查看: 1929|回復(fù): 3
單片機溫度上下限的程序問題 速求大神解答!
ID:356928 發(fā)表于 2018-6-26 21:11 | 顯示全部樓層 |閱讀模式
QQ圖片20180626210250.png QQ圖片201806262101300.png 當(dāng)設(shè)置下限為負(fù)數(shù)時  從0一下就到8.5多   設(shè)置不成負(fù)數(shù)   求大神幫忙找一下錯誤  我完全是小白一個。程序如下
#include<reg51.h>
sbit d1=P2^2;
sbit d2=P2^1;
sbit d3=P2^0;
sbit d4=P2^3;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit beep=P3^3;
sbit DS=P1^2;
sbit ACC_7=ACC^7;
uint count=1000,alarm=300;
uchar shu;
uchar shi,fen,ri,yue,nian,xq,miao,ss;
uint temp;
uchar flag;
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90};
uchar code tab1[]={0x40,0x79,0x24,0x30,
0x19,0x12,0x02,0x78,0x00,0x10};
void delay(uint z)
              uint x,y;
              for(x=z;x>0;x--)
               for(y=120;y>0;y--);
void dsreset()
              uint i;
              DS=0;
              i=103;
              while(i>0)i--;
              DS=1;
              i=4;
              while(i>0)i--;
uchar tmpread()
              uchar j,k,dat;
              uint i;
    for(j=1;j<=8;j++)
                  DS=0;i++;
                  DS=1;i++;i++;
                   k=DS;
                  i=8;while(i>0)i--;
                            dat=(k<<7)|(dat>>1);
    return(dat);
void tmpwritebyte(uchar dat)
        uint i;
    uchar j;
    bit testb;
    for(j=1;j<=8;j++)
                  testb=dat&0x01;
                  dat=dat>>1;
                  if(testb)
           DS=0;
           i++;i++;
           DS=1;
           i=8;while(i>0)i--;
              DS=0;
              i=8;while(i>0)i--;
              DS=1;
              i++;i++;
void tmpchange()
              dsreset();
              delay(1);
              tmpwritebyte(0xcc);
              tmpwritebyte(0x44);
uint tmp()
              float tt;
              uchar a,b;
              dsreset();
              delay(1);
              tmpwritebyte(0xcc);
              tmpwritebyte(0xbe);
              a=tmpread();
              b=tmpread();
              temp=b;
              temp<<=8;
              temp=temp|a;
              if(b>127)
              flag=1;
              ss=flag;
              temp=~temp+1;
              tt=temp*0.0625;
              temp=tt*10+0.5;
              return(temp);
void displayTemp(uint temp)
              uchar ge,shi,bai,qian,ser;
              d1=0;
              d1=0;
              d3=0;
              d4=0;
              dsreset();
              ser=temp/10;
              SBUF=ser;
              qian=temp/1000;
              bai=temp/100%10;
              shi=temp/10%10;
              ge=temp%10;
              if(flag==1)
                            flag=0;
                            P0=0xbf;
                            d1=1;
                            delay(2);
                            d1=0;
              if(qian!=0)
                            P0=tab[qian];
                            d1=1;
                            delay(2);
                            d1=0;
                            P0=0xff;
                            d1=1;
                            delay(2);
                            d1=0;
              if(temp>99)
                  P0=tab[bai];
                  d2=1;
                  delay(2);
                  d2=0;
                   P0=tab1[shi];
                   d3=1;
                   delay(2);
                   d3=0;
                   P0=tab[ge];
                   d4=1;
                   delay(2);
                   d4=0;
uint keyscan()
     if(key1==0)
              delay(5);
              if(key1==0)
                        while(!key1);
                        shu++;
                   if(key2==0)
                          delay(5);
                          if(key2==0)
                                 while(!key2);
                                 count=count+10;
                                 if(shu==2)
                                       alarm+=10;
                       if(key3==0)
                       delay(5);
                       if(key3==0)
                              while(!key3);
                              count=count-10;
                              if(shu==2);
                                    alarm-=10;
              return(count);
             beep=0;
              delay(10);
              while( 1 )
              tmpchange();
              if(shu==0)
                  displayTemp(tmp( ));
              keyscan();
              if(shu==1)
                                          displayTemp(count);
              if(shu==2)
                                          displayTemp(alarm);
              if(shu==3)
                            shu=0;
              if(temp>count||(temp<alarm))
              beep=0;
              beep=1;
ID:356928 發(fā)表于 2018-6-26 21:18 | 顯示全部樓層
求大神直接改好  我能獎勵黑幣
ID:320306 發(fā)表于 2018-6-27 08:34 | 顯示全部樓層
論壇中很多18B20的程序,自己移植一下吧。。。。。。
ID:356928 發(fā)表于 2018-6-27 12:52 | 顯示全部樓層
zsyzdx 發(fā)表于 2018-6-27 08:34
論壇中很多18B20的程序,自己移植一下吧!。。。。。
不應(yīng)該是根據(jù)程序畫圖或者根據(jù)圖寫程序?
