查看: 1601|回復(fù): 0
求問(wèn)怎么改變蛇的初始長(zhǎng)度,以及可以幫忙看一下是用什么原理吃掉食物和蛇身變長(zhǎng)的嗎?
ID:364491 發(fā)表于 2018-7-10 12:08 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <at89x51.h>
#include "12864.h"
#include "zf.h"
uchar length[62]={0,6,1,1};
bit flag2,flag4,flag=0;
bit flag3,flag5=0;
bit flag1=0;
uchar k,dengji=2;
uchar direction=1;
uchar p=10;
sbit LED=P1;
sbit REST=P3^5;
sbit SPK=P3^4;
uchar code SONG_TONE[]=
  212,212,190,212,159,169,0
uchar code SONG_LONG[]=
  9,3,12,12,12,24,0
void delay(unsigned char n)
unsigned char a;
for(a=0;a<n;a++);
void PlayMusic()
  uint i =0,j,k;
while(SONG_LONG!=0||SONG_TONE!=0)
   for(j=0;j<SONG_LONG*20;j++)
    SPK = ~SPK;
   for(k=0;k<SONG_TONE/3;k++);
  delay(5);
  i++;
void DelayMS(uint x)
  uchar t;
while(x--)
   for(t=0;t<120;t++);
void Play(uchar t)
  uchar i;
for(i=0;i<100;i++)
   SPK = ~SPK;
  DelayMS(t);
SPK = 0;
unsigned char counter;
void zhongduan() interrupt 0 using 0
k=(P2>>6);
k=k&0x03;
if(flag)
   if(k==1)   direction=3; Play(1);
   if(k==2)  direction=1;Play(1);
   if(k==0)  direction=4;Play(1);
   if(k==3)  direction=2;Play(1);
   if(k==0)P1=0xfe;
else if(k==1)P1=0xfd;
else if(k==2)P1=0xfb;
else if(k==3)P1=0xf7;
else P1=0xff;
void zhongduan1() interrupt 2 using 2
  if(!flag5)
     flag5=1;
   Play(1);
   P1=0xef;
     flag5=0;
   Play(1);
   P1=0xef;
void dingshi() interrupt 1  using 1
   if(p--)
    TL0=0;
TH0=0xa0;
flag1=0;
     flag1=1;
  TL0=0;
  TH0=0x00;
  p=10-(dengji>>1);
main()
  uchar food[2]={12,8};
  uchar i,x,y;
  choose12864(2);
  init12864();
  clear12864();
  length[62]=2;
  delay1ms(350);
  delay1ms(350);
  choose12864(2);
  clear12864();
  vertical(1,61,30);
  vertical(1,61,127);
  for(i=0;i<98;i++)
    dot(30+i,1);
dot(30+i,62);
  play16(0,0,0,tan);
  play16(0,0,1,chi);
  play16(0,0,2,she);
  change(length,(length+1));
  change((length+2),(length+3));
  change(food,food+1);
  TMOD=1;
  IT0=1;
  IT1=1;
  EA=1;
  ET0=1;
  EX0=1;
  EX1=1;
  TL0=0x00;
  TH0=0x00;
  TR0=1;
  do
   while(flag5|!flag1);
   x=*(length);
   y=*(length+1);
   switch(direction)
   case 1:
       for(i=0;i<dengji-1;i++)
          *(length+(i<<1))=*(length+(i<<1)+2);
       *(length+(i<<1)+1)=*(length+(i<<1)+3);
        (*(length+(dengji<<1)-2))++;
     flag=0;
     break;
     case 2:
      (*(length+(dengji<<1)-1))++;
   flag=1;
   break;
  case 3:
        (*(length+(dengji<<1)-2))--;
     flag=0;
     break;
  case 4:
      (*(length+(dengji<<1)-1))--;
   flag=1;
   break;
  flag4=((*(length+(dengji<<1)-2))==food[0])&&((*(length+(dengji<<1)-1))==food[1]);
  if(flag4)
  for(i=dengji;i>0;i--)
    *(length+(i<<1))=*(length+(i<<1)-2);
    *(length+(i<<1)+1)=*(length+(i<<1)-1);
  *length=x;
  *(length+1)=y;
  dengji++;
  do
    flag3=0;
    food[0]=TL0%24;
       food[1]=TL0%15;
      if((*(length+(i<<1)))==food[0]&&((*(length+(i<<1)+1))==food[1]))
     flag3=1;
     break;
  }while(flag3);
     flag2=1;
     if(*(length+(i<<1))==*(length+(dengji<<1)-2)&&(*(length+(i<<1)+1)==*(length+(dengji<<1)-1)))
       flag2=0;
    break;
   flag2=flag2&&*(length+(dengji<<1)-2)>=0&&*(length+(dengji<<1)-2)<24;
   flag2=flag2&&*(length+(dengji<<1)-1)>=0&&*(length+(dengji<<1)-1)<15;
   if(flag2)
     clear(&x,&y);
        change(length+(dengji<<1)-2,length+(dengji<<1)-1);
   if(flag4)
     change(&x,&y);
     flag1=0;
     play8(0,0,3,shu0+((dengji/10)<<4));
     play8(0,1,3,shu0+(((dengji)%10)<<4));
   while(flag2);
   delay1ms(450);
   delay1ms(450);
   choose12864(2);
   clear12864();
   play16(0,4,1,over);
   play16(0,6,1,over+32);
   play16(1,0,1,over+64);
   play16(1,2,1,over+96);
  PlayMusic();
  SPK=1;
   delay1ms(450);
   delay1ms(450);
   if(flag5!=flag)
      (*(void(*)())0)();
  choose12864(2);
  init12864();
  clear12864();
