基于51單片機(jī)的電子時(shí)鐘設(shè)計(jì) *** 山東工商學(xué)院 264005 摘 要:本文介紹了基于51單片機(jī)的電子時(shí)鐘的設(shè)計(jì),從硬件和軟件兩個(gè)方面給出了具體實(shí)現(xiàn)過(guò)程。該時(shí)鐘的設(shè)計(jì)采用功能分塊的思想方法,將硬件電路劃分為開(kāi)關(guān)電路,顯示驅(qū)動(dòng)電路和數(shù)碼管電路等若干獨(dú)立模塊,而軟件的實(shí)現(xiàn)則由鬧鐘的聲音程序、時(shí)間顯示程序、日期顯示程序,秒表顯示程序,時(shí)間調(diào)整程序、鬧鐘調(diào)整程序、定時(shí)調(diào)整程序,延時(shí)程序等組成。文中給出了各個(gè)模塊的電路圖,并用Proteus的ISIS軟件對(duì)電子時(shí)鐘系統(tǒng)的各個(gè)功能進(jìn)行了仿真,并給出了相應(yīng)的仿真結(jié)果圖像。 關(guān)鍵詞:單片機(jī);電子時(shí)鐘;鍵盤控制 Electronic Clock DesignBased on 51 Single-chip *** Shandong Institute of Business and Technology , 264005 Abstract: This paperintroduces the electronic clock design based on 51 single-chip microcomputer,and it provides us specific implementation process from aspects of hardware andsoftware. This clock is designed by the method of function blocks. In hardware,it’s circuit is divided into switch block, display drive block and digitalcontrol block. However, the software consist of the program of alarm clock,time display, date display, stopwatch display, time adjust, timing adjustment,the alarm clock adjustment, time delay and so on. Circuit diagrams of eachmodule is also given and the corresponding simulation image of this clock producedby software of Proteus is also showed in this paper. Key words: single chip microcomputer; electronic clock; Keyboard control 一, 引言 1957年,Ventura發(fā)明了世界上第一個(gè)電子表,從而奠定了電子時(shí)鐘的基礎(chǔ),電子時(shí)鐘開(kāi)始迅速發(fā)展起來(lái),F(xiàn)代的電子時(shí)鐘是基于單片機(jī)的一種計(jì)時(shí)工具,采用延時(shí)程序產(chǎn)生一定的時(shí)間中斷,用于一秒的定義,通過(guò)計(jì)數(shù)方式進(jìn)行滿六十秒分鐘進(jìn)一,滿六十分小時(shí)進(jìn)一,滿二十四小時(shí)小時(shí)清零。從而達(dá)到計(jì)時(shí)的功能,是人民日常生活補(bǔ)課缺少的工具,F(xiàn)在高精度的計(jì)時(shí)工具大多數(shù)都使用了石英晶體振蕩器,由于電子鐘、石英鐘、石英表都采用了石英技術(shù),因此走時(shí)精度高,穩(wěn)定性好,使用方便,不需要經(jīng)常調(diào)試,數(shù)字式電子鐘用集成電路計(jì)時(shí)時(shí),譯碼代替機(jī)械式傳動(dòng),用LED顯示器代替指針顯示進(jìn)而顯示時(shí)間,減小了計(jì)時(shí)誤差,這種表具有時(shí)、分、秒顯示時(shí)間的功能,還可以進(jìn)行時(shí)和分的校對(duì),片選的靈活性好。 二,時(shí)鐘的基本原理分析 利用單片機(jī)定時(shí)器完成計(jì)時(shí)功能,定時(shí)器0計(jì)時(shí)中斷程序每隔0.01s中斷一次并當(dāng)作一個(gè)計(jì)數(shù),設(shè)定定時(shí)1秒的中斷計(jì)數(shù)初值為100,每中斷一次中斷計(jì)數(shù)初值減1,當(dāng)減到0時(shí),則表示1s到了,秒變量加1,同理再判斷是否1min鐘到了,再判斷是否1h到了。 為了將時(shí)間在LED數(shù)碼管上顯示,可采用靜態(tài)顯示法和動(dòng)態(tài)顯示法,由于靜態(tài)顯示法需要譯碼器,數(shù)據(jù)鎖存器等較多硬件,可采用動(dòng)態(tài)顯示法實(shí)現(xiàn)LED顯示,通過(guò)對(duì)每位數(shù)碼管的依次掃描,使對(duì)應(yīng)數(shù)碼管亮,同時(shí)向該數(shù)碼管送對(duì)應(yīng)的字碼,使其顯示數(shù)字。由于數(shù)碼管掃描周期很短,由于人眼的視覺(jué)暫留效應(yīng),使數(shù)碼管看起來(lái)總是亮的,從而實(shí)現(xiàn)了各種顯示。 三,時(shí)鐘設(shè)計(jì)分析 針對(duì)要實(shí)現(xiàn)的功能,采用AT89S51單片機(jī)進(jìn)行設(shè)計(jì),AT89S51 單片機(jī)是一款低功耗,高性能CMOS8位單片機(jī),片內(nèi)含4KB在線可編程(ISP)的可反復(fù)擦寫1000次的Flash只讀程序存儲(chǔ)器,器件采用高密度、非易失性存儲(chǔ)技術(shù)制造,兼容標(biāo)準(zhǔn)MCS- 51指令系統(tǒng)及80C51引腳結(jié)構(gòu)。這樣,既能做到經(jīng)濟(jì)合理又能實(shí)現(xiàn)預(yù)期的功能。 在程序方面,采用分塊設(shè)計(jì)的方法,這樣既減小了編程難度、使程序易于理解,又能便于添加各項(xiàng)功能。程序可分為鬧鐘的聲音程序、時(shí)間顯示程序、日期顯示程序,秒表顯示程序,時(shí)間調(diào)整程序、鬧鐘調(diào)整程序、定時(shí)調(diào)整程序,延時(shí)程序等。運(yùn)用這種方法,關(guān)鍵在于各模塊的兼容和配合,若各模塊不匹配會(huì)出現(xiàn)意想不到的錯(cuò)誤。 首先,在編程之前必須了解硬件結(jié)構(gòu)尤其是各引腳的用法,以及內(nèi)部寄存器、存儲(chǔ)單元的用法,否則,編程無(wú)從下手,電路也無(wú)法設(shè)計(jì)。這是前期準(zhǔn)備工作。第二部分是硬件部分:依據(jù)想要的功能分塊設(shè)計(jì)設(shè)計(jì),比如輸入需要開(kāi)關(guān)電路,輸出需要顯示驅(qū)動(dòng)電路和數(shù)碼管電路等。第三部分是軟件部分:先學(xué)習(xí)理解匯編語(yǔ)言的編程方法再根據(jù)設(shè)計(jì)的硬件電路進(jìn)行分塊的編程調(diào)試,最終完成程序設(shè)計(jì)。第四部分是軟件畫圖部分:設(shè)計(jì)好電路后進(jìn)行畫圖,包括電路圖和仿真圖的繪制。第五部分是軟件仿真部分:軟硬件設(shè)計(jì)好后將軟件載入芯片中進(jìn)行仿真,仿真無(wú)法完成時(shí)檢查軟件程序和硬件電路并進(jìn)行修改直到仿真成功。第六部分是硬件實(shí)現(xiàn)部分:連接電路并導(dǎo)入程序檢查電路,若與設(shè)計(jì)的完全一樣一般能實(shí)現(xiàn)想要的功能。最后進(jìn)行功能擴(kuò)展,在已經(jīng)正確的設(shè)計(jì)基礎(chǔ)上,添加額外的功能! 四,時(shí)鐘的實(shí)現(xiàn) A.電路設(shè)計(jì) 1. 整體設(shè)計(jì) 此次設(shè)計(jì)主要是應(yīng)用單片機(jī)來(lái)設(shè)計(jì)電子時(shí)鐘,硬件部分主要分以下電路模塊:顯示電路用8個(gè)共陰數(shù)碼管分別顯示,星期(年份),小時(shí)、分鐘(月份)和秒(日),通過(guò)動(dòng)態(tài)掃描進(jìn)行顯示,從而避免了譯碼器的使用,同時(shí)節(jié)約了I/0端口,使電路更加簡(jiǎn)單。單片機(jī)采用AT89S51系列,這種單片機(jī)應(yīng)用簡(jiǎn)單,適合電子鐘設(shè)計(jì)。 電路的總體設(shè)計(jì)框架如下:
| | file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.png |
2. 分塊設(shè)計(jì) 模塊電路主要分為:輸入部分、輸出部分、復(fù)位和晶振電路。 2.1 輸入部分 輸入信號(hào)主要是各種模式選擇和調(diào)整信號(hào),由按鍵開(kāi)關(guān)提供。 以下為輸入部分樣例: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg 在本實(shí)驗(yàn)中主要用用P3口輸入按鍵信號(hào),還用到了特殊的P0口。對(duì)于P0口,由于其存在高阻狀態(tài),為了實(shí)現(xiàn)開(kāi)關(guān)功能,給其添加上拉電阻,具體如下圖所示: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg 2.2 輸出部分 本電路的輸出信號(hào)為7段數(shù)碼管的位選和段選信號(hào),鬧鈴脈沖信號(hào),提示燈信號(hào)。 本實(shí)驗(yàn)的數(shù)碼管是共陰的,為了防止段選信號(hào)不能驅(qū)動(dòng)數(shù)碼管,故在P1口連接上拉電阻后,再送段選信號(hào),以提高驅(qū)動(dòng),位選信號(hào)直接從P2口接入,如下圖: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg 鬧鈴由P2.6端輸出,模塊如下: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg 2.3 晶振與復(fù)位電路 本實(shí)驗(yàn)單片機(jī)時(shí)鐘用內(nèi)部時(shí)鐘,模塊如下: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg 復(fù)位電路為手動(dòng)復(fù)位構(gòu)成,模塊如下: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg 各模塊拼接組合,電路總體設(shè)計(jì)圖如下file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg: B.程序設(shè)計(jì) B.1 程序總體設(shè)計(jì) 本實(shí)驗(yàn)用匯編程序完成. 程序總的流程圖如下: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image017.png
3. B.2 程序主要模塊 B.2.1 延時(shí)模塊 數(shù)碼管顯示動(dòng)態(tài)掃描時(shí),用到延時(shí)程序,這里使用延遲1ms的程序,此程序需反復(fù)調(diào),除數(shù)碼管動(dòng)態(tài)掃描外,數(shù)碼管的閃爍提示,以及音樂(lè)模塊也用到了延時(shí),只是延時(shí)的長(zhǎng)短不同罷了,在此不再贅述。 B.2.2中斷服務(wù)程序 本實(shí)驗(yàn)中,計(jì)數(shù)器T0,T1中斷都有運(yùn)用,其中T0中斷為時(shí)鐘定時(shí)所用,T1中斷用于音樂(lè)播放。T0的定時(shí)長(zhǎng)度為0.01s,工作于方式1,計(jì)數(shù)1次,時(shí)長(zhǎng)1us,故計(jì)數(shù)器計(jì)數(shù)10000次,進(jìn)入中斷,計(jì)數(shù)初值為65536-10000=55536=#0D8F0,裝滿定時(shí)器需要0.01s的時(shí)間,從而100次中斷為一秒,一秒之后,判斷是否到60秒,若不到則秒加一,然后返回,若到,則秒賦值為0,分加一,依次類推。包括日期顯示的功能也是如此。另外,由于要實(shí)現(xiàn)倒計(jì)時(shí)功能,因此在中斷程序中還要加入減一的寄存器,需要時(shí)將其進(jìn)行顯示。基于以上考慮,以R3為倒計(jì)時(shí)中的秒,R4為倒計(jì)時(shí)的分,當(dāng)秒加1時(shí)R3減一,減到0之后,秒賦值為59,分減一,直到分為0。 計(jì)數(shù)器T1工作于方式1, 當(dāng)調(diào)用響鈴程序時(shí),其計(jì)數(shù)功能開(kāi)啟,為音樂(lè)音調(diào)不同頻率的方波的形成,提供延時(shí)。其中斷服務(wù)程序就是根據(jù)音調(diào)改變音樂(lè)方波輸出口電平的高低,用語(yǔ)句 CPL實(shí)現(xiàn)。 中斷服務(wù)程序中日歷的實(shí)現(xiàn)較為復(fù)雜,要考慮平年,閏年,特殊的2月,每月的天數(shù)的不盡相同。具體的邏輯判斷方法為:首先,要考慮年份是不是閏年,閏年的判斷方法是:將年份除以100,若能整除,則將年份除以400,若還能整除,則為閏年,若不能,則為平年;若不能被100整除,則判斷是否能被4整除,若能,則為閏年,若不能則為平年。只有2月與平、閏年相關(guān),因此在閏年和平年的子程序中,要判斷是不是2月,若是則在相應(yīng)的年中進(jìn)行日期的增加,若不是則轉(zhuǎn)入平時(shí)的月份。其中1、3、5、7、8、10、12月是每月31天,4、6、9、11月為每月30天。 日歷進(jìn)位判斷流程圖如下: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image018.png
本實(shí)驗(yàn)用8個(gè)數(shù)碼管,剛好能顯示年,月,日,掃描顯示與時(shí)間的掃描顯示類似。年比較特殊,由兩個(gè)寄存器存儲(chǔ),個(gè)位,十位為0時(shí),表明年數(shù)能被100整除,若此時(shí)千位,百位 組成兩位數(shù)能被4整除,則年數(shù)被400整除,為閏年。若十位,個(gè)位組成兩位數(shù)能被4整除,則年數(shù)能被4整除,為閏年。 B.2.3主程序 主程序主要對(duì)按鍵進(jìn)行掃描,以及判斷定時(shí)和鬧鈴時(shí)間是否已到,若到則調(diào)用相關(guān)程序。 B.2.4 顯示子程序 8個(gè)數(shù)碼管輪流進(jìn)行顯示,分別顯示1ms,依賴人的視覺(jué) 暫留效應(yīng),給人以數(shù)碼管持續(xù)高亮的錯(cuò)覺(jué)。 日期的顯示,秒表的顯示,倒計(jì)時(shí)的顯示,調(diào)鬧鈴,調(diào)定時(shí)的顯示,閃爍的顯示程序與以上的的掃描相似,有的以子程序的方式出現(xiàn),通過(guò)子程序調(diào)用語(yǔ)句ACALL調(diào)用;有點(diǎn)直接嵌套在相應(yīng)的程序里面,順序執(zhí)行,或者用調(diào)轉(zhuǎn)語(yǔ)句AJMP調(diào)用。 C 程序調(diào)試及仿真 本程序通過(guò)Keil單片機(jī)開(kāi)發(fā)平臺(tái)實(shí)現(xiàn)程序的編譯,鏈接,生成HEX文件。通過(guò)Keil和硬件仿真平臺(tái)Proteus的聯(lián)合,可以將設(shè)計(jì)效果仿真出來(lái),根據(jù)效果,有目的的改變?cè)O(shè)計(jì),優(yōu)化程序。 利用Proteus仿真實(shí)驗(yàn)過(guò)程截圖: 普通時(shí)間顯示模式仿真圖,表示:星期一 9點(diǎn)10分38秒 file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image020.jpg 五,總結(jié) 本文先從整體論述了設(shè)計(jì)電子鐘的大致思路,然后再采用劃分模塊的方法,將硬件電路劃分為開(kāi)關(guān)電路,顯示驅(qū)動(dòng)電路,以及數(shù)碼管電路等,而軟件部分,則依據(jù)要實(shí)現(xiàn)的功能,劃分為:鬧鐘的聲音程序,時(shí)間顯示程序,日期顯示程序,秒表顯示程序,時(shí)間調(diào)整程序、鬧鐘調(diào)整程序、定時(shí)調(diào)整程序,延時(shí)程序等。最后將各模塊集成為一個(gè)整體,合成一個(gè)多功能的電子鐘。 參考文獻(xiàn) [1] 謝自美.電子線路設(shè)計(jì)·實(shí)驗(yàn)·測(cè)試[M].武漢:華中理工大學(xué)出版社,1992. [2] 何立民.單片機(jī)應(yīng)用系統(tǒng)設(shè)計(jì)[M].北京:北京航空航天大學(xué)出版社,1993. [3] 樓然笛.單片機(jī)開(kāi)發(fā)[M].北京:人民郵電出版社,1994.
[4] 付家才.單片機(jī)控制工程實(shí)踐技術(shù)[M].北京:化學(xué)工業(yè)出版社 2004.3.
[5] 李光才.單片機(jī)課程設(shè)計(jì) 實(shí)例指導(dǎo)[M]. 北京:北京航空航天大學(xué)出版社 2004.3.
[6] 朱定華.單片機(jī)原理及接口技術(shù)實(shí)驗(yàn)[M].北京:北方交通大學(xué)出版社2002.11. [7] 劉湘濤.江世明.單片機(jī)原理與應(yīng)用[M]. 北京:電子工業(yè)出版社,2006. 附錄: 延時(shí)程序: D_1MS: MOV R7,#2 D_5: MOV R2,#250 DJNZ R2,$ DJNZ R7,D_5 RET 主程序: MAIN: JNBP3.0,DATETZ ;按下0鍵,顯示日期并可對(duì)日期進(jìn)行調(diào)整 JNB P3.1,ZSTZ1 ;按下1鍵,顯示時(shí)間,并可調(diào)時(shí) JNB P3.2,NLTZZ ;按下2鍵,進(jìn)行鬧鈴設(shè)置 JNB P3.3,DSTZ ;按下3鍵,進(jìn)行定時(shí)設(shè)置 JNB P3.4,CESHI ;鬧鈴測(cè)試 JNBP3.6,STOPWATCHTZ ;按下6鍵,進(jìn)入秒表方式 ACALL DISP ;調(diào)用時(shí)鐘顯示子程序 JNB P0.6,RERING ;判斷是否開(kāi)啟鬧鈴重響功能 RE: JNB P2.7,DSPDKQ ;判斷是否開(kāi)啟鬧鈴功能,沒(méi)開(kāi)則去判斷定時(shí) FMQPD: ;判斷定時(shí)值R4,R3是否到零、鬧鈴時(shí)刻是否已到 MOV A,HOUR; SUBB A,38H; JZ FEN ;判斷小時(shí)數(shù)是否到鬧鈴所定時(shí)間,若到,則對(duì)分進(jìn)行判斷;若不到,則對(duì)定時(shí)進(jìn)行判斷 AJMP DSPDKQ FEN: MOV A,MINUTE; SUBB A,37H; JZ MIAO ;判斷分是否到鬧鈴所定時(shí)間,若到,則對(duì)秒進(jìn)行判斷;若不到,則對(duì)定時(shí)進(jìn)行判斷 AJMP DSPDKQ MIAO: MOV A,SECOND SUBB A,#0 JZ SHENGYIN1 ;判斷秒是否到鬧鈴所定時(shí)間,若到,則時(shí),分,秒都到達(dá)鬧鈴時(shí)刻,進(jìn)入響鈴子程序;若不到則判斷定時(shí) AJMP DSPDKQ RERING: ;鬧鈴重響判斷程序 JNB F0, RE ;標(biāo)志位F0為0,不進(jìn)行鬧鈴重響設(shè)定 CPL F0 MOV 3CH,#1 ;定時(shí)判斷標(biāo)志位賦1,定時(shí)判斷功能開(kāi)啟 JNB P0.7,M1 ;鬧鈴重響間隔時(shí)間選取 MOV R4,#0 ;鬧鈴重響間隔30秒 MOV R3,#30 AJMP MAIN M1: ;鬧鈴重響間隔60秒 MOV R4,#1 MOV R3,#0 AJMP MAIN DSPDKQ: ;判斷是否應(yīng)該進(jìn)行定時(shí)判斷 MOV A,3CH ;3CH是引入的判斷因子,當(dāng)其為0時(shí),不對(duì)定時(shí)時(shí)間是否到0進(jìn)行判斷 JNZ DSPD2 ;當(dāng)3CH不是0時(shí),跳轉(zhuǎn)到定時(shí)判斷程序 AJMP MAIN DSPD2: MOV A,R4; JZ S_PD ;R4所存定時(shí)分?jǐn)?shù)為0,則轉(zhuǎn)而判斷R3所存定時(shí)秒數(shù) AJMP MAIN; S_PD: MOV A,R3; JNZ MAIN ;R4,R3所存參數(shù)減為0,定時(shí)長(zhǎng)度已到 JNBP0.6,SHENGYIN2 ;鬧鈴重響功能開(kāi)啟時(shí),跳入響鈴程序 AJMP TISHI ;不是鬧鈴重響定時(shí),則定時(shí)時(shí)間到時(shí),跳入提示程序 AJMP MAIN CESHI: ACALL RING AJMP MAIN SHENGYIN1: ;調(diào)用響鈴子程序 LCALL RING AJMP MAIN SHENGYIN2: SETB F0 ;鬧鈴重響標(biāo)志位設(shè)定 LCALL RING ;響鈴 CLR F0 ;標(biāo)志位復(fù)位 AJMP MAIN NLTZZ: AJMP NLTZ1 ;跳入鬧鈴調(diào)整程序 DSTZ: AJMP DSTZ1 ;跳入定時(shí)調(diào)整程序 DATETZ: AJMP DATETZ1 ;跳入日期調(diào)整程序 STOPWATCHTZ: AJMPSTOPWATCHTZ1 ;跳入秒表程序 顯示子程序: DISP: ;時(shí)間顯示子程序 JNB P3.7,OUT1 ;判斷節(jié)能開(kāi)關(guān)7是否按下,按下則數(shù)碼管不顯示,延長(zhǎng)其壽命 MOV DPTR,#LEDTAB MOV A,SECOND ;顯示當(dāng)前時(shí)間秒位 MOV B,#10 DIV AB ;A存十位,B存?zhèn)位 MOVC A,@A+DPTR MOV P1,A CLR SEC_S ACALL D_1MS ;顯示當(dāng)前時(shí)間秒十位 SETB SEC_S MOV A,B MOVC A,@A+DPTR MOV P1,A CLR SEC_G ACALL D_1MS ;顯示當(dāng)前時(shí)間秒個(gè)位 SETB SEC_G MOV A,MINUTE ;顯示當(dāng)前時(shí)間分位 MOV B,#10 DIV AB MOVC A,@A+DPTR MOV P1,A CLR MIN_S ACALL D_1MS SETB MIN_S MOV A,B MOVC A,@A+DPTR MOV P1,A CLR MIN_G ACALL D_1MS SETB MIN_G MOV A,HOUR ;顯示當(dāng)前時(shí)間時(shí)位 MOV B,#10 DIV AB MOV DPTR,#LEDTAB MOVC A,@A+DPTR MOV P1,A CLR HOU_S ACALL D_1MS SETB HOU_S MOV A,B MOVC A,@A+DPTR MOV P1,A CLR HOU_G ACALL D_1MS SETB HOU_G MOV A,WEEK ;顯示當(dāng)前星期數(shù) MOVC A,@A+DPTR MOV P1,A CLR Y_S ACALL D_1MS SETB Y_S OUT1: RET
