UCOS + 紅外控制+編碼為志高空調(diào)遙控器編碼
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "key.h"
- #include "IR_ENCODE.h"
- #include "pwm.h"
- #include "includes.h"
- #include "remote.h"
- #include "24cxx.h"
- #include "myiic.h"
- #include "touch.h"
- #define KEYMSG_Q_NUM 1 //按鍵消息隊(duì)列的數(shù)量
- #define RMOTEMSG_Q_NUM 1 //按鍵消息隊(duì)列的數(shù)量
- OS_Q KEY_Msg; //定義一個消息隊(duì)列,用于按鍵消息傳遞,模擬消息郵箱
- //OS_Q REMOTE_Msg;
- OS_SEM *REMOTE_Sem;
- //任務(wù)優(yōu)先級
- #define START_TASK_PRIO 3
- //任務(wù)堆棧大小
- #define START_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB StartTaskTCB;
- //任務(wù)堆棧
- CPU_STK START_TASK_STK[START_STK_SIZE];
- //任務(wù)函數(shù)
- void start_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define TASK1_TASK_PRIO 5
- //任務(wù)堆棧大小
- #define TASK1_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task1_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK1_TASK_STK[TASK1_STK_SIZE];
- void task1_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define TASK2_TASK_PRIO 6
- //任務(wù)堆棧大小
- #define TASK2_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task2_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK2_TASK_STK[TASK2_STK_SIZE];
- void task2_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define TASK3_TASK_PRIO 4
- //任務(wù)堆棧大小
- #define TASK3_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task3_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK3_TASK_STK[TASK3_STK_SIZE];
- void task3_task(void *p_arg);
- //任務(wù)優(yōu)先級
- #define TASK4_TASK_PRIO 7
- //任務(wù)堆棧大小
- #define TASK4_STK_SIZE 128
- //任務(wù)控制塊
- OS_TCB Task4_TaskTCB;
- //任務(wù)堆棧
- CPU_STK TASK4_TASK_STK[TASK4_STK_SIZE];
- void task4_task(void *p_arg);
- //u8 share_resource[30]; //共享資源區(qū)
- static u8 ucLCD_SW=1;
- //主函數(shù)
- int main(void)
- OS_ERR err;
- u32 Timer3_Frq;
- CPU_SR_ALLOC();
- delay_init(); //時鐘初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//中斷分組配置
- uart_init(115200); //串口初始化
- LED_Init(); //LED初始化
- LCD_Init(); //LCD初始化
- KEY_Init(); //按鍵初始化
- tp_dev.init();
- Timer3_Frq=38500;
- PWM_Freq_Set(Timer3_Frq); //38KHz
- Remote_Init(); //初始化紅外接收
- POINT_COLOR = RED;
- LCD_Clear(LIGHTBLUE);
- OSInit(&err); //初始化UCOSIII
- OS_CRITICAL_ENTER(); //進(jìn)入臨界區(qū)
- //創(chuàng)建開始任務(wù)
- OSTaskCreate((OS_TCB * )&StartTaskTCB, //任務(wù)控制塊
- (CPU_CHAR * )"start task", //任務(wù)名字
- (OS_TASK_PTR )start_task, //任務(wù)函數(shù)
- (void * )0, //傳遞給任務(wù)函數(shù)的參數(shù)
- (OS_PRIO )START_TASK_PRIO, //任務(wù)優(yōu)先級
- (CPU_STK * )&START_TASK_STK[0], //任務(wù)堆棧基地址
- (CPU_STK_SIZE)START_STK_SIZE/10, //任務(wù)堆棧深度限位
- (CPU_STK_SIZE)START_STK_SIZE, //任務(wù)堆棧大小
- (OS_MSG_QTY )0, //任務(wù)內(nèi)部消息隊(duì)列能夠接收的最大消息數(shù)目,為0時禁止接收消息
- (OS_TICK )0, //當(dāng)使能時間片輪轉(zhuǎn)時的時間片長度,為0時為默認(rèn)長度,
- (void * )0, //用戶補(bǔ)充的存儲區(qū)
- (OS_OPT )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR, //任務(wù)選項(xiàng)
- (OS_ERR * )&err); //存放該函數(shù)錯誤時的返回值
- OS_CRITICAL_EXIT(); //退出臨界區(qū)
- OSStart(&err); //開啟UCOSIII
- //開始任務(wù)函數(shù)
- OS_ERR err;
- CPU_SR_ALLOC();
- p_arg = p_arg;
- CPU_Init();
- #if OS_CFG_STAT_TASK_EN > 0u
- OSStatTaskCPUUsageInit(&err); //統(tǒng)計任務(wù)
- #endif
- #ifdef CPU_CFG_INT_DIS_MEAS_EN //如果使能了測量中斷關(guān)閉時間
- CPU_IntDisMeasMaxCurReset();
- #endif
- #if OS_CFG_SCHED_ROUND_ROBIN_EN //當(dāng)使用時間片輪轉(zhuǎn)的時候
- //使能時間片輪轉(zhuǎn)調(diào)度功能,時間片長度為1個系統(tǒng)時鐘節(jié)拍,既1*5=5ms
- OSSchedRoundRobinCfg(DEF_ENABLED,1,&err);
- #endif
- CreateBtn();
- //創(chuàng)建消息隊(duì)列KEY_Msg
- OSQCreate ((OS_Q* )&KEY_Msg, //消息隊(duì)列
- (CPU_CHAR* )"KEY Msg", //消息隊(duì)列名稱
- (OS_MSG_QTY )KEYMSG_Q_NUM, //消息隊(duì)列長度,這里設(shè)置為1
- (OS_ERR* )&err); //錯誤碼
- OSSemCreate( (OS_SEM*)REMOTE_Sem,//消息隊(duì)列長度,這里設(shè)置為1
- "Rmote Sem",
- 0,
- //創(chuàng)建TASK1任務(wù)
- OSTaskCreate((OS_TCB * )&Task1_TaskTCB,
- (CPU_CHAR * )"Task1 task",
- (OS_TASK_PTR )task1_task,
- (void * )0,
- (OS_PRIO )TASK1_TASK_PRIO,
- (CPU_STK * )&TASK1_TASK_STK[0],
- (CPU_STK_SIZE)TASK1_STK_SIZE/10,
- (CPU_STK_SIZE)TASK1_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- //創(chuàng)建TASK2任務(wù)
- OSTaskCreate((OS_TCB * )&Task2_TaskTCB,
- (CPU_CHAR * )"Task2 task",
- (OS_TASK_PTR )task2_task,
- (void * )0,
- (OS_PRIO )TASK2_TASK_PRIO,
- (CPU_STK * )&TASK2_TASK_STK[0],
- (CPU_STK_SIZE)TASK2_STK_SIZE/10,
- (CPU_STK_SIZE)TASK2_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- OSTaskCreate((OS_TCB * )&Task3_TaskTCB,
- (CPU_CHAR * )"Task3 task",
- (OS_TASK_PTR )task3_task,
- (void * )0,
- (OS_PRIO )TASK3_TASK_PRIO,
- (CPU_STK * )&TASK3_TASK_STK[0],
- (CPU_STK_SIZE)TASK3_STK_SIZE/10,
- (CPU_STK_SIZE)TASK3_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- OSTaskCreate((OS_TCB * )&Task4_TaskTCB,
- (CPU_CHAR * )"Task4 task",
- (OS_TASK_PTR )task4_task,
- (void * )0,
- (OS_PRIO )TASK4_TASK_PRIO,
- (CPU_STK * )&TASK4_TASK_STK[0],
- (CPU_STK_SIZE)TASK4_STK_SIZE/10,
- (CPU_STK_SIZE)TASK4_STK_SIZE,
- (OS_MSG_QTY )0,
- (OS_TICK )0,
- (void * )0,
- (OS_ERR * )&err);
- OSTaskDel((OS_TCB*)0,&err); //刪除start_task任務(wù)自身
- //任務(wù)1的任務(wù)函數(shù)
- void task1_task(void *p_arg) //觸屏按鍵處理
- OS_ERR err;
- u8 key;
- u8 ucAirCndiSw=KEY0_PRES; //初始為開
- u8 ucBtnId=-1;
- u8 task1_str[]="First task Running!";
- while(1)
- key = KEY_Scan(0); //掃描按鍵
- if(key)
- //發(fā)送消息
- OSQPost((OS_Q* )&KEY_Msg,
- (void* )&key,
- (OS_MSG_SIZE)1,
- (OS_OPT )OS_OPT_POST_FIFO,
- (OS_ERR* )&err);
- ucBtnId=BtnProcess();
- if(ucBtnId!= (u8)(-1) && ucLCD_SW) //屏幕開著時候
- switch(ucBtnId)
- case 0:
- if(stIrTime.StartTime>5) //開始時間+
- stIrTime.StartTime-=5;
- LCD_ShowNum(145,12,stIrTime.StartTime,3,16);
- break;
- case 1:
- if(stIrTime.StartTime<=115) //開始時間-
- stIrTime.StartTime+=5;
- break;
- case 2:
- if(stIrTime.OnTime>5)
- stIrTime.OnTime-=5;
- LCD_ShowNum(145,37,stIrTime.OnTime,3,16);
- break;
- case 3:
- if(stIrTime.OnTime<=115)
- stIrTime.OnTime+=5;
- break;
- case 4:
- if(stIrTime.OffTime>5)
- stIrTime.OffTime-=5;
- LCD_ShowNum(145,62,stIrTime.OffTime,3,16);
- break;
- case 5:
- if(stIrTime.OffTime<=115)
- stIrTime.OffTime+=5;
- break;
- case 6: //開關(guān)空調(diào)
- if(KEY0_PRES== ucAirCndiSw)
- ucAirCndiSw= KEY1_PRES;
- else if(KEY1_PRES== ucAirCndiSw)
- ucAirCndiSw= KEY0_PRES;
- (void* )&ucAirCndiSw,
- (OS_MSG_SIZE)1,
- (OS_ERR* )&err);
- break;
- case 7: //LCD 背光開關(guān)
- ucLCD_SW=0;
- LCD_DisplayOff();
- OSTimeDlyHMSM(0,0,0,100,OS_OPT_TIME_PERIODIC,&err); //延時1s
- break;
- default: break;
- //LCD_ShowNum(40,250,btn_id,2,16);
- else if(DEF_PRESS_DOWN)
- ucLCD_SW=1;
- LCD_DisplayOn();
- //任務(wù)2的任務(wù)函數(shù)
- void task2_task(void *p_arg) //自動開關(guān)機(jī)
- OS_ERR err;
- OS_TICK Os_Tick;
- u8 uc_ir_sendfg=0;
- u32 ulDelayTime=0;
- CPU_SR_ALLOC();
- stIrTime.StartTime=120;//開始時間
- stIrTime.OnTime=30;//開啟時間
- stIrTime.OffTime=20;
- LCD_ShowString(30,100,200,16,16,"Sys Time ");
- LCD_ShowChar(120,100,':',16,0);
- LCD_ShowChar(146,100,':',16,0);
- SetRmtIntStat(DISABLE);
- Continues_Send(IR_SEND_OPEN);
- SetRmtIntStat(ENABLE);
- while(1)
- Os_Tick= OSTimeGet(&err)/OSCfg_TickRate_Hz;
- LCD_ShowNum(148,100,Os_Tick%60,2,16);
- LCD_ShowNum(124,100,Os_Tick/60%60,2,16);
- LCD_ShowNum(100,100,Os_Tick/3600,2,16);
- if((Os_Tick/60)>stIrTime.StartTime ) //開始時間之后,開始間隔開關(guān)機(jī)
- if(Os_Tick> ulDelayTime )
- if(uc_ir_sendfg)
- ulDelayTime=Os_Tick+ stIrTime.OnTime*60; //
- LCD_ShowString(50,140,200,16,16,"Timer OPEN ");
- else
- ulDelayTime=Os_Tick+ stIrTime.OffTime*60; //
- Continues_Send(IR_SEND_CLOSE);
- LCD_ShowString(50,140,200,16,16,"Timer CLOSE");
- uc_ir_sendfg=!uc_ir_sendfg;
- OSTimeDlyHMSM(0,0,1,0,OS_OPT_TIME_PERIODIC,&err); //延時1s
- void task3_task(void *p_arg) //按鍵處理
- OS_ERR err;
- u8 *key;
- OS_MSG_SIZE size;
- CPU_SR_ALLOC();
- while(1)
- //請求消息KEY_Msg
- key=OSQPend((OS_Q* )&KEY_Msg,
- (OS_TICK )0,
- (OS_OPT )OS_OPT_PEND_BLOCKING,
- (OS_MSG_SIZE* )&size,
- (CPU_TS* )0,
- (OS_ERR* )&err);
- switch(*key)
- case WKUP_PRES: //KEY_UP控制LED1
- ucLCD_SW=!ucLCD_SW;
- if(ucLCD_SW)
- LCD_DisplayOn();
- else
- LCD_DisplayOff();
- break;
- case KEY0_PRES:
- LCD_ShowString(50,140,200,16,16,"OPEN ");
- break;
- case KEY1_PRES:
- LCD_ShowString(50,140,200,16,16,"CLOSE ");
- break;
- case REMOTE:
- break;
- default :break;
- OSTimeDlyHMSM(0,0,0,200,OS_OPT_TIME_PERIODIC,&err); //延時200ms
- void task4_task(void *p_arg) //紅外解碼
- OS_ERR err;
- OS_MSG_SIZE size;
- CPU_SR_ALLOC();
- u32 *data;
- char str[9];
- while(1)
- //請求消息KEY_Msg
- OSSemPend(REMOTE_Sem,
- 0,
- OS_OPT_PEND_BLOCKING,
- (CPU_TS* )0,
- (OS_ERR* )&err);
- sprintf(str,"%8X",ir_data[0]);
- LCD_ShowString(15,300,200,16,16,str);//顯示鍵值
- sprintf(str,"%8X",ir_data[1]);
- LCD_ShowString(90,300,200,16,16,str);//顯示鍵值
- sprintf(str,"%8X",ir_data[2]);
- LCD_ShowString(165,300,200,16,16,str);//顯示鍵值
- OSTimeDlyHMSM(0,0,0,300,OS_OPT_TIME_PERIODIC,&err); //延時200ms
空調(diào)遙控紅外.rar
(688.09 KB, 下載次數(shù): 106)
2018-7-18 09:40 上傳
點(diǎn)擊文件名下載附件
UCOSII
