+h)
write_data(0x30+mg);
write_data(':');
write_data(0x30+ss);
write_data(0x30+sg);
write_com(0x8c); //在0c位置輸出
write_data(0x30+js);
write_com(0x80+0x45);
write_data(0x30+ags);
write_data(0x30+agg);
write_com(0x80+0x4b);
write_data(0x30+bgs);
write_data(0x30+bgg);
TMOD=0x01; //定義定時(shí)器0的工作方式為0001
TH0=(65536-45872)/256; //裝初值50ms
TL0=(65536-45872)%256;
EA=1; //打開總中斷
ET0=1; //打開定時(shí)器0的中斷
TR0=0; //暫停計(jì)時(shí)
lcd_init();
init_start();
if(key_ST==0)
delayms(5);
if(key_ST==0)
if(flag==0)
lcd_init(); //清屏設(shè)置屬性
init(); //顯示“T-”、“Q-”、“A:”、“B:”
flag=1;
TR0=~TR0;
while(!key_ST)
display(min,sec,C,D,js);
if(key_A1==0)
delayms(5);
if(key_A1==0)
C++;
while(!key_A1)
if(key_A2==0)
delayms(5);
if(key_A2==0)
C+=2;
while(!key_A2)
if(key_1A==0)
delayms(5);
if(key_1A==0)
C--;
while(!key_1A)
if(key_B1==0)
delayms(5);
if(key_B1==0)
D++;
while(!key_B1)
if(key_B2==0)
delayms(5);
if(key_B2==0)
D+=2;
while(!key_B2)
if(key_1B==0)
delayms(5);
if(key_1B==0)
D--;
while(!key_1B)
while(min==0&&sec==0)
TR0=0; //定時(shí)器0暫停
if(key_ST==0)
delayms(5);
if(key_ST==0)
min=11;
sec=60;
TR0=~TR0;
while(!key_ST) //等于0進(jìn)行
if((key_EX==0)&&(js==2))
delayms(10);
if((key_EX==0)&&(js=2))
write_data('B');
write_data('A');
t=C;
C=D;
D=t;
while(!key_EX)
if(key_JS==0)
delayms(10);
if(key_JS==0)
js++;
while(!key_JS)
void T0_time()interrupt 1 //定時(shí)器0控制晶碼管顯示時(shí)間
TH0=(65536-45872)/256; // 重裝初值
num++;
if(num==20)
num=0;
sec--;
if(sec<0)
sec=59;
min--;
