#include"reg51.h"
環(huán)宇電子秤系統(tǒng) stc89C52單片機控制
12864 LCD顯示 制作日期:2015/06/27
unsigned char jian_ma,flag,jiao_flag,set_flag;
unsigned int heavy,price=1,money,alarm=500,jiao_zhun=1010; //相關(guān)變量定義 ,上限報警值初始值為500克
unsigned char menu,jia,jian,confr,fu,menu_flag,exit;
long data_num,data_temp,data_flash;
unsigned char f=0;
unsigned char code table[]={" Welcome to you"};
unsigned char code table1[]={" Weight "};
sbit IRIN = P3^3; //紅外接收器數(shù)據(jù)線
sbit ADDO=P1^0; //ad采集數(shù)據(jù)接口
sbit ADSK= P1^1; //ad采集時鐘接口
sbit rs=P2^3;
sbit rw=P2^4; //液晶接口定義
sbit lcden=P2^5;
sbit bell=P3^6; //蜂鳴器定義
sbit key=P2^7; //按鍵定義
#define Imax 14000 //此處為晶振為12時的取值, 紅外解碼
#define Imin 8000 //如用其它頻率的晶振時,
#define Inum1 1450 //要改變相應的取值。
#define Inum2 700
#define Inum3 3000
unsigned char Im[4]={0x00,0x00,0x00,0x00};
unsigned long m,Tc;
void delay_ms(unsigned char x) //x*0.14MS
unsigned char i;
while(x--)
for (i = 0; i<13; i++) {}
void delay(unsigned int t) //延時函數(shù)
uint x,y;
for(x=t;x>0;x--)
for(y=12;y>0;y--);
/* 名稱:寫命令函數(shù)
功能:向LED1602中寫命令
入口參數(shù):uchar com
出口參數(shù):無
void write_com(unsigned char com)
rs=0;
rw=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
/* 名稱:寫數(shù)據(jù)函數(shù)
功能:向LED1602中寫數(shù)據(jù)
入口參數(shù):uchar date
出口參數(shù):無
void write_date(unsigned char date)
rs=1;
rw=0;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
/* 名稱:初始化函數(shù)
功能:初始化LED1602
入口參數(shù):無
出口參數(shù):無
void lcd_init()
unsigned char num;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01); //清屏
write_com(0x80);
delay(5);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
delay(20000);
write_com(0x80);
write_date(table1[num]);
delay(5);
void display( unsigned int weight,unsigned int bj,unsigned int vl)
{ unsigned int qian,bai,shi,ge;
qian=(weight/1000)%10;
bai=(weight/100)%10;
shi=(weight/10)%10;
ge=weight%10;
write_com(0x87); //重量顯示
write_date(':');
if(fu) //為賦值則顯示負號
fu=0;
write_date('-');
write_date(' ');
if(qian)
write_date(0x30+qian);
write_date(0x30+bai);
write_date(0x30+shi);
write_date(0x30+ge);
if(bai)
write_date(' ');
if(shi)
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
write_date('g');
qian=(bj/1000)%10;
bai=(bj/100)%10;
shi=(bj/10)%10;
ge=bj%10;
write_com(0x80+0x40); //報警值顯示
write_date('M');
write_date(':');
if(qian)
if(bai)
write_date(' ');
if(shi)
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
qian=(vl/1000)%10; //校準值顯示
bai=(vl/100)%10;
shi=(vl/10)%10;
ge=vl%10;
write_com(0x80+0x47);
write_date('V');
write_date(':');
if(qian)
if(bai)
write_date(' ');
if(shi)
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
write_date(' ');
if(set_flag) //報警上限光標打開
write_com(0x80+0x40); //報警值閃爍
write_com(0x0f); //報警值顯示
write_date('M');
if(jiao_flag)
write_com(0x0f); // 校準值閃爍
write_date('V');
void read_count() //ad采集函數(shù)
unsigned long count;
unsigned char i;
ADSK=0;//使能ad
count=0;
while(ADDO); //等待ad轉(zhuǎn)換結(jié)束
for(i=0;i<24;i++)
ADSK=1; //PD_SCK置高,發(fā)送脈沖
count=count<<1;
// delayp();
ADSK=0; //pd_sck置低
if(ADDO)count++;
ADSK=1;
count=count^0x800000; //第25個脈沖下降沿來時,轉(zhuǎn)換數(shù)據(jù)
// delayp();
ADSK=0;
data_num=count; // 讀出來的數(shù)據(jù)賦值給變量data_num
蜂鳴器 報警
void beep()
unsigned char i;
for(i=0;i<20;i++)
bell = 0;
delay(40);
bell = 1;
void price_change() //遙控按鍵掃描函數(shù)
jian_ma=jian_ma&0x1f;
if(jian_ma>=0x1f)
flag=0;
if(flag)
flag=0;
switch (jian_ma)
case 0x01: //按下2號按鍵進入 校準值設定
menu_flag=1;
jiao_flag=1;
set_flag=0;
beep();
break;
case 0x02: //按下3號按鍵進入 報警值設定狀態(tài)
menu_flag=2;
jiao_flag=0;
set_flag=1;
beep();
break;
case 0x0c: //*鍵進入清零
read_count();
data_temp=data_num;
beep();
break;
case 0x11: //加鍵
jia=1;
beep();
break;
case 0x19: //減鍵
jian=1;
beep();
break;
case 0x15:
flag=0;
menu_flag=0;//按下ok按鍵退出
set_flag=0;
jiao_flag=0;
write_com(0x0c);
beep();
exit=1;
break;
void sao_miao()//按鍵掃描函數(shù)
if(key==0)
delay(10);
if(!key)
while(!key);
read_count();
delay(500);
read_count();
data_temp=data_num; //重新讀取ad采集值,進入清零功能
void chu_li() //單價設定函數(shù)
price_change(); //遙控按鍵掃描函數(shù)
while(menu_flag) //對遙控按鍵的處理
price_change();
if(set_flag) //報警值設定
if(jia)
jia=0;
if(alarm<5000) //最大數(shù)值為5000
alarm++;
if(jian)
jian=0;
if(alarm>=2) //最小數(shù)值為1
alarm--;
if(jiao_flag) //校準值設定
if(jia)
jia=0;
if(jiao_zhun<5000) //最大數(shù)值為5000
jiao_zhun++;
if(jian)
jian=0;
if(jiao_zhun>=2) //最小數(shù)值為1
jiao_zhun--;
delay(500);
read_count();
if(data_num>=data_temp) // 比較采集出來的數(shù)值與臨時變量
data_num=(data_num-data_temp);
heavy=(unsigned int)(data_num/jiao_zhun);//1677; //計算重量
delay(5000);
display(heavy,alarm,jiao_zhun);
sao_miao(); //按鍵掃描函數(shù)
主函數(shù)
uchar i=0;
IRIN=1; //I/O口初始化
m=0;
f=0;
lcd_init();
IT1=1;
EX1=1; //開外部中斷
TMOD=0x11; //定時器方式
TH0=0;
TL0=0;
TR0=1; //開定時器
EA=1; //開總中斷
P0=0;
delay(50);
delay(100);
read_count(); //ad采集函數(shù)
delay(3000);
delay(3000);
data_temp=data_num; //采集數(shù)據(jù)賦值給臨時變量 data_temp
read_count();
data_num=(data_temp-data_num);
if(data_num>=500)
fu=1;
fu=0;
data_num=0;
delay(500);
data_flash=heavy*price; // 總價=單價*重量
money=(unsigned int)data_flash;
if(exit) //如果進行了設置
exit=0;
//show() ; //顯示刷新
display(heavy,alarm,jiao_zhun); //計算完成后送到液晶顯示
delay(500);
chu_li(); //掃描函數(shù)
if(heavy>alarm) //重量超過上限報警
beep();
delay(500);
//外部中斷解碼程序
void intersvr1(void) interrupt 2 using 1
Tc=TH0*256+TL0; //提取中斷時間間隔時長
TH0=0;
TL0=0; //定時中斷重新置零
if((Tc>Imin)&&(Tc<Imax)) //定時器判斷讀取的啟始碼正確
m=0;
f=1;
return;
} //找到啟始碼
if(f==1)
if(Tc>Inum1&&Tc<Inum3)
Im[m/8]=Im[m/8]>>1|0x80; m++;
if(Tc>Inum2&&Tc<Inum1)
Im[m/8]=Im[m/8]>>1; m++; //取碼
if(m==32)
m=0;
f=0;
if(Im[2]==~Im[3])
flag=1;
jian_ma=Im[2];
else flag=0; //取碼完成后判斷讀碼是否正?
if(jian_ma==0x15)
//準備讀下一碼
開發(fā)板原理圖.pdf
2018-7-19 10:32 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
625.91 KB, 下載次數(shù): 16, 下載積分: 黑幣 -5
