給你一個(gè)示例參考,有詳細(xì)注釋。
//8位數(shù)碼管時(shí)鐘+鬧鐘
//K1鍵調(diào)整選擇,K2鍵+,長按連+,K3鍵-,長按連-,K4鍵鬧鐘設(shè)置
//定時(shí)器初始化程序根據(jù)晶振頻率選擇
//用計(jì)數(shù)法代替軟件延時(shí),消除按鍵干擾其它程序
//數(shù)碼管采用分時(shí)動態(tài)顯示,2ms顯示1位
- #include <reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define key_S 300 //宏定義短按時(shí)間(約20ms)
- #define key_L 6000 //宏定義長按時(shí)間(約2/3s)
- #define key_M 3000 //宏定義長按連+/-間隔時(shí)間(約1/3s)
- sbit K1 = P3^0; //時(shí)鐘調(diào)整選擇/退出
- sbit K2 = P3^1; //+鍵,長按連+
- sbit K3 = P3^2; //--鍵,長按連-
- sbit K4 = P3^3; //鬧鐘調(diào)整選擇/退出
- sbit Buzzer=P2^5; //蜂鳴器
- sbit led138c=P2^4; //38譯碼器位選
- sbit led138b=P2^3; //38譯碼器位選
- sbit led138a=P2^2; //38譯碼器位選
- uchar code table[]={ //共陰數(shù)碼管0~F數(shù)組
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- uint Cnt2ms; //定義2ms秒變量
- uchar hour=0,min=0,sec=0; //定義時(shí)、分、秒變量
- uchar hour_1=0,min_1=0; //定義鬧鐘時(shí)、分變量
- uchar Choice=0,Choice_1=0; //調(diào)整走時(shí)的選擇變量、設(shè)置鬧鐘的選擇變量
- bit Buzzer_sign; //蜂鳴器鬧鐘標(biāo)志
- bit Twinkle,second=1; //閃爍標(biāo)志、秒標(biāo)志
- bit flag=0; //2ms數(shù)碼管動態(tài)顯示周期標(biāo)志
- 定時(shí)器T0/T1初始化程序 @12MHz
- void Timer_Init()
- TMOD = 0x21; //設(shè)置T0模式1,T1模式2
- TL0 = 0x30; //設(shè)置定時(shí)初值2ms
- TH0 = 0xF8; //設(shè)置定時(shí)初值2ms
- TL1 = 0x06; //設(shè)置定時(shí)初值250微秒
- TH1 = 0x06; //設(shè)置定時(shí)重載值250微秒
- TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- // TR1 = 1; //定時(shí)器1開始計(jì)時(shí)
- EA=1; //開總中斷
- ET0=1; //開定時(shí)器1中斷
- ET1=1; //開定時(shí)器1中斷
- 定時(shí)器T0/T1初始化程序 @11.0592MHz
- void Timer_Init()
- TL0 = 0xCD; //設(shè)置定時(shí)初值2ms
- TL1 = 0x1A; //設(shè)置定時(shí)初值250微秒
- TH1 = 0x1A; //設(shè)置定時(shí)重載值250微秒
- EA=1; //開總中斷
- 按鍵掃描程序
- void key_scan()
- static bit key1_sign,key4_sign; //按鍵自鎖標(biāo)志變量
- static uint count1,count2,count3=0,count4=0;//消抖計(jì)數(shù)變量
- if(!K1) //檢測按鍵1按下
- count1++; //消抖計(jì)數(shù)1自+1
- if((count1>=key_S)&&(key1_sign==0))//檢測消抖計(jì)數(shù)與按鍵1自鎖標(biāo)志
- key1_sign=1; //按鍵1自鎖標(biāo)志置1
- Choice++; //調(diào)整選擇變量自+1
- if(Choice>=4) //調(diào)整時(shí)間選擇0正常走時(shí),1調(diào)時(shí),2調(diào)分,3調(diào)秒
- Choice=0; //調(diào)整時(shí)間選擇清0
- Cnt2ms=0; //時(shí)間變量Cnt2ms清0
- else
- key1_sign=0; //按鍵1自鎖標(biāo)志清0
- count1=0; //消抖計(jì)數(shù)count1清0
- if(!K2)
- count2++;
- if(count2>=key_L) //長按快調(diào)
- if(Choice==1) //選擇變量1調(diào)時(shí)
- hour++;
- if(hour>=24)
- hour=0;
- if(Choice==2) //選擇變量2調(diào)分
- min++;
- if(min>=60)
- min=0;
- if(Choice==3) //選擇變量3調(diào)秒
- sec++;
- if(sec>=60)
- sec=0;
- if(Choice_1==1) //選擇變量1調(diào)時(shí)
- hour_1++;
- if(hour_1>=24)
- hour_1=0;
- if(Choice_1==2) //選擇變量2調(diào)分
- min_1++;
- if(min_1>=60)
- min_1=0;
- count2=key_M;
- else //按鍵抬起
- if(count2>key_S && count2<key_L)//短按
- hour++;
- if(hour>=24)
- hour=0;
- min++;
- if(min>=60)
- min=0;
- sec++;
- if(sec>=60)
- sec=0;
- hour_1++;
- if(hour_1>=24)
- hour_1=0;
- min_1++;
- if(min_1>=60)
- min_1=0;
- count2=0; //count2清0
- if(!K3)
- count3++;
- if(count3>=key_L) //長按
- hour--;
- if(hour>=24)
- hour=23;
- min--;
- if(min>=60)
- min=59;
- sec--;
- if(sec>=60)
- sec=59;
- hour_1--;
- if(hour_1>=24)
- hour_1=23;
- min_1--;
- if(min_1>=60)
- min_1=59;
- count3=key_M;
- else //按鍵抬起
- if(count3>key_S && count3<key_L)//短按
- hour--;
- if(hour>=24)
- hour=23;
- min--;
- if(min>=60)
- min=59;
- sec--;
- if(sec>=60)
- sec=59;
- hour_1--;
- if(hour_1>=24)
- hour_1=23;
- min_1--;
- if(min_1>=60)
- min_1=59;
- count3=0; //count3清0
- if(!K4) //檢測按鍵1按下
- count4++; //消抖計(jì)數(shù)1自+1
- if((count4>=key_S)&&(key4_sign==0))//檢測消抖計(jì)數(shù)與按鍵1自鎖標(biāo)志
- key4_sign=1; //按鍵1自鎖標(biāo)志置1
- Choice_1++; //調(diào)整選擇變量自+1
- if(Choice_1>=4) //調(diào)整鬧鐘時(shí)間選擇0鬧鐘關(guān)閉,1調(diào)時(shí),2調(diào)分,3開啟鬧鐘
- Choice_1=0; //調(diào)整時(shí)間選擇清0
- else
- key4_sign=0; //按鍵1自鎖標(biāo)志清0
- count4=0; //消抖計(jì)數(shù)count1清0
- 數(shù)碼管顯示程序
- void display()
- static uchar num=0; //分時(shí)顯示變量
- if(flag==1)
- flag=0;
- if((Choice_1>0)&&(Choice_1<3))//鬧鐘設(shè)置顯示部分
- switch(num)
- case 0:
- P0=0x00; //消隱
- led138a=0;led138b=0;led138c=0;//時(shí)十位位碼
- P0=table[hour_1/10]; //時(shí)十位段碼
- num++;
- break;
- case 1:
- P0=0x00; //消隱
- led138a=1;led138b=0;led138c=0;//時(shí)個(gè)位位碼
- if((Twinkle==1)&&(Choice_1==1))//時(shí)點(diǎn)閃爍
- P0=table[hour_1%10]|0x80;
- else
- P0=table[hour_1%10];//時(shí)個(gè)位段碼+點(diǎn)
- num++;
- break;
- case 2:
- P0=0x00; //消隱
- led138a=0;led138b=1;led138c=0;//-
- P0=0x40; //-
- num++;
- break;
- case 3:
- P0=0x00; //消隱
- led138a=1;led138b=1;led138c=0;//分十位位碼
- P0=table[min_1/10]; //分十位段碼
- num++;
- break;
- case 4:
- P0=0x00; //消隱
- led138a=0;led138b=0;led138c=1;//分個(gè)位位碼
- if((Twinkle==1)&&(Choice_1==2))//分點(diǎn)閃爍
- P0=table[min_1%10]|0x80;
- else
- P0=table[min_1%10];//分個(gè)位段碼+點(diǎn)
- num++;
- break;
- case 5:
- P0=0x00; //消隱
- led138a=1;led138b=0;led138c=1;//-
- P0=0x40; //-
- num++;
- break;
- case 6:
- P0=0x00; //消隱
- led138a=0;led138b=1;led138c=1;//秒十位位碼
- P0=0x40; //秒十位段碼
- num++;
- break;
- case 7:
- P0=0x00; //消隱
- led138a=1;led138b=1;led138c=1;//秒個(gè)位位碼
- P0=0x40;//秒個(gè)位段碼
- num=0;
- break;
- else //正常走時(shí)顯示部分
- switch(num)
- case 0:
- P0=0x00; //消隱
- P0=table[hour/10]; //時(shí)十位段碼
- num++;
- break;
- case 1:
- P0=0x00; //消隱
- if((Twinkle==1)&&(Choice==1))//時(shí)點(diǎn)閃爍
- P0=table[hour%10]|0x80;
- else
- P0=table[hour%10];//時(shí)個(gè)位段碼+點(diǎn)
- num++;
- break;
- case 2:
- P0=0x00; //消隱
- P0=0x40; //-
- num++;
- break;
- case 3:
- P0=0x00; //消隱
- P0=table[min/10]; //分十位段碼
- num++;
- break;
- case 4:
- P0=0x00; //消隱
- if((Twinkle==1)&&(Choice==2))//分點(diǎn)閃爍
- P0=table[min%10]|0x80;
- else
- P0=table[min%10];//分個(gè)位段碼+點(diǎn)
- num++;
- break;
- case 5:
- P0=0x00; //消隱
- P0=0x40; //-
- num++;
- break;
- case 6:
- P0=0x00; //消隱
- P0=table[sec/10]; //秒十位段碼
- num++;
- break;
- case 7:
- P0=0x00; //消隱
- if(Choice_1==3)
- P0=table[sec%10]|0x80;//鬧鐘啟動后秒個(gè)位+點(diǎn)
- else if((Twinkle==1)&&(Choice==3))//秒點(diǎn)閃爍+點(diǎn)
- else
- P0=table[sec%10];//秒個(gè)位段碼
- num=0;
- break;
- 鬧鐘程序
- void Buzzer_nz()
- if((Choice_1==3)&&(hour_1==hour)&&(min_1==min)&&(sec<30))
- Buzzer_sign=1;
- else Buzzer_sign=0;
- if((second==1)&&(Buzzer_sign==1)) //計(jì)時(shí)周期1s
- TR1 = 1; //定時(shí)器1開,蜂鳴器響一下
- second=0; //定時(shí)周期1s變量清0
- 主程序
- void main(void)
- Timer_Init(); //初始化定時(shí)器
- while(1)
- key_scan(); //按鍵掃描
- display(); //顯示
- Buzzer_nz(); //鬧鐘
- 定時(shí)器0中斷服務(wù)程序 2毫秒
- void timer0() interrupt 1
- Cnt2ms++; //時(shí)間變量Cnt2ms自+1
- flag=1;
- if((Cnt2ms>125 && Cnt2ms<250)||(Cnt2ms>375 && Cnt2ms<500))//閃爍頻率2Hz
- Twinkle=1; //閃爍標(biāo)志
- else Twinkle=0;
- if(Cnt2ms>=500) //在此可以調(diào)整精度
- Cnt2ms=0; //變量Cnt2ms清0
- second=1;
- if(Choice!=3) //調(diào)整選擇變量為3停止走秒
- sec++; //秒自+1
- if(sec>=60) //如果秒>=60
- sec=0; //秒清0
- min++; //分自+1
- if(min>=60) //分>=60
- min=0; //分清0
- hour++; //小時(shí)自+1
- if(hour>=24) //小時(shí)>=24
- hour=0; //小時(shí)清0
- 定時(shí)器1中斷服務(wù)程序 250微秒
- (無源蜂鳴器驅(qū)動程序)
- void timer1() interrupt 3
- static uint count3=0; //中斷計(jì)數(shù)變量
- count3++; //中斷計(jì)數(shù)變量count3自+1
- Buzzer=~Buzzer; //蜂鳴器端口取反
- if(count3>=500) //0.1秒時(shí)間到500
- count3=0; //計(jì)數(shù)清0
- Buzzer=1; //蜂鳴器端口復(fù)位
- TR1 = 0; //定時(shí)器1關(guān)閉
