查看: 22316|回復(fù): 25
關(guān)于keil5的黑色背景代碼配色方案global.prop文件下載
ID:371270 發(fā)表于 2018-7-14 09:39 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
1、找到安裝Keil路徑;
2、在UV4目錄下的global.prop文件;
3、替換這個文件就可以了。
  1. # properties for all file types
  2. indent.automatic=1
  3. virtual.space=0
  4. view.whitespace=0
  5. view.endofline=0
  6. code.page=0
  7. caretline.visible=0
  8. highlight.matchingbraces=1
  9. print.syntax.coloring=1
  10. use.tab.color=1
  11. create.backup.files=0
  12. auto.load.ext.modfiles=0
  13. save.prj.before.dbg=0
  14. save.files.before.dbg=0
  15. function.scanner.project=1
  16. function.scanner.files=1
  17. function.scanner.modules=1
  18. # properties for c/cpp files
  19. syntax.colouring.cpp=1
  20. use.tab.cpp=0
  21. tabsize.cpp=2
  22. line.margin.visible.cpp=1
  23. fold.cpp=1
  24. monospaced.font.cpp=1
  25. # properties for asm files
  26. syntax.colouring.asm=1
  27. use.tab.asm=0
  28. tabsize.asm=4
  29. line.margin.visible.asm=1
  30. monospaced.font.asm=1
  31. # properties for other files
  32. use.tabs=0
  33. tabsize=4
  34. line.margin.visible.txt=0
  35. monospaced.font.txt=1
  36. # setting for code completion and syntax check
  37. cc.autolist=1
  38. cc.highlightsyntax=1
  39. cc.showparameters=1
  40. cc.triggerlist=0
  41. cc.triggernumchars=3
  42. cc.enter.as.fillup=0
  43. # autosave for editor files
  44. autosave=0
  45. autosave.interval=5
  46. # vertical edge at right margin
  47. edge.mode=0
  48. edge.column=80
  49. # Specification for text selection and caret line
  50. selection.fore=#000000
  51. selection.back=#FFFFFF
  52. caret.fore=#D8D8D8
  53. caret.back=#3E3E3E
  54. # Color for vertical edge
  55. edge.colour=#66FAFA
  56. # C/C++ Editor files
  57. template.cpp="#define","#define |";"#if","#if |\r\n\r\n#endif";\\
  58.     "#include","#include ";"Header","// Header:\r\n// File Name: |\r\n// Author:\r\n// Date:\r\n";\\
  59.     "continue","continue;";"do","do\r\n{\r\n\t// TODO: enter the block content here\r\n\t\r\n\t|\r\n} while ();\r\n";\\
  60.     "enum","enum |\r\n{\r\n\t\r\n};\r\n";"for","for(|;;)\r\n{\r\n}";\\
  61.     "fpointer_type","typedef int (* |F)();\r\n";"function","void function(|)\r\n{\r\n\r\n}\r\n";\\
  62.     "if","if (|)";"ifelse","if (|)\r\n{\r\n}\r\nelse\r\n{\r\n}";\\
  63.     "struct","struct | \r\n{\r\n\r\n};\r\n";"switch","switch (|)\r\n{\r\n\tcase:\r\n\t\tbreak;\r\n\tcase:\r\n\t\tbreak;\r\n\tdefault:\r\n\t\tbreak;\r\n}";\\
  64.     "void","void | ();\r\n";"while","while (|)\r\n{\r\n}";\\
  65.
  66. font.monospace.cpp=Consolas
  67. style.cpp.32=font:Consolas,size:12,fore:#CFCFCF,back:#2F2F2F
  68. style.cpp.4=font:Consolas,size:12,fore:#FF2291,back:#2F2F2F
  69. style.cpp.10=font:Consolas,size:12,fore:#0098E1,back:#2F2F2F
  70. style.cpp.1=font:Consolas,size:12,fore:#8080FF,back:#2F2F2F
  71. style.cpp.2=font:Consolas,size:12,fore:#7F7F7F,back:#2F2F2F
  72. style.cpp.5=font:Consolas,size:12,fore:#FF00FF,back:#2F2F2F,italics
  73. style.cpp.6=font:Consolas,size:12,fore:#80FF80,back:#2F2F2F
  74. style.cpp.11=font:Consolas,size:12,fore:#FFFFFF,back:#2F2F2F
  75. style.cpp.9=font:Consolas,size:12,fore:#FF8080,back:#2F2F2F
  76. style.cpp.7=font:Consolas,size:12,fore:#FF0080,back:#2F2F2F
  77. style.cpp.34=font:Consolas,size:12,fore:#500000,back:#20FFFF
  78. style.cpp.35=font:Consolas,size:12,fore:#FF0000,back:#FFFFFF
  79. style.cpp.16=font:Consolas,size:12,fore:#D9006C,back:#FFFFFF
  80. style.cpp.12=font:Consolas,size:12,fore:#000000,back:#E0C0E0
  81. # Asm Editor files
  82. font.monospace.asm=Courier New
  83. style.asm.32=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
  84. style.asm.1=font:Courier New,size:10,fore:#808040,back:#2F2F2F
  85. style.asm.2=font:Courier New,size:10,fore:#D56A00,back:#2F2F2F
  86. style.asm.3=font:Courier New,size:10,fore:#FF8040,back:#2F2F2F
  87. style.asm.4=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
  88. style.asm.5=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
  89. style.asm.6=font:Courier New,size:10,fore:#FFFF80,back:#2F2F2F
  90. style.asm.7=font:Courier New,size:10,fore:#FFFF80,back:#2F2F2F
  91. style.asm.9=font:Courier New,size:10,fore:#80FFFF,back:#2F2F2F
  92. style.asm.10=font:Courier New,size:10,fore:#80FFFF,back:#2F2F2F
  93. style.asm.11=font:Courier New,size:10,fore:#007F00,back:#2F2F2F
  94. style.asm.12=font:Courier New,size:10,fore:#FF80FF,back:#2F2F2F
  95. style.asm.8=font:Courier New,size:10,fore:#46AA03,back:#2F2F2F
  96. # Editor Text files
  97. font.monospace.txt=Courier New
  98. style.txt.32=font:Verdana,size:10,fore:#FFFFFF,back:#2F2F2F
全部資料51hei下載地址:
keil5 代碼配色.rar (1.55 KB, 下載次數(shù): 906)
admin + 50 共享資料的黑幣獎勵!
收藏收藏6 分享淘帖 頂3 踩
ID:373228 發(fā)表于 2018-7-17 13:28 | 只看該作者
下載積分不夠,能分享下嗎,BYS9588@126.com
ID:334979 發(fā)表于 2018-8-3 09:16 | 只看該作者
沒用,最后全部變黑
ID:281904 發(fā)表于 2018-8-27 22:23 | 只看該作者
很棒,很好看,謝謝分享
ID:195187 發(fā)表于 2018-8-28 17:15 | 只看該作者
下載了試試,看起來不錯啊。
ID:195187 發(fā)表于 2018-8-28 17:40 | 只看該作者
無需下載,復(fù)制代碼,粘貼到修改哪個文件就好了。
ID:63042 發(fā)表于 2018-9-6 09:28 | 只看該作者
謝謝分享啊 。。。。。。。。。!
ID:278651 發(fā)表于 2018-10-26 19:23 | 只看該作者
謝謝分享啊 !。。。。。。。
ID:345098 發(fā)表于 2018-11-18 22:36 | 只看該作者
謝謝。。。。。
ID:469833 發(fā)表于 2019-2-28 17:08 | 只看該作者
謝謝0000
ID:529757 發(fā)表于 2019-5-7 16:49 | 只看該作者
感謝大佬
ID:529757 發(fā)表于 2019-5-7 16:50 | 只看該作者
lb342 發(fā)表于 2018-8-28 17:40
感謝大佬
ID:283987 發(fā)表于 2019-5-10 16:32 | 只看該作者
z謝謝分享
ID:183159 發(fā)表于 2019-7-16 14:08 | 只看該作者
謝謝分享
ID:585378 發(fā)表于 2019-7-16 20:57 來自觸屏版 | 只看該作者
謝謝樓主分享
ID:599284 發(fā)表于 2019-8-12 10:19 | 只看該作者
感謝分享!。。。。!1
ID:469359 發(fā)表于 2019-8-28 21:40 | 只看該作者
劉溜溜 發(fā)表于 2018-8-3 09:16
沒用,最后全部變黑
我也是
ID:550240 發(fā)表于 2019-8-31 07:58 | 只看該作者
到底可不可以用
ID:626813 發(fā)表于 2019-10-19 22:17 | 只看該作者
有用,謝謝分享
ID:148363 發(fā)表于 2019-11-11 15:29 | 只看該作者
lz牛逼 這個配色賊好看
ID:46750 發(fā)表于 2019-11-19 14:29 | 只看該作者
謝謝分享啊 。。。。。。。。。!
ID:660292 發(fā)表于 2019-12-10 09:38 | 只看該作者
good下載下來看看
ID:322454 發(fā)表于 2020-2-22 10:25 | 只看該作者
好的,謝謝
ID:69057 發(fā)表于 2020-4-18 13:30 | 只看該作者
謝謝了
ID:966260 發(fā)表于 2024-10-24 16:41 | 只看該作者
謝謝,非常好看
ID:828160 發(fā)表于 2024-11-4 21:32 | 只看該作者
vs code了解一下,vs code安裝一個插件eide,就可以建工程了,可以編譯、仿真、燒錄,也可以安裝keil助手,直接打開keil的工程,keil就只用來建工程,vs code可以調(diào)用keil進(jìn)行編譯,燒錄。
