stm32單片機源程序如下:
- #include "stm32f10x.h"
- #include "delay.h"
- #include "sys.h"
- void Delay(u32 count)
- u32 i=0;
- for(;i<count;i++);
- void NVIC_Configuration(void)
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應優(yōu)先級
- * 函數(shù)名:void GPIO_Config(void)
- * 描述 :配置復用輸出PWM時用到的I/O
- * 輸入 :無
- * 輸出 :無
- * 調(diào)用 :main()調(diào)用
- PA6 PA7 兩路 PWM
- void GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* GPIOA and GPIOB clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO,ENABLE); //
- /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 復用推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- * 函數(shù)名:void TIM3_Config(void)
- * 描述 :配置TIM3輸出的PWM信號的模式
- * CH1:輸出 T=2.5ms(f=1/2.5ms=400Hz) 占空比D=0.6的PWM波(高電平在前,低電平在后)
- * CH2:輸出 T=2.5ms(f=1/2.5ms=400Hz) D=0.4的PWM波(高電平在后,低電平在前)
- * 步驟一:通過T和TIMxCLK的時鐘源確定TIM_Period和TIM_Prescaler (計數(shù)值和預分頻)
- * T=(TIM_Period+1)*(TIM_Prescaler+1)/TIMxCLK=2.5ms
- * 因為 TIM_Period<65535,所以 TIM_Prescaler>1,即 TIM_Prescaler=2 //(預分頻 參數(shù))
- * 所以 TIM_Period=59999=0xEA5F //計數(shù)值
- * 步驟二:根據(jù)TIM_Period的值,高低電平的先后D,確定CCR和TIM_OCPolarity
- * CH1:因為D=0.6,先高后低;
- * 所以CCR1=(TIM_Period+1)* D=36000;TIM_OCPolarity=TIM_OCPolarity_High
- * CH2:因為D=0.4,先高后低;
- * 所以CCR1=(TIM_Period+1)* (1-D)=36000;TIM_OCPolarity=TIM_OCPolarity_Low
- * 步驟三:基礎寄存器初始化
- * 步驟四:通道寄存器初始化
- * 步驟五:使能TIM3重載寄存器ARR
- * 步驟六:使能TIM3
- * 輸入 :無
- * 輸出 :無
- void TIM3_Config(u16 arr,u16 CCR1,u16 CCR2)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /*PCLK1經(jīng)過2倍頻后作為TIM3的時鐘源等于72MHz*/
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
- /* Time base configuration 47999*/
- TIM_TimeBaseStructure.TIM_Period =arr; // 計數(shù)值 47999
- TIM_TimeBaseStructure.TIM_Prescaler = 720; //設置預分頻:預分頻=2,即為72/3=24MHz 預分頻(時鐘分頻)72M/(2+1)=24M
- TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設置時鐘分頻系數(shù):不分頻
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計數(shù)溢出模式
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置為PWM模式1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = CCR1; //設置跳變值,當計數(shù)器計數(shù)到這個值時,電平發(fā)生跳變
- TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High; //當定時器計數(shù)值小于CCR1時為高電平
- TIM_OC1Init(TIM3, &TIM_OCInitStructure); //使能通道1
- TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
- /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.TIM_Pulse = CCR2; //設置通道2的電平跳變值,輸出另外一個占空比的PWM
- //TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //當定時器計數(shù)值小于CCR2時為低電平
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //當定時器計數(shù)值小于CCr2 時為高電平
- TIM_OC2Init(TIM3, &TIM_OCInitStructure); //使能通道2
- TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(TIM3, ENABLE); //使能TIM3重載寄存器ARR
- /* TIM3 enable counter */
- TIM_Cmd(TIM3, ENABLE); //使能TIM3
- * 函數(shù)名:main
- * 描述 :主函數(shù)
- * 輸入 :無
- * 輸出 :無
- int main(void)
- u16 CCR1=80;
- u16 CCR2=80;
- delay_init(); //延時初始化
- SystemInit(); /* 配置系統(tǒng)時鐘為72M */
- NVIC_Configuration();
- GPIO_Config();
- TIM3_Config(1999,CCR1,CCR2);
- delay_ms(1500);
- delay_ms(1500);
- // TIM3_Init();
- while (1)
- TIM3->CCR2=140;
- TIM3->CCR2=140;
復制代碼
PWM.rar
(285.54 KB, 下載次數(shù): 21)
2018-7-30 19:58 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
