kea128的庫
2018-6-30 18:12 上傳
- #include "headfile.h"
- /*系統(tǒng)變量初始化部分*/
- void PIDStructurePointerInit(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff ){ //PID初始值給定
- PID_Balance->Kp = 8;
- PID_Balance->Kd = 1.2;
- PID_Balance->out = 0;
- PID_Speed->Kp = 10;
- PID_Speed->Ki = 0.05;
- PID_Speed->out = 0;
- PID_Path->Kp = 2.0;
- PID_Path->Kd = 0.0;
- PID_Path->offset = 1.0;
- PID_Path->out = 0;
- PID_Diff->Kp = 15.0;
- PID_Diff->Kd = 2.0;
- PID_Diff->Ki = 0.0;
- PID_Diff->offset = 0.35;
- PID_Diff->out = 0;
- for(uint8 n=0; n<10; n++){
- PID_Balance->err_k[n] = 0;
- PID_Speed->err_k[n] = 0;
- PID_Path->err_k[n] = 0;
- PID_Diff->err_k[n] = 0;
- PID_Speed->out_k[n] = 0;
- void SensorStructurePointerInit(Acc_Type_Def *Acc, Gyro_Type_Def *Gyro, Angle_Type_Def *Angle, Speed_Type_Def *Speed, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB){ //結(jié)構(gòu)體指針初始化成員
- /*Gyro*/
- Gyro->X_Final=0;
- Gyro->X_Offset=0;
- Gyro->X_Value[0]=0;
- Gyro->X_Value[1]=0;
- Gyro->X_Value[2]=0;
- Gyro->Z_Final=0;
- Gyro->Z_Offset=0;
- Gyro->Z_Value[0]=0;
- Gyro->Z_Value[1]=0;
- Gyro->Z_Value[2]=0;
- InductorA->LeftFinal=0;
- InductorA->RightFinal=0;
- InductorA->LeftValue[0]=0;
- InductorA->LeftValue[1]=0;
- InductorA->LeftValue[2]=0;
- InductorB->LeftFinal=0;
- InductorB->RightFinal=0;
- InductorB->LeftValue[0]=0;
- InductorB->LeftValue[1]=0;
- InductorB->LeftValue[2]=0;
- //角度目標(biāo)值 也就是平衡值 沒有轉(zhuǎn)換成角度值 但是是線性關(guān)系。
- Angle->PiontValue = 2300;
- //速度目標(biāo)值 沒有轉(zhuǎn)換成真實(shí)速度 與速度線性關(guān)系
- Speed->PiontSpeed = 2000;
- Speed->PiontSpeedMax=5000;
- Speed->PiontSpeedMin=1500;
- //此處應(yīng)照車放在賽道上 電感在導(dǎo)線正上方 最大值 電感離導(dǎo)線最遠(yuǎn)點(diǎn)為最小值
- InductorA->LeftMax = 1200;
- InductorA->LeftMin = 125;
- InductorA->RightMax = 1200;
- InductorA->RightMin = 125;
- InductorB->LeftMax = 1200;
- InductorB->LeftMin = 125;
- InductorB->RightMax = 1200;
- InductorB->RightMin = 125;
- void CarBalanceSystemInit(Gyro_Type_Def *Gyro){//系統(tǒng)初始化
- //uart_init(UART1,9600);
- gpio_init(H2,GPO,1);
- //關(guān)于ADC管腳接的東西 在headfile.h里有定義
- adc_init(ADC0_SE0);
- adc_init(ADC0_SE1);
- adc_init(ADC0_SE2);
- adc_init(ADC0_SE3);
- adc_init(ADC0_SE4);
- adc_init(ADC0_SE5);
- adc_init(ADC0_SE6);
- adc_init(ADC0_SE7);
- adc_init(ADC0_SE8);
- adc_init(ADC0_SE9);
- adc_init(ADC0_SE10);
- adc_init(ADC0_SE11);
- adc_init(ADC0_SE12);
- adc_init(ADC0_SE13);
- adc_init(ADC0_SE14);
- adc_init(ADC0_SE15);
- OLED_Init();
- OLED_ShowString(0,0,"SysInit Finish!");
- OLED_ShowString(0,16,"Car balance2.0V");
- OLED_Refresh_Gram();
- // 使用數(shù)字陀螺儀 要初始化IIC
- //IIC_init();
- //此處陀螺儀中值獲取很重要 不過數(shù)字陀螺儀默認(rèn)就是中值 無需獲取
- // 如果數(shù)字陀螺儀中值為0 那么 此處 直接賦值0即可
- Gyro->Z_Offset = adc_once(ADC0_SE2, ADC_12bit);
- Gyro->X_Offset = adc_once(ADC0_SE3, ADC_12bit);
- systick_delay_ms(10);
- //左電機(jī)
- ftm_pwm_init(ftm2,ftm_ch2,13000,0);
- ftm_pwm_init(ftm2,ftm_ch3,13000,0);
- //右電機(jī)
- ftm_pwm_init(ftm2,ftm_ch4,13000,0);
- ftm_pwm_init(ftm2,ftm_ch5,13000,0);
- //ftm的計(jì)數(shù)引腳可查看KEA128_port_cfg.h文件內(nèi)的FTM0_COUNT_PIN與FTM1_COUNT_PIN的宏定義得知
- //一個(gè)ftm同一時(shí)間只能實(shí)現(xiàn)一種功能,如果用于測速就不能用于輸出PWM
- ftm_count_init(ftm0); //對E0引腳輸入的脈沖進(jìn)行計(jì)數(shù) E0接編碼器LSB
- gpio_init(E1,GPI,0); //用于判斷方向 C5接編碼器DIR
- port_pull(E1); //IO上拉
- ftm_count_init(ftm1); //對E7引腳輸入的脈沖進(jìn)行計(jì)數(shù) E7接編碼器LSB
- gpio_init(H6,GPI,0); //用于判斷方向 H5接編碼器DIR
- port_pull(H6); //IO上拉
- //定時(shí)器中斷
- pit_init(pit0,0x9000);//1.539ms
- //絕對值函數(shù) 必須要取地址放入形參
- void AbsoluteValue(float *Value, float *Return){
- if( (*Value) <0) (*Return) = -1*(*Value);
- else *Value = *Return;
- /*原始數(shù)據(jù)獲取部分*/
- void GetAccelerationValue(Acc_Type_Def *Acc){ //獲取ACC原始數(shù)據(jù)
- Acc->Z_Value[0] = Acc->Z_Value[1];
- Acc->Z_Value[1] = Acc->Z_Value[2];
- Acc->Z_Value[2] = ACC_Z;//本句是獲取當(dāng)前加速度 上兩句都是 上次值和上上次值
- //利用多次值進(jìn)行濾波 參數(shù)自行調(diào)整看效果
- Acc->Z_Final = 0.33*Acc->Z_Value[2]+0.33*Acc->Z_Value[1]+0.33*Acc->Z_Value[0];
- void GetAngleSpeedValue(Gyro_Type_Def *Gyro){ //獲取Gyro原始數(shù)據(jù)
- Gyro->Z_Value[0] = Gyro->Z_Value[1];
- Gyro->Z_Value[1] = Gyro->Z_Value[2];
- Gyro->Z_Value[2] = GYRO_Z - Gyro->Z_Offset;//如果是數(shù)字陀螺儀請給Gyro->Z_Offset賦值 在初始化的時(shí)候
- Gyro->X_Value[0] = Gyro->X_Value[1]; //前前次
- Gyro->X_Value[1] = Gyro->X_Value[2]; //前次
- Gyro->X_Value[2] = GYRO_X - Gyro->X_Offset; //本次
- void GetInductorValue(Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB){ //獲取inductor原始數(shù)據(jù)
- InductorA->LeftValue[0] = InductorA->LeftValue[1];
- InductorA->LeftValue[1] = InductorA->LeftValue[2];
- InductorA->LeftValue[2] = L1;//本句是獲取當(dāng)前電感值 L1在haedfile.h文件中有定義
- InductorA->RightValue[0] = InductorA->RightValue[1];
- InductorA->RightValue[1] = InductorA->RightValue[2];
- InductorA->RightValue[2] = L2;//本句是獲取當(dāng)前電感值 L2在haedfile.h文件中有定義
- InductorB->LeftValue[0] = InductorB->LeftValue[1];
- InductorB->LeftValue[1] = InductorB->LeftValue[2];
- InductorB->LeftValue[2] = L3;//本句是獲取當(dāng)前電感值 L3在haedfile.h文件中有定義
- InductorB->RightValue[0] = InductorB->RightValue[1];
- InductorB->RightValue[1] = InductorB->RightValue[2];
- InductorB->RightValue[2] = L4;//本句是獲取當(dāng)前電感值 L4在haedfile.h文件中有定義
- void GetSpeedValue(Speed_Type_Def *Speed){ //獲取Speed原始數(shù)據(jù)
- for(uint8 n=0; n<15 ; n++){ //循環(huán)誤差保存
- //存儲(chǔ)前14次的值
- Speed->ActualLiftPulse[n] = Speed->ActualLiftPulse[n+1]; //0~14位賦值
- if( n==14 ){ //當(dāng)前值 15次 最新值
- Speed->ActualLiftPulse[n+1] = ftm_count_get(ftm1)*(-1); //本次 15位賦值
- ftm_count_clean(ftm1); //清除ftm1計(jì)數(shù)值
- }//此處一定要修改好 根據(jù)你們實(shí)際的硬件 對應(yīng)好左右輪子 因?yàn)榫幋a器是對著安裝的 那么
- //在車子往前走的時(shí)候 左右是相反的 所以要把其中一個(gè)負(fù)值編碼器變?yōu)檎?br />
- //兩個(gè)電機(jī)存在同樣的問題 都是對著安裝的
- for(uint8 n=0; n<15 ; n++){ //循環(huán)保存
- Speed->ActualRightPulse[n] = Speed->ActualRightPulse[n+1]; //0~14位賦值
- if( n==14 ){
- Speed->ActualRightPulse[n+1] = ftm_count_get(ftm0); //本次 15位賦值
- ftm_count_clean(ftm0); //清除ftm0計(jì)數(shù)值
- if(gpio_get(H6)) //檢測 ftm1的轉(zhuǎn)向 H6 E1是針對左右編碼器的 要弄清楚 不要到時(shí)候改過以后
- //左邊編碼器的方向 去控制右邊編碼器的 正負(fù)號(hào) 那就完蛋了
- Speed->ActualLiftPulse[15] = Speed->ActualLiftPulse[15];
- else
- Speed->ActualLiftPulse[15] = -Speed->ActualLiftPulse[15];
- if(gpio_get(E1)) //檢測 ftm0的轉(zhuǎn)向
- Speed->ActualRightPulse[15] = Speed->ActualRightPulse[15];
- else
- Speed->ActualRightPulse[15] = -Speed->ActualRightPulse[15]; //這個(gè)負(fù)號(hào)取決于你車向前走時(shí) 編碼器值是否為正
- void GetButtonStatus(Button_Type_Def *Button){ //Button原始數(shù)據(jù)獲取
- Button->Up[0] = Button->Up[1];
- Button->Up[1] = Button->Up[2];
- Button->Up[2] = Button->Up[3];
- Button->Up[3] = Button->Up[4];
- Button->Up[4] = UP;//第四次是最新的值 按鍵值 在haedfile.h文件中有定義
- Button->Down[0] = Button->Down[1];
- Button->Down[1] = Button->Down[2];
- Button->Down[2] = Button->Down[3];
- Button->Down[3] = Button->Down[4];
- Button->Down[4] = DOWN;//第四次是最新的值 按鍵值 在haedfile.h文件中有定義
- Button->Life[0] = Button->Life[1];
- Button->Life[1] = Button->Life[2];
- Button->Life[2] = Button->Life[3];
- Button->Life[3] = Button->Life[4];
- Button->Life[4] = LIFE;//第四次是最新的值 按鍵值 在haedfile.h文件中有定義
- Button->Right[0] = Button->Right[1];
- Button->Right[1] = Button->Right[2];
- Button->Right[2] = Button->Right[3];
- Button->Right[3] = Button->Right[4];
- Button->Right[4] = RIGHT;//第四次是最新的值 按鍵值 在haedfile.h文件中有定義
- Button->Enter[0] = Button->Enter[1];
- Button->Enter[1] = Button->Enter[2];
- Button->Enter[2] = Button->Enter[3];
- Button->Enter[3] = Button->Enter[4];
- Button->Enter[4] = ENTER;//第四次是最新的值 按鍵值 在haedfile.h文件中有定義
- void GetSwitchStatus(Switch_Type_Def *Switch){ //開關(guān)原始數(shù)據(jù)獲取
- Switch->Bm1[0] = Switch->Bm1[1];
- Switch->Bm1[1] = Switch->Bm1[2];
- Switch->Bm1[2] = SW1; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- Switch->Bm2[0] = Switch->Bm2[1];
- Switch->Bm2[1] = Switch->Bm2[2];
- Switch->Bm2[2] = SW2; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- Switch->Bm3[0] = Switch->Bm3[1];
- Switch->Bm3[1] = Switch->Bm3[2];
- Switch->Bm3[2] = SW3; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- Switch->Bm4[0] = Switch->Bm4[1];
- Switch->Bm4[1] = Switch->Bm4[2];
- Switch->Bm4[2] = SW4; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- Switch->Bm5[0] = Switch->Bm5[1];
- Switch->Bm5[1] = Switch->Bm5[2];
- Switch->Bm5[2] = SW5; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- Switch->Bm6[0] = Switch->Bm6[1];
- Switch->Bm6[1] = Switch->Bm6[2];
- Switch->Bm6[2] = SW6; //撥碼開關(guān) 第四次是最新的值 在haedfile.h文件中有定義
- /*原始數(shù)據(jù)處理部分*/
- void GyroHighPassFilter(Gyro_Type_Def *Gyro){ //Gyro濾波
- float K =0.58;//權(quán)值濾波 看情況調(diào)節(jié)
- Gyro->Z_Value[2] = K * Gyro->Z_Value[2] + (1-K) * Gyro->Z_Value[1];
- Gyro->Z_Final = Gyro->Z_Value[2];
- Gyro->X_Value[2] = K * Gyro->X_Value[2] + (1-K) * Gyro->X_Value[1];
- Gyro->X_Final = Gyro->X_Value[2];
- //權(quán)值濾波 去除高頻干擾
- void AngleHardwareFilter(Angle_Type_Def *Angle){ //角度濾波
- //本函數(shù)是直接采集角度的 只有模擬陀螺儀和加速度計(jì)進(jìn)行硬件融合直接解算角度值
- Angle->ActualValue[0] = Angle->ActualValue[1];
- Angle->ActualValue[1] = Angle->ActualValue[2];
- Angle->ActualValue[2] = ANGLE; //此處是獲取 最新角度值
- //濾波 Angle->FinalValue為最終值
- Angle->FinalValue = 0.6*Angle->ActualValue[2] + 0.2*Angle->ActualValue[1] + 0.2*Angle->ActualValue[0];
- void AngleSoftwareFilter(Acc_Type_Def *Acc, Gyro_Type_Def *Gyro , Angle_Type_Def *Angle){//角度濾波
- //本函數(shù)是適用于數(shù)字陀螺儀 通過軟件互補(bǔ)融合濾波解算角度
- Acc->Z_Final = 0.9*Acc->Z_Value[2] + 0.05*Acc->Z_Value[1] + 0.05*Acc->Z_Value[0];//權(quán)值低通濾波
- Gyro->Z_Final = 0.92*Gyro->Z_Value[2] + 0.05*Gyro->Z_Value[1] + 0.03*Gyro->Z_Value[0];//權(quán)值低通濾波
- //加速度 角速度采集
- //此處參數(shù)需要根據(jù) 清華方案里的方法去調(diào)節(jié)參數(shù) 看波形法
- Angle->FinalValue = 0.92*(Angle->FinalValue + 0.05*Gyro->Z_Final) + 0.08*(Acc->Z_Final);//融合濾波
- void InductorSoftwareFilter(Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Angle_Type_Def *Angle, Switch_Type_Def *Switch){//電感值歸一濾波
- /*權(quán)值濾波 警告無視 */
- InductorA->LeftFinal = 0.8*InductorA->LeftValue[2] + 0.15*InductorA->LeftValue[1] + 0.05*InductorA->LeftValue[0];//-InductorA->LeftMin;
- InductorA->RightFinal = 0.8*InductorA->RightValue[2] + 0.15*InductorA->RightValue[1] + 0.05*InductorA->RightValue[0];//-InductorA->RightMin;
- InductorB->LeftFinal = 0.8*InductorB->LeftValue[2] + 0.15*InductorB->LeftValue[1] + 0.05*InductorB->LeftValue[0];
- InductorB->RightFinal = 0.8*InductorB->RightValue[2] + 0.15*InductorB->RightValue[1] + 0.05*InductorB->RightValue[0];
- /*數(shù)據(jù)歸一化到0~1000*/
- InductorA->LeftFinal = 1000*( (float)(InductorA->LeftFinal-InductorA->LeftMin)/(InductorA->LeftMax-InductorA->LeftMin) );
- InductorA->RightFinal = 1000*( (float)(InductorA->RightFinal-InductorA->RightMin)/(InductorA->RightMax-InductorA->RightMin) );
- InductorB->LeftFinal = 1000*( (float)(InductorB->LeftFinal-InductorB->LeftMin)/(InductorB->LeftMax-InductorB->LeftMin) );
- InductorB->RightFinal = 1000*( (float)(InductorB->RightFinal-InductorB->RightMin)/(InductorB->RightMax-InductorB->RightMin) );
- if(InductorA->LeftFinal>999)InductorA->LeftFinal=999;
- if(InductorA->LeftFinal< 0)InductorA->LeftFinal= 0;
- if(InductorA->RightFinal>999)InductorA->RightFinal=999;
- if(InductorA->RightFinal< 0)InductorA->RightFinal= 0;
- if(InductorB->LeftFinal>999)InductorB->LeftFinal=999;
- if(InductorB->LeftFinal< 0)InductorB->LeftFinal= 0;
- if(InductorB->RightFinal>999)InductorB->RightFinal=999;
- if(InductorB->RightFinal< 0)InductorB->RightFinal= 0;
- //電感AB A 是靠外側(cè)的電感 B是靠內(nèi)側(cè)電感 RL就是左右
- InductorA->AndValues = InductorA->LeftFinal+InductorA->RightFinal;//電感和值
- InductorA->LeftDerivative = InductorA->LeftValue[2] - InductorA->LeftValue[0]; //左點(diǎn)感變化率
- InductorA->RightDerivative= InductorA->RightValue[2] - InductorA->RightValue[0];//右電感變化率
- InductorB->LeftDerivative = InductorB->LeftValue[2] - InductorB->LeftValue[0];
- void SpeedSoftwareFilter(Speed_Type_Def *Speed){ //速度低通濾波
- /*警告無視*/
- Speed->ActualLiftPulse[15]=0.33*Speed->ActualLiftPulse[15] + 0.33*Speed->ActualLiftPulse[14] + 0.33*Speed->ActualLiftPulse[13];
- Speed->ActualRightPulse[15]=0.33*Speed->ActualRightPulse[15] + 0.33*Speed->ActualRightPulse[14] + 0.33*Speed->ActualRightPulse[13];
- // 6 2 2
- //實(shí)際速度 = R+L
- Speed->ActualSpeed[0] = Speed->ActualSpeed[1];
- Speed->ActualSpeed[1] = Speed->ActualSpeed[2];
- Speed->ActualSpeed[2] =
- (Speed->ActualRightPulse[0]+Speed->ActualLiftPulse[0])+
- (Speed->ActualRightPulse[1]+Speed->ActualLiftPulse[1])+
- (Speed->ActualRightPulse[2]+Speed->ActualLiftPulse[2])+
- (Speed->ActualRightPulse[3]+Speed->ActualLiftPulse[3])+
- (Speed->ActualRightPulse[4]+Speed->ActualLiftPulse[4])+
- (Speed->ActualRightPulse[5]+Speed->ActualLiftPulse[5])+
- (Speed->ActualRightPulse[6]+Speed->ActualLiftPulse[6])+
- (Speed->ActualRightPulse[7]+Speed->ActualLiftPulse[7])+
- (Speed->ActualRightPulse[8]+Speed->ActualLiftPulse[8])+
- (Speed->ActualRightPulse[9]+Speed->ActualLiftPulse[9])+
- (Speed->ActualRightPulse[10]+Speed->ActualLiftPulse[10])+
- (Speed->ActualRightPulse[11]+Speed->ActualLiftPulse[11])+
- (Speed->ActualRightPulse[12]+Speed->ActualLiftPulse[12])+
- (Speed->ActualRightPulse[13]+Speed->ActualLiftPulse[13])+
- (Speed->ActualRightPulse[14]+Speed->ActualLiftPulse[14])+
- (Speed->ActualRightPulse[15]+Speed->ActualLiftPulse[15]);
- //濾波
- Speed->ActualSpeed[2] = 0.85*Speed->ActualSpeed[2]+0.1*Speed->ActualSpeed[1]+0.05*Speed->ActualSpeed[0];
- //7 2 1
- //實(shí)際差速 = L-R
- Speed->ActualDifferential[0] = Speed->ActualDifferential[1];
- Speed->ActualDifferential[1] = Speed->ActualDifferential[2];
- Speed->ActualDifferential[2] = Speed->ActualLiftPulse[15]-Speed->ActualRightPulse[15];
- Speed->ActualDifferential[2] = 0.8*Speed->ActualDifferential[2]+0.15*Speed->ActualDifferential[1]+0.05*Speed->ActualDifferential[0];
- //實(shí)際差速
- Speed->ActualInstantaneous[0] = Speed->ActualInstantaneous[1];
- Speed->ActualInstantaneous[1] = Speed->ActualInstantaneous[2];
- Speed->ActualInstantaneous[2] = (Speed->ActualLiftPulse[15]+Speed->ActualRightPulse[15] + (Speed->ActualLiftPulse[14]+Speed->ActualRightPulse[14])) ;
- //瞬時(shí)速度計(jì)算
- Speed->ActualAcceleration = Speed->ActualInstantaneous[2] - Speed->ActualInstantaneous[0];
- //加速度計(jì)算
- void ButtonLowPassFilter(Button_Type_Def *Button){ //按鍵低通濾波
- Button->Up_Final = Button->Up[0] || Button->Up[1] || Button->Up[2] || Button->Up[3] || Button->Up[4];
- //有一個(gè)1 最終值就是1 全部為0 最終值才為0
- if(Button->Up_Final==1) Button->Up_Final = 0;//取反 以1為有效值
- else Button->Up_Final = 1;
- Button->Down_Final = Button->Down[0] || Button->Down[1] || Button->Down[2] || Button->Down[3] || Button->Down[4];
- if(Button->Down_Final==1) Button->Down_Final = 0;//取反 以1為有效值
- else Button->Down_Final = 1;
- Button->Life_Final = Button->Life[0] || Button->Life[1] || Button->Life[2] || Button->Life[3] || Button->Life[4];
- if(Button->Life_Final==1) Button->Life_Final = 0;//取反 以1為有效值
- else Button->Life_Final = 1;
- Button->Right_Final = Button->Right[0] || Button->Right[1] || Button->Right[2] || Button->Right[3] || Button->Right[4];
- if(Button->Right_Final==1) Button->Right_Final = 0;//取反 以1為有效值
- else Button->Right_Final = 1;
- Button->Enter_Final = Button->Enter[0] || Button->Enter[1] || Button->Enter[2] || Button->Enter[3] || Button->Enter[4];
- if(Button->Enter_Final==1) Button->Enter_Final = 0;//取反 以1為有效值
- else Button->Enter_Final = 1;
- void SwitchLowPassFilter(Switch_Type_Def *Switch){ //開關(guān)低通濾波
- Switch->Bm1_Final = Switch->Bm1[0] || Switch->Bm1[1] || Switch->Bm1[2];
- if(Switch->Bm1_Final==1) Switch->Bm1_Final = 0;//取反 以1為有效值
- else Switch->Bm1_Final = 1;
- Switch->Bm2_Final = Switch->Bm2[0] || Switch->Bm2[1] || Switch->Bm2[2];
- if(Switch->Bm2_Final==1) Switch->Bm2_Final = 0;//取反 以1為有效值
- else Switch->Bm2_Final = 1;
- Switch->Bm3_Final = Switch->Bm3[0] || Switch->Bm3[1] || Switch->Bm3[2];
- if(Switch->Bm3_Final==1) Switch->Bm3_Final = 0;//取反 以1為有效值
- else Switch->Bm3_Final = 1;
- Switch->Bm4_Final = Switch->Bm4[0] || Switch->Bm4[1] || Switch->Bm4[2];
- if(Switch->Bm4_Final==1) Switch->Bm4_Final = 0;//取反 以1為有效值
- else Switch->Bm4_Final = 1;
- Switch->Bm5_Final = Switch->Bm5[0] || Switch->Bm5[1] || Switch->Bm5[2];
- if(Switch->Bm5_Final==1) Switch->Bm5_Final = 0;//取反 以1為有效值
- else Switch->Bm5_Final = 1;
- Switch->Bm6_Final = Switch->Bm6[0] || Switch->Bm6[1] || Switch->Bm6[2];
- if(Switch->Bm6_Final==1) Switch->Bm6_Final = 0;//取反 以1為有效值
- else Switch->Bm6_Final = 1;
- void OutOfControlSignal(Speed_Type_Def *Speed, PID_Type_Def *PID){ //速度失控信號(hào)檢測
- if( (Speed->ActualSpeed[2]-Speed->ActualSpeed[1]) > 400 && Speed->ActualSpeed[2]>10000){
- //加速度過大 車輪空轉(zhuǎn)
- ftm_pwm_duty(ftm2,ftm_ch2,0);
- ftm_pwm_duty(ftm2,ftm_ch3,0);
- ftm_pwm_duty(ftm2,ftm_ch4,0);
- ftm_pwm_duty(ftm2,ftm_ch5,0);
- while(1){
- // led(LED0,LED_ON); //根據(jù)你們的硬件設(shè)置報(bào)警燈
- systick_delay_ms(80);
- // led(LED0,LED_OFF);
- /*被控制量處理部分*/
- void BalanceFeedbackControl(PID_Type_Def *PID, Angle_Type_Def *Angle, Gyro_Type_Def *Gyro, Ramp_Type_Def *Ramp){ //直立反饋控制
- PID->err = (Angle->PiontValue-Angle->FinalValue);//硬件
- //偏差 = 角度目標(biāo)-角度反饋值
- PID->out = 1000 + PID->Kp * PID->err + PID->Kd * Gyro->Z_Final;
- //1000是為了給一個(gè)PWM中點(diǎn) Gyro->Z_Final就是 直立的角速度 也就是D控制 PD
- //一般情況下 調(diào)直立時(shí) 先給一個(gè)P參數(shù) D給0 就能立起來 如果發(fā)現(xiàn)不能立瘋轉(zhuǎn)
- //多半是 pid方向相反 把(Angle->PiontValue-Angle->FinalValue) 里面調(diào)換下位置 即可
- void DirectionFeedbackControl(PID_Type_Def *PID, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Gyro_Type_Def *Gyro, Speed_Type_Def *Speed, Ramp_Type_Def *Ramp){ //方向反饋控制
- InductorA->RightFinal = PID->offset*InductorA->RightFinal;
- InductorA->LeftFinal = (2-PID->offset)*InductorA->LeftFinal;
- //調(diào)整零偏
- //主要是在用 A電感
- PID->err = 10.0*(sqrt(1.0*InductorA->RightFinal)-sqrt(1.0*InductorA->LeftFinal) )/ (InductorA->RightFinal+InductorA->LeftFinal);
- if( InductorA->AndValues < 25 && Ramp->Flag[0]!=1) {//丟線找回 且不在坡道
- PID->err += 0.55*PID->err_k[6]; //找回強(qiáng)度
- else if( InductorA->AndValues < 50 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.50*PID->err_k[6]; //找回強(qiáng)度
- else if( InductorA->AndValues < 75 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.45*PID->err_k[7]; //找回強(qiáng)度
- else if( InductorA->AndValues < 100 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.40*PID->err_k[7]; //找回強(qiáng)度
- else if( InductorA->AndValues < 125 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.35*PID->err_k[8]; //找回強(qiáng)度
- else if( InductorA->AndValues< 150 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.30*PID->err_k[8]; //找回強(qiáng)度
- else if( InductorA->AndValues < 175 && Ramp->Flag[0]!=1) {//丟線找回
- PID->err += 0.25*PID->err_k[9]; //找回強(qiáng)度9
- else if( InductorA->AndValues < 200 && Ramp->Flag[0]!=1) {//丟線找回200
- PID->err += 0.2*PID->err_k[9]; //找回強(qiáng)度9
- if(InductorA->AndValues<150) PID->err = 0;
- PID->out = PID->Kp * PID->err * Speed->ActualInstantaneous[2] + PID->Kd * Gyro->X_Final;
- //轉(zhuǎn)向PID輸出計(jì)算 Gyro->X_Final; 是轉(zhuǎn)向角速度 也是D控制
- Speed->PiontDifferential = (int16)(PID->out); //給定差速環(huán)目標(biāo)值
- //把轉(zhuǎn)向環(huán) 計(jì)算出來的輸出值 給差速目標(biāo)環(huán)
- for(uint8 n=0; n<9 ; n++){ //循環(huán)誤差保存
- PID->err_k[n] = PID->err_k[n+1]; //0~8位賦值
- if( n==8 )
- PID->err_k[n+1] = PID->err; //本次 9位賦值
- void DifferentialFeedbackControl(PID_Type_Def *PID, Speed_Type_Def *Speed, Gyro_Type_Def *Gyro){//差速反饋控制
- //PID->offset只是一個(gè)比例分配 PID->offset=2
- int16 SpeedDifferentialValue = PID->offset * Speed->ActualDifferential[2] + (1-PID->offset)*(-0.18*Gyro->X_Final);
- // 得到差速值 是編碼器和 轉(zhuǎn)向角速度共同決定差速反饋值
- //Speed->PiontDifferential = 0;
- //差速目標(biāo)- 差速實(shí)際值
- PID->err = ( Speed->PiontDifferential - SpeedDifferentialValue);
- PID->integral += PID->err;
- //積分上下限
- if(PID->integral>50000)PID->integral=50000;
- if(PID->integral<-50000)PID->integral=-50000;
- if(Speed->ActualSpeed[2]< 50)PID->integral = 0;
- //低速積分清零
- PID->out = PID->Kp * PID->err + PID->Kd * ( SpeedDifferentialValue + PID->err_k[0]);// + PID->Ki * PID->integral;
- //PID計(jì)算
- if( n==8 )
- PID->err_k[0] = SpeedDifferentialValue;//借用一下PID->err_k[0]咯 存入上次值 差速
- //輸出幅度限制
- if(PID->out>2000)PID->out=2000;//1800
- if(PID->out<-2000)PID->out=-2000;
- void SpeedFeedbackControl(PID_Type_Def *PID, Speed_Type_Def *Speed, Ramp_Type_Def *Ramp, Switch_Type_Def *Switch){ //速度反饋控制
- PID->out_k[9] = PID->out;//保存成上一次輸出值
- PID->out_k[0] = 0;
- PID->err = Speed->ActualSpeed[2] - Speed->PiontSpeed;
- PID->integral = PID->err_k[0]+PID->err_k[1]+PID->err_k[2]+PID->err_k[3]+PID->err_k[4]+
- PID->err_k[5]+PID->err_k[6]+PID->err_k[7]+PID->err_k[8]+PID->err_k[9]+PID->err;
- PID->out = PID->Kp * PID->err;// + PID->Ki * PID->integral;
- PID->out *= 0.05; //縮小速度環(huán)輸出
- if(PID->out > 4800) PID->out= 4800; //后退最低角度4200
- if(PID->out < -1800) PID->out= -1800;//前進(jìn)最低角度-1800
- if( n==8 )
- void PWMFeedbackControl(PWM_Type_Def *PWM, PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Speed_Type_Def *Speed, Switch_Type_Def *Switch){ //PWM疊加反饋控制
- float DiffK=1;
- PID_Speed->out_k[0] += (PID_Speed->out - PID_Speed->out_k[9]) * 0.0625;//分段成1/16分增量
- //PID_Speed->out_k[9]是上次值 //PID_Speed->out是本次值 PID_Speed->out_k[0] 是平滑輸出增量值
- //疊加的時(shí)候把 平滑輸出增量值 + 上次的值 得到16個(gè)周期內(nèi) 每4ms周期應(yīng)給的值
- PWM->PiontValue = (int16)(PID_Balance->out)+ (int16)(PID_Speed->out_k[0] + PID_Speed->out_k[9]) ;
- //把所有環(huán)輸出相加
- PWM->Differential = (int16)(PID_Diff->out);
- //差速PWM
- if(PWM->Differential>0){
- PWM->LiftValue = PWM->PiontValue + (DiffK) * PWM->Differential;
- PWM->RightValue = PWM->PiontValue - (2-DiffK) * PWM->Differential;
- if(PWM->Differential<0){ //差速小于零時(shí) 左邊給目標(biāo)占空比+ 系數(shù)*差速
- PWM->LiftValue = PWM->PiontValue + (2-DiffK) * PWM->Differential;
- PWM->RightValue = PWM->PiontValue - (DiffK) * PWM->Differential;
- if(PWM->Differential==0){ //差速=0時(shí) 左右給一樣的目標(biāo)占空比
- PWM->LiftValue = PWM->PiontValue;
- PWM->RightValue = PWM->PiontValue;
- void ButtonFunctionControl(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Angle_Type_Def *Angle, Speed_Type_Def *Speed, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Button_Type_Def *Button, uint8 *Page){ //按鍵功能實(shí)現(xiàn)
- //OLED 按鍵 調(diào)節(jié)PID參數(shù)用的
- if(Button->Life_Final==1)if(*Page>0)(*Page)--;
- if(Button->Right_Final==1)if(*Page<135)(*Page)++;
- //page0
- if(*Page<=5){ //UP kp
- if(Button->Up_Final==1 ){
- if(PID_Balance->Kp<30) PID_Balance->Kp = PID_Balance->Kp+0.01;
- if(Button->Down_Final==1 ){
- if(PID_Balance->Kp>0) PID_Balance->Kp = PID_Balance->Kp-0.01;
- if(*Page<=10 && *Page>5){ //UP kd
- if(Button->Up_Final==1){
- if(PID_Balance->Kd<30) PID_Balance->Kd = PID_Balance->Kd+0.01;
- if(Button->Down_Final==1){
- if(PID_Balance->Kd>0) PID_Balance->Kd = PID_Balance->Kd-0.01;
- if(*Page<=15 && *Page>10){ // angle piont
- if(Angle->PiontValue<2400) Angle->PiontValue = Angle->PiontValue+1;
- if(Angle->PiontValue>1600) Angle->PiontValue = Angle->PiontValue-1;
- if(*Page<=20 && *Page>15){ //speed kp
- if(PID_Speed->Kp<30)PID_Speed->Kp = PID_Speed->Kp+0.1;
- if(PID_Speed->Kp>0)PID_Speed->Kp = PID_Speed->Kp-0.1;
- if(*Page<=25 && *Page>20){ //speed ki
- if(PID_Speed->Ki<10)PID_Speed->Ki = PID_Speed->Ki+0.001;
- if(PID_Speed->Ki>0)PID_Speed->Ki = PID_Speed->Ki-0.001;
- if(*Page<=30 && *Page>25){ //speeed piont
- if(Speed->PiontSpeed<10000)Speed->PiontSpeed = Speed->PiontSpeed+10;
- if(Speed->PiontSpeed>0)Speed->PiontSpeed = Speed->PiontSpeed-10;
- //page1
- if(*Page<=35 && *Page>30){ //path kp
- if(PID_Path->Kp<30)PID_Path->Kp = PID_Path->Kp+0.01;
- if(PID_Path->Kp>0)PID_Path->Kp = PID_Path->Kp-0.01;
- if(*Page<=40 && *Page>35){ //path kd
- if(PID_Path->Kd<30)PID_Path->Kd = PID_Path->Kd+0.01;
- if(PID_Path->Kd>0)PID_Path->Kd = PID_Path->Kd-0.01;
- if(*Page<=45 && *Page>40){ //path piont
- if(PID_Path->offset<2)PID_Path->offset = PID_Path->offset+0.001;
- if(PID_Path->offset>0)PID_Path->offset = PID_Path->offset-0.001;
- if(*Page<=50 && *Page>45){ //diff kp
- if(PID_Diff->Kp<30)PID_Diff->Kp = PID_Diff->Kp+0.01;
- if(PID_Diff->Kp>0)PID_Diff->Kp = PID_Diff->Kp-0.01;
- if(*Page<=55 && *Page>50){ //diff kd
- if(PID_Diff->Kd<30)PID_Diff->Kd = PID_Diff->Kd+0.01;
- if(PID_Diff->Kd>0)PID_Diff->Kd = PID_Diff->Kd-0.01;
- if(*Page<=60 && *Page>55){ //diff kd
- if(PID_Diff->Ki<30)PID_Diff->Ki = PID_Diff->Ki+0.01;
- if(PID_Diff->Ki>0)PID_Diff->Ki = PID_Diff->Ki-0.01;
- if(*Page<=65 && *Page>60){ //diff offset
- if(PID_Diff->offset<1)PID_Diff->offset = PID_Diff->offset+0.001;
- if(PID_Diff->offset>0)PID_Diff->offset = PID_Diff->offset-0.001;
- //page2
- if(*Page<=70 && *Page>65){ //左電感最大值
- if(Button->Up_Final==1 && InductorA->LeftMax < 4000)InductorA->LeftMax ++;
- if(Button->Down_Final==1 && InductorA->LeftMax > 100)InductorA->LeftMax --;
- if(*Page<=75 && *Page>70){ //左電感最小值
- if(Button->Up_Final==1 && InductorA->LeftMin < 4000)InductorA->LeftMin ++;
- if(Button->Down_Final==1 && InductorA->LeftMin > 100)InductorA->LeftMin --;
- if(*Page<=80 && *Page>75){ //右電感最大值
- if(Button->Up_Final==1 && InductorA->RightMax < 4000)InductorA->RightMax ++;
- if(Button->Down_Final==1 && InductorA->RightMax > 100)InductorA->RightMax --;
- if(*Page<=85 && *Page>80){ //右電感最小值
- if(Button->Up_Final==1 && InductorA->RightMin< 4000)InductorA->RightMin ++;
- if(Button->Down_Final==1 && InductorA->RightMin> 100)InductorA->RightMin --;
- if(*Page<=90 && *Page>85){ //中間電感最大值
- if(Button->Up_Final==1 && InductorB->LeftMax< 4000)InductorB->LeftMax ++;
- if(Button->Down_Final==1 && InductorB->LeftMax> 100)InductorB->LeftMax --;
- if(*Page<=95 && *Page>90){//中間電感最小值
- if(Button->Up_Final==1 && InductorB->LeftMin< 4000)InductorB->LeftMin ++;
- if(Button->Down_Final==1 && InductorB->LeftMin> 100)InductorB->LeftMin --;
- if(*Page<=100 && *Page>95){//最大速度
- if(Button->Up_Final==1 && Speed->PiontSpeedMax<10000)Speed->PiontSpeedMax ++;
- if(Button->Down_Final==1 && Speed->PiontSpeedMax >0)Speed->PiontSpeedMax --;
- if(*Page<=105 && *Page>100){//最小速度
- if(Button->Up_Final==1 && Speed->PiontSpeedMin < Speed->PiontSpeedMax)Speed->PiontSpeedMin ++;
- if(Button->Down_Final==1 && Speed->PiontSpeedMin > 0)Speed->PiontSpeedMin --;
- // //page3
- // if(*Page<=110 && *Page>105){//減速距離
- // if(Button->Up_Final==1 && Speed->SlowDistance < 6000)Speed->SlowDistance ++;
- // if(Button->Down_Final==1 && Speed->SlowDistance > 0)Speed->SlowDistance --;
- // if(*Page<=115 && *Page>110){//加速距離
- // if(Button->Up_Final==1 && Speed->AccDistance < 6000)Speed->AccDistance ++;
- // if(Button->Down_Final==1 && Speed->AccDistance > 0)Speed->AccDistance --;
- // if(*Page<=120 && *Page>115){//錯(cuò)誤距離
- // if(Button->Up_Final==1 && Speed->FaultDistance < 150000)Speed->FaultDistance+=100;
- // if(Button->Down_Final==1 && Speed->FaultDistance > 100)Speed->FaultDistance-=100;
- /*輸出量處理部分*/
- void PrintParameterToOLED(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Angle_Type_Def *Angle, Speed_Type_Def *Speed , PWM_Type_Def *PWM, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Curve_Type_Def *Curve, uint8 Page){ //打印參數(shù)到OLED上
- uint8 mode[10];
- static uint8 Last=0;
- if(Page<=30){
- if(Page<=5) mode[0] = 0;
- else mode[0] = 1;
- if(Page<=10 && Page>5) mode[1] =0;
- else mode[1] = 1;
- if(Page<=15 && Page>10) mode[2] =0;
- else mode[2] = 1;
- if(Page<=20 && Page>15) mode[3] =0;
- else mode[3] = 1;
- if(Page<=25 && Page>20) mode[4] =0;
- else mode[4] = 1;
- if(Page<=30 && Page>25) mode[5] =0;
- else mode[5] = 1;
- if( Last!=1 ){
- OLED_Fill(0,0,127,63,0);
- Last = 1;
- OLED_ShowString(0,0,"UP P D ");
- OLED_ShowNum(36,0,(int)(PID_Balance->Kp*10),3,12,mode[0]);
- OLED_ShowNum(72,0,(int)(PID_Balance->Kd*10),3,12,mode[1]);
- OLED_ShowString(0,12 ,"AnglePiont ");
- OLED_ShowNum(96,12,(int)(Angle->PiontValue),4,12,mode[2]);
- OLED_ShowString(0,24 ,"Speed P I ");
- OLED_ShowNum(56,24,(int)(PID_Speed->Kp*10),3,12,mode[3]);
- OLED_ShowNum(96,24,(int)(PID_Speed->Ki*1000),3,12,mode[4]);
- OLED_ShowString(0,36 ,"SpeedPiont ");
- OLED_ShowNum(96,36,(int)(Speed->PiontSpeed),4,12,mode[5]);
- OLED_ShowNum(32,48,(int)(InductorA->LeftFinal),3,12,0);
- OLED_ShowNum(56,48,(int)(InductorA->RightFinal),3,12,0);
- OLED_ShowNum(86,48,(int)(InductorB->LeftFinal),3,12,0);
- else if(Page>30 && Page<=65){
- if(Page<=35 && Page>30) mode[0] = 0;
- else mode[0] = 1;
- if(Page<=40 && Page>35) mode[1] =0;
- else mode[1] = 1;
- if(Page<=45 && Page>40) mode[2] =0;
- else mode[2] = 1;
- if(Page<=50 && Page>45) mode[3] =0;
- else mode[3] = 1;
- if(Page<=55 && Page>50) mode[4] =0;
- else mode[4] = 1;
- if(Page<=60 && Page>55) mode[5] =0;
- else mode[5] = 1;
- if(Page<=65 && Page>60) mode[6] =0;
- else mode[6] = 1;
- if( Last!=2 ){
- Last = 2;
- OLED_ShowString(0,0,"Path P D ");
- OLED_ShowNum(48,0,(int)(PID_Path->Kp*10),3,12,mode[0]);
- OLED_ShowNum(96,0,(int)(PID_Path->Kd*100),3,12,mode[1]);
- OLED_ShowString(0,12 ,"PathPiont ");
- OLED_ShowNum(84,12,(int)(PID_Path->offset*100),3,12,mode[2]);
- OLED_ShowString(0,24 ,"Diff P D ");
- OLED_ShowNum(56,24,(int)(PID_Diff->Kp*10),3,12,mode[3]);
- OLED_ShowNum(96,24,(int)(PID_Diff->Kd*10),3,12,mode[4]);
- OLED_ShowString(0,36 ,"Diff I S ");
- OLED_ShowNum(56,36,(int)(PID_Diff->Ki*10),3,12,mode[5]);
- OLED_ShowNum(96,36,(int)(PID_Diff->offset*100),3,12,mode[6]); //差速與陀螺儀融合比率
- else if(Page>65 && Page<=105){
- if(Page<=70 && Page>65) mode[0] = 0;
- else mode[0] = 1;
- if(Page<=75 && Page>70) mode[1] =0;
- else mode[1] = 1;
- if(Page<=80 && Page>75) mode[2] =0;
- else mode[2] = 1;
- if(Page<=85 && Page>80) mode[3] =0;
- else mode[3] = 1;
- if(Page<=90 && Page>85) mode[4] =0;
- else mode[4] = 1;
- if(Page<=95 && Page>90) mode[5] =0;
- else mode[5] = 1;
- if(Page<=100 && Page>95) mode[6] =0;
- else mode[6] = 1;
- if(Page<=105 && Page>100) mode[7] =0;
- else mode[7] = 1;
- if( Last!=3 ){
- Last = 3;
- OLED_ShowString(0,0 ,"LAMAX");
- OLED_ShowNum(38,0,(int)(InductorA->LeftMax),4,12,mode[0]);
- OLED_ShowString(68,0 ,"LAMIN");
- OLED_ShowNum(108,0,(int)(InductorA->LeftMin),3,12,mode[1]);
- OLED_ShowString(0,12 ,"RAMAX");
- OLED_ShowNum(38,12,(int)(InductorA->RightMax),4,12,mode[2]);
- OLED_ShowString(68,12 ,"RAMIN");
- OLED_ShowNum(108,12,(int)(InductorA->RightMin),3,12,mode[3]);
- OLED_ShowString(0,24 ,"ZBMAX");
- OLED_ShowNum(38,24,(int)(InductorB->LeftMax),4,12,mode[4]);
- OLED_ShowString(68,24 ,"ZBMIN");
- OLED_ShowNum(108,24,(int)(InductorB->LeftMin),3,12,mode[5]);
- OLED_ShowString(0,36 ,"SpeedMax");
- OLED_ShowNum(84,36,(uint32)(Speed->PiontSpeedMax),4,12,mode[6]);
- OLED_ShowString(0,48 ,"SpeedMin");
- OLED_ShowNum(84,48,(uint32)(Speed->PiontSpeedMin),4,12,mode[7]);
- void MotorControlFlow(PWM_Type_Def *PWM, Ramp_Type_Def *Ramp){ //電機(jī)直接控制
- //如測試線序 在此處 對*PWM賦值 測試完畢再注釋
- //PWM->LiftValue = 1200;//左輪正傳 往前走
- //PWM->LiftValue = 1000;
- //PWM->LiftValue = 800;
- //PWM->RightValue = 1200;//右輪正傳 往前走
- //PWM->RightValue = 1000;
- //PWM->RightValue = 800;
- //左邊右邊都給 1000的時(shí)候 應(yīng)該是不轉(zhuǎn)的
- if(PWM->LiftValue>(PWMMAX))PWM->LiftValue = (PWMMAX);
- if(PWM->LiftValue<(PWMMIN))PWM->LiftValue = (PWMMIN);
- if(PWM->RightValue>(PWMMAX))PWM->RightValue = (PWMMAX);
- if(PWM->RightValue<(PWMMIN))PWM->RightValue = (PWMMIN);
- //此處必須先調(diào)整好 保證 PWM值是 >1000時(shí) 是前進(jìn)
- //PWM值< 1000 是后退 而且 兩輪必須一致
- //能改硬件 就改驅(qū)動(dòng)線 和 電機(jī)引線 例如
- //給同樣都是 1200 左邊電機(jī)慢速往前 右邊慢速往后 這時(shí)候 調(diào)換右電機(jī)線
- //如果出現(xiàn)如下情況 給1200 理論上是 正轉(zhuǎn) 20%占空比 但出現(xiàn)轉(zhuǎn)速很快 說明
- //驅(qū)動(dòng)線序不對 可以在這里調(diào)換 通道 或者 直接改線序
- if(PWM->LiftValue>1000){ //邊輪前進(jìn) 1000~2000
- ftm_pwm_duty(ftm2,ftm_ch3,PWM->LiftValue-1000);
- else if(PWM->LiftValue<1000){ //左輪是后退 0~1000
- ftm_pwm_duty(ftm2,ftm_ch2,1000-PWM->LiftValue);
- } //如果發(fā)現(xiàn) 此處給定的是 控制 右輪轉(zhuǎn)動(dòng) 則調(diào)換下硬件驅(qū)動(dòng)線線序 注意 是兩根兩根的調(diào)換
- if(PWM->RightValue>1000){ //右輪是前進(jìn) 1000~2000
- ftm_pwm_duty(ftm2,ftm_ch5,PWM->RightValue-1000);
- else if(PWM->RightValue<1000){ //右輪是后退 0~1000
- ftm_pwm_duty(ftm2,ftm_ch4,1000-PWM->RightValue);
- } //如果發(fā)現(xiàn) 此處給定的是 控制 左邊輪轉(zhuǎn)動(dòng) 則調(diào)換下硬件驅(qū)動(dòng)線線序 注意 是兩根兩根的調(diào)換
- uint8 timer3ms = 0, timer4_5ms=0,timer24ms=0 ,timer64ms=0;
- int main(void){
- //由于本程序閉環(huán)較多 調(diào)試過程比較繁瑣 建議一開始的時(shí)候 屏蔽掉其他環(huán)
- //只調(diào)節(jié)最基礎(chǔ)的環(huán)節(jié) 平衡車主要就是對于兩個(gè)電機(jī)的控制 其中有一個(gè)函數(shù)
- //MotorControlFlow函數(shù)是直接控制電機(jī)的 這個(gè)函數(shù)需要調(diào)試好 其要求就是
- //占空比0~1000退后 1000~2000向前 通過調(diào)換驅(qū)動(dòng)線 和 調(diào)換電機(jī)線 或者
- //調(diào)換程序中 ch2 3 4 5 的 23順序 45順序來 達(dá)到最終的效果 兩個(gè)電機(jī)
- //給1000以上是向前走 1000一下向后走 2000往前最快 0往后最快
- //當(dāng)電機(jī)輸出調(diào)整好了以后 再調(diào)節(jié)編碼器反饋 我們在MotorControlFlow函數(shù)里
- //直接給 PWM->LiftValue = 1200;PWM->RightValue = 1200; 讓兩個(gè)電機(jī)固定占空比
- //轉(zhuǎn)動(dòng) 這時(shí)候 通過IAR在線調(diào)試觀察 編碼器測速值 是否正確 是否對應(yīng)左輪右輪
- //(左電機(jī)轉(zhuǎn)動(dòng)對應(yīng)左編碼器 右電機(jī)轉(zhuǎn)動(dòng)對應(yīng)右邊編碼器 不能錯(cuò)!)
- //用手阻止一個(gè)電機(jī)觀察是否是那個(gè)電機(jī)的編碼器轉(zhuǎn)速下降 確保 編碼器的方向一致!
- //編碼器 和 電機(jī)調(diào)整好以后就方便了很多 接下來就是直立 前提是陀螺儀參數(shù)已經(jīng)整定好
- //我們調(diào)試直立的時(shí)候 要把其他環(huán)都關(guān)閉 方法如下 函數(shù)PWMFeedbackControl 是把所有環(huán)輸出
- //整合到電機(jī)PWM上的函數(shù) 其中 PWM->PiontValue = (int16)(PID_Balance->out)+ (int16)(PID_Speed->out_k[0] + PID_Speed->out_k[9]) ;
- //這句話是把 三個(gè)環(huán)的輸出 疊加在一起 我們只需要保留 直立環(huán) 這樣調(diào)節(jié)直立比較順手
- //其中還有一個(gè) 差速 也要給0 對直立就無影響
- //當(dāng)直立調(diào)節(jié)完畢后 速度環(huán)和直立的融合是比較難的 直立和速度是并環(huán) 需要精心調(diào)試,也可以
- //跳過速度環(huán)的調(diào)試 直接進(jìn)入轉(zhuǎn)向環(huán) 與差速環(huán) 他們之間是串級(jí)PID的關(guān)系
- //如果出現(xiàn)中斷 跑飛 或者 卡住在ADC死循環(huán)里 說明堆棧溢出 調(diào)整KEA128.ICF文件的 堆棧值 擴(kuò)大 不超過12K即可
- get_clk(); //獲取時(shí)鐘頻率 必須執(zhí)行
- uint8 Page=0;
- PID_Type_Def PID_Balance, PID_Speed, PID_Path, PID_Diff;
- RUN_Type_Def RUN;
- Stop_Type_Def Stop;
- Ramp_Type_Def Ramp;
- Curve_Type_Def Curve;
- Acc_Type_Def Acc;
- Gyro_Type_Def Gyro;
- Angle_Type_Def Angle;
- PWM_Type_Def PWM;
- Speed_Type_Def Speed;
- Button_Type_Def Button;
- Switch_Type_Def Switch;
- Inductor_Type_Def InductorA, InductorB;
- SensorStructurePointerInit( &Acc, &Gyro, &Angle, &Speed, &InductorA, &InductorB );//傳感器參數(shù)初始化
- PIDStructurePointerInit( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff );//PID參數(shù)初始化
- CarBalanceSystemInit( &Gyro ); //系統(tǒng)初始化
- RUN.Flag[4] = 1;//運(yùn)行出界標(biāo)志位
- RUN.Flag[5] = 0;//啟動(dòng)電機(jī)標(biāo)志位
- Stop.Flag[0] = 0;//停止線標(biāo)志位延時(shí)啟動(dòng)標(biāo)志位
- Stop.Flag[1] = 0;//停止標(biāo)志位
- Ramp.Flag[0] = 0;//接近坡道標(biāo)志位
- Ramp.Flag[1] = 0;//上坡道標(biāo)志位
- Curve.Flag[1] = 0;//正差速標(biāo)志位
- Curve.Flag[2] = 0;//反差速標(biāo)志位
- Curve.Flag[3] = 0;//差速數(shù)目
- while(1){
- if( timer4_5ms ){
- gpio_set(H2,1);//
- GetAccelerationValue( &Acc ); //加速度原始數(shù)據(jù)采集
- GetAngleSpeedValue( &Gyro ); //角速度原始數(shù)據(jù)采集
- GetSpeedValue( &Speed ); //獲取原始速度數(shù)據(jù)
- GetInductorValue( &InductorA, &InductorB );//電感電壓原始數(shù)據(jù)采集
- GyroHighPassFilter( &Gyro ); //角速度濾波處理
- AngleHardwareFilter( &Angle );//角度濾波處理
- SpeedSoftwareFilter( &Speed );//速度遞歸權(quán)值濾波
- InductorSoftwareFilter( &InductorA, &InductorB, &Angle, &Switch);//電感濾波處理
- BalanceFeedbackControl( &PID_Balance, &Angle, &Gyro, &Ramp );//平衡度反饋計(jì)算
- DirectionFeedbackControl( &PID_Path, &InductorA, &InductorB, &Gyro, &Speed, &Ramp );//路徑反饋計(jì)算
- DifferentialFeedbackControl( &PID_Diff, &Speed, &Gyro);//差速反饋計(jì)算
- PWMFeedbackControl( &PWM, &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Speed, &Switch );//PWM疊加 直立 方向 速度PWM
- MotorControlFlow( &PWM, &Ramp ); //電機(jī)PWM輸出控制
- gpio_set(H2,0);//
- timer4_5ms = 0;//清除時(shí)間標(biāo)志位
- //車子跑起來以后就不會(huì)執(zhí)行 因?yàn)殚_銷比較大 影響PID控制周期
- if( Speed.ActualSpeed[2]<100 && timer24ms && timer4_5ms != 1 ){
- GetButtonStatus( &Button ); //獲取按鍵狀態(tài)
- ButtonLowPassFilter( &Button );//判斷按鍵狀態(tài)
- ButtonFunctionControl( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Angle, &Speed, &InductorA, &InductorB, &Button, &Page );//實(shí)現(xiàn)按鍵狀態(tài)
- GetSwitchStatus( &Switch ); //獲取開關(guān)狀態(tài)
- SwitchLowPassFilter( &Switch );//判斷開關(guān)狀態(tài)
- timer24ms = 0;
- if(timer64ms && timer4_5ms != 1 ){
- if(Speed.ActualSpeed[2]<100)PrintParameterToOLED( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Angle, &Speed, &PWM, &InductorA, &InductorB, &Curve, Page );
- //人機(jī)交互界面 高速運(yùn)行不執(zhí)行
- SpeedFeedbackControl( &PID_Speed, &Speed, &Ramp, &Switch ); //速度環(huán)反饋控制
- timer64ms = 0;
- uint8 count = 0;
- void PIT_CH0_IRQHandler(void)
- if( count<84 ) count++;
- else count = 0;
- // if( count%2==0 ) timer3ms = 1;
- if( count%3==0 ) timer4_5ms = 1;
- if( count%16==0 ) timer24ms = 1;
- if( count%42==0 ) timer64ms=1;
- PIT_FlAG_CLR(pit0);//清除中斷標(biāo)志位
KEA128直立.zip
(4.71 MB, 下載次數(shù): 37)
2018-6-30 18:10 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
