#include <reg52.h>
#include "eepom52.h"
//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff}; //斷碼
//數(shù)碼管位選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
uchar dis_smg[8] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
sbit dq = P2^4; //18b20 IO口的定義
sbit beep = P2^5; //蜂鳴器IO口定義
uchar a_a;
uint temperature ; //
bit flag_300ms ;
uchar key_can; //按鍵值的變量
uchar menu_1; //菜單設(shè)計(jì)的變量
uint t_high = 300,t_low = 100;
bit flag_lj_en; //按鍵連加使能
bit flag_lj_3_en; //按鍵連3次連加后使能 加的數(shù)就越大了
uchar key_time,flag_value; //用做連加的中間變量
bit key_500ms ;
uchar flag_clock;
uchar zd_break_en,zd_break_value; //自動(dòng)退出設(shè)置界面
/***********************1ms延時(shí)函數(shù)*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************小延時(shí)函數(shù)*****************************/
void delay_uint(uint q)
while(q--);
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
uchar i;
for(i=0;i<smg_i;i++)
P3 = smg_we[i]; //位選
P1 = dis_smg[i]; //段選
delay_1ms(1);
P3 = 0xff; //位選
P1 = 0xff; //消隱
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eepom中******************/
void write_eepom()
SectorErase(0x2000);
byte_write(0x2000, t_high % 256);
byte_write(0x2001, t_high / 256);
byte_write(0x2002, t_low % 256);
byte_write(0x2003, t_low / 256);
byte_write(0x2055, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eepom中讀出來*****************/
void read_eepom()
t_high = byte_read(0x2001);
t_high <<= 8;
t_high |= byte_read(0x2000);
t_low = byte_read(0x2003);
t_low <<= 8;
t_low |= byte_read(0x2002);
a_a = byte_read(0x2055);
/***********************18b20初始化函數(shù)*****************************/
void init_18b20()
bit q;
dq = 1; //把總線拿高
delay_uint(1); //15us
dq = 0; //給復(fù)位脈沖
delay_uint(80); //750us
dq = 1; //把總線拿高 等待
delay_uint(10); //110us
q = dq; //讀取18b20初始化信號(hào)
delay_uint(20); //200us
dq = 1; //把總線拿高 釋放總線
/*************寫18b20內(nèi)的數(shù)據(jù)***************/
void write_18b20(uchar dat)
uchar i;
for(i=0;i<8;i++)
{ //寫數(shù)據(jù)是低位開始
dq = 0; //把總線拿低寫時(shí)間隙開始
dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
delay_uint(5); // 60us
dq = 1; //釋放總線
dat >>= 1;
/*************讀取18b20內(nèi)的數(shù)據(jù)***************/
uchar read_18b20()
uchar i,value;
for(i=0;i<8;i++)
dq = 0; //把總線拿低讀時(shí)間隙開始
value >>= 1; //讀數(shù)據(jù)是低位開始
dq = 1; //釋放總線
if(dq == 1) //開始讀寫數(shù)據(jù)
value |= 0x80;
delay_uint(5); //60us 讀一個(gè)時(shí)間隙最少要保持60us的時(shí)間
return value; //返回?cái)?shù)據(jù)
/*************讀取溫度的值 讀出來的是小數(shù)***************/
uint read_temp()
uint value;
uchar low; //在讀取溫度的時(shí)候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會(huì)影響到18b20的時(shí)序
init_18b20(); //初始化18b20
write_18b20(0xcc); //跳過64位ROM
write_18b20(0x44); //啟動(dòng)一次溫度轉(zhuǎn)換命令
delay_uint(50); //500us
write_18b20(0xbe); //發(fā)出讀取暫存器命令
EA = 0;
low = read_18b20(); //讀溫度低字節(jié)
value = read_18b20(); //讀溫度高字節(jié)
EA = 1;
value <<= 8; //把溫度的高位左移8位
value |= low; //把讀出的溫度低位放到value的低八位中
value *= 0.625; //轉(zhuǎn)換到溫度值 小數(shù)
return value; //返回讀出的溫度 帶小數(shù)
/*************定時(shí)器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X01; //定時(shí)器0、定時(shí)器1工作方式1
ET0 = 1; //開定時(shí)器0中斷
TR0 = 1; //允許定時(shí)器0定時(shí)
/****************獨(dú)立按鍵處理函數(shù)************************/
void key()
static uchar key_new = 0,key_old = 0,key_value = 0;
if(key_new == 0)
{ //按鍵松開的時(shí)候做松手檢測(cè)
if((P2 & 0x0f) == 0x0f)
key_value ++;
key_value = 0;
if(key_value >= 10)
write_eepom();
key_value = 0;
key_new = 1;
flag_lj_en = 0; //關(guān)閉連加使能
flag_lj_3_en = 0; //關(guān)閉3秒后使能
flag_value = 0; //清零
if((P2 & 0x0f) != 0x0f)
key_value ++; //按鍵按下的時(shí)候
key_value = 0;
if(key_value >= 7)
key_value = 0;
key_new = 0;
flag_lj_en = 1; //連加使能
zd_break_en = 1; //自動(dòng)退出設(shè)置界使能
zd_break_value = 0; //自動(dòng)退出設(shè)置界變量清零
key_can = 20;
if(key_500ms == 1)
key_500ms = 0;
key_new = 0;
key_old = 1;
if((key_new == 0) && (key_old == 1))
switch(P2 & 0x0f)
case 0x0e: key_can = 4; break; //得到k1鍵值
case 0x0d: key_can = 3; break; //得到k2鍵值
case 0x0b: key_can = 2; break; //得到k3鍵值
case 0x07: key_can = 1; break; //得到k4鍵值
key_old = key_new;
/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
void key_with()
if(key_can == 4)
menu_1 ++;
if(menu_1 >= 3)
menu_1 = 0;
if(menu_1 == 0)
dis_smg[0] = smg_du[temperature % 10]; //取溫度的小數(shù)顯示
dis_smg[1] = smg_du[temperature / 10 % 10] & 0x7f; //取溫度的個(gè)位顯示
dis_smg[2] = smg_du[temperature / 100 % 10] ; //取溫度的十位顯示
smg_i = 3;
if(menu_1 == 1)
dis_smg[0] = smg_du[t_high % 10]; //取小數(shù)顯示
dis_smg[1] = smg_du[t_high / 10 % 10] & 0x7f; //取個(gè)位顯示
dis_smg[2] = smg_du[t_high / 100 % 10] ; //取low十位顯示
dis_smg[3] = 0x89;
smg_i = 4;
if(menu_1 == 2)
dis_smg[0] = smg_du[t_low % 10]; //取low小數(shù)顯示
dis_smg[1] = smg_du[t_low / 10 % 10] & 0x7f; //取個(gè)位顯示
dis_smg[2] = smg_du[t_low / 100 % 10] ; //取十位顯示
dis_smg[3] = 0xc7;
smg_i = 4;
if(menu_1 == 1) //設(shè)置高溫報(bào)警
if(key_can == 3)
if(flag_lj_3_en == 0)
t_high ++ ; //按鍵按下未松開自動(dòng)加三次
t_high += 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
if(t_high > 990)
t_high = 990;
dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位顯示
dis_smg[3] = 0x89; //H
if(key_can == 1)
t_high -- ; //按鍵按下未松開自動(dòng)加三次
t_high -= 10; //按鍵按下未松開自動(dòng)減三次之后每次自動(dòng)減10
if(t_high <= t_low)
t_high = t_low + 1;
// write_eepom();
if(menu_1 == 2) //設(shè)置低溫報(bào)警
if(key_can == 3)
t_low ++ ;
t_low += 10;
if(t_low >= t_high)
t_low = t_high - 1;
dis_smg[0] = smg_du[t_low % 10]; //取小數(shù)顯示
dis_smg[3] = 0xc7; //L
if(key_can == 1)
t_low -- ;
t_low -= 10;
if(t_low <= 10)
t_low = 10;
// write_eepom();
/****************報(bào)警函數(shù)***************/
void clock_h_l()
if((temperature <= t_low) || (temperature >= t_high))
flag_clock = 1;
flag_clock = 0;
beep = 1;
temperature = read_temp(); //先讀出溫度的值
time_init(); //初始化定時(shí)器
read_eepom();
if(a_a == 0xff) //新的單片機(jī)初始單片機(jī)內(nèi)問EEPOM
t_high = 300;
t_low = 100;
a_a = 1;
write_eepom();
delay_1ms(650);
display(); //顯示函數(shù)
key(); //按鍵程序
if(key_can < 10)
key_with(); //設(shè)置報(bào)警溫度
if(flag_300ms == 1) //300ms 處理一次溫度程序
clock_h_l(); //報(bào)警函數(shù)
if(flag_clock == 1)
beep = ~beep;
flag_300ms = 0;
if(menu_1 == 0)
smg_i = 3;
if(zd_break_en == 1) //自動(dòng)退出設(shè)置界面程序
zd_break_value ++; //每300ms加一次
if(zd_break_value > 50) //15秒后自動(dòng)退出設(shè)置界面
menu_1 = 0;
zd_break_en = 0;
zd_break_value = 0;
/*************定時(shí)器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
value ++;
if(value % 6 == 0)
flag_300ms = 1; //300ms
value = 0;
if(flag_lj_en == 1) //按下按鍵使能
key_time ++;
if(key_time >= 10) //500ms
key_time = 0;
key_500ms = 1; //500ms
flag_value ++;
if(flag_value > 3)
flag_value = 10;
flag_lj_3_en = 1; //3次后1.5秒連加大些
