#include<reg52.h>
uchar code table[]=".. Play ball! ....";
uchar code table1[]="Welcome to here!" ;
sbit key_ST=P1^5; //功能鍵(開(kāi)始/暫停)
sbit key_A1=P1^0; //功能鍵(A隊(duì)分?jǐn)?shù)加1)
sbit key_A2=P1^3; //功能鍵(A隊(duì)分?jǐn)?shù)加2)
sbit key_1A=P1^6; //功能鍵(A隊(duì)分?jǐn)?shù)減1)
sbit key_B1=P1^1; //功能鍵(B隊(duì)分?jǐn)?shù)加1)
sbit key_B2=P1^4; //功能鍵(B隊(duì)分?jǐn)?shù)加2)
sbit key_1B=P1^7; //功能鍵(B隊(duì)分?jǐn)?shù)減1)
sbit key_EX=P1^2; //功能鍵(交換場(chǎng)地,A/B兩隊(duì)分?jǐn)?shù)交換)
sbit key_JS=P3^0; //功能鍵(比賽節(jié)數(shù)加1)
sbit FMQ=P3^3; //蜂鳴器
sbit lcdrs=P3^5; //LCD顯示的數(shù)據(jù)/命令選擇端
sbit lcden=P3^4; //LCD顯示的使能信號(hào)
uchar flag,ms,mg,ss,sg,ags,agg,bgs,bgg,num,num1,num2,js=1,C,D,t,min=11,time_fmq;
int sec=59;
void delayms(uint xms) //定義延時(shí)函數(shù)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void write_data(uchar date) //定義為數(shù)據(jù)模式
lcdrs=1;
P0=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void write_com(uchar com) //定義為命令模式
lcdrs=0;
P0=com;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void lcd_init() //LCD顯示屏的初始化
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
void init() //LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
lcden=0;
write_com(0x82);
write_data('T');
write_data('-');
write_com(0x8a);
write_data('Q');
write_data('-');
write_com(0x80+0x43);
write_data('A');
write_data(':');
write_com(0x80+0x49);
write_data('B');
write_data(':');
void init_start() //LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
lcden=0;
/* write_com(0x80+0x10);
for(num2=0;num2<16;num2++)
write_data(table1[num2]);
delayms(5);
write_com(0x80+0x50);
for(num2=0;num2<17;num2++)
write_data(table[num2]);
delayms(5);
write_com(0x18);
delayms(400);
void display(uchar min,int sec,uchar C,uchar D,uchar js) //顯示函數(shù)
ss=sec/10;
sg=sec%10;
ms=min/10;
mg=min%10;
ags=C/10;
agg=C%10;
bgs=D/10;
bgg=D%10;
write_com(0x84);
write_data(0x30+ms);
write_data(0x30+mg);
write_data(':');
write_data(0x30+ss);
write_data(0x30+sg);
write_com(0x8d-1);
write_data(0x30+js);
write_com(0x80+0x45);
write_data(0x30+ags);
write_data(0x30+agg);
write_com(0x80+0x4b);
write_data(0x30+bgs);
write_data(0x30+bgg);
TMOD=0x11; //定義定時(shí)器0的工作方式為0001
TH0=(65536-45872)/256; //裝初值
TL0=(65536-45872)%256;
TH1=(65536-45872)/256; //裝初值
TL1=(65536-45872)%256;
EA=1; //打開(kāi)總中斷
ET0=1; //打開(kāi)定時(shí)器0的中斷
TR0=0;
ET1=1;
TR1=0;
lcd_init();
init_start();
TR1=0;
if(key_ST==0)
delayms(5);
if(key_ST==0)
FMQ=0;
if(flag==0)
lcd_init();
init();
flag=1;
TR0=~TR0;
while(!key_ST)
display(min,sec,C,D,js);
FMQ=1;
if(key_A1==0)
delayms(5);
if(key_A1==0)
FMQ=0;
C++;
while(!key_A1)
FMQ=1;
if(key_A2==0)
delayms(5);
if(key_A2==0)
FMQ=0;
C+=2;
while(!key_A2)
FMQ=1;
if(key_1A==0)
delayms(5);
if(key_1A==0)
FMQ=0;
C--;
while(!key_1A)
FMQ=1;
if(key_B1==0)
delayms(5);
if(key_B1==0)
FMQ=0;
D++;
while(!key_B1)
FMQ=1;
if(key_B2==0)
delayms(5);
if(key_B2==0)
FMQ=0;
D+=2;
while(!key_B2)
FMQ=1;
if(key_1B==0)
delayms(5);
if(key_1B==0)
FMQ=0;
D--;
while(!key_1B)
FMQ=1;
/* while(min==0&&sec==0)
TR0=0;
TR1=1;
if(key_ST==0)
delayms(5);
if(key_ST==0)
FMQ=0;
min=11;
sec=60;
TR0=~TR0;
while(!key_ST)
FMQ=1;
if((key_EX==0)&&(js==2))
delayms(10);
if((key_EX==0)&&(js=2))
FMQ=0;
write_data('B');
write_data('A');
D=C;
t=D;
C=t;
/*t=C;
C=D;
D=t; */
while(!key_EX)
FMQ=1;
if(key_JS==0)
delayms(10);
if(key_JS==0)
FMQ=0;
js++;
while(!key_JS)
display(min,sec,C,D,2);
FMQ=1;
void T0_time()interrupt 1 //中斷0控制晶碼管顯示時(shí)間
TH0=(65536-45872)/256; // 重裝初值
num++;
if(num==20)
num=0;
sec--;
if(sec<0)
sec=59;
min--;
void T1_time()interrupt 3 //中斷0控制晶碼管顯示時(shí)間
TH1=(65536-45872)/256; // 重裝初值
num1++;
if(num1==20)
num1=0;
time_fmq++;
if(time_fmq>=4)
FMQ=1;
FMQ=0;
