資料來自于ST官網(wǎng),需要的朋友自取
2018-7-14 21:45 上傳
- * @file Multi/Examples/MotionControl/IHM13A1_ExampleFor1BiDirMotor/Src/main.c
- * @author IPC Rennes
- * @version V1.3.0
- * @date March 16th, 2018
- * @brief This example shows how to use one X-NUCLEO-IHM13A1 expansion board with
- * 1 bidirectionnal Brush DC motor.
- * The demo sequence starts when the user button is pressed.
- * Each time, the user button is pressed, the demo step is changed
- * @attention
- * <h2><center>© COPYRIGHT(c) 2018 STMicroelectronics</center></h2>
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /** @defgroup IHM13A1_Example_for_1_Bidirectionnal_motor
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define MAX_STEPS (11)
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static volatile uint16_t gLastError;
- static volatile bool gButtonPressed = FALSE;
- static volatile uint8_t gStep = MAX_STEPS;
- Stspin240_250_Init_t gStspin240_250InitParams =
- {20000}, // Frequency of PWM of Input Bridge in Hz up to 100000Hz
- 20000, // Frequency of PWM used for Ref pin in Hz up to 100000Hz
- 50, //Duty cycle of PWM used for Ref pin (from 0 to 100)
- 0 // Dual Bridge configuration ( always FALSE for STSPIN250)
- /* Private function prototypes -----------------------------------------------*/
- static void MyFlagInterruptHandler(void);
- void ButtonHandler(void);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program
- * @param None
- * @retval None
- int main(void)
- /* STM32xx HAL library initialization */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Configure KEY Button */
- BSP_PB_Init(BUTTON_KEY, BUTTON_MODE_EXTI);
- /* Set Systick Interrupt to the highest priority to have HAL_Delay working*/
- /* under the user button handler */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0x0, 0x0);
- //----- Init of the Motor control library
- /* Set the Stspin240_250 library to use 1 device */
- BSP_MotorControl_SetNbDevices(BSP_MOTOR_CONTROL_BOARD_ID_STSPIN250, 1);
- /* When BSP_MotorControl_Init is called with NULL pointer, */
- /* the Stspin240_250 library parameters are set with the predefined values from file */
- /* stspin240_250_target_config.h, otherwise the registers are set using the */
- /* Stspin240_250_Init_t pointer structure */
- /* Uncomment the call to BSP_MotorControl_Init below to initialize the */
- /* device with the structure gStspin240_250InitParams declared in the the main.c file */
- /* and comment the subsequent call having the NULL pointer */
- BSP_MotorControl_Init(BSP_MOTOR_CONTROL_BOARD_ID_STSPIN250, &gStspin240_250InitParams);
- //BSP_MotorControl_Init(BSP_MOTOR_CONTROL_BOARD_ID_STSPIN250, NULL);
- /* Disable Dual bridge configuration as it is not supported by STSPIN250*/
- BSP_MotorControl_SetDualFullBridgeConfig(0);
- /* Attach the function MyFlagInterruptHandler (defined below) to the flag interrupt */
- BSP_MotorControl_AttachFlagInterrupt(MyFlagInterruptHandler);
- /* Attach the function Error_Handler (defined below) to the error Handler*/
- BSP_MotorControl_AttachErrorHandler(Error_Handler);
- /* Set PWM Frequency of Ref to 15000 Hz */
- BSP_MotorControl_SetRefFreq(0,15000);
- /* Set PWM duty cycle of Ref to 60% */
- BSP_MotorControl_SetRefDc(0,60);
- /* Set PWM Frequency of bridge A inputs to 10000 Hz */
- BSP_MotorControl_SetBridgeInputPwmFreq(0,10000);
- /* Infinite loop */
- while(1)
- /* Each time the user button is pressed, the step is increased by 1 */
- if (gButtonPressed)
- gButtonPressed = FALSE;
- gStep++;
- if (gStep > MAX_STEPS)
- gStep = 0;
- switch (gStep)
- case 0:
- /*********** Step 0 ************/
- /* Set speed of motor 0 to 100 % */
- BSP_MotorControl_SetMaxSpeed(0,100);
- /* start motor 0 to run forward*/
- /* if chip is in standby mode */
- /* it is automatically awakened */
- BSP_MotorControl_Run(0, FORWARD);
- break;
- case 1:
- /*********** Step 1 ************/
- /* Set speed of motor 0 to 75 % */
- BSP_MotorControl_SetMaxSpeed(0,75);
- break;
- case 2:
- /*********** Step 2 ************/
- /* Set speed of motor 0 to 50 % */
- BSP_MotorControl_SetMaxSpeed(0,50);
- break;
- case 3:
- /*********** Step 3 ************/
- /* Set speed of motor 0 to 25 % */
- BSP_MotorControl_SetMaxSpeed(0,25);
- break;
- case 4:
- /*********** Step 4 ************/
- /* Stop Motor 0 */
- BSP_MotorControl_HardStop(0);
- break;
- case 5:
- /*********** Step 5 ************/
- /* start motor 0 to run backward */
- BSP_MotorControl_Run(0, BACKWARD);
- break;
- case 6:
- /*********** Step 6 ************/
- break;
- case 7:
- /*********** Step 7 ************/
- break;
- case 8:
- /*********** Step 8 ************/
- break;
- case 9:
- /*********** Step 9 ************/
- /* Stop motor and disable bridge */
- BSP_MotorControl_CmdHardHiZ(0);
- break;
- case 10:
- /*********** Step 10 ************/
- /* Start motor to go forward*/
- BSP_MotorControl_Run(0,FORWARD);
- break;
- case 11:
- default:
- /*********** Step 11 ************/
- /* Stop motor and put chip in standby mode */
- BSP_MotorControl_Reset(0);
- break;
- * @brief This function is the User handler for the flag interrupt
- * @param None
- * @retval None
- void MyFlagInterruptHandler(void)
- /* Code to be customised */
- /* Get the state of bridge */
- uint16_t bridgeState = BSP_MotorControl_CmdGetStatus(0);
- if (bridgeState == 0)
- if (BSP_MotorControl_GetDeviceState(0) != INACTIVE)
- /* Bridges were disabled due to overcurrent or over temperature */
- /* When motor was running */
- Error_Handler(0XBAD0);
- * @brief This function is executed in case of error occurrence.
- * @param error number of the error
- * @retval None
- void Error_Handler(uint16_t error)
- /* Backup error number */
- gLastError = error;
- while(1)
- * @brief This function is executed when the Nucleo User button is pressed
- * @retval None
- gButtonPressed = TRUE;
- /* Let 300 ms before clearing the IT for key debouncing */
- HAL_Delay(300);
- __HAL_GPIO_EXTI_CLEAR_IT(KEY_BUTTON_PIN);
- HAL_NVIC_ClearPendingIRQ(KEY_BUTTON_EXTI_IRQn);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
低壓有刷直流馬達(dá)驅(qū)動(dòng)-適合stm32全系列.zip
(12.5 MB, 下載次數(shù): 34)
2018-7-14 21:38 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
