- #include <reg52.h>
- #include<intrins.h>
- #define TH0HIGH 0xe1
- #define TL0LOWW 0xa7
- #define LOW 0
- #define HIGH 1
- #define DIS_DAT P0
- #define DIS_POS P2 //數(shù)碼管只用到低四位
- #define NOP() _nop_()
- #define false 0
- #define FALSE 0
- #define true 1
- #define TRUE 1
- #define uint unsigned int
- extern unsigned char idata flag; //定義外部變量,溫度正負(fù)標(biāo)志
- uint HNum = 50,LNum = 10; //報警溫度的高低值
- uint Tem;
- void delay_16us();
- void SetLowTem();
- void SetHighTem();
- void initalarm();
- void alarm();
- void delay_ms(uint timer);
- typedef unsigned char u8;
- typedef unsigned int u16;
- typedef unsigned long u32;
- typedef signed char s8;
- typedef signed int s16;
- typedef signed long s32;
- typedef bit BOOL;
- void delay_16us(u16 us);
- void init_various(void);
- void dynamic_display(void);
- float set_temp_data(void);
- u8 ds18b20_reset(void);
- void ds18b20_write_byte(u8 wByte);
- u8 ds18b20_read_byte(void);
- u16 ds18b20_get_temp(void);
- BOOL b10msEvent;
- BOOL b500msEvent;
- sbit k1 = P3^0;
- sbit k2 = P3^1;
- sbit k3 = P3^2;
- sbit k4 = P3^3;
- sbit led1 = P1^0;
- sbit led2 = P1^1;
- sbit led3 = P1^2;
- sbit buzzer = P3^7;
- sbit DQ_PIN = P3^6;//管腳定義
- code u8 float_tab[16] = {0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};//小數(shù)表
- code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff, 0xbf};
- u8 DisNum[4] = {0x0a, 0x0a, 0x00, 0x00};
- u8 DisPosition = 0;
- void delay_16us(u16 us) //(14 + 16 * us) 微秒
- while(--us);
- void init_c51(void)
- TMOD = 0x01;
- TH0 = TH0HIGH;
- TL0 = TL0LOWW;
- ET0 = 1;
- TR0 = 1;
- EA = 0;
- init_c51();
- ds18b20_reset();
- ds18b20_get_temp();
- EA = 1;
- static u8 DisPinOn = 0x01;
- DisPinOn <<= 1;//DisPinON位選
- if(DisPinOn == 0x10)
- DisPosition = 0;
- DisPinOn = 0x01;
- DIS_DAT = 0xff;
- DIS_POS = DisPinOn;
- DIS_DAT = DisCode[DisNum[DisPosition++]];
- if(DisPinOn == 0x04)
- DIS_DAT &= 0x7f;
- void SetHighTem()//函 數(shù):設(shè)置高溫溫度報警值函數(shù)
- HNum = 50;
- if(k1 == 0) //按鍵消抖
- delay_ms(10);
- if(k1 == 0)
- { while(!k1); //等待按鍵釋放
- while(1)
- dynamic_display();
- if(k1 == 0)
- delay_ms(50); //按鍵消抖
- if(k1 == 0)
- SetLowTem(); //設(shè)置低溫報警溫度
- break;
- if(k2 == 0)
- if(k2 == 0)
- { while(!k2); //等待按鍵釋放
- HNum++;
- if(k3 == 0)
- if(k3 == 0)
- { while(!k3); //等待按鍵釋放
- HNum--;
- if(k4 == 0)
- if(k4 == 0)
- { while(!k4); //等待按鍵釋放
- break;
- void SetLowTem()//函 數(shù):設(shè)置低溫溫度報警值函數(shù)
- while(1)
- if(k2 == 0)
- if(k2 == 0)
- LNum++;
- if(k3 == 0)
- if(k3 == 0)
- LNum--;
- if(k4 == 0)
- if(k4 == 0)
- break;
- u16 TempData;
- float Temp;
- u8 Negative;
- s8 i;
- float j;
- TempData = ds18b20_get_temp(); //度溫度數(shù)據(jù)
- /* 小于零 */
- if(TempData & 0xf000)
- TempData = ~TempData + 1;
- TempData &= 0x0fff;
- Negative = 1;
- /* 大于零 */
- else
- Negative = 0;
- Temp = (TempData >> 4) * 10; //溫度讀數(shù)乘以精度(0.0625),顯示小數(shù)點一位,所以乘以10
- j=Temp;
- Temp = Temp + float_tab[(TempData & 0x000f)] + 0.5; //加上小數(shù)部分,四舍五入所以加0.5
- TempData = Temp;
- for(i=3; i>=0; i--)//循環(huán)4次,分別顯示小,個,十,百
- DisNum[i] = TempData % 10;
- TempData /= 10;
- for(i=0; i<2; i++)
- if(DisNum[i] != 0)
- break;
- else
- DisNum[i] = 0x0a; //前面為0不顯示
- /* 顯示負(fù)號 */
- if(Negative == 1)
- for(i=2; i>=0; i--)
- if(DisNum[i] == 0x0a)
- DisNum[i] = 0x0b; //'-'
- break;
- return j;
- DQ_PIN = HIGH;
- delay_16us(1);
- DQ_PIN = LOW;
- delay_16us(30); //延時600us
- DQ_PIN = HIGH;
- delay_16us(5); //延時80us
- if(!DQ_PIN)
- delay_16us(30); //延時420us
- return 1;
- else
- return 0;
- u8 i;
- for(i=0; i<8; i++)
- DQ_PIN = LOW;
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- DQ_PIN = wByte & 0x01;
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- DQ_PIN = HIGH;
- NOP();
- NOP();
- NOP();
- wByte >>= 1;
- u8 rByte;
- u8 i;
- DQ_PIN = LOW;
- NOP();
- NOP();
- rByte >>= 1;
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- DQ_PIN = HIGH;
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- if(DQ_PIN)
- rByte |= 0x80;
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- NOP();
- DQ_PIN = HIGH;
- return rByte;
- u16 Temp;
- if(ds18b20_reset() == 0) //復(fù)位
- return 0;
- ds18b20_write_byte(0xcc); //忽略ROM
- ds18b20_write_byte(0x44); //發(fā)送溫度轉(zhuǎn)化命令
- delay_16us(30);
- if(ds18b20_reset() == 0) //再次復(fù)位
- return 0;
- ds18b20_write_byte(0xbe);
- Temp = ds18b20_read_byte();
- Temp |= ds18b20_read_byte() << 8;
- return Temp;
- void main()
- initalarm();
- init_various();
- while(1)
- alarm();
- SetHighTem();
- if(b10msEvent)
- b10msEvent = false;
- dynamic_display(); //顯示
- if(b500msEvent)
- b500msEvent = false;
- set_temp_data(); //讀溫度
- void timer0(void) interrupt 1
- static u8 SecCount = 0;
- TH0 = TH0HIGH;
- TL0 = TL0LOWW;
- b10msEvent = true; //10毫秒中斷
- if(++SecCount == 50)
- SecCount = 0;
- b500msEvent = true; //1秒到時
- uint i,j;
- for(i=0; i<timer; i++)
- for(j=0; j<110; j++);
- void initalarm()//led和蜂鳴器初始化
- led1 = 0;
- led2 = 0;
- led3 = 0;
- buzzer = 1;
- void alarm()//函 數(shù):led和蜂鳴器控制
- Tem = set_temp_data();
- if(Tem > HNum)
- led2 = 1;
- led1 = 0;
- led3 = 0;
- buzzer = 0; //蜂鳴器工作
- else if(Tem < LNum)
- led3 = 1;
- led1 = 0;
- led2 = 0;
- buzzer = 0;
- else
- led1 = 1;
- led2 = 0;
- led3 = 0;
- buzzer = 1;
