查看: 2175|回復(fù): 0
wifi遠(yuǎn)程控制c程序ok
ID:374751 發(fā)表于 2018-7-19 12:41 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include<reg52.h>
  2. #include<math.h>
  3. #include <stdio.h>
  5. #define uint unsigned int
  6. code uchar smg[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x00};
  7. sbit jdq1=P2^0;
  8. sbit jdq2=P2^1;
  9. sbit jdq3=P2^2;
  10. sbit jdq4=P2^3;
  11. sbit LED=P1^0;
  12. uchar *pr;                        //指針-重啟模塊(AT指令)
  13. uchar *pc;                        //指針-設(shè)置工作模式(1-STA,2-AP,3-STA+AP)
  14. uchar *pd;                        //指針-設(shè)置AP熱點(diǎn)的SSID,密碼,和加密方式等0-OPEN,1-WEP,2-WPA_PSK,3-WPA2_PSK,4-WPA_WPA2_PSK
  15. uchar *pa;                        //指針-設(shè)置AP地址(AT指令)
  16. uchar *pm;                        //指針-設(shè)置多連接(AT指令)
  17. uchar *ps;                        //指針-開啟TCP服務(wù)器模式(AT指令)
  18. uchar *pt;                        //指針-設(shè)置服務(wù)超時(shí)時(shí)長(AT指令)
  19. uchar Buffer='a';      //從串口接收的數(shù)據(jù)(給個(gè)初值用于防誤判)
  20. uint i,j;
  21. uint aa=200;
  22. void Delay_1ms(uint i)//1ms延時(shí)
  23. {
  24.         uint x,j;
  25.         for(j=0;j<i;j++)
  26.         for(x=0;x<=148;x++);
  27. }
  28. void Com_Int(void) interrupt 4        //串口中斷函數(shù)
  29. {
  30.         EA = 0;
  31.         if(RI == 1)   //當(dāng)硬件接收到一個(gè)數(shù)據(jù)時(shí),RI會置位
  32.         {
  33.                 Buffer=SBUF;
  34.                 RI = 0;
  35.         }
  36.         EA = 1;
  37. }
  38. void Com_Init(void)         //        串口初始化        -- 晶振11.0592,波特率9600,使能串口中斷
  39. {
  40.      TMOD = 0x20;
  41.      PCON = 0x00;
  42.      SCON = 0x50;
  43.      TH1 = 0xFd;    //設(shè)置波特率 9600
  44.      TL1 = 0xFd;
  45.      TR1 = 1;                //啟動(dòng)定時(shí)器1
  46.          ES = 1;                //開串口中斷
  47.          EA = 1;                //開總中斷
  48. }
  49. void main()
  50. {
  51.         Com_Init();//串口初始化
  52.     Delay_1ms(2000);          //延時(shí)幾秒時(shí)間等模塊啟動(dòng)
  53.           LED=1;
  54.           while(0)
  55.          {
  56.           pr="AT+RST\r\n";
  57.           while(*pr)
  58.           {
  59.             SBUF=*(pr++);
  60.             while(TI==0);                                 //以查詢方式查詢串口是否發(fā)送完畢
  61.             TI=0;                                                 //清發(fā)送標(biāo)志
  62.           }
  63.           Delay_1ms(900);
  64.           if(Buffer=='\n')
  65.           {
  66.             Buffer='a';
  67.             break;
  68.            }
  69.          }
  70.            //設(shè)置工作模式(1-STA,2-AP,3-STA+AP)
  71.         while(1)
  72.         {
  73.           pc="AT+CWMODE=2\r\n";
  74.           while(*pc)
  75.           {
  76.             SBUF=*(pc++);
  77.             while(TI==0);
  78.             TI=0;
  79.           }
  80.           Delay_1ms(900);
  81.           if(Buffer=='\n')
  82.           {
  83.             Buffer='a';
  84.             break;
  85.            }
  86.         }
  87.           //設(shè)置AP熱點(diǎn)的SSID,密碼,和加密方式等
  88.           pd="AT+CWSAP=\"ESP8266_xiaoyu\",\"0123456789\",11,4\r\n";
  89.          while(1)
  90.         {
  91.           while(*pd)
  92.           {
  93.             SBUF=*(pd++);
  94.             while(TI==0);
  95.             TI=0;
  96.           }
  97.           Delay_1ms(900);
  98.           if(Buffer=='\n')
  99.           {
  100.             Buffer='a';
  101.             break;
  102.            }
  103.         }
  104.           //串口發(fā)送指令A(yù)T+CIPMUX=1,讓ESP8266進(jìn)入多連接模式
  105.         while(1)
  106.         {
  107.           pm="AT+CIPMUX=1\r\n";
  108.           while(*pm)
  109.           {
  110.             SBUF=*(pm++);
  111.             while(TI==0);                                 //以查詢方式查詢串口是否發(fā)送完畢
  112.             TI=0;                                                 //清發(fā)送標(biāo)志
  113.           }
  114.           Delay_1ms(900);
  115.           if(Buffer=='\n')
  116.           {
  117.             Buffer='a';
  118.             break;
  119.            }
  120.         }
  121.         //串口發(fā)送指令A(yù)T+CIPSERVER=1,5000,讓模塊開啟TCP服務(wù)器模式,端口為5000
  122.         while(1)
  123.         {
  124.           ps="AT+CIPSERVER=1,5000\r\n";
  125.           while(*ps)
  126.           {
  127.             SBUF=*(ps++);
  128.             while(TI==0);
  129.             TI=0;
  130.           }
  131.           Delay_1ms(900);
  132.           if(Buffer=='\n')
  133.           {
  134.             Buffer='a';
  135.             break;
  136.            }
  137.         }
  138.
  139.         //串口發(fā)送指令A(yù)T+CIPSTO=0,設(shè)置服務(wù)超時(shí)時(shí)間,0即永遠(yuǎn)不超時(shí)
  140.         while(1)
  141.         {
  142.           pt="AT+CIPSTO=0\r\n";
  143.           while(*pt)
  144.           {
  145.             SBUF=*(pt++);
  146.             while(TI==0);
  147.             TI=0;
  148.           }
  149.           Delay_1ms(900);
  150.           if(Buffer=='\n')
  151.           {
  152.             Buffer='a';
  153.             break;
  154.            }
  155.         }
  156.         //串口發(fā)送指令A(yù)T+CIPAP="192.168.1.110",設(shè)置8266 AP地址
  157.         while(1)
  158.         {
  159.           pa="AT+CIPAP=\"192.168.1.110\"\r\n";
  160.           while(*pa)
  161.           {
  162.             SBUF=*(pa++);
  163.             while(TI==0);
  164.             TI=0;
  165.           }
  166.           Delay_1ms(900);
  167.           if(Buffer=='\n')
  168.           {
  169.             Buffer='a';
  170.             break;
  171.            }
  172.         }
  173.
  174.
  175.           LED=0;
  176.           while(1)
  177.           {
  178.                   if(Buffer=='q')
  179.                  jdq1=0;
  180.                   if(Buffer=='w')
  181.                  jdq2=0;
  182.                          if(Buffer=='e')
  183.                  jdq3=0;
  184.                          if(Buffer=='r')
  185.                  jdq4=0;
  186.                         if(Buffer=='a')
  187.                  jdq1=1;
  188.                   if(Buffer=='s')
  189.                  jdq2=1;
  190.                          if(Buffer=='d')
  191.                  jdq3=1;
  192.                          if(Buffer=='f')
  193.                  jdq4=1;
  194.           }
  195. }
wifi遠(yuǎn)程控制c程序ok.rar
31.62 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
