查看: 1569|回復(fù): 2
大佬幫忙看看c程序哪里少了點(diǎn)什么 感謝萬(wàn)分
ID:359165 發(fā)表于 2018-6-29 10:10 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
1.實(shí)驗(yàn)?zāi)康?/font>
掌握SPI總線的ADC0832模數(shù)轉(zhuǎn)換的使用方法。
2.實(shí)驗(yàn)內(nèi)容
利用ADC0832采集直流0~5V的電壓,并在LCD1602上顯示結(jié)果。
C語(yǔ)程序
#include <reg52.H>
#include"LCD1602.h"
#include"ADC0832.h"
uchar Voltage = 0;
/*主函數(shù)*/
        LCD1602_init();
        LCD1602_string(1,1," ADC0832 Test");
        LCD1602_string(2,1," Voltsge:   V");
                Voltage = adc0832(1);
                Display_2num_dot(2,10,Voltage*50/255);
#include<reg52.h>
#include<intrins.h>
#define  unit  unsigned int
sbit ADCS =P1^5;
sbit ADDI =P3^2;
sbit ADDO =P1^7;
sbit ADCLK=P1^6;
uchar adc0832(uchar channel)
        uchar i=0;
        uchar dat=0;
          if(channel==0)channel=2;
      if(channel==1)channel=3;
          ADDI=0;ADCS=1;ADCLK=0;
          ADDI=1;ADCS=0;ADCLK=1;
          ADCLK=0;ADCLK=1;
          ADDI=channel&0x1;
          ADCLK=0;ADCLK=1;
          ADDI=(channel>>1)&0x1;
          ADCLK=0;ADDI=1;
          dat=0;
          for(i=0;i<8;i++)
                  dat|=ADDO;
                  ADCLK=1;
                  ADCLK=0;
                  dat<<=1;
                  if(i==7)dat|=ADDO;
          ADCS=1;ADCLK=0;ADDO=1;
          return(dat);
#ifndef __ADC0832_H__
#define __ADC0832_H__
unsigned char adc0832(unsigned char channel);
#endif
參與人數(shù) 1黑幣 +5 收起 理由
大家好才是真的 + 5 贊一個(gè)!
ID:361910 發(fā)表于 2018-6-29 17:40 | 只看該作者
#include<reg52.h> #include<intrins.h> #define uchar unsigned char #define  unit  unsigned int sbit ADCS =P1^5; sbit ADDI =P3^2; sbit ADDO =P1^7; sbit ADCLK=P1^6;應(yīng)該放在主函數(shù)前面吧
掃福11 + 5 贊一個(gè)!
ID:359165 發(fā)表于 2018-6-30 11:57 | 只看該作者
菜雞養(yǎng)成攻略 發(fā)表于 2018-6-29 17:40
#include #include #define uchar unsigned char #define  unit  unsigned int sbit ADCS =P1^5; sbit ADDI ...
還有沒(méi)有什么錯(cuò)呢,大哥。謝謝
