stm32f103c8t6練習(xí)pwm(脈沖寬度調(diào)制)實(shí)驗(yàn),從網(wǎng)上找到一串代碼,稍作修改后運(yùn)行,不能實(shí)現(xiàn)呼吸燈效果,僅僅是PB5,PB6 led燈初始化成功發(fā)光,初學(xué)stm32,新手上路,有諸多問(wèn)題難解,還望大神賜教
代碼如下:
- #include "stm32f10x.h"
- #include "my.h"
- void RCC_cfg(void);
- void GPIO_cfg(void);
- void TIMER_cfg(void);
- void PWM_cfg(void);
- int led_fx=1;
- int led_dt=0;
- void LED_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE); //使能PB,PE端口時(shí)鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6; //LED0-->PB.5 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOB, &GPIO_InitStructure); //根據(jù)設(shè)定參數(shù)初始化GPIOB.5
- GPIO_SetBits(GPIOB,GPIO_Pin_5 | GPIO_Pin_6 ); //PB.5 輸出高
- //PE.5 輸出高
- int main(void)
- RCC_cfg();
- GPIO_cfg();
- TIMER_cfg();
- PWM_cfg();
- //使能TIM2計(jì)時(shí)器,開(kāi)始輸出PWM
- TIM_Cmd(TIM2, ENABLE);
- LED_Init();
- while(1)
- delay_ms(5);
- if(led_fx==1)
- led_dt++;
- else
- led_dt--;
- if(led_dt>500) led_fx=0;
- if(led_dt==0) led_fx=1;
- TIM_SetCompare4(TIM2,led_dt);
- //定義錯(cuò)誤狀態(tài)變量
- ErrorStatus HSEStartUpStatus;
- //將RCC寄存器重新設(shè)置為默認(rèn)值
- RCC_DeInit();
- //打開(kāi)外部高速時(shí)鐘晶振
- RCC_HSEConfig(RCC_HSE_ON);
- //等待外部高速時(shí)鐘晶振工作
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- //設(shè)置AHB時(shí)鐘(HCLK)為系統(tǒng)時(shí)鐘
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- //設(shè)置高速AHB時(shí)鐘(APB2)為HCLK時(shí)鐘
- RCC_PCLK2Config(RCC_HCLK_Div1);
- //設(shè)置低速AHB時(shí)鐘(APB1)為HCLK的2分頻
- RCC_PCLK1Config(RCC_HCLK_Div2);
- //設(shè)置FLASH代碼延時(shí)
- FLASH_SetLatency(FLASH_Latency_2);
- //使能預(yù)取指緩存
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- //設(shè)置PLL時(shí)鐘,為HSE的9倍頻 8MHz * 9 = 72MHz
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- //使能PLL
- RCC_PLLCmd(ENABLE);
- //等待PLL準(zhǔn)備就緒
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
- //設(shè)置PLL為系統(tǒng)時(shí)鐘源
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- //判斷PLL是否是系統(tǒng)時(shí)鐘
- while(RCC_GetSYSCLKSource() != 0x08);
- //開(kāi)啟TIM2的時(shí)鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
- //開(kāi)啟GPIOB的時(shí)鐘和復(fù)用功能
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
- // GPIO_PinRemapConfig(GPIO_PartialRemap1_TIM2, ENABLE); //映射引腳,默認(rèn)PA3 ->TIM2_CH4因此不用映射
- //選擇引腳3
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
- //輸出頻率最大50MHz
- //復(fù)用推挽輸出
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- //PA
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- //重新將Timer設(shè)置為缺省值
- TIM_DeInit(TIM2);
- //采用內(nèi)部時(shí)鐘給TIM2提供時(shí)鐘源
- TIM_InternalClockConfig(TIM2);
- //預(yù)分頻系數(shù)為0
- TIM_TimeBaseStructure.TIM_Prescaler = 0;
- //設(shè)置計(jì)數(shù)溢出大小
- TIM_TimeBaseStructure.TIM_Period = 500;
- //設(shè)置計(jì)數(shù)器模式為向上計(jì)數(shù)模式(+1)
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- //設(shè)置時(shí)鐘分割
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
- //將配置應(yīng)用到TIM2中
- TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
- TIM_OCInitTypeDef TimOCInitStructure;
- //設(shè)置缺省值
- TIM_OCStructInit(&TimOCInitStructure);
- //PWM模式1輸出
- TimOCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
- //設(shè)置占空比 (Led亮度)
- TimOCInitStructure.TIM_Pulse = 0;
- //TIM輸出比較極性高
- TimOCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- //使能輸出狀態(tài)
- TimOCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- //TIM2的CH4輸出
- TIM_OC4Init(TIM2, &TimOCInitStructure);
- //設(shè)置TIM2的PWM輸出為使能
- TIM_CtrlPWMOutputs(TIM2,ENABLE);
