具體見附件,有代碼。
單片機源程序如下:
- #include "delay.h"
- #include "GPIO.h"
- #include "config.h"
- #include "lcd_12864.h"
- #include "display.h"
- sbit key0=P1^0;
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit big_case=P1^5;
- sbit small_case=P1^6;
- long int freq,n,cap;
- //uchar n;
- uchar lcd_i;
- uint count_t0,s;
- uchar keystate='A';
- uchar code dis1[]={"<-電容測量儀->"};
- uchar code dis2[]={"頻率: Hz"};
- uchar code dis3[]={"電容: F"};
- uchar code dis4[]={"檔位:"};
- uchar code dis_auto[]={"自動擋"};
- uchar code dis_big[]={"大量程"};
- uchar code dis_small[]={"小量程"};
- //端口初始化
- void GPIO_config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.Pin = GPIO_Pin_All;
- GPIO_InitStructure.Mode = GPIO_PullUp;
- GPIO_Inilize(GPIO_P0,&GPIO_InitStructure);
- // GPIO_Inilize(GPIO_P1,&GPIO_InitStructure);
- GPIO_Inilize(GPIO_P2,&GPIO_InitStructure);
- // GPIO_Inilize(GPIO_P3,&GPIO_InitStructure);
- //定時器0初始化
- void Timer0Init(void) //1毫秒@11.0592MHz--16位自動重裝
- AUXR |= 0x80; //定時器時鐘1T模式
- TMOD &= 0xF0; //設(shè)置定時器模式
- TL0 = 0xCD; //設(shè)置定時初值
- TH0 = 0xD4; //設(shè)置定時初值
- TF0 = 0; //清除TF0標志
- TR0 = 1; //定時器0開始計時
- ET0=1;
- EA=1;
- //外部中斷0初始化
- void exint0_init()
- INT0=1;
- IT0=1;//設(shè)置INT0中斷類型(1:僅下降沿;0:上升沿和下降沿)
- EX0=1;//使能INT0
- void main()
- GPIO_config();//端口初始化
- lcd_init();//液晶初始化
- Timer0Init();//定時器0初始化
- exint0_init();//外部中斷初始化
- //顯示測量變量及檔位
- lcd_dis_str(0,0,dis1);
- lcd_dis_str(1,0,dis2);
- lcd_dis_str(2,0,dis3);
- lcd_dis_str(3,0,dis4);
- while(1)
- dis_freq(freq);
- switch(keystate)
- //默認自動擋---------------------------------------------
- case 'A':
- lcd_dis_str(3,5,dis_auto);//顯示自動擋
- if(freq>40000)
- big_case=1;
- small_case=0;
- cap = 1430000000 / (3* (freq+1));//計算電容值
- else
- big_case=0;
- small_case=1;
- cap = 1430000000 / (20001* freq)-27;//計算電容值
- dis_cap(cap);//顯示電容值
- if(key1==0)//key1按下切換到大量程
- delay_ms(5);
- if(key1==0)
- keystate='B';
- while(!key1);
- if(key2==0)//key2按下切換到小量程
- delay_ms(5);
- if(key2==0)
- keystate='C';
- while(!key2);
- break;
- //大量程檔位---------------------------------------------------
- case 'B':
- big_case=1;
- small_case=0;
- lcd_dis_str(3,5,dis_big);//顯示大量程
- if(key0==0)//key0按下切換到自動擋
- delay_ms(5);
- if(key0==0)
- keystate='A';
- while(!key0);
- delay_ms(key2==0);
- if(key2==0)
- keystate='C';
- while(!key2);
- break;
- //小量程檔位---------------------------------------------
- case 'C':
- big_case=0;
- small_case=1;
- lcd_dis_str(3,5,dis_small);//顯示小檔位
- delay_ms(5);
- if(key0==0)
- keystate='A';
- while(!key0);
- delay_ms(5);
- if(key1==0)
- keystate='B';
- while(!key1);
- break;
電容測量儀2.0.zip
(110.95 KB, 下載次數(shù): 59)
2018-7-13 15:55 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
