查看: 6391|回復(fù): 2
52單片機(jī)用ESP8266控制電機(jī)正轉(zhuǎn)反轉(zhuǎn)和停止 的程序簡(jiǎn)單邏輯
ID:367369 發(fā)表于 2018-7-9 21:08 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit P00=P0^0;
sbit P01=P0^1;//第一個(gè)輪子
sbit P02=P0^2;
sbit P03=P0^3;//第二個(gè)輪子
/**串口數(shù)據(jù)使用**/
#define        RX1_Lenth                32                        //串口接收緩沖長(zhǎng)度
uchar        idata RX1_Buffer[RX1_Lenth];        //接收緩沖
uchar        TX1_Cnt;        //發(fā)送計(jì)數(shù)
uchar        RX1_Cnt;        //接收計(jì)數(shù)
uchar i;
signed char a=0;
bit                B_TX1_Busy;        //發(fā)送忙標(biāo)志
/**wifi模塊命令**/
unsigned char        idata LYMS[13]="AT+CWMODE=2\r\n";
unsigned char idata SZLY[38]="AT+CWSAP='ESP8266','0123456789',11,0\r\n";
unsigned char idata RST[8]="AT+RST\r\n";
unsigned char idata SZDLJ[13]="AT+CIPMUX=1\r\n";
unsigned char idata KQFU[21]="AT+CIPSERVER=1,5000\r\n";
unsigned char idata FSSJ[13]="AT+CIPSEND=\r\n";//AT+CIPSEND= 發(fā)送數(shù)據(jù)
void Delay3(unsigned int N)
        int i;
        for(i=0;i<N*10;i++);
void Uart_Init(void)
     TMOD = 0x20;   //定時(shí)器工作在定時(shí)器1的方式2
     PCON = 0x00;   //不倍頻
     SCON = 0x50;        //串口工作在方式1,并且啟動(dòng)串行接收
     TH1 = 0xFd;    //設(shè)置波特率 9600
     TL1 = 0xFd;
     TR1 = 1;                //啟動(dòng)定時(shí)器1
                 IT0=1;
           IT1=1;
           EX0=1;
           EX1=1;
                 PX0=0;
           PX1=0;
                 PS=1;
           ES = 1;                //開(kāi)串口中斷
           EA = 1;                //開(kāi)總中斷
           RX1_Cnt=0;                //接受計(jì)數(shù)清零
           TX1_Cnt = 0;        //發(fā)送計(jì)數(shù)清零
           B_TX1_Busy = 0;//初始化判忙標(biāo)志位
void wifi(void)
        char i=0;
        /******************設(shè)置WiFi模塊**********************************************/
        for(i=0;i<13;i++)//AT+CWMODE=2 設(shè)置成路由模式
                SBUF=LYMS[i];Delay3(5);
        Delay3(1000);
        for(i=0;i<38;i++)//AT+CWSAP="ESP8266","0123456789",11,0 設(shè)置路由
                SBUF=SZLY[i];Delay3(5);
        Delay3(3000);
        for(i=0;i<8;i++)//AT+RST 重啟
                SBUF=RST[i];Delay3(5);
        Delay3(5000);
        for(i=0;i<13;i++)//AT+CIPMUX=1 設(shè)置成多連接
                SBUF=SZDLJ[i];Delay3(5);
        Delay3(2000);
        for(i=0;i<21;i++)//AT+CIPSERVER=1,5000 開(kāi)啟TCP服務(wù)端口
                SBUF=KQFU[i];Delay3(5);
        Delay3(2000);
void dianji1()//左上至右下
        P00=0;P01=1;
        P02=0;P03=1;
void dianji2()//右上至左下
        P00=1;P01=0;
        P02=1;P03=0;
void dianjig()//停止電機(jī)轉(zhuǎn)動(dòng)
        P00=0;P01=0;
        P02=0;P03=0;
        Uart_Init();
        wifi();
                if(a==2)
                        dianji1();
                        if(a==1)
                                dianji2();
                                if(a==3)
                                        dianjig();
void UART1_int (void) interrupt 4
        if(RI)
                RI = 0;
                RX1_Buffer[RX1_Cnt] = SBUF;                //保存一個(gè)字節(jié)
                if(RX1_Buffer[0]==0x45)
                        RX1_Cnt++;
                        RX1_Cnt=0;
                if(RX1_Cnt>=10)
                        if(RX1_Buffer[0]==0x45&&RX1_Buffer[1]==0x53&&RX1_Buffer[2]==0x50)
                                if(RX1_Buffer[4]==0x4C&&RX1_Buffer[5]==0x45&&RX1_Buffer[6]==0x44)
                                        if(RX1_Buffer[7]==0x31)
                                                if(RX1_Buffer[3]==0x44)
                                                        a=0;
                                                if(RX1_Buffer[3]==0x45)
                                                        a=1;
                                                if(RX1_Buffer[3]==0x46)
                                                        a=2;
                                                if(RX1_Buffer[3]==0x47)
                                                        a=3;
                        RX1_Cnt=0;
        if(TI)
                TI = 0;
                B_TX1_Busy = 0;                //清除發(fā)送忙標(biāo)志
ID:361216 發(fā)表于 2020-5-3 11:56 | 顯示全部樓層
能單獨(dú)用esp8266來(lái)控制電機(jī)正反停轉(zhuǎn)不呢 ?
ID:964308 發(fā)表于 2021-10-30 13:43 來(lái)自觸屏版 | 顯示全部樓層
lhqsbz 發(fā)表于 2020-5-3 11:56
可以是可以,但你的程序就要寫(xiě)在esp8266里了,esp8266用的是arduino或MicroPython,而且沒(méi)辦法用esp-01/esp-01s,因?yàn)樗鼈兌紱](méi)有io口
