查看: 2344|回復(fù): 1
51數(shù)碼八音盒
ID:352889 發(fā)表于 2018-7-7 15:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"                         //此文件中定義了單片機(jī)的一些特殊功能寄存器
#include "SoundPlay.h"
#include"music.h"
typedef unsigned int u16;          //對數(shù)據(jù)類型進(jìn)行聲明定義
typedef unsigned char u8;
void Delay1ms(unsigned int count)
        unsigned int i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
        InitialSound();
                Play(Music_Girl,0,3,360);
                Delay1ms(500);
                Play(Music_Same,0,3,360);
                Delay1ms(500);
                Play(Music_Two,0,3,360);
                Delay1ms(500);
#ifndef __SOUNDPLAY_H_REVISION_FIRST__
#define __SOUNDPLAY_H_REVISION_FIRST__
#include"music.h"
#define SYSTEM_OSC                 12000000        //定義晶振頻率12000000HZ
#define SOUND_SPACE         4/5                 //定義普通音符演奏的長度分率,//每4分音符間隔
sbit    BeepIO    =           P1^5;                //定義輸出管腳
unsigned char value=0;
unsigned int  code FreTab[12]  = { 262,277,294,311,330,349,369,392,415,440,466,494 }; //原始頻率表
unsigned char code SignTab[7]  = { 0,2,4,5,7,9,11 };        //1~7在頻率表中的位置
unsigned char code LengthTab[7]= { 1,2,4,8,16,32,64 };
unsigned char Sound_Temp_TH0,Sound_Temp_TL0;        //音符定時器初值暫存
unsigned char Sound_Temp_TH1,Sound_Temp_TL1;        //音長定時器初值暫存
void InitialSound(void)
        BeepIO = 0;
        Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256;        // 計算TL1應(yīng)裝入的初值         (10ms的初裝值)
        Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256;        // 計算TH1應(yīng)裝入的初值
        TH1 = Sound_Temp_TH1;
        TL1 = Sound_Temp_TL1;
        TMOD  |= 0x11;
        ET0    = 1;
        ET1           = 0;
        TR0           = 0;
        TR1    = 0;
        EA     = 1;
void BeepTimer0(void) interrupt 1        //音符發(fā)生中斷
        static unsigned char i;
        BeepIO = !BeepIO;
        TH0    = Sound_Temp_TH0;
        TL0    = Sound_Temp_TL0;
        i++;
        if(i==100)
                i=0;
                value++;
                if(value==5)value=0;
void Play(unsigned char *Sound,unsigned char Signature,unsigned Octachord,unsigned int Speed)
        unsigned int NewFreTab[12];                //新的頻率表
        unsigned char i,j;
        unsigned int Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
        unsigned char Tone,Length,SL,SH,SM,SLen,XG,FD;
        for(i=0;i<12;i++)                                 // 根據(jù)調(diào)號及升降八度來生成新的頻率表
                j = i + Signature;
                if(j > 11)
                        j = j-12;
                        NewFreTab[i] = FreTab[j]*2;
                        NewFreTab[i] = FreTab[j];
                if(Octachord == 1)
                        NewFreTab[i]>>=2;
                else if(Octachord == 3)
                        NewFreTab[i]<<=2;
        SoundLength = 0;
        while(Sound[SoundLength] != 0x00)        //計算歌曲長度
                SoundLength+=2;
        Point = 0;
        Tone   = Sound[Point];
        Length = Sound[Point+1];                         // 讀出第一個音符和它時時值
        LDiv0 = 12000/Speed;                                // 算出1分音符的長度(幾個10ms)
        LDiv4 = LDiv0/4;                                         // 算出4分音符的長度
        LDiv4 = LDiv4-LDiv4*SOUND_SPACE;         // 普通音最長間隔標(biāo)準(zhǔn)
        TR0          = 0;
        TR1   = 1;
        while(Point < SoundLength)
                SL=Tone%10;        //計算出音符
                SM=Tone/10%10;        //計算出高低音
                SH=Tone/100;        //計算出是否升半
                CurrentFre = NewFreTab[SignTab[SL-1]+SH];         //查出對應(yīng)音符的頻率
                if(SL!=0)
                        if (SM==1) CurrentFre >>= 2;                 //低音
                        if (SM==3) CurrentFre <<= 2;                 //高音
                        Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//計算計數(shù)器初值
                        Sound_Temp_TH0 = Temp_T/256;
                        Sound_Temp_TL0 = Temp_T%256;
                        TL0 = Sound_Temp_TL0 + 12; //加12是對中斷延時的補(bǔ)償
                SLen=LengthTab[Length%10];         //算出是幾分音符
                XG=Length/10%10;                         //算出音符類型(0普通1連音2頓音)
                FD=Length/100;
                LDiv=LDiv0/SLen;                         //算出連音音符演奏的長度(多少個10ms)
                if (FD==1)
                        LDiv=LDiv+LDiv/2;
                if(XG!=1)
                        if(XG==0)                                 //算出普通音符的演奏長度
                                if (SLen<=4)
                                        LDiv1=LDiv-LDiv4;
                                        LDiv1=LDiv*SOUND_SPACE;
                                LDiv1=LDiv/2;                 //算出頓音的演奏長度
                        LDiv1=LDiv;
                if(SL==0) LDiv1=0;
                        LDiv2=LDiv-LDiv1;                 //算出不發(fā)音的長度
                  if (SL!=0)
                        TR0=1;
                        for(i=LDiv1;i>0;i--)         //發(fā)規(guī)定長度的音
                                while(TF1==0);
                                TF1=0;
                if(LDiv2!=0)
                        TR0=0; BeepIO=0;
                        for(i=LDiv2;i>0;i--)         //音符間的間隔
                                while(TF1==0);
                                TF1=0;
                Point+=2;
                Tone=Sound[Point];
                Length=Sound[Point+1];
        BeepIO = 0;
#endif
數(shù)碼八音盒.docx
16.44 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
ID:560798 發(fā)表于 2019-6-12 13:02 | 只看該作者
謝謝分享啊
