查看: 3124|回復(fù): 1
智能儀器溫度檢測,12位AD轉(zhuǎn)換
ID:361406 發(fā)表于 2018-6-28 22:29 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
智能儀器溫度檢測,12位AD轉(zhuǎn)換。
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. sbit rs = P2 ^ 0;
  6. sbit rw = P2 ^ 1;
  7. sbit ep = P2 ^ 2;
  8. uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88, 0x83,0xc6,0xa1,0x86,0x8e};
  9. /***定義0831引腳***/
  10. sbit CS1=P1^0;
  11. sbit CLK1=P1^1;
  12. sbit DO1=P1^2;
  13. /***定義溫度報警引腳***/
  14. sbit P24=P2^4;
  15. sbit P25=P2^5;
  16. /***定義按鍵引腳***/
  17. sbit Key0=P1^3;
  18. sbit Key1=P1^4;
  19. sbit Key2=P1^5;
  20. sbit Key3=P1^6;
  21. uchar i_flag=0;
  22. uchar len=0;
  23. uchar key_flag=0;
  24. uchar key_operate=0;
  25. uchar counter;
  26. uchar flag=0;
  27. uint Tl=0;
  28. uchar TV;
  29. uint Th[]={100,110,120,120};
  30. uchar tempH[3];
  31. uchar tempL[3];
  32. uchar tmpdata[]={0,0,0};
  33. uchar i=0,i1=0,n=0;
  34. int tmp=0;
  35. /***延時程序1***/
  36. void delayUs()
  37. {
  38.     _nop_();
  39.     _nop_();
  40.         _nop_();
  41.         _nop_();
  42.         _nop_();
  43.         }
  44. /***延時程序2***/
  45. void delayms(uint i)
  46. {
  47.         uint j;
  48.         for(;i>0;i--)
  49.         for(j=55;j>0;j--);
  50.         }
  51. /***0831初始化和數(shù)據(jù)讀取***/
  52. uchar readad0831()
  53. {
  54.         uchar i=0,tmp=0;
  55.         DO1=1;
  56.         CS1=1;
  57.         delayUs();
  58.         CLK1=0;
  59.     CS1=0;
  60.    delayUs();
  61.    CLK1=1;
  62.    delayUs();
  63.    CLK1=0;
  64.    delayUs();
  65.    CLK1=1;
  66.    delayUs();
  67.    CLK1=0;
  68.    delayUs();
  69.    for(i=0;i<=7;i++)
  70.    {
  71.    tmp<<=1;    //左移一位
  72.    if(DO1)
  73.    tmp++;
  74.    CLK1=1;
  75.    delayUs();
  76.    CLK1=0;
  77.    delayUs();
  78.    }
  79.    CS1=1;
  80.    return tmp;
  81.    }
  82. /***主函數(shù)***/
  83. void main()
  84. {
  85.    TMOD=0x01;
  86.    TH0=(65535-50000)/256;   //定時器0賦初值
  87.    TL0=(65535-50000)%256;
  88.    TH1=(65535-30000)/256;   //定時器1賦初值
  89.    TL1=(65535-30000)%256;
  90.    ET1=1;                   //允許定時器1中斷
  91.    ET0=1;                   //允許定時器0中斷
  92.    TR0=1;                   //定時器0開始工作
  93.    TR1=1;                   //定時器1開始工作
  94.    EA=1;                    //開放總中斷
  95.    while(1)
  96.    {
  97.         P2=P2&0xf0;        //關(guān)閉所有數(shù)碼管
  98.                 P2=P2|0x01;        //打開第一個數(shù)碼管
  99.                 P0=table[i];       //第一個數(shù)碼管顯示數(shù)據(jù)
  100.                 delayms(1);
  101.                 if(flag==0)
  102.                 {
  103.                 tmpdata[0]=tmp/100;      //百位
  104.                  tmpdata[1]=tmp%100/10;   //十位
  105.                   tmpdata[2]=tmp%100%10;   //個位
  106.                   if(tmp>=Th[i-1])         //溫度上限報警
  107.                   P24=0;                //紅燈亮
  108.                   else
  109.                    P24=1;
  110.                    if(tmp<=Tl)              //溫度下限報警
  111.                    P25=0;                //黃燈亮
  112.                    else
  113.                         P25=1;
  114.                          display(tmpdata);        //顯示溫度值
  115.                           }
  116.                          if(flag==1)                  //報警溫度上限值的顯示
  117.                          {
  118.                          tempH[0]=Th[i-1]/100;     //百位
  119.                          tempH[1]=Th[i-1]%100/10;  //十位
  120.                          tempH[2]=Th[i-1]%100%10;  //個位
  121.                          display(tempH);
  122.                          }
  123.                          }
  124.                          }
  125. /***定時器0開中斷***/
  126. void timer0() interrupt 1  {
  127.         TH0=(65535-50000)/256;        //定時器0重新賦初值
  128.         TL0=(65535-50000)%256;
  129.         /***溫度循環(huán)檢測***/
  130.         n++;
  131.         P3=0x00;
  132.         if(n==50)
  133.      {
  134.          /***單路溫度檢測***/
  135.          if(i_flag==0)
  136.          {
  137.          i++;
  138.          if(i==5)
  139.          i=1;
  140.          i1=i;
  141.           }
  142.          else
  143.          {
  144.          i=i1;
  145.          }
  146.          /***四路溫度循環(huán)檢測***/
  147.          if(i==1)        //第一路
  148.          {
  149.          P3=0x01;
  150.          }
  151.          else if(i==2)  //第二路
  152.          {
  153.          P3=0x02;
  154.          }
  155.          else if(i==3)  //第三路
  156.          {
  157.          P3=0x04;
  158.          }
  159.          else           //第四路
  160.          {
  161.          P3=0x08;
  162.          }
  163.           n=0;
  164.            delayUs();
  165.            TV=readad0831();               //讀取溫度值
  166.            tmp=TV*(120.0/255.0)+0.5;      //A/D轉(zhuǎn)換
  167.            }
  168.            }
  169. /***定時器1開中斷***/
  170. void Timer_1(void) interrupt 3 using 2 {
  171.    TH1=(65536-30000)/256;         //定時器1重新賦初值
  172.    TL1=(65536-30000)%256;
  173. if(((!Key0)|(!Key1)|(!Key2)|(!Key3))&(key_flag==0))    //進(jìn)入按鍵設(shè)置
  174. {
  175. key_flag=20;
  176. while(--key_flag);      //延時去抖動
  177.   key_flag=1;
  178.   if(!Key0)               //進(jìn)入單路溫度檢測模式
  179.   {
  180.   if(key_operate==0)
  181.    {
  182.    key_flag=0;       //允許按鍵長按
  183.    if(counter++>30)  //Modle鍵要長按2S生效
  184.     {
  185.         i_flag=1;
  186.         i1=i;
  187.         key_operate++;
  188.         flag=0;
  189.         key_flag=1;  //不允許按鍵長按
  190.          }
  191.          }
  192.          else
  193.           {
  194.            flag=1;
  195.            }
  196.            }
  197.            if(key_flag==1)         //進(jìn)入單路溫度上限值的設(shè)定
  198.            {
  199.            if(!Key1)            //加1鍵
  200.            {
  201.            Th[i-1]++;
  202.            }
  203.            if(!Key2)            //減1鍵
  204.            {
  205.            Th[i-1]--;
  206.         }
  207.                 }
  208.                 if(!Key3)                 //恢復(fù)四路溫度檢測
  209.                 {
  210.                 key_operate=0;
  211.                 counter=0;
  212.                 flag=0;
  213.                 i_flag=0;
  214.                 }
  215.                 }
  216.                 if((Key0)&(Key1)&(Key2)&(Key3))
  217.                 key_flag=0;
  218.                 }
智能儀器溫度檢測.zip (57.34 KB, 下載次數(shù): 20)
admin + 50 共享資料的黑幣獎勵!
ID:543049 發(fā)表于 2019-5-30 10:05 | 只看該作者
報警時是哪一個led燈亮啊?
