- //#include<reg52.h>
- #include <LCD1602.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit beep=P1^0;
- sbit DOUT=P2^0;
- sbit HYG =P2^1;
- void delay()
- uchar m,n,s;
- for(m=20;m>0;m--);
- for(n=20;n>0;n--);
- for(s=248;s>0;s--);
- void main()
- /* 系統(tǒng)初始化 */
- TMOD = 0x20; //定時器T1使用工作方式2
- TH1 = 253; // 設(shè)置初值
- TL1 = 253;
- TR1 = 1; // 開始計時
- SCON = 0x50; //工作方式1,波特率9600bps,允許接收
- ES = 1;
- EA = 1; // 打開所以中斷
- TI = 0;
- RI = 0;
- SendData(str) ; //發(fā)送到串口
- Delay(1); //延時100US(12M晶振)
- while(1)
- //調(diào)用溫濕度讀取子程序
- RH();
- //串口顯示程序
- beep=1;
- if(HYG==0||DOUT==0)
- delay();
- if(HYG==0||DOUT==0)beep=0;
- str[0]=U8RH_data_H;
- str[1]=U8RH_data_L;
- str[2]=U8T_data_H;
- str[3]=U8T_data_L;
- str[4]=U8checkdata;
- //讀取模塊數(shù)據(jù)周期不易小于 2S
- lcddisplay();
- Delay(20000);
- }//elihw
- }// main
- void RSINTR() interrupt 4 using 2
- U8 InPut3;
- if(TI==1) //發(fā)送中斷
- TI=0;
- if(count!=5) //發(fā)送完5位數(shù)據(jù)
- SBUF= outdata[count];
- count++;
- if(RI==1) //接收中斷
- InPut3=SBUF;
- indata[count_r]=InPut3;
- count_r++;
- RI=0;
- if (count_r==5)//接收完4位數(shù)據(jù)
- //數(shù)據(jù)接收完畢處理。
- count_r=0;
- str[0]=indata[0];
- str[1]=indata[1];
- str[2]=indata[2];
- str[3]=indata[3];
- str[4]=indata[4];
- P0=0;
LCD1602.h
- // DHT21使用范例
- //單片機(jī) AT89S52 或 STC89C52RC
- //功能 串口發(fā)送溫濕度數(shù)據(jù) 晶振 11.0592M 波特率 9600
- //硬件 P2.0口為通訊口連接DHT11,DHT11的電源和地連接單片機(jī)的電源和地
- #include <reg51.h>
- #include <intrins.h>
- #define LCD1602_DB P0 //LCD1602數(shù)據(jù)總線
- sbit LCD1602_RS = P3^5; //RS端
- sbit LCD1602_RW = P3^6; //RW端
- sbit LCD1602_EN = P3^4; //EN端
- //sbit DU = P2^6;//
- //sbit WE = P2^7;//數(shù)碼管位選段選用于關(guān)閉數(shù)碼管顯示
- typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
- typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
- typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
- typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
- typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
- typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
- typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長度) */
- typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長度) */
- #define Data_0_time 4
- //----------------IO口定義區(qū)--------------------//
- sbit P2_0 = P2^0 ;
- //----------------定義區(qū)--------------------//
- U8 U8FLAG,k;
- U8 U8count,U8temp;
- U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- U8 U8comdata;
- U8 outdata[5]; //定義發(fā)送的字節(jié)數(shù)
- U8 indata[5];
- U8 a1[5];
- U8 b[10];
- U8 count, count_r=0;
- U8 str[5]={"RS232"};
- U16 U16temp1,U16temp2;
- void SendData(U8 *a)
- outdata[0] = a[0];
- outdata[1] = a[1];
- outdata[2] = a[2];
- outdata[3] = a[3];
- outdata[4] = a[4];
- count = 1;
- SBUF=outdata[0];
- void Delay(U16 j)
- { U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void Delay_10us(void)
- U8 i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void COM(void)
- U8 i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!P2_0)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(P2_0)U8temp=1;
- U8FLAG=2;
- while((P2_0)&&U8FLAG++);
- //超時則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //0
- }//rof
- //-----濕度讀取子程序 ------------
- //----以下變量均為全局變量--------
- //----溫度高8位== U8T_data_H------
- //----溫度低8位== U8T_data_L------
- //----濕度高8位== U8RH_data_H-----
- //----濕度低8位== U8RH_data_L-----
- //----校驗 8位 == U8checkdata-----
- //----調(diào)用相關(guān)子程序如下----------
- //---- Delay();, Delay_10us();,COM();
- void RH(void)
- //主機(jī)拉低18ms
- P2_0=0;
- Delay(180);
- P2_0=1;
- //總線由上拉電阻拉高 主機(jī)延時20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號
- P2_0=1;
- //判斷從機(jī)是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
- if(!P2_0) //T !
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- P2_0=1;
- //數(shù)據(jù)校驗
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- }//fi
- }//fi
- *函數(shù)名稱:Read_Busy
- *函數(shù)功能:判斷1602液晶忙,并等待
- void Read_Busy()
- U8 busy;
- LCD1602_DB = 0xff;//復(fù)位數(shù)據(jù)總線
- LCD1602_RS = 0; //拉低RS
- LCD1602_RW = 1; //拉高RW讀
- do
- LCD1602_EN = 1;//使能EN
- busy = LCD1602_DB;//讀回數(shù)據(jù)
- LCD1602_EN = 0; //拉低使能以便于下一次產(chǎn)生上升沿
- }while(busy & 0x80); //判斷狀態(tài)字BIT7位是否為1,為1則表示忙,程序等待
- *函數(shù)名稱:LCD1602_Write_Cmd
- *函數(shù)功能:寫LCD1602命令
- *調(diào)用:Read_Busy();
- *輸入:cmd:要寫的命令
- void LCD1602_Write_Cmd(U8 cmd)
- Read_Busy(); //判斷忙,忙則等待
- LCD1602_RS = 0;
- LCD1602_RW = 0; //拉低RS、RW操作時序情況1602課件下中文使用說明基本操作時序章節(jié)
- LCD1602_DB = cmd;//寫入命令
- LCD1602_EN = 1; //拉高使能端 數(shù)據(jù)被傳輸?shù)絃CD1602內(nèi)
- *函數(shù)名稱:LCD1602_Write_Dat
- *函數(shù)功能:寫LCD1602數(shù)據(jù)
- *輸入:dat:需要寫入的數(shù)據(jù)
- void LCD1602_Write_Dat(U8 dat)
- Read_Busy();
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- LCD1602_DB = dat;
- LCD1602_EN = 1;
- LCD1602_EN = 0;
- *函數(shù)名稱:LCD1602_Dis_OneChar
- *函數(shù)功能:在指定位置顯示一個字符
- *調(diào)用:LCD1602_Write_Cmd(); LCD1602_Write_Dat();
- *輸入:x:要顯示的橫坐標(biāo)取值0-40,y:要顯示的行坐標(biāo)取值0-1(0為第一行,1為第二行)
- dat:需要顯示的數(shù)據(jù)以ASCLL形式顯示
- /*void LCD1602_Dis_OneChar(U8 x, U8 y,U8 dat)
- if(y) x |= 0x40;
- x |= 0x80;
- LCD1602_Write_Cmd(x);
- LCD1602_Write_Dat(dat);
- // LCD1602_Dis_Str(5, 1, & humidity [5]);
- // LCD1602_Dis_Str(6, 1, & humidity [6]);
- // LCD1602_Dis_Str(7, 1, & humidity [7]);
- // LCD1602_Dis_Str(8, 1, & humidity [8]);
- // LCD1602_Dis_Str(9, 1, & humidity [9]);
- *函數(shù)名稱:LCD1602_Dis_Str
- *函數(shù)功能:在指定位置顯示字符串
- *str:需要顯示的字符串
- void LCD1602_Dis_Str(U8 x, U8 y, U8 *str)
- if(y) x |= 0x40;
- x |= 0x80;
- while(*str != '\0')
- LCD1602_Write_Dat(*str++);
- *函數(shù)名稱:Init_LCD1602
- *函數(shù)功能:1602初始化
- *調(diào)用: LCD1602_Write_Cmd();
- void Init_LCD1602()
- LCD1602_Write_Cmd(0x38); // 設(shè)置16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
- LCD1602_Write_Cmd(0x0c); //開顯示
- LCD1602_Write_Cmd(0x06); //讀寫一字節(jié)后地址指針加1
- LCD1602_Write_Cmd(0x01); //清除顯示
- /*lcd1602液晶顯示*/
- void lcddisplay()
- U8 temperature[] = {"temp: "};
- U8 humidity [] = {"humi: %RH"};
- // DU = 0;
- // WE = 0;//關(guān)閉數(shù)碼管顯示
- Init_LCD1602();//1602初始化
- LCD1602_Dis_Str(0, 0, &temperature[0]); //顯示字符串
- LCD1602_Dis_Str(0, 1, & humidity [0]); //顯示字符串
- a1[0]=U8RH_data_H;
- a1[1]=U8RH_data_L;
- a1[2]=U8T_data_H;
- a1[3]=U8T_data_L;
- a1[4]=U8checkdata;
- temperature [5] =(0x30+a1[2]/10);
- temperature [6] =(0x30+a1[2]%10);
- temperature [7] ='.';
- temperature [8] =(0x30+a1[3]/100);
- temperature [9] =(0x30+(a1[3]%100)/10);
- temperature [14] =(0xdf);
- temperature [15] =(0x43);
- humidity [5] =(0x30+a1[0]/10);
- humidity [6] =(0x30+a1[0]%10);
- humidity [7] ='.';
- humidity [8] =(0x30+a1[1]/100);
- humidity [9] =(0x30+(a1[1]%100)/10);
- LCD1602_Dis_Str(5, 0, & temperature [5]);
- LCD1602_Dis_Str(6, 0, & temperature [6]);
- LCD1602_Dis_Str(7, 0, & temperature [7]);
- LCD1602_Dis_Str(8, 0, & temperature [8]);
- LCD1602_Dis_Str(9, 0, & temperature [9]);
- LCD1602_Dis_Str(14, 0, & temperature [14]);
- LCD1602_Dis_Str(15, 0, & temperature [15]);
- LCD1602_Dis_Str(5, 1, & humidity [5]);
- LCD1602_Dis_Str(6, 1, & humidity [6]);
- LCD1602_Dis_Str(7, 1, & humidity [7]);
- LCD1602_Dis_Str(8, 1, & humidity [8]);
- LCD1602_Dis_Str(9, 1, & humidity [9]);
- //LCD1602_Dis_OneChar(15, 1, 0xff); //顯示一個黑方格 請查表
- //main()功能描述: AT89C51 11.0592MHz 串口發(fā)
- //送溫濕度數(shù)據(jù),波特率 9600
