直流無刷電機開環(huán)控制程序-6步換向法
STM32單片機源程序如下:
- #include "stm32f10x.h"
- #include <stdio.h>
- unsigned short int CCR1_Val = 0;
- unsigned short int CCR2_Val = 0;
- unsigned short int CCR3_Val = 0;
- volatile unsigned char HALL_Value = 0;
- unsigned char HALL_flag =1;
- * 函數(shù)名稱: Timer1_Init();
- * 功能描述: 定時器1初始化
- * 輸入參數(shù): void
- * 返回參數(shù): 無
- void PWM_GPIO_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- //時鐘配置
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); // 使能GPIOA/GPIOB端口
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10; //PWM???PA8,9,10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //??????
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStructure); //???GPIO
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; //PWM???PA7
- GPIO_Init(GPIOB,&GPIO_InitStructure); //???GPIO
- * 函數(shù)名稱: HALL_GPIO_Init();
- * 功能描述: 霍爾端口初始化
- * 輸入參數(shù): void
- * 返回參數(shù): 無
- void HALL_GPIO_Init(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE); // 使能GPIOC端口
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2; //PWM???PA7
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //??????
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- * 功能描述: 定時器1初始化
- * 輸入參數(shù): void
- * 返回參數(shù): 無
- void Timer1_Init(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
- PWM_GPIO_Init(); //端口初始化
- HALL_GPIO_Init();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE); // 打開定時器1的時鐘
- // 默認20KHZ
- //設定3對PWM占空比
- CCR1_Val = 2799;
- CCR2_Val = 2799;
- CCR3_Val = 2799;
- //設置定時器相關參數(shù)
- TIM_TimeBaseInitStructure.TIM_Prescaler = 0; // 72MHZ
- TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; // 向上計數(shù)模式
- TIM_TimeBaseInitStructure.TIM_Period = 3599; // 自動重裝載計數(shù)器周期的值
- TIM_TimeBaseInitStructure.TIM_ClockDivision = 0; // 時鐘分頻系數(shù)--不分頻
- TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
- //PWM模式設置-CH1
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; //PWM模式
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //輸出使能
- TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;//互補端使能輸出
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val ; //設置占空比
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //設置輸出極性
- TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; //設置輸出端互補極性
- TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; //死區(qū)后輸出狀態(tài)
- TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set; //死區(qū)后互補端輸出狀態(tài)
- TIM_OC1Init(TIM1, &TIM_OCInitStructure);
- TIM_OCInitStructure.TIM_Pulse = CCR2_Val ;
- TIM_OC2Init(TIM1, &TIM_OCInitStructure);
- TIM_OCInitStructure.TIM_Pulse = CCR3_Val ;
- TIM_OC3Init(TIM1, &TIM_OCInitStructure);
- //死區(qū)和剎車功能配置,使用了高級定時器
- TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;//運行模式下輸出選擇
- TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;//空閑模式下輸出選擇
- TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF; //鎖定設置
- TIM_BDTRInitStructure.TIM_DeadTime = 0xc8; //死區(qū)時間--2us
- TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; //剎車功能使能
- TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;//剎車輸入極性
- TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;//自動輸出使能
- TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
- TIM_CCPreloadControl(TIM1, ENABLE); //使能預裝值
- TIM_ITConfig(TIM1, TIM_IT_COM, ENABLE); //開啟通信事件
- TIM_Cmd(TIM1, ENABLE);
- TIM_CtrlPWMOutputs(TIM1, ENABLE);
- * 函數(shù)名稱: BLDC_Hall_Convet();
- * 功能描述: 根據霍爾狀態(tài)進行換向--T1 T3 T5/T4 T6 T2排列
- * 輸入參數(shù): 無
- * 返回參數(shù): 無
- void BLDC_Hall_Convet(void)
- // char PB0_Value,PB1_Value,PB2_Value;
- // PB0_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0);
- // PB1_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1)*2;
- // PB2_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_2)*4;
- // HALL_Value = PB0_Value+PB1_Value+PB2_Value;
- HALL_Value =(unsigned char)((GPIO_ReadInputData(GPIOB) & 0x0007)); //讀轉子位置
- if(HALL_flag ==1) //正轉
- switch(HALL_Value) //根據轉子位置,決定CCER輸出相位和轉子字偏移量
- case 0x05: //配置 T3/T4
- /* Channel2 configuration */
- TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1);
- TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Enable);
- TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
- /* Channel1 configuration */
- TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
- TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
- TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_Active);
- /* Channel3 configuration */
- TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Disable);
- TIM_CCxNCmd(TIM1, TIM_Channel_3,TIM_CCxN_Enable);
- TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_InActive);
- TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
- break;
- case 0x04: //T4 T5
- TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_OCMode_PWM1);
- TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
- TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
- TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Disable);
- TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
- TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_InActive);
- break;
- case 0x06: //T5 T6
- TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_Active);
- TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_InActive);
- break;
- case 0x02: //T6 T1
- TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
- TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
- TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
- TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
- break;
- case 0x03: // T1 T2
- TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_Active);
- TIM_CCxNCmd(TIM1, TIM_Channel_2,TIM_CCxN_Enable);
- break;
- case 0x01: //T2 T3
- TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1 );
- break;
- default:break;
- void Nvic_Init(void)
- NVIC_InitTypeDef NVIC_InitStructure; //中斷結構體定?
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- NVIC_InitStructure.NVIC_IRQChannel = TIM1_TRG_COM_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //搶占優(yōu)先級0
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //從優(yōu)先級0
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能IRQ通道
- NVIC_Init(&NVIC_InitStructure);
- // 可以繼續(xù)增加,設置中斷優(yōu)先級
- void TIM1_TRG_COM_IRQHandler(void)
- /* Clear TIM1 COM pending bit */
- TIM_ClearITPendingBit(TIM1, TIM_IT_COM);
- BLDC_Hall_Convet();//換向
- int main(void)
- SystemInit(); //系統(tǒng)時鐘配置函數(shù),通過不同的時鐘定義,來選擇不同的主頻
- Nvic_Init();
- Timer1_Init();
- while(1)
復制代碼
霍爾六步換向成功.rar
(289.9 KB, 下載次數(shù): 250)
2018-7-12 00:03 上傳
點擊文件名下載附件
