查看: 2726|回復: 0
單片機家庭花卉養(yǎng)殖系統(tǒng) 檢測土壤溫濕度,自動澆水
ID:354412 發(fā)表于 2018-6-28 15:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
實現(xiàn)溫濕度監(jiān)測和控制抽水機在土壤濕度低于一定門限值是自動澆水
單片機源程序如下:
  1. #include "stm32f10x.h"
  2. #include "bsp_SysTick.h"
  3. #include "bsp_usart1.h"
  4. #include "bsp_adc.h"
  5. #include "GPIO_map.h"
  6. #include "bsp_dht11.h"
  7. #include "bsp_eeprom.h"
  8. #include "bsp_relay.h"
  9. #include "touch.h"
  10. #include "lcd.h"
  11. #include "sys.h"
  12. #include "caculator.h"
  13. #include "bsp_Timbase.h"
  14. #include "bsp_key.h"
  15. extern __IO uint16_t ADC_ConvertedValue;
  16. extern DHT11_Data_TypeDef DHT11_Data;
  17. extern unsigned int Task_Delay[NumOfTask];
  18. extern void KEY_Scan(void);
  19. extern void KEY_Init(void);
  20. u16 Temp,Hum,Soil_hum;
  21. u16 Soil_hum = 100;
  22. u16 Hum_limit = 98;
  23. void Load_Drow_Dialog(void)
  24. {
  25.         LCD_Clear(WHITE);//清屏
  26.         POINT_COLOR=BLUE;//設置字體為藍色
  27.         LCD_ShowString(216,0,"RST");//顯示清屏區(qū)域
  28.   POINT_COLOR=RED;//設置畫筆藍色
  29. }
  30. int main(void)
  31. {
  32.         /* 配置SysTick 為10us中斷一次 */
  33. //        int v = 0;
  34.         Relay_Init();
  35.         KEY_Init();
  36.         SystemInit();
  37.         SysTick_Init();
  38.         NVIC_Configuration();
  39.         ADC1_Init();
  40.         USART1_Config();
  41.         DHT11_GPIO_Config();
  42. //        FLASH_Unlock();
  43. //  EE_INIT();
  44. //        EE_READ_ACC_OFFSET();
  45.   LCD_Init();
  46. //        CA_Init();
  47.         GUI_Init();
  48.         Delay_ms(100);
  49. //        Touch_Init();
  50.         Delay_ms(1500);
  51.         //Load_Drow_Dialog();
  52.         TIM2_Configuration();
  53.         TIM2_NVIC_Configuration();
  54.
  55.         while(1)
  56.           {
  57.
  58.                         if(Soil_hum < Hum_limit)
  59.                                 {
  60.                                         GPIO_SetBits(GPIOC,GPIO_Pin_11);
  61.                                 }
  62.                                 else GPIO_ResetBits(GPIOC,GPIO_Pin_11);
  63.                         if( Read_DHT11(&DHT11_Data)==SUCCESS )       //溫度采集并顯示
  64.                                 {
  65.                                         Temp = DHT11_Data.temp_int;
  66.                                         LCD_Show2Num(95,60,Temp,2,16,0);
  67.                                         Hum = DHT11_Data.humi_int;
  68.                                         LCD_Show2Num(95,100,Hum,2,16,0);
  69.                                 }
  70. //                        Soil_hum = (ADC_ConvertedValue*100)/4096;
  71. //                        LCD_Show2Num(115,90,Soil_hum,2,16,0);
  72. //                        LCD_Show2Num(115,130,Hum_limit,2,16,0);
  73. //                        CA_ScreenInput();
  74.                                         Soil_hum = (ADC_ConvertedValue*100)/4096;
  75.                                         LCD_Show2Num(145,140,Soil_hum,2,16,0);
  76.                                         KEY_Scan();
  77.                                         LCD_Show2Num(145,180,Hum_limit,2,16,0);
  78. //                        if(Task_Delay[1]==TASK_ENABLE)        //鍵盤任務
  79. //                                {
  80. //                                        LCD_Show2Num(115,130,Hum_limit,2,16,0);
  81. //                                        CA_ScreenInput();
  82. //                                        Task_Delay[1]=20;                  //此值每1ms會減1,減到0才可以重新進來這里,所以執(zhí)行的周期是20ms
  83. //                                }
  84.                 }
  85. }
  86. /*********************************************END OF FILE**********************/
復制代碼
家庭花卉養(yǎng)殖系統(tǒng) - 按鍵.rar (363 KB, 下載次數(shù): 57)
admin + 50 共享資料的黑幣獎勵!
