#include <reg52.h>
#include <STDIO.H>
#include <string.h>
#include "main.h"
#include "mfrc522.h"
sbit dula=P2^6;
sbit wela=P2^7;
int num,num1,flag;
unsigned char code table[]={
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,0x77,
0x7c,0x39,0x5e,0x79,0x71};
unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
//M1卡的某一塊寫(xiě)為如下格式,則該塊為錢(qián)包,可接收扣款和充值命令
//4字節(jié)金額(低字節(jié)在前)+4字節(jié)金額取反+4字節(jié)金額+1字節(jié)塊地址+1字節(jié)塊地址取反+1字節(jié)塊地址+1字節(jié)塊地址取反
unsigned char code data2[4] = {0,0,0,0x01};
unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
unsigned char g_ucTempbuf[20];
void Delay1000ms() //@11.0592MHz
unsigned char i, j, k;
i = 8;
j = 1;
k = 243;
do{
do{
while (--k);
} while (--j);
} while (--i);
void display(unsigned char num)
dula=1;
P0=table[num];
dula=0;
wela=1;
P0=0xfe;
wela=0;
void main( ) {
unsigned char status,i;
unsigned int temp;
InitializeSystem( );
PcdReset();
PcdAntennaOff();
PcdAntennaOn();
while (1)
status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
if (status != MI_OK) {
PcdReset();
PcdAntennaOff();
PcdAntennaOn();
continue;
printf("卡的類(lèi)型:");
for(i=0; i<2; i++) {
temp=g_ucTempbuf[i];
printf("%X",temp);
status = PcdAnticoll(g_ucTempbuf);//防沖撞
continue;
////////以下為超級(jí)終端打印出的內(nèi)容////////////////////////
printf("卡序列號(hào):"); //超級(jí)終端顯示,
for(i=0; i<4; i++) {
printf("%X",temp);
status = PcdSelect(g_ucTempbuf);//選定卡片
continue;
status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗(yàn)證卡片密碼
continue;
status = PcdWrite(1, data1);//寫(xiě)塊
continue;
while(1) {
display(num);
PcdReset();
PcdAntennaOff();
PcdAntennaOn();
continue;
printf("防沖撞失敗\n");
continue;
printf("%X",temp);
printf("\n");
printf("選卡失敗\n");
continue;
printf("密碼驗(yàn)證失敗\n");
continue;
status = PcdValue(PICC_DECREMENT,1,data2);//扣款
printf("扣款失敗\n");
continue;
status = PcdBakValue(1, 2);//塊備份
printf("塊備份失敗\n");
continue;
status = PcdRead(2, g_ucTempbuf);//讀塊
printf("讀塊失敗\n");
continue;
printf("卡讀塊:"); //超級(jí)終端顯示,
for(i=0; i<16; i++) {
printf("%X",temp);
printf("\n");
if(PcdHalt() != MI_OK){
printf("休眠卡片失敗\n");
Delay1000ms();
num=num+3;
flag=1;
//系統(tǒng)初始化
void InitializeSystem() {
P0 = 0xFF;
P1 = 0xFF;
P2 = 0xFF;
P3 = 0xFF;
TMOD=0x21; //設(shè)T0為方式1,GATE=1;
SCON=0x50;
TH1=0xF4; //波特率為2400bps
TL1=0xF4;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
ET0=1; //允許T0中斷
TR1=1; //開(kāi)啟定時(shí)器
TI=1; //發(fā)送標(biāo)志位
EA=1; //開(kāi)啟總中斷
// ES = 1; //允許串口中斷
// RI = 1; //接收標(biāo)志位
void timer0() interrupt 1
if(flag==1)
num1++;
if(num1==20)
num1=0;
num=num-1;
if(num<=0)
num=9;
void Uart(void) interrupt 4
if(RI)
if(SBUF == 0)
printf("接收到\n");
RI = 0;
